Remote:
DEF WallMountedThermostat 1c0792
FUUID 61589be7-f33f-ac20-9803-1962811ec9cecb04
IODev cm
NAME MAX_1c0792
NR 24
NTFY_ORDER 50-MAX_1c0792
STATE 26.6
SVN 23517
TYPE MAX
TimeSlot 0
addr 1c0792
devtype 3
type WallMountedThermostat
webCmd desiredTemperature
2021-10-02 22:36:35 IODev cm
2021-10-02 19:50:54 PairedTo 000000
2021-10-02 20:00:49 RSSI -49.5
2021-10-02 19:50:54 SerialNr QEQ1648061
2021-10-02 19:57:28 battery ok
2021-10-02 19:57:28 batteryState ok
2021-10-02 19:50:54 boostDuration 25
2021-10-02 19:50:54 boostValveposition 80
2021-10-02 19:50:54 comfortTemperature 21.0
2021-10-02 20:00:49 desiredTemperature 21.0
2021-10-02 19:59:06 deviation 8.6
2021-10-02 19:57:28 displayActualTemperature 1
2021-10-02 19:50:54 ecoTemperature 17.0
2021-10-02 19:50:31 error invalid or missing value for READING .weekProfile
2021-10-02 19:50:54 firmware 1.0
2021-10-02 19:57:28 gateway 1
2021-10-02 19:50:31 groupid 0
2021-10-02 19:50:56 lastTimeSync 2021-10-02 19:50:56
2021-10-02 19:50:54 lastcmd WallThermostatConfig
2021-10-02 19:50:54 maximumTemperature on
2021-10-02 19:50:54 measurementOffset 0.0
2021-10-02 19:50:54 minimumTemperature off
2021-10-02 20:00:49 mode auto
2021-10-02 19:50:56 msgcnt 2
2021-10-02 19:57:28 panel unlocked
2021-10-02 19:59:06 peerIDs 000000
2021-10-02 19:59:06 peerList Broadcast
2021-10-02 19:57:28 rferror 0
2021-10-02 20:00:49 state 21.0
2021-10-02 19:59:06 temperature 26.6
2021-10-02 19:50:54 testresult 255
2021-10-02 19:50:54 weekprofile-0-Sat-temp 17.0 °C / 21.0 °C / 17.0 °C
2021-10-02 19:50:54 weekprofile-0-Sat-time 00:00-06:00 / 06:00-22:00 / 22:00-24:00
2021-10-02 19:50:54 weekprofile-1-Sun-temp 17.0 °C / 21.0 °C / 17.0 °C
2021-10-02 19:50:54 weekprofile-1-Sun-time 00:00-06:00 / 06:00-22:00 / 22:00-24:00
2021-10-02 19:50:54 weekprofile-2-Mon-temp 17.0 °C / 21.0 °C / 17.0 °C / 21.0 °C / 17.0 °C
2021-10-02 19:50:54 weekprofile-2-Mon-time 00:00-06:00 / 06:00-09:00 / 09:00-17:00 / 17:00-23:00 / 23:00-24:00
2021-10-02 19:50:54 weekprofile-3-Tue-temp 17.0 °C / 21.0 °C / 17.0 °C / 21.0 °C / 17.0 °C
2021-10-02 19:50:54 weekprofile-3-Tue-time 00:00-06:00 / 06:00-09:00 / 09:00-17:00 / 17:00-23:00 / 23:00-24:00
2021-10-02 19:50:54 weekprofile-4-Wed-temp 17.0 °C / 21.0 °C / 17.0 °C / 21.0 °C / 17.0 °C
2021-10-02 19:50:54 weekprofile-4-Wed-time 00:00-06:00 / 06:00-09:00 / 09:00-17:00 / 17:00-23:00 / 23:00-24:00
2021-10-02 19:50:54 weekprofile-5-Thu-temp 17.0 °C / 21.0 °C / 17.0 °C / 21.0 °C / 17.0 °C
2021-10-02 19:50:54 weekprofile-5-Thu-time 00:00-06:00 / 06:00-09:00 / 09:00-17:00 / 17:00-23:00 / 23:00-24:00
2021-10-02 19:50:54 weekprofile-6-Fri-temp 17.0 °C / 21.0 °C / 17.0 °C / 21.0 °C / 17.0 °C
2021-10-02 19:50:54 weekprofile-6-Fri-time 00:00-06:00 / 06:00-09:00 / 09:00-17:00 / 17:00-23:00 / 23:00-24:00
2021-10-02 19:50:54 windowOpenTemperature 12.0
IODev cm
model WallMountedThermostat
room FHEMSync,MAX
stateFormat temperature
Master:
CFGFN
DEF MAX MAX_1c0792
FUUID 6159f4f4-f33f-9a7c-1e9b-bf6cade900647cdd
NAME MAX_1c0792
NR 6225
REMOTENAME MAX_1c0792
REMOTETYPE MAX
STATE 26.6
SVN 23517
TYPE FHEMSYNC_DEVICE
TimeSlot 0
addr 1c0792
devtype 3
2021-10-03 20:22:45 IODev cm
2021-10-03 20:22:45 PairedTo 000000
2021-10-03 20:22:45 RSSI -49.5
2021-10-03 20:22:45 SerialNr QEQ1648061
2021-10-03 20:22:45 battery ok
2021-10-03 20:22:45 batteryState ok
2021-10-03 20:22:45 boostDuration 25
2021-10-03 20:22:45 boostValveposition 80
2021-10-03 20:22:45 comfortTemperature 21.0
2021-10-03 20:22:45 desiredTemperature 21.0
2021-10-03 20:22:45 deviation 8.6
2021-10-03 20:22:45 displayActualTemperature 1
2021-10-03 20:22:45 ecoTemperature 17.0
2021-10-03 20:22:45 error invalid or missing value for READING .weekProfile
2021-10-03 20:22:45 firmware 1.0
2021-10-03 20:22:45 gateway 1
2021-10-03 20:22:45 groupid 0
2021-10-03 20:22:45 lastTimeSync 2021-10-02 19:50:56
2021-10-03 20:22:45 lastcmd WallThermostatConfig
2021-10-03 20:22:45 maximumTemperature on
2021-10-03 20:22:45 measurementOffset 0.0
2021-10-03 20:22:45 minimumTemperature off
2021-10-03 20:22:45 mode auto
2021-10-03 20:22:45 msgcnt 2
2021-10-03 20:22:45 panel unlocked
2021-10-03 20:22:45 peerIDs 000000
2021-10-03 20:22:45 peerList Broadcast
2021-10-03 20:22:45 rferror 0
2021-10-03 20:22:45 state 21.0
2021-10-03 20:22:45 temperature 26.6
2021-10-03 20:22:45 testresult 255
2021-10-03 20:22:45 weekprofile-0-Sat-temp 17.0 °C / 21.0 °C / 17.0 °C
2021-10-03 20:22:45 weekprofile-0-Sat-time 00:00-06:00 / 06:00-22:00 / 22:00-24:00
2021-10-03 20:22:45 weekprofile-1-Sun-temp 17.0 °C / 21.0 °C / 17.0 °C
2021-10-03 20:22:45 weekprofile-1-Sun-time 00:00-06:00 / 06:00-22:00 / 22:00-24:00
2021-10-03 20:22:45 weekprofile-2-Mon-temp 17.0 °C / 21.0 °C / 17.0 °C / 21.0 °C / 17.0 °C
2021-10-03 20:22:45 weekprofile-2-Mon-time 00:00-06:00 / 06:00-09:00 / 09:00-17:00 / 17:00-23:00 / 23:00-24:00
2021-10-03 20:22:45 weekprofile-3-Tue-temp 17.0 °C / 21.0 °C / 17.0 °C / 21.0 °C / 17.0 °C
2021-10-03 20:22:45 weekprofile-3-Tue-time 00:00-06:00 / 06:00-09:00 / 09:00-17:00 / 17:00-23:00 / 23:00-24:00
2021-10-03 20:22:45 weekprofile-4-Wed-temp 17.0 °C / 21.0 °C / 17.0 °C / 21.0 °C / 17.0 °C
2021-10-03 20:22:45 weekprofile-4-Wed-time 00:00-06:00 / 06:00-09:00 / 09:00-17:00 / 17:00-23:00 / 23:00-24:00
2021-10-03 20:22:45 weekprofile-5-Thu-temp 17.0 °C / 21.0 °C / 17.0 °C / 21.0 °C / 17.0 °C
2021-10-03 20:22:45 weekprofile-5-Thu-time 00:00-06:00 / 06:00-09:00 / 09:00-17:00 / 17:00-23:00 / 23:00-24:00
2021-10-03 20:22:45 weekprofile-6-Fri-temp 17.0 °C / 21.0 °C / 17.0 °C / 21.0 °C / 17.0 °C
2021-10-03 20:22:45 weekprofile-6-Fri-time 00:00-06:00 / 06:00-09:00 / 09:00-17:00 / 17:00-23:00 / 23:00-24:00
2021-10-03 20:22:45 windowOpenTemperature 12.0
helper:
getlist show_savedConfig:
setlist deviceRename wakeUp:noArg factoryReset:noArg groupid associate:fakeShutterContact deassociate:fakeShutterContact desiredTemperature:eco,comfort,boost,auto,off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0,on comfortTemperature:off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0,on ecoTemperature:off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0,on measurementOffset:-3.5,-3.0,-2.5,-2.0,-1.5,-1.0,-0.5,0.0,0.5,1.0,1.5,2.0,2.5,3.0,3.5 boostDuration:0,10,15,20,25,30,5,60 boostValveposition maximumTemperature:off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0,on minimumTemperature:off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0,on windowOpenTemperature:off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0,on saveConfig weekProfile restoreReadings: restoreDevice: displayActualTemperature:0,1 attrTemplate:?,MAX_WallMountedThermostat_dark
json:
Name MAX_1c0792
PossibleAttrs alias comment:textField-long eventMap:textField-long group room suppressReading userattr userReadings:textField-long verbose:0,1,2,3,4,5 IODev CULdev actCycle do_not_notify:1,0 ignore:0,1 dummy:0,1 keepAuto:0,1 debug:0,1 scanTemp:0,1 skipDouble:0,1 externalSensor model:HeatingThermostat,HeatingThermostatPlus,WallMountedThermostat,ShutterContact,PushButton,Cube,PlugAdapter autosaveConfig:1,0 peers sendMode:peers,group,Broadcast dTempCheck:0,1 windowOpenCheck:0,1 DbLog_log_onoff:0,1 event-aggregator event-min-interval event-on-change-reading event-on-update-reading oldreadings stateFormat:textField-long timestamp-on-change-reading cmdIcon devStateIcon:textField-long devStateStyle icon sortby webCmd webCmdLabel:textField-long widgetOverride
PossibleSets deviceRename wakeUp:noArg factoryReset:noArg groupid associate:fakeShutterContact deassociate:fakeShutterContact desiredTemperature:eco,comfort,boost,auto,off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0,on comfortTemperature:off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0,on ecoTemperature:off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0,on measurementOffset:-3.5,-3.0,-2.5,-2.0,-1.5,-1.0,-0.5,0.0,0.5,1.0,1.5,2.0,2.5,3.0,3.5 boostDuration:0,10,15,20,25,30,5,60 boostValveposition maximumTemperature:off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0,on minimumTemperature:off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0,on windowOpenTemperature:off,5.0,5.5,6.0,6.5,7.0,7.5,8.0,8.5,9.0,9.5,10.0,10.5,11.0,11.5,12.0,12.5,13.0,13.5,14.0,14.5,15.0,15.5,16.0,16.5,17.0,17.5,18.0,18.5,19.0,19.5,20.0,20.5,21.0,21.5,22.0,22.5,23.0,23.5,24.0,24.5,25.0,25.5,26.0,26.5,27.0,27.5,28.0,28.5,29.0,29.5,30.0,on saveConfig weekProfile restoreReadings: restoreDevice: displayActualTemperature:0,1 attrTemplate:?,MAX_WallMountedThermostat_dark
IODev cm
room FHEMSync,MAX
IODev cm
NAME MAX_1c0792
NR 24
STATE 26.6
SVN 23517
TYPE MAX
TimeSlot 0
addr 1c0792
devtype 3
Readings:
IODev
PairedTo:
Time 2021-10-02 19:50:54
Value 000000
RSSI:
Time 2021-10-02 20:00:49
Value -49.5
SerialNr:
Value QEQ1648061
battery:
Time 2021-10-02 19:57:28
Value ok
batteryState:
Value ok
boostDuration:
Value 25
boostValveposition:
Value 80
comfortTemperature:
Value 21.0
desiredTemperature:
Value 21.0
deviation:
Time 2021-10-02 19:59:06
Value 8.6
Value 1
ecoTemperature:
Value 17.0
error:
Time 2021-10-02 19:50:31
Value invalid or missing value for READING .weekProfile
firmware:
Value 1.0
gateway:
Value 1
groupid:
Value 0
lastTimeSync:
Time 2021-10-02 19:50:56
Value 2021-10-02 19:50:56
lastcmd:
Value WallThermostatConfig
maximumTemperature:
Value on
measurementOffset:
Value 0.0
minimumTemperature:
Value off
mode:
Value auto
msgcnt:
Value 2
panel:
Value unlocked
peerIDs:
Value 000000
peerList:
Value Broadcast
rferror:
Value 0
state:
Value 21.0
temperature:
Value 26.6
testresult:
Value 255
weekprofile-0-Sat-temp:
Value 17.0 �C / 21.0 �C / 17.0 �C
weekprofile-0-Sat-time:
Value 00:00-06:00 / 06:00-22:00 / 22:00-24:00
weekprofile-1-Sun-temp:
weekprofile-1-Sun-time:
weekprofile-2-Mon-temp:
Value 17.0 �C / 21.0 �C / 17.0 �C / 21.0 �C / 17.0 �C
weekprofile-2-Mon-time:
Value 00:00-06:00 / 06:00-09:00 / 09:00-17:00 / 17:00-23:00 / 23:00-24:00
weekprofile-3-Tue-temp:
weekprofile-3-Tue-time:
weekprofile-4-Wed-temp:
weekprofile-4-Wed-time:
weekprofile-5-Thu-temp:
weekprofile-5-Thu-time:
weekprofile-6-Fri-temp:
weekprofile-6-Fri-time:
Value 12.0
room FHEMSync
userattr model stateFormat
Hab auch das im Log gefunden:
2021-10-05 12:49:06 FHEMSYNC_DEVICE MAX_1c0792 x_getlist show_savedConfig:
2021-10-05 12:49:06 FHEMSYNC_DEVICE MAX_1c0792 COMMANDSET,?
