[gelöst] Update v. 27.1.20 ESP_Easy Modul zur Info
Begonnen von oldscout, 28 Januar 2020, 06:52:19
oldscout
seit dem gestirgen Update hhabe ich diese Logs vom ESP_Easy Modul, das Modul meldet aber noch die Devices an fhem:
ESPEasy ESPBridge_192.168.1.82_52841: WARNING: value name or value is missing (192.168.1.82). Skip processing this value.
2020.01.28 02:18:21 2: ESPEasy ESPBridge_192.168.1.82_52841: Data: {"module":"ESPEasy","version":"1.04","data":{"ESP":{"name":"ESP2","unit":1,"version":2,"build":20104,"build_notes":" - Mega","build_git":"mega-20191208","node_type_id":17,"sleep":60,"ip":"192.168.1.82"},"SENSOR":{"0":{"deviceName":"RSSI","valueName":"rssi","type":7,"value":"-78"},"1":{"deviceName":"RSSI","valueName":"vcc","type":7,"value":"-1.00"},"2":{"deviceName":"RSSI","valueName":"","type":7,"value":"0.00"},"3":{"deviceName":"RSSI","valueName":"","type":7,"value":"0.00"}}}}
2020.01.28 02:18:21 2: ESPEasy ESPBridge_192.168.1.82_52841: WARNING: value name or value is missing (192.168.1.82). Skip processing this value.
2020.01.28 02:19:19 2: ESPEasy ESPBridge_192.168.1.82_60236: WARNING: value name or value is missing (192.168.1.82). Skip processing this value.
2020.01.28 02:19:19 2: ESPEasy ESPBridge_192.168.1.82_60236: Data: {"module":"ESPEasy","version":"1.04","data":{"ESP":{"name":"ESP2","unit":1,"version":2,"build":20104,"build_notes":" - Mega","build_git":"mega-20191208","node_type_id":17,"sleep":60,"ip":"192.168.1.82"},"SENSOR":{"0":{"deviceName":"RSSI","valueName":"rssi","type":7,"value":"-77"},"1":{"deviceName":"RSSI","valueName":"vcc","type":7,"value":"-1.00"},"2":{"deviceName":"RSSI","valueName":"","type":7,"value":"0.00"},"3":{"deviceName":"RSSI","valueName":"","type":7,"value":"0.00"}}}}
Bisher lief alles problemlos was diese Logs betrifft.
Danke.
FHEM 5.8 auf Intel Celeron CPU
HM-.*, 1-Wire DS18B20, HMLAN, HMUSB, Arduino Uno, ESP8266, Shelly, Tasmota, Enigma2, FB7490, MySql-DB,Unifi, RaspiCCU
oldscout
hat sich eben erledigt. Der Fehler ist schon länger drin. Gehe selbst auf die Suche.
gelbwichtel
Hi oldscout,
ich hab diese Fehlermeldungen jetzt auch drin. Hab allerdings länger nicht mehr mit den betroffenen ESPDevices gearbeitet.
Kannst du mir posten, was du bei deiner Fehlersuche herausgefunden hast ?
Danke vorab
cu
gelbwichtel
Frank_Huber
Zitat von: gelbwichtel am 01 Mai 2020, 09:23:50
Hi oldscout,
Danke vorab
hat er doch schon:
Zitatvalue name or value is missing
und im code sieht man:
Da hat ein RSSI device im ESP keinen ValueName.
