98_Hyperion: add effect args, add set addEffect, add attr hyperionCustomEffects, add reading effectArgs, fix clear, fix effect names with dash, update commandref
Begonnen von System, 24 November 2016, 01:45:06
System
98_Hyperion: add effect args, add set addEffect, add attr hyperionCustomEffects, add reading effectArgs, fix clear, fix effect names with dash, update commandrefView Changes
Source: 98_Hyperion: add effect args, add set addEffect, add attr hyperionCustomEffects, add reading effectArgs, fix clear, fix effect names with dash, update commandref
