DOIF Perl unwanted replacement of [+-] with ::DOIF_time_once()
Begonnen von Nestor, 31 Dezember 2020, 13:29:09
Nestor
I have the following code in the middle a DOIF Perl condition:
$alias =~ s/[+-][\d.]+\s//;
which gets replaced with
$alias =~ s/[::DOIF_time_once($hash,3,$wday)][\d.]+\s//;
which is nonsensical.
Simple fix for now:
my $prefix = '+-';
$alias =~ s/[${prefix}][\d.]+\s//;
Should DOIF Perl just check the first line of the condition for timer syntax instead of replacing it in the whole function?
Damian
Simple fix for now:
my $prefix = '+-';
Time triggers may occur anywhere within a Perl block. It is incorrectly recognized as a time trigger. I would have to further restrict the time trigger check. Outsourcing to a function in the subs block would also help.
