ERROR: Malformed prototype for
Begonnen von Amenophis86, 10 November 2020, 12:42:23
Amenophis86
kann mir mal einer sagen was mir dieser Fehler sagen will:
ERROR:Malformed prototype for main::KNX_TypAendern: $device, $dpt, $gr, $anz at ./FHEM/99_myUtils_Allgemein.pm line 38.
Ich komme nicht weiter. Hier mein Code:
# $Id: myUtilsTemplate.pm 21509 2020-03-25 11:20:51Z rudolfkoenig $
# Save this file as 99_myUtils.pm, and create your own functions in the new
# file. They are then available in every Perl expression.
package main;
use strict;
use warnings;
sub
myUtils_Allgemein_Initialize($$)
  my ($hash) = @_;
# Enter you functions below _this_ line.
sub test()
sub KNX_rename ()
my @devices = devspec2array("NAME=KNX.*");
my $anz = 0;
my ($ugr, $gr);
foreach my $device (@devices)
#1/1/ - Schalten
if (substr($device,4,4) eq "0101")
KNX_TypAendern($device, "1.001", "1/2/", $anz);
#1/2/ - Dimmen
elsif (substr($device,4,4) eq "0102")
KNX_TypAendern($device, "3.007", "1/2/", $anz);
#1/3/ - Wert (Dimmen)
elsif (substr($device,4,4) eq "0103")
KNX_TypAendern($device, "5.001", "1/3/", $anz);
#1/4/ - RMs
elsif (substr($device,4,4) eq "0104")
KNX_TypAendern($device, "1.001", "1/4/", $anz);
#1/5/ - RMw
elsif (substr($device,4,4) eq "0105")
KNX_TypAendern($device, "5.001", "1/5/", $anz);
#2/0/ - Temperaturmesswert
elsif (substr($device,4,4) eq "0200")
KNX_TypAendern($device, "9.001", "2/0/", $anz);
#2/2/ - Betriebsartvorwahl
elsif (substr($device,4,4) eq "0202")
KNX_TypAendern($device, "20.102", "2/2/", $anz);
#2/3/ - Betriebsart Direkt
elsif (substr($device,4,4) eq "0203")
KNX_TypAendern($device, "1.001", "2/3/", $anz);
#3/1/ - Auf / Ab
elsif (substr($device,4,4) eq "0301")
KNX_TypAendern($device, "1.008", "3/1/", $anz);
#3/3/ - Absolute Position (inkl Lamellenposition)
elsif (substr($device,4,4) eq "0303")
KNX_TypAendern($device, "5.001", "3/3/", $anz);
#3/6/ - Diagnosetext
elsif (substr($device,4,4) eq "0306")
KNX_TypAendern($device, "16.000", "3/6/", $anz);
#4/0/ - Fensterkontakt auf/zu
elsif (substr($device,4,4) eq "0400")
KNX_TypAendern($device, "1.001", "4/0/", $anz);
elsif (substr($device,4,4) eq "0401")
KNX_TypAendern($device, "1.001", "4/1/", $anz);
elsif (substr($device,4,4) eq "0402")
KNX_TypAendern($device, "1.001", "4/2/", $anz);
sub KNX_TypAendern ($device, $dpt, $gr, $anz)
my ($device, $dpt, $gr, $anz) = @_;
my $ugr;
$anz++;
$ugr = substr($device,8);
if(substr($ugr,0,1) eq "0") {$ugr =~ s/0//;}
$gr = $gr.$ugr;
fhem("defmod ".$device." KNX ".$gr.":dpt".$dpt);
1;
Line 38 ist übrigens: KNX_TypAendern($device, "1.001", "1/2/", $anz);
Sidey
Du kannst in den Prototypen keine Variablen Namen angeben:
https://docstore.mik.ua/orelly/perl/prog3/ch06_04.htm
Am besten lässt Du die auch gleich weg und verlierst dich nicht in dem Glauben, sie würden dir wirklich helfen.
Es gibt nur wenige Fälle in denen in Perl Prototypen verwendet werden sollten.
Pack die Validierung der übergebenen Variablen besser in die sub.
Gruß Sidey
Signalduino, Homematic, Raspberry Pi, Mysensors, MQTT, Alexa, Docker, AlexaFhem,zigbee2mqtt
Maintainer von: SIGNALduino, fhem-docker, alexa-fhem-docker, fhempy-docker, WebAuth, fhem-mcp
Amenophis86
#2
Ich habe nichtmal ahnung was Prototypen sind. Ich kann null mit dem Fehler anfange. Sorry. Wo habe ich den Prototypen genutzt?
Edit:
Was ich will ist folgendes. Die Sub KNX_TypAendern wird immer wieder gebraucht und muss aus der Haupt Sub ja die Daten bekommen, welche sich teilweise ändern. Wo liegt nun der Fehler in der Übergabe bzw. wo nutze ich dies Prototypen?
CoolTux
sub KNX_TypAendern ($$$$)
oder gleich ganz weg lassen
sub KNX_TypAendern {
Das TuxNet Wiki:
https://www.cooltux.net
Amenophis86
#4
Edit:
Ich komme gleich nochmal neu :D
Amenophis86
Habe es jetzt wie folgt geändert:
package main;
use strict;
use warnings;
sub
  my ($hash) = @_;
sub test()
sub KNX_rename ()
my $anz = 0;
my ($ugr, $gr);
#1/1/ - Schalten
#1/2/ - Dimmen
#1/4/ - RMs
#1/5/ - RMw
#3/1/ - Auf / Ab
my $ugr;
$anz++;
$gr = $gr.$ugr;
1;
Der neue Fehler lautet:
oo many arguments for main::KNX_TypAendern at ./FHEM/99_myUtils_Allgemein.pm line 38, near "$anz)"
Ich bin doch net doof und habe das schon ein paar Mal gemacht. Irgendwas muss ich doch übersehen, was ich sonst anders mache. Komisch
Amenophis86
Ich habe mal die Rheinfolge der Subs geändert, das scheint geholfen zu haben. Warum auch immer. Hoffen wir, dass es dabei bleibt. Danke für die Hilfe
CoolTux
package main;
use strict;
use warnings;
sub
myUtils_TestFn_Initialize($$)
  my ($hash) = @_;
sub test()
my $ugr;
$anz++;
$gr = $gr.$ugr;
sub KNX_rename ()
my $anz = 0;
my ($ugr, $gr);
#1/1/ - Schalten
KNX_TypAendern($device, $anz);
#1/2/ - Dimmen
#1/4/ - RMs
#1/5/ - RMw
#3/1/ - Auf / Ab
1;
Es liegt in der Tat an der Reihnfolge
Das TuxNet Wiki:
Amenophis86
Ich meine mich auch zu erinnern, dass subs vorhanden sein müssen bevor sie aufgerufen werden ;)
CoolTux
Das Sollte sich aber eigentlich erledigt haben wenn man Prototypen nicht verwendet. Und ich habe das gerade getestet. Bei mir geht es
package main;
use strict;
use warnings;
sub
myUtils_TestFn_Initialize {
  my ($hash) = @_;
sub test {
sub KNX_rename {
my $anz = 0;
my ($ugr, $gr);
#1/1/ - Schalten
#1/2/ - Dimmen
#1/4/ - RMs
#1/5/ - RMw
#3/1/ - Auf / Ab
my $ugr;
$anz++;
$gr = $gr.$ugr;
1;
Das TuxNet Wiki:
Amenophis86
Hex, Hex.... :D Keine Ahnung woran es lag. Vielleicht weil die sub neu eingelesen wurde und alles neu angelegt?
Sidey
Prototypen sind subs in denen angegeben wird, wie viele Variablen und von welchem Typ sie erwartet werden:
Genau genommen die ($$$$) Angabe beschreibt den Prototypen.
Lässt Du es weg, wird kein Prototyp erzeugt gegen den der Compiler den Aufruf validiert.
Empfehlung: Prototypen in Perl meiden, solange es nicht zwingend Gründe gibt sie zu verwenden.
Christoph Morrison
#12
Du rufst da vierzehn mal substr($device,4,4) auf - das könntest du auch auf einen Aufruf + eine Variable eindampfen.
Vorallem ist das ja eine exklusive Bedingung, d.h. der Rückgabewerk von substr erfüllt genau nur eine deiner Bedingungen - du prüfst aber jede Bedingung bei jedem Durchlauf durch, auch wenn z.B. die erste Bedingung wahr ist.
$anz ist in KNX_rename auch immer 0.
Wzut
oh haben wir hier ein neues Spiel  ala "wir stellen Amenophis86 99myUtils heute mal auf den Kopf " ?
Wenn ja hätte ich auch noch einen der mich inwischen oft anspringt : der unötige Wechsel FHEM->Perl->FHEM usw.
Bsp : fhem("defmod  -> CommandDefMod :)
Christoph Morrison
Ich dachte heute wäre MyUtils-Dienstag?!
