[GELÖST] Fehlerhafte Werte Bresser SD_WS07_TH_1
Begonnen von Burny4600, 13 Oktober 2020, 16:52:58
Burny4600
Ich habe Bresser Sensoren des Typs SD_WS07_TH die mit einen sduino empfangen werden.
list sduino_ab
   CFGFN      /media/hdd/fhem/mycfg/schnittstellen_rasp01.cfg
   Clients    :IT:CUL_TCM97001:SD_RSL:OREGON:CUL_TX:SD_AS:Hideki:SD_WS07:SD_WS09: :SD_WS:RFXX10REC:Dooya:SOMFY:SD_BELL:SD_UT:SD_WS_Maverick:FLAMINGO:CUL_WS:Revolt: :FS10:CUL_FHTTK:Siro:FHT:FS20:CUL_EM:Fernotron:SD_Keeloq:SD_GT:SIGNALduino_un:
   DEF        192.168.17.184:40733
   DMSG       u52#FFFFF5F1428BC0C9002602265
   DevState   initialized
   DeviceName 192.168.17.184:40733
   FD         365
   FUUID      5e6227ab-f33f-21bc-acd7-9dce1977680f0d37
   LASTDMSG   u52#FFFFF5F1428BC0C9002602265
   LASTDMSGID 52
   MSGCNT     107738
   NAME       sduino_ab
   NR         376
   PARTIAL
   RAWMSG     MC;LL=-1033;LH=912;SL=-546;SH=435;D=00000A0EBD743F36FFD9FDD9A;C=487;L=99;
   STATE      opened
   TIME       1602600398.00193
   TYPE       SIGNALduino
   sendworking 0
   unknownmessages
   version    V 3.4.0 SIGNALduino  - compiled at Jul 16 2020 20:52:03
   versionProtocols 1.20
   versionmodul v3.4.4_dev+14042020
   DoubleMsgIDs:
   MatchList:
     10:SD_WS07 ^P7#[A-Fa-f0-9]{6}[AFaf][A-Fa-f0-9]{2,3}
     11:SD_WS09 ^P9#F[A-Fa-f0-9]+
     12:SD_WS   ^W\d+x{0,1}#.*
     13:RFXX10REC ^(20|29)[A-Fa-f0-9]+
     14:Dooya   ^P16#[A-Fa-f0-9]+
     15:SOMFY   ^Ys[0-9A-F]+
     16:SD_WS_Maverick ^P47#[A-Fa-f0-9]+
     17:SD_UT   ^P(?:14|20|26|29|30|34|46|68|69|76|81|83|86|90|91|91.1|92|93|95|97|99|104)#.*
     18:FLAMINGO ^P13\.?1?#[A-Fa-f0-9]+
     19:CUL_WS  ^K[A-Fa-f0-9]{5,}
     1:IT       ^i......
     20:Revolt  ^r[A-Fa-f0-9]{22}
     21:FS10    ^P61#[A-F0-9]+
     22:Siro    ^P72#[A-Fa-f0-9]+
     23:FHT     ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
     24:FS20    ^81..(04|0c)..0101a001
     25:CUL_EM  ^E0.................
     26:Fernotron ^P82#.*
     27:SD_BELL ^P(?:15|32|41|42|57|79|96|98)#.*
     28:SD_Keeloq ^P(?:87|88)#.*
     29:SD_GT   ^P49#[A-Fa-f0-9]+
     2:CUL_TCM97001 ^s[A-Fa-f0-9]+
     3:SD_RSL   ^P1#[A-Fa-f0-9]{8}
     4:OREGON   ^(3[8-9A-F]|[4-6][0-9A-F]|7[0-8]).*
     5:CUL_TX   ^TX..........
     6:SD_AS    ^P2#[A-Fa-f0-9]{7,8}
     7:Hideki   ^P12#75[A-F0-9]+
     9:CUL_FHTTK ^T[A-F0-9]{8}
     X:SIGNALduino_un ^[u]\d+#.*
   QUEUE:
     2020-05-11 20:10:46   ping            OK
     2020-10-13 16:00:54   state           opened
     2020-03-11 18:13:18   version         V 3.3.2.1-rc9 SIGNALduino - compiled at Jun 16 2019 18:11:42
   additionalSets:
   helper:
   keepalive:
     ok         0
     retry      0
   mcIdList:
     10
     11
     12
     18
     43
     47
     52
     57
     58
     96
   msIdList:
     0
     0.1
     0.2
     0.3
     0.4
     0.5
     1
     3
     3.1
     4
     6
     7
     13
     13.2
     14
     15
     17
     20
     23
     25
     33
     33.1
     33.2
     35
     41
     49
     51
     53
     54.1
     55
     65
     68
     74.1
     87
     88
     90
     91.1
     93
   muIdList:
     8
     9
     13.1
     16
     17.1
     19
     21
     22
     24
     26
     27
     28
     29
     30
     31
     32
     34
     36
     37
     38
     39
     40
     42
     44
     44.1
     45
     46
     48
     49.1
     49.2
     50
     54
     56
     59
     60
     61
     62
     64
     66
     67
     69
     70
     71
     72
     73
     74
     76
     79
     80
     81
     83
     84
     85
     86
     89
     91
     92
     94
     95
   alias      SIGNALduino - AB Wetterstation
   devStateIcon Initialized:it_network@0CFB0C opened:it_network@0CFB0C disconnected:it_network@red closed:it_network@red
   flashCommand avrdude -c arduino -b 57600 -P [PORT] -p atmega328p -vv -U flash:w:[HEXFILE] 2>[LOGFILE]
   group      Schnittstellen ser2net
   hardware   nano328
   icon       cul_usb
   longids    0
   room       _RxTx
   updateChannelFW stable
   verbose    0
   whitelist_IDs 0,0.1,0.2,0.3,0.4,0.5,1,3,3.1,4,6,7,8,9,10,11,12,13,13.1,13.2,14,15,16,17,17.1,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,33.1,33.2,34,35,36,37,38,39,40,41,42,43,44,44.1,45,46,47,48,49,49.1,49.2,50,51,52,53,54,54.1,55,56,57,58,59,60,61,62,64,65,66,67,68,69,70,71,72,73,74,74.1,76,79,80,81,83,84,85,86,87,88,89,90,91,91.1,92,93,94,95,96
Nur die Sensorwerte springen herum, und ständig wechselt der Batterie Status von ok auf low und umgekehrt, obwohl die Batterien neu sind.
list SD_WS07_TH_1
   CFGFN      /media/hdd/fhem/mycfg/umwelt/umwelt_rasp01.cfg
   CODE       SD_WS07_TH_1
   DEF        SD_WS07_TH_1
   FUUID      5e5d087f-f33f-21bc-eff5-0aa90524b16baa40
   LASTInputDev sduino_ab
   MSGCNT     4341
   NAME       SD_WS07_TH_1
   NR         5885
   STATE      Temperatur: 8.9 °C<br>Luftfeuchte abs.: 5.9 g/m³<br>Luftfeuchte rel.: 67.0 %F<br>Taupunkt: 3.1 °C<br>Dampfdruck: 7.6 hPa
   TYPE       SD_WS07
   bitMSG     10111101 0000 000001011001 1111 01000011
   lastMSG    BD0059F430
   lastReceive 1602600492.34284
   nanoCUL433_EG_DMSG P7#B680B4F470
   nanoCUL433_EG_MSGCNT 1
   nanoCUL433_EG_RAWMSG 2F2
   nanoCUL433_EG_TIME 2020-10-12 17:19:10
   sduino_ab_DMSG P7#BD0059F430
   sduino_ab_MSGCNT 4348
   sduino_ab_Protocol_ID 7
   sduino_ab_RAWMSG MS;P1=-2011;P3=-952;P4=496;P5=-4047;D=4541434141414143414343434343434343434143414143434141414141434143434343414143;CP=4;SP=5;O;m2;
   sduino_ab_TIME 2020-10-13 16:48:12
     2020-10-13 16:48:12   absoluteHumidity 5.9
     2020-10-13 16:48:12   absoluteHumidityof 5.9
     2020-10-13 16:48:12   alarm           off
     2020-10-13 16:48:12   batteryState    low
     2020-10-13 16:48:12   channel         1
     2020-10-13 16:48:12   dewpoint        3.1
     2020-10-13 16:48:12   dewpointof      3.1
     2020-10-13 16:48:12   humidity        67
     2020-10-13 16:48:12   humidityof      67
     2020-10-13 16:48:12   state           T: 8.9 H: 67
     2020-10-13 16:48:12   temperature     8.9
     2020-10-13 16:48:12   temperatureof   8.9
     2020-10-13 16:48:12   vapourPressure  7.6
   alias      AB Glashaus - Raumtemperatur & Feuchte (Bresser)
   devStateStyle style="text-align:left;;font-weight:bold;;"
   event-min-interval .*:600
   event-on-change-reading temperature,temperatureof,humidity,humidityof,dewpoint,dewpointof,absoluteHumidity,absoluteHumidityof,batteryState
   group      .Sensoren Temperatur & Feuchte
   icon       temperature_humidity
   room       AB-Glashaus,_Bresser
   sortby     01.01
   stateFormat {sprintf
("Temperatur: %.1f °C<br>Luftfeuchte abs.: %.1f g/m³<br>Luftfeuchte rel.: %.1f %%F<br>Taupunkt: %.1f °C<br>Dampfdruck: %.1f hPa",
ReadingsNum("$name","temperatureof",0),
ReadingsNum("$name","absoluteHumidityof",0),
ReadingsNum("$name","humidityof",0),
ReadingsNum("$name","dewpointof",0),
ReadingsNum("$name","vapourPressure",0))}
   userReadings absoluteHumidityof:absoluteHumidity.* {ReadingsNum("$name","absoluteHumidity",0)-0},
dewpointof:dewpoint.* {ReadingsNum("$name","dewpoint",0)-0},
humidityof:humidity.* {ReadingsNum("$name","humidity",0)-0},
temperatureof:temperature.* {ReadingsNum("$name","temperature",0)-0}
   userattr   max-deviation-hum:1,2,3,4,5,6,7,8,9,10,15,20,25,30,35,40,45,50 offset-hum
Eigentlich ist alles aktuell nur bei den Bresser Sensoren gibt es diese Schwankungen die nicht realistisch sind.
Gibt es für die Bresser Sensoren aktuelleres?
LG Chris
Devices: APC, Davis, Eastron, FS20, Homematic, IT, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, SkyWind, TEK603
Ralf9
Es sieht so aus als wären 2 Sensoren des Typs SD_WS07 auf Kanal 1 eingestellt
Burny4600
ZitatEs sieht so aus als wären 2 Sensoren des Typs SD_WS07 auf Kanal 1 eingestellt
Auf die einfachste Lösung kommt man nicht immer!
Ich habe zwar nur einen Sensor mit dieser Adresse, aber es sind gleich zwei dieser Sensoren bei einigen Nachbaren mit der gleichen Adresse im Einsatz.
So einfach ist dieser Fall gelöst.
LG Chris
