Autor Thema: [gelöst] Support von Abus HomeTec Pro CFA3010 Türschloss  (Gelesen 11758 mal)
Offline omnior
  • Full Member
Antw:[gelöst] Support von Abus HomeTec Pro CFA3010 Türschloss
« Antwort #45 am: 27 August 2021, 14:11:13 »
ok, sorry, ich dachte das Log reicht bis dahin...
hier also der hoffentlich korrekt und relevante Rest.
Woher weiß ich genau wo das relevante Ende ist?
2021.08.27 12:07:23.941 5: ZWDongle_Write 004a050a ()
2021.08.27 12:07:23.942 5: DevIo_SimpleWrite ZBoard: 0105004a050abf
2021.08.27 12:07:23.970 2: ZWAVE Starting secure init for ZWave_ENTRY_CONTROL_33
2021.08.27 12:07:23.971 5: ZWDongle_Write 001321039804002526 (caf65990)
2021.08.27 12:07:23.973 5: ACK received, removing 0105004a050abf from dongle sendstack
2021.08.27 12:07:23.974 5: DevIo_SimpleWrite ZBoard: 010a0013210398040025265b
2021.08.27 12:07:23.977 5: ACK received, WaitForAck=>2 for 010a0013210398040025265b
2021.08.27 12:07:23.983 4: ZWDongle_Read ZBoard: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.27 12:07:23.983 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:23.985 5: ZBoard: dispatch 011301
2021.08.27 12:07:23.996 4: ZWDongle_Read ZBoard: rcvd 004a0a062100 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2021.08.27 12:07:23.996 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:23.997 5: ZBoard: dispatch 004a0a062100
2021.08.27 12:07:23.998 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:2100 CB:0a
2021.08.27 12:07:24.002 4: ZBoard ZW_ADD_NODE_TO_NETWORK done
2021.08.27 12:07:24.008 4: ZWDongle_Read ZBoard: rcvd 00132600000300be7f7f7f7f0001040000000002010000 (request ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.008 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.009 5: device ack reveived, removing 010a0013210398040025265b from dongle sendstack
2021.08.27 12:07:24.010 5: ZBoard: dispatch 00132600000300be7f7f7f7f0001040000000002010000
2021.08.27 12:07:24.010 4: CMD:ZW_SEND_DATA ID:00 ARG:000300be7f7f7f7f0001040000000002010000 CB:26
2021.08.27 12:07:24.010 4: ZBoard transmit OK for CB 26, target ZWave_ENTRY_CONTROL_33
2021.08.27 12:07:24.010 5: ZWave_ENTRY_CONTROL_33: timeToCb:0.03 repeaters:0 rssi0:-66 dBm ackCh:0 lastCh:1 scheme:NextToLastWorkingRoute rep:at 40kbps routeTries:1 lastFailed:
2021.08.27 12:07:24.040 4: ZWDongle_Read ZBoard: rcvd 0004002103980500be00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.27 12:07:24.041 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.042 5: ZBoard: dispatch 0004002103980500be00
2021.08.27 12:07:24.043 4: CMD:APPLICATION_COMMAND_HANDLER ID:21 ARG:03980500be00 CB:00
2021.08.27 12:07:24.043 5: ZWDongle_Write 0013210298402527 (caf65990)
2021.08.27 12:07:24.043 5: DevIo_SimpleWrite ZBoard: 010900132102984025271c
2021.08.27 12:07:24.046 5: ACK received, WaitForAck=>2 for 010900132102984025271c
2021.08.27 12:07:24.052 4: ZWDongle_Read ZBoard: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.052 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.053 5: ZBoard: dispatch 011301
2021.08.27 12:07:24.076 4: ZWDongle_Read ZBoard: rcvd 00132700000300be7f7f7f7f0001030000000002010000 (request ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.076 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.077 5: device ack reveived, removing 010900132102984025271c from dongle sendstack
2021.08.27 12:07:24.078 5: ZBoard: dispatch 00132700000300be7f7f7f7f0001030000000002010000
2021.08.27 12:07:24.078 4: CMD:ZW_SEND_DATA ID:00 ARG:000300be7f7f7f7f0001030000000002010000 CB:27
2021.08.27 12:07:24.078 4: ZBoard transmit OK for CB 27, target ZWave_ENTRY_CONTROL_33
2021.08.27 12:07:24.078 5: ZWave_ENTRY_CONTROL_33: timeToCb:0.03 repeaters:0 rssi0:-66 dBm ackCh:0 lastCh:1 scheme:LastWorkingRoute rep:at 40kbps routeTries:1 lastFailed:
2021.08.27 12:07:24.100 4: ZWDongle_Read ZBoard: rcvd 000400210a9880644eb92b3b39e71fbc00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.27 12:07:24.100 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.101 5: ZBoard: dispatch 000400210a9880644eb92b3b39e71fbc00
2021.08.27 12:07:24.102 4: CMD:APPLICATION_COMMAND_HANDLER ID:21 ARG:0a9880644eb92b3b39e71fbc00 CB:00
2021.08.27 12:07:24.103 5: ZWDongle_Write 001321269881ccc1d9b6ec48ce44156a385ddc8af13dd64c1811c17472fc06d6a06455defd699a6b4fee2528 (caf65990)
2021.08.27 12:07:24.103 5: DevIo_SimpleWrite ZBoard: 012d001321269881ccc1d9b6ec48ce44156a385ddc8af13dd64c1811c17472fc06d6a06455defd699a6b4fee2528ed
2021.08.27 12:07:24.108 5: ACK received, WaitForAck=>2 for 012d001321269881ccc1d9b6ec48ce44156a385ddc8af13dd64c1811c17472fc06d6a06455defd699a6b4fee2528ed
2021.08.27 12:07:24.116 4: ZWDongle_Read ZBoard: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.116 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.118 5: ZBoard: dispatch 011301
2021.08.27 12:07:24.147 4: ZWDongle_Read ZBoard: rcvd 00132800000300be7f7f7f7f0001030000000002010000 (request ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.147 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.148 5: device ack reveived, removing 012d001321269881ccc1d9b6ec48ce44156a385ddc8af13dd64c1811c17472fc06d6a06455defd699a6b4fee2528ed from dongle sendstack
2021.08.27 12:07:24.149 5: ZBoard: dispatch 00132800000300be7f7f7f7f0001030000000002010000
2021.08.27 12:07:24.149 4: CMD:ZW_SEND_DATA ID:00 ARG:000300be7f7f7f7f0001030000000002010000 CB:28
2021.08.27 12:07:24.149 4: ZBoard transmit OK for CB 28, target ZWave_ENTRY_CONTROL_33
2021.08.27 12:07:24.150 5: ZWave_ENTRY_CONTROL_33: timeToCb:0.03 repeaters:0 rssi0:-66 dBm ackCh:0 lastCh:1 scheme:LastWorkingRoute rep:at 40kbps routeTries:1 lastFailed:
2021.08.27 12:07:24.188 4: ZWDongle_Read ZBoard: rcvd 00040021029840bc00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.27 12:07:24.188 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.189 5: ZBoard: dispatch 00040021029840bc00
2021.08.27 12:07:24.190 4: CMD:APPLICATION_COMMAND_HANDLER ID:21 ARG:029840bc00 CB:00
2021.08.27 12:07:24.190 5: ZWDongle_Write 0013210a988014968009a35d22612529 (caf65990)
2021.08.27 12:07:24.191 5: DevIo_SimpleWrite ZBoard: 01110013210a988014968009a35d2261252974
2021.08.27 12:07:24.194 5: ACK received, WaitForAck=>2 for 01110013210a988014968009a35d2261252974
2021.08.27 12:07:24.199 4: ZWDongle_Read ZBoard: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.200 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.201 5: ZBoard: dispatch 011301
2021.08.27 12:07:24.226 4: ZWDongle_Read ZBoard: rcvd 00132900000300bc7f7f7f7f0001030000000002010000 (request ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.226 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.227 5: device ack reveived, removing 01110013210a988014968009a35d2261252974 from dongle sendstack
2021.08.27 12:07:24.228 5: ZBoard: dispatch 00132900000300bc7f7f7f7f0001030000000002010000
2021.08.27 12:07:24.228 4: CMD:ZW_SEND_DATA ID:00 ARG:000300bc7f7f7f7f0001030000000002010000 CB:29
2021.08.27 12:07:24.228 4: ZBoard transmit OK for CB 29, target ZWave_ENTRY_CONTROL_33
2021.08.27 12:07:24.229 5: ZWave_ENTRY_CONTROL_33: timeToCb:0.03 repeaters:0 rssi0:-68 dBm ackCh:0 lastCh:1 scheme:LastWorkingRoute rep:at 40kbps routeTries:1 lastFailed:
2021.08.27 12:07:24.257 4: ZWDongle_Read ZBoard: rcvd 000400211698816d700e0d84f4439fba7db614723308919437926ebe00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.27 12:07:24.257 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.259 5: ZBoard: dispatch 000400211698816d700e0d84f4439fba7db614723308919437926ebe00
2021.08.27 12:07:24.259 4: CMD:APPLICATION_COMMAND_HANDLER ID:21 ARG:1698816d700e0d84f4439fba7db614723308919437926ebe00 CB:00
2021.08.27 12:07:24.260 4: CMD:APPLICATION_COMMAND_HANDLER ID:21 ARG:029807 CB:00
2021.08.27 12:07:24.261 3: ZWave_ENTRY_CONTROL_33: SECURITY enabled, networkkey was verified
2021.08.27 12:07:41.421 4: ZWDongle_Read ZBoard: rcvd 0004001e03400301c600 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.27 12:07:41.421 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:41.423 5: ZBoard: dispatch 0004001e03400301c600
2021.08.27 12:07:41.424 4: CMD:APPLICATION_COMMAND_HANDLER ID:1e ARG:03400301c600 CB:00
2021.08.27 12:07:41.703 4: ZWDongle_Read ZBoard: rcvd 00040010097105000000ff070800ad00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.27 12:07:41.704 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:41.705 5: ZBoard: dispatch 00040010097105000000ff070800ad00
2021.08.27 12:07:41.706 4: CMD:APPLICATION_COMMAND_HANDLER ID:10 ARG:097105000000ff070800ad00 CB:00
Offline rudolfkoenig
  • Administrator
« Antwort #46 am: 27 August 2021, 15:10:08 »
Da ich den Security-Code nicht geschrieben habe, rate ich nur: Nach "SECURITY enabled, networkkey was verified" (d.h. Schluesselaustausch mit dem Geraet ist durch) wird eine Nachricht vom Geraet mit "ARG:..9803..." erwartet, um daraus die Liste der vom S0 unterstuetzten Klassen abzuleiten. Diese Nachricht kommt nicht, stattdessen 17 Sekunden spaeter ein THERMOSTAT_MODE (ARG:..40...) und ein ALARM (ARG:..71...).
Mich verwirren etwas die routInfo Zeilen (40kbps usw). @krikan: gibt es einen weg diese abzuschalten? Und ich meine damit nicht das Parsen der Nachricht, sondern die Nachricht selbst.
Ansonsten bin ich ratlos.
Offline krikan
« Antwort #47 am: 28 August 2021, 11:35:51 »
In INS13478 unter ZW_SendData gibt es eine Beschreibung zum Ein-/Ausschalten des txStatusReport im Callback über "HOST->ZW: REQ | 0x0B | 0x02 | bEnable". Habe das nie getestet, da das im Standard beim UZB/Razberry an ist, was meinem Wunsch entspricht. Zu SECURITY habe ich aktuell auch keine Erfahrungswerte mehr; nutze es derzeit nicht. Evtl. komme ich morgen zum Testen/Probieren.
Offline krikan
« Antwort #48 am: 29 August 2021, 12:48:02 »
txStatusReport ausschalten:
get <ZWDongle> raw 0B0200
txStatusReport einschalten per Befehl:
get <ZWDongle> raw 0B0201
Alternativ wird txStatusReport durch kurzes stromlosmachen des Controllers wieder eingeschlatet. shutdown restart von FHEM führt nach Ausschalten von txStatusReport nicht zum automatischen Einschalten.
Ich schaffe es auch nach 8 Versuchen mit einem Philio-Sensor nicht eine secure-Inklusion erfolgreich durchzuführen. Endet beim Sensor jeweils mit "INITIALIZING (starting secure inclusion)". Nounce kommen nie. Mir fehlt nur gerade die Zeit weiter zu suchen. Später ggfs. mehr.
  • Administrator
« Antwort #49 am: 30 August 2021, 21:44:38 »
Ich habe mit meinem "AEON Labs ZW096 Smart Switch 6" und ein uzb1 (version 4.61) keine Probleme gehabt.
Hier ist das "attr zwd verbose 5" Log, falls jemand ein Secure-Inclusion nachverfolgen will.
Ich habe es beim Ausführen der init Befehle abgeschnitten, ab da wird es langweilig.
2021.08.30 21:27:15.941 4: ZWDongle *** set zwd addNode onSec
2021.08.30 21:27:15.941 5: ZWDongle_Write 004a8102 ()
2021.08.30 21:27:15.941 5: DevIo_SimpleWrite zwd: 0105004a810233
2021.08.30 21:27:15.943 5: ACK received, removing 0105004a810233 from dongle sendstack
2021.08.30 21:27:15.944 4: ZWDongle_Read zwd: rcvd 004a02010000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2021.08.30 21:27:15.945 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:15.946 5: zwd: dispatch 004a02010000
2021.08.30 21:27:15.946 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:01 ARG:0000 CB:02
2021.08.30 21:27:15.946 4: zwd ZW_ADD_NODE_TO_NETWORK learnReady
2021.08.30 21:27:18.824 4: ZWDongle_Read zwd: rcvd 004a02020000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2021.08.30 21:27:18.824 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:18.825 5: zwd: dispatch 004a02020000
2021.08.30 21:27:18.825 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:02 ARG:0000 CB:02
2021.08.30 21:27:18.826 4: zwd ZW_ADD_NODE_TO_NETWORK nodeFound
2021.08.30 21:27:19.072 4: ZWDongle_Read zwd: rcvd 004a020312150410015e25263370273281855972867a7398ef5a82 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2021.08.30 21:27:19.072 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:19.073 5: zwd: dispatch 004a020312150410015e25263370273281855972867a7398ef5a82
2021.08.30 21:27:19.073 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:03 ARG:12150410015e25263370273281855972867a7398ef5a82 CB:02
2021.08.30 21:27:19.073 2: autocreate: define ZWave_SWITCH_BINARY_18 ZWave db25d628 18 5e25263370273281855972867a7398ef5a82
2021.08.30 21:27:20.524 4: ZWDongle_Read zwd: rcvd 004a02051200 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2021.08.30 21:27:20.524 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.526 5: zwd: dispatch 004a02051200
2021.08.30 21:27:20.536 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:05 ARG:1200 CB:02
2021.08.30 21:27:20.536 4: ZWDongle *** set zwd addNode off
2021.08.30 21:27:20.536 5: ZWDongle_Write 004a0503 ()
2021.08.30 21:27:20.536 5: DevIo_SimpleWrite zwd: 0105004a0503b6
2021.08.30 21:27:20.538 2: ZWAVE Starting secure init for ZWave_SWITCH_BINARY_18
2021.08.30 21:27:20.538 5: ZWDongle_Write 001312039804002501 (db25d628)
2021.08.30 21:27:20.538 5: ACK received, removing 0105004a0503b6 from dongle sendstack
2021.08.30 21:27:20.538 5: DevIo_SimpleWrite zwd: 010a0013120398040025014f
2021.08.30 21:27:20.542 5: ACK received, WaitForAck=>2 for 010a0013120398040025014f
2021.08.30 21:27:20.548 4: ZWDongle_Read zwd: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.548 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.550 5: zwd: dispatch 011301
2021.08.30 21:27:20.567 4: ZWDongle_Read zwd: rcvd 00130100 (request ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.567 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.568 5: device ack reveived, removing 010a0013120398040025014f from dongle sendstack
2021.08.30 21:27:20.568 5: zwd: dispatch 00130100
2021.08.30 21:27:20.568 4: CMD:ZW_SEND_DATA ID:00 ARG: CB:01
2021.08.30 21:27:20.568 4: zwd transmit OK for CB 01, target ZWave_SWITCH_BINARY_18
2021.08.30 21:27:20.582 4: ZWDongle_Read zwd: rcvd 0004001203980500cd00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.30 21:27:20.582 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.583 5: zwd: dispatch 0004001203980500cd00
2021.08.30 21:27:20.583 4: CMD:APPLICATION_COMMAND_HANDLER ID:12 ARG:03980500cd00 CB:00
2021.08.30 21:27:20.583 5: ZWDongle_Write 0013120298402502 (db25d628)
2021.08.30 21:27:20.584 5: DevIo_SimpleWrite zwd: 010900131202984025020a
2021.08.30 21:27:20.585 5: ACK received, WaitForAck=>2 for 010900131202984025020a
2021.08.30 21:27:20.591 4: ZWDongle_Read zwd: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.592 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.593 5: zwd: dispatch 011301
2021.08.30 21:27:20.597 4: ZWDongle_Read zwd: rcvd 004a03061200 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2021.08.30 21:27:20.597 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.598 5: zwd: dispatch 004a03061200
2021.08.30 21:27:20.598 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:1200 CB:03
2021.08.30 21:27:20.598 4: zwd ZW_ADD_NODE_TO_NETWORK done
2021.08.30 21:27:20.610 4: ZWDongle_Read zwd: rcvd 00130200 (request ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.610 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.611 5: device ack reveived, removing 010900131202984025020a from dongle sendstack
2021.08.30 21:27:20.611 5: zwd: dispatch 00130200
2021.08.30 21:27:20.611 4: CMD:ZW_SEND_DATA ID:00 ARG: CB:02
2021.08.30 21:27:20.611 4: zwd transmit OK for CB 02, target ZWave_SWITCH_BINARY_18
2021.08.30 21:27:20.627 4: ZWDongle_Read zwd: rcvd 000400120a98805ddb386e6a231a62cd00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.30 21:27:20.627 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.628 5: zwd: dispatch 000400120a98805ddb386e6a231a62cd00
2021.08.30 21:27:20.628 4: CMD:APPLICATION_COMMAND_HANDLER ID:12 ARG:0a98805ddb386e6a231a62cd00 CB:00
2021.08.30 21:27:20.629 5: ZWDongle_Write 001312269881faa009ba081be488bd73eb8c3ae28e939c20482c4aab211313fd205dc4cf0bfb67ebd2ac2503 (db25d628)
2021.08.30 21:27:20.629 5: DevIo_SimpleWrite zwd: 012d001312269881faa009ba081be488bd73eb8c3ae28e939c20482c4aab211313fd205dc4cf0bfb67ebd2ac2503a1
2021.08.30 21:27:20.633 5: ACK received, WaitForAck=>2 for 012d001312269881faa009ba081be488bd73eb8c3ae28e939c20482c4aab211313fd205dc4cf0bfb67ebd2ac2503a1
2021.08.30 21:27:20.641 4: ZWDongle_Read zwd: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.641 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.642 5: zwd: dispatch 011301
2021.08.30 21:27:20.662 4: ZWDongle_Read zwd: rcvd 00130300 (request ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.662 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.663 5: device ack reveived, removing 012d001312269881faa009ba081be488bd73eb8c3ae28e939c20482c4aab211313fd205dc4cf0bfb67ebd2ac2503a1 from dongle sendstack
2021.08.30 21:27:20.663 5: zwd: dispatch 00130300
2021.08.30 21:27:20.663 4: CMD:ZW_SEND_DATA ID:00 ARG: CB:03
2021.08.30 21:27:20.663 4: zwd transmit OK for CB 03, target ZWave_SWITCH_BINARY_18
2021.08.30 21:27:20.689 4: ZWDongle_Read zwd: rcvd 00040012029840cd00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.30 21:27:20.689 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.690 5: zwd: dispatch 00040012029840cd00
2021.08.30 21:27:20.690 4: CMD:APPLICATION_COMMAND_HANDLER ID:12 ARG:029840cd00 CB:00
2021.08.30 21:27:20.691 5: ZWDongle_Write 0013120a9880a6810d99b82e46202504 (db25d628)
2021.08.30 21:27:20.691 5: DevIo_SimpleWrite zwd: 01110013120a9880a6810d99b82e462025049f
2021.08.30 21:27:20.693 5: ACK received, WaitForAck=>2 for 01110013120a9880a6810d99b82e462025049f
2021.08.30 21:27:20.699 4: ZWDongle_Read zwd: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.699 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.701 5: zwd: dispatch 011301
2021.08.30 21:27:20.718 4: ZWDongle_Read zwd: rcvd 00130400 (request ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.718 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.720 5: device ack reveived, removing 01110013120a9880a6810d99b82e462025049f from dongle sendstack
2021.08.30 21:27:20.720 5: zwd: dispatch 00130400
2021.08.30 21:27:20.720 4: CMD:ZW_SEND_DATA ID:00 ARG: CB:04
2021.08.30 21:27:20.720 4: zwd transmit OK for CB 04, target ZWave_SWITCH_BINARY_18
2021.08.30 21:27:20.739 4: ZWDongle_Read zwd: rcvd 000400121698811b84d5e29dad089ca87bb5a6473bb65a7f1c156ecc00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.30 21:27:20.740 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.741 5: zwd: dispatch 000400121698811b84d5e29dad089ca87bb5a6473bb65a7f1c156ecc00
2021.08.30 21:27:20.741 4: CMD:APPLICATION_COMMAND_HANDLER ID:12 ARG:1698811b84d5e29dad089ca87bb5a6473bb65a7f1c156ecc00 CB:00
2021.08.30 21:27:20.742 4: CMD:APPLICATION_COMMAND_HANDLER ID:12 ARG:029807 CB:00
2021.08.30 21:27:20.742 3: ZWave_SWITCH_BINARY_18: SECURITY enabled, networkkey was verified
2021.08.30 21:27:20.743 3: ZWave set ZWave_SWITCH_BINARY_18 secSupportedReport
2021.08.30 21:27:20.743 5: ZWDongle_Write 0013120298402506 (db25d628)
2021.08.30 21:27:20.743 5: DevIo_SimpleWrite zwd: 010900131202984025060e
2021.08.30 21:27:20.745 5: ACK received, WaitForAck=>2 for 010900131202984025060e
2021.08.30 21:27:20.750 4: ZWDongle_Read zwd: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.751 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.752 5: zwd: dispatch 011301
2021.08.30 21:27:20.769 4: ZWDongle_Read zwd: rcvd 00130600 (request ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.769 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.770 5: device ack reveived, removing 010900131202984025060e from dongle sendstack
2021.08.30 21:27:20.770 5: zwd: dispatch 00130600
2021.08.30 21:27:20.770 4: CMD:ZW_SEND_DATA ID:00 ARG: CB:06
2021.08.30 21:27:20.770 4: zwd transmit OK for CB 06, target ZWave_SWITCH_BINARY_18
2021.08.30 21:27:20.785 4: ZWDongle_Read zwd: rcvd 000400120a988037e7877d9af96ec2cc00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.30 21:27:20.785 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.786 5: zwd: dispatch 000400120a988037e7877d9af96ec2cc00
2021.08.30 21:27:20.786 4: CMD:APPLICATION_COMMAND_HANDLER ID:12 ARG:0a988037e7877d9af96ec2cc00 CB:00
2021.08.30 21:27:20.787 5: ZWDongle_Write 0013121698814727d33079b2626232f991371f4b637489900aa92507 (db25d628)
2021.08.30 21:27:20.787 5: DevIo_SimpleWrite zwd: 011d0013121698814727d33079b2626232f991371f4b637489900aa9250712
2021.08.30 21:27:20.790 5: ACK received, WaitForAck=>2 for 011d0013121698814727d33079b2626232f991371f4b637489900aa9250712
2021.08.30 21:27:20.797 4: ZWDongle_Read zwd: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.797 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.798 5: zwd: dispatch 011301
2021.08.30 21:27:20.817 4: ZWDongle_Read zwd: rcvd 00130700 (request ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.817 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.818 5: device ack reveived, removing 011d0013121698814727d33079b2626232f991371f4b637489900aa9250712 from dongle sendstack
2021.08.30 21:27:20.818 5: zwd: dispatch 00130700
2021.08.30 21:27:20.818 4: CMD:ZW_SEND_DATA ID:00 ARG: CB:07
2021.08.30 21:27:20.818 4: zwd transmit OK for CB 07, target ZWave_SWITCH_BINARY_18
2021.08.30 21:27:20.833 4: ZWDongle_Read zwd: rcvd 00040012029840cd00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.30 21:27:20.833 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.835 5: zwd: dispatch 00040012029840cd00
2021.08.30 21:27:20.835 4: CMD:APPLICATION_COMMAND_HANDLER ID:12 ARG:029840cd00 CB:00
2021.08.30 21:27:20.835 5: ZWDongle_Write 0013120a98804ae798a36abf51612508 (db25d628)
2021.08.30 21:27:20.836 5: DevIo_SimpleWrite zwd: 01110013120a98804ae798a36abf51612508a3
2021.08.30 21:27:20.838 5: ACK received, WaitForAck=>2 for 01110013120a98804ae798a36abf51612508a3
2021.08.30 21:27:20.844 4: ZWDongle_Read zwd: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.844 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.845 5: zwd: dispatch 011301
2021.08.30 21:27:20.863 4: ZWDongle_Read zwd: rcvd 00130800 (request ZW_SEND_DATA), sending ACK
2021.08.30 21:27:20.863 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.864 5: device ack reveived, removing 01110013120a98804ae798a36abf51612508a3 from dongle sendstack
2021.08.30 21:27:20.865 5: zwd: dispatch 00130800
2021.08.30 21:27:20.865 4: CMD:ZW_SEND_DATA ID:00 ARG: CB:08
2021.08.30 21:27:20.865 4: zwd transmit OK for CB 08, target ZWave_SWITCH_BINARY_18
2021.08.30 21:27:20.888 4: ZWDongle_Read zwd: rcvd 00040012239881dd65057a3ca76959d9f9d159de84a07859458f0d0b27db6c4a063cd4df47dfc189cd00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.30 21:27:20.888 5: DevIo_SimpleWrite zwd: 06
2021.08.30 21:27:20.889 5: zwd: dispatch 00040012239881dd65057a3ca76959d9f9d159de84a07859458f0d0b27db6c4a063cd4df47dfc189cd00
2021.08.30 21:27:20.889 4: CMD:APPLICATION_COMMAND_HANDLER ID:12 ARG:239881dd65057a3ca76959d9f9d159de84a07859458f0d0b27db6c4a063cd4df47dfc189cd00 CB:00
2021.08.30 21:27:20.890 4: CMD:APPLICATION_COMMAND_HANDLER ID:12 ARG:0f9803002526337027328185597a73ef CB:00
2021.08.30 21:27:20.891 1: ZWAVE INIT: get ZWave_SWITCH_BINARY_18 model: Secure operation in progress, executing in background
2021.08.30 21:27:20.891 1: ZWAVE INIT: get ZWave_SWITCH_BINARY_18 versionClassAll: Secure operation in progress, executing in background
2021.08.30 21:27:20.891 1: ZWAVE INIT: get ZWave_SWITCH_BINARY_18 zwavePlusInfo: Secure operation in progress, executing in background
2021.08.30 21:27:20.892 3: ZWave get ZWave_SWITCH_BINARY_18 model
2021.08.30 21:27:20.892 5: ZWDongle_Write 0013120272042509 (db25d628)
2021.08.30 21:27:20.892 5: DevIo_SimpleWrite zwd: 01090013120272042509af
2021.08.30 21:27:20.894 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass ASSOCIATION
2021.08.30 21:27:20.895 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass ASSOCIATION_GRP_INFO
2021.08.30 21:27:20.895 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass CLOCK
2021.08.30 21:27:20.896 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass COLOR_CONTROL
2021.08.30 21:27:20.896 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass CONFIGURATION
2021.08.30 21:27:20.897 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass DEVICE_RESET_LOCALLY
2021.08.30 21:27:20.897 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass FIRMWARE_UPDATE_MD
2021.08.30 21:27:20.898 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass HAIL
2021.08.30 21:27:20.898 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass MANUFACTURER_SPECIFIC
2021.08.30 21:27:20.899 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass METER
2021.08.30 21:27:20.899 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass POWERLEVEL
2021.08.30 21:27:20.900 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass SECURITY
2021.08.30 21:27:20.900 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass SWITCH_ALL
2021.08.30 21:27:20.901 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass SWITCH_BINARY
2021.08.30 21:27:20.901 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass SWITCH_MULTILEVEL
2021.08.30 21:27:20.902 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass VERSION
2021.08.30 21:27:20.902 3: ZWave get ZWave_SWITCH_BINARY_18 versionClass ZWAVEPLUS_INFO
2021.08.30 21:27:20.902 1: ERROR: get ZWave_SWITCH_BINARY_18 versionClassAll => working in the background, check the vclasses attribute
2021.08.30 21:27:20.903 3: ZWave set ZWave_SWITCH_BINARY_18 associationAdd 1 1
2021.08.30 21:27:20.903 1: ERROR: get ZWave_SWITCH_BINARY_18 zwavePlusInfo => Secure operation in progress, executing in background
2021.08.30 21:27:20.903 5: ZWDongle_Write 00131203861385250a (db25d628)
2021.08.30 21:27:20.904 5: ACK received, WaitForAck=>2 for 01090013120272042509af
2021.08.30 21:27:20.904 4: ZWDongle_Read zwd: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
Offline krikan
« Antwort #50 am: 02 September 2021, 18:37:17 »
Schiebe das secure-Inklusionsproblem auf eine Macke des Philio Sensors:
secure-Inklusion unter Linux und aktuellem FHEM mit UZB1 hat auch nach 16(!) Versuchen -egal ob txStatusReport an oder aus war- nicht geklappt.
Unter Windows mit Vision ZWavePlus-Stick 2 Erfolge bei 12(!) Versuchen. 1x mit aktuellem FHEM und 1x mit Stand svn-Tag FHEM 5.8 bei jeweils 7 bzw. 5 Versuchen. Wollte Abhängigkeit von Änderungem im FHEM-Code ausschließen, da der Sensor das gut funktionierende Testgerät beim Einbau von SECURITY war.
Evtl. hat der zickige CFA3010 ein ähnliches Leiden wie mein Philio Sensor.
Offline tremichl
  • Jr. Member
« Antwort #51 am: 08 November 2021, 19:06:49 »
gibt es Neuigkeiten zum Thema "nur Aufschließen" aber nicht "Öffnen". Ich bin gerade von einer KeyMatic auf das ABUS Modul umgestiegen, da sich dort nach etwas mehr als 2 Jahren das Getriebe verabschiedet hat. Dort gab es dass ja. Ich hatte aber erst gekauft und dann gelesen.
Wäre schön, wenn einer dazu ein Feedback geben könnte.
VG Felix
Das möchte ich auch gerne wissen. Hat das (lock-unlock-open statt nur open und close) schon jemand gebrauch bzw. gelöst?
Danke, LG Michael
Wir haben keine Ahnung davon, was wir nicht wissen
