Autor Thema: [GELÖST]Cul plötzlich disconnect  (Gelesen 1631 mal)
Offline Tommy82
« am: 28 Dezember 2020, 07:12:35 »
Hallo, gestern abend funktionierte noch alles, heute morgen ist mein Cul plötzlich disconnected. Auch ein fhem neustart brachte keine Hilfe.
Woran kann das liegen und was kann ich machen?
[Internals:
   CMDS
   Clients    :FS20:FHT.*:KS300:USF1000:BS:HMS:FS20V: :CUL_EM:CUL_WS:CUL_FHTTK:CUL_HOERMANN: :ESA2000:CUL_IR:CUL_TX:Revolt:IT:UNIRoll:SOMFY: :STACKABLE_CC:TSSTACKED:STACKABLE:CUL_RFR::CUL_TCM97001:CUL_REDIRECT:
   DEF        /dev/ttyACM0@9600 1234
   DeviceName /dev/ttyACM0@9600
   FHTID      1234
   FUUID      5c48d229-f33f-f412-174b-bad2f6a8e7093fe1
   NAME       Cul433
   NR         235
   PARTIAL
   STATE      disconnected
   TYPE       CUL
   initString X21
   Helper:
     DBLOG:
       raw:
         myDbLog:
           TIME       1609134150.21821
           VALUE      No answer
       state:
         myDbLog:
           TIME       1609134210.33985
           VALUE      reopen
       uptime:
         myDbLog:
           TIME       1609134221.06416
           VALUE      No answer
   MatchList:
     0:FS20V    ^81..(04|0c)..0101a001......00[89a-f]...
     1:USF1000  ^81..(04|0c)..0101a001a5ceaa00....
     2:BS       ^81..(04|0c)..0101a001a5cf
     3:FS20     ^81..(04|0c)..0101a001
     4:FHT      ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
     5:KS300    ^810d04..4027a001
     6:CUL_WS   ^K.....
     7:CUL_EM   ^E0.................$
     8:HMS      ^810e04......a001
     9:CUL_FHTTK ^T[A-F0-9]{8}
     A:CUL_RFR  ^[0-9A-F]{4}U.
     B:CUL_HOERMANN ^R..........
     C:ESA2000  ^S................................$
     D:CUL_IR   ^I............
     E:CUL_TX   ^TX[A-F0-9]{10}
     F:Revolt   ^r......................$
     G:IT       ^i......
     H:STACKABLE_CC ^\*
     I:UNIRoll  ^[0-9A-F]{5}(B|D|E)
     J:SOMFY    ^Y[r|t|s]:?[A-F0-9]+
     K:CUL_TCM97001 ^s[A-F0-9]+
     L:CUL_REDIRECT ^o+
     M:TSSTACKED ^\*
     N:STACKABLE ^\*
     2018-01-21 16:25:25   ccconf          freq:433.920MHz bWidth:325KHz rAmpl:42dB sens:8dB
     2020-12-21 19:41:59   cmds            A B C E e F G h i K k L l M m R T t U u V W X x Y
     2017-12-03 10:19:22   credit10ms      900
     2017-12-03 10:19:27   fhtbuf          AE
     2020-12-28 06:42:30   raw             No answer
     2020-12-28 06:40:32   state           disconnected
     2020-12-28 06:43:41   uptime          No answer
     2017-12-03 10:19:36   version         V 1.26.01 a-culfw Build: 271 (2017-09-18_20-23-44) CUL433 (F-Band: 433MHz)
   group      Hardeware
   room       Wohnzimmer
   verbose    2]
« Letzte Änderung: 20 Januar 2021, 20:11:39 von Tommy82 »
Allnetl Wandtablett mit FTUI
Offline KölnSolar
Antw:Cul plötzlich disconnect
« Antwort #1 am: 28 Dezember 2020, 10:05:54 »
ist er denn noch im System ?  ::)
Offline Tommy82
« Antwort #2 am: 28 Dezember 2020, 10:13:21 »
Also angesteckt ist er
Offline MadMax-FHEM
  • NIVEAu ist keine Creme...
« Antwort #3 am: 28 Dezember 2020, 10:15:48 »
Da war wohl eher gemeint, ob er vom OS noch erkannt wird ;)
lsusb
ls -la /dev/tty*
Usw.
Gruß, Joachim
FHEM PI3B+ Buster: HM-CFG-USB, 40x HM, ZWave-USB, 13x ZWave, EnOcean-PI, 15x EnOcean, HUE/deCONZ, CO2, ESP-Multisensor, Shelly, alexa-fhem, ...
FHEM PI3 Buster (Test)
FHEM PI3 RaspiOS (Test)
Offline Tommy82
« Antwort #4 am: 28 Dezember 2020, 19:05:17 »
Ja das wars, wieso auch immer hatte sich das Device geändert, nach dem reboot ist alles wieder normal.
Danke für den Hinweis
Offline MadMax-FHEM
« Antwort #5 am: 28 Dezember 2020, 19:20:20 »
Eine Anmerkung noch: besser mit "by-id" (oder wenigstens "by-path") einbinden...
https://wiki.fhem.de/wiki/Mehrere_USB-Ger%C3%A4te_einbinden
Auch wenn es nur ein USB-Device gibt...
Und wenn gelöst, dann "pack" doch noch ein [gelöst] o.ä. vor den ersten Post, danke.
Gruß, Joachim
