Autor Thema: [gelöst] floorplan LCARS "Backimg/Aktuelle Seite" - funktionierende definition  (Gelesen 2687 mal)
Offline Brot
  • New Member
  • ...taste the bread.
    • Ich habe SHAS
Grüet'si!
Ich bin gerade an dem LCARS floorplan:
https://wiki.fhem.de/wiki/Floorplan_im_LCARS_Design
Die dort erwähnte Definition zur "Erweiterung Backimg/Aktuelle Seite"..:
define current_fp_page weblink htmlCode {'<a class="svg"><svg xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:cc="http://creativecommons.org/ns#" xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#" xmlns:svg="http://www.w3.org/2000/svg" xmlns="http://www.w3.org/2000/svg" xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd" xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape" xmlns:xlink="http://www.w3.org/1999/xlink" id="svg2" version="1.1" inkscape:version="0.91 r13725" sodipodi:docname="switch_off.svg" viewBox="0 0 170 45.000001" width="170" height="45"> <style type="text/css" id="style3"> @font-face { font-family: "lcars"; src: url("/fhem/images/default/lcars/lcarsgtj3-webfont.eot"); src: url("/fhem/images/default/lcars/lcarsgtj3-webfont.eot?#iefix") format("embedded-opentype"), url("/fhem/images/default/lcars/lcarsgtj3-webfont.woff") format("woff"), url("/fhem/images/default/lcars/lcarsgtj3-webfont.ttf") format("truetype"), url("/fhem/images/default/lcars/lcarsgtj3-webfont.svg#lcarsgtj3lcarsgtj3") format("svg"); font-weight: normal; font-style: normal;} </style> <defs id="defs4"/> <sodipodi:namedview id="base" pagecolor="#ffffff" bordercolor="#666666" borderopacity="1.0" inkscape:pageopacity="0.0" inkscape:pageshadow="2" inkscape:zoom="3.9185501" inkscape:cx="8.571662" inkscape:cy="52.612298" inkscape:document-units="px" inkscape:current-layer="layer1" showgrid="false" units="px" inkscape:window-width="1827" inkscape:window-height="1051" inkscape:window-x="84" inkscape:window-y="-9" inkscape:window-maximized="1"/> <metadata id="metadata7"> <rdf:RDF> <cc:Work rdf:about=""> <dc:format>image/svg+xml</dc:format> <dc:type rdf:resource="http://purl.org/dc/dcmitype/StillImage"/> <dc:title/> </cc:Work> </rdf:RDF> </metadata> <g inkscape:label="Ebene 1" inkscape:groupmode="layer" id="layer1" transform="translate(0,0)"> <text font-size="35" font-family="lcars" id="text_current" fill="#0000DD" text-anchor="middle" y="25" x="85">NIFP</text> </g> </svg></a><script>$("#text_current").html($("#backimg").html().replace("fp_LCARS_", ""));</script>' }
..wird von FHEM direkt abgeschmettert mit:
Unknown command src:, try help.
Unknown command font-weight:, try help.
Unknown command font-style:, try help.
Unknown command }, try help.
Unknown command ', try help.
Kann schon sein, weil hier schätzungsweise die enthaltenen...
mehr so escaped werden könnten/sollten:
Macht man das, wird die definition erstellt, allerdings haut es einem dann so etwas um die Ohren:
fhem?detail=current_fp_page&fw_id=4800 line 137:
TypeError: $(...).html() is undefined
Kann mir wer sagen wie ich das gelöst bekomme oder hat womöglich für den LCARS floorplan hier eine funktionierende Variante für mich?
Grüße,
Buttermilch-Dinkel-Brot
« Letzte Änderung: 30 August 2020, 22:23:43 von Brot »
diverse Raspberry Pis, Orange Pi 3, Odroid N2, Alexa, jede Menge ESP8266er
Raspbian, FHEM, NextCloud, Pi-Hole, OctoPrint, MagicMirror²
Tasmota, Eqiva Bluetooth Thermo, Senseo-ESP8266-Mod, Conbee-II HUE, Z-Wave, BTLE_FlowerSens...
Offline Brot
  • New Member
    • Ich habe SHAS
Nicht dass das an dem eigentlichen Problem etwas lösen würde, aber zumindest so würde die recht nervige Fehlermeldung nicht mehr erscheinen (die sonst bei jedem Aufruf des devices aufpoppen würde):
attr WEB confirmJSError 0
Offline Brot
  • New Member
    • Ich habe SHAS
Nach "leichtem Ausdünnen" der Definition - so geht's:
defmod current_fp_page weblink htmlCode {'<a class="svg"><svg> <style type="text/css" id="iriestyle"> @font-face { font-family: "lcars";; src: url("/fhem/images/default/lcars/lcarsgtj3-webfont.eot");; src: url("/fhem/images/default/lcars/lcarsgtj3-webfont.eot?#iefix") format("embedded-opentype"), url("/fhem/images/default/lcars/lcarsgtj3-webfont.woff") format("woff"), url("/fhem/images/default/lcars/lcarsgtj3-webfont.ttf") format("truetype"), url("/fhem/images/default/lcars/lcarsgtj3-webfont.svg#lcarsgtj3lcarsgtj3") format("svg");; font-weight: normal;; font-style: normal;;} </style> <defs id="defs4"/> <id="base" pagecolor="#ffffff" bordercolor="#666666" borderopacity="1.0" showgrid="false" units="px"/> <g id="layer1" transform="translate(0,0)"> <text font-size="35" font-family="lcars" id="text_current" fill="#0000DD" text-anchor="middle" y="27" x="90">Superendprimatext</text> </g> </svg></a><script>$("#text_current").html($("#backimg").html().replace("fp_LCARS_", ""));;</script>'}
