CCU startet nicht
Begonnen von LotharRappsilber, 11 Januar 2021, 13:37:05
LotharRappsilber
brauche mal wieder Eure Hilfe. Meine CCU startet nicht. Hier das List!
   CCUNum     1
   Clients    :HMCCUDEV:HMCCUCHN:HMCCURPC:HMCCURPCPROC:
   DEF        192.168.4.8
   FUUID      5cfa4569-f33f-2440-6ffe-ca612b90af7a3625
   NAME       HMIPCCU
   NOTIFYDEV  global,TYPE=(HMCCU|HMCCUDEV|HMCCUCHN)
   NR         52
   NTFY_ORDER 50-HMIPCCU
   RPCState   error
   STATE      error/Error
   TYPE       HMCCU
   ccuaddr    BidCoS-RF
   ccuchannels 129
   ccudevices 10
   ccuif      BidCos-RF
   ccuinterfaces BidCos-RF,HmIP-RF,VirtualDevices,CUxD
   ccuip      192.168.4.8
   ccuname    HM-RCV-50 BidCoS-RF
   ccustate   active
   ccutype    CCU2/3
   host       192.168.4.8
   prot       http
   version    4.3.025
     2021-01-11 12:46:53   count_channels  129
     2021-01-11 12:46:53   count_devices   10
     2021-01-11 12:46:53   count_groups    0
     2021-01-11 12:46:53   count_interfaces 4
     2021-01-11 12:46:53   count_programs  4
     2021-01-11 13:19:02   rpcstate        error
     2021-01-11 13:25:41   state           Error
   hmccu:
     defInterface BidCos-RF
     defPort    2001
     evtime     0
     evtimeout  0
     rpccount   0
     rpcports   2001,2010
     updatetime 0
dann folgen jede Menge Adressen und dann
   ccuflags   procrpc
   cmdIcon    on:general_an off:general_aus
   event-on-update-reading .*
   eventMap   /rpcserver on:on/rpcserver off:off/
   room       Homematic
   rpcinterfaces BidCos-RF,HmIP-RF
   rpcinterval 5
   rpcport    2001,2010
   rpcqueue   /tmp
   rpcserver  on
   stateFormat rpcstate/state
Meine Definition:
define HMIPCCU HMCCU 192.168.x.x
setuuid HMIPCCU 5cfa4569-f33f-2440-6ffe-ca612b90af7a3625
attr HMIPCCU ccudef-hmstatevals 1
attr HMIPCCU ccuflags procrpc
attr HMIPCCU cmdIcon on:general_an off:general_aus
attr HMIPCCU event-on-update-reading .*
attr HMIPCCU eventMap /rpcserver on:on/rpcserver off:off/
attr HMIPCCU room Homematic
attr HMIPCCU rpcinterfaces BidCos-RF,HmIP-RF
attr HMIPCCU rpcinterval 5
attr HMIPCCU rpcport 2001,2010
attr HMIPCCU rpcqueue /tmp
attr HMIPCCU rpcserver on
attr HMIPCCU stateFormat rpcstate/state
Arbeite mit windows
Gruss
Lothar
FB 7590, FHEM, 1xCCU2, 6xDECT200, 1xDECT201, 1xHMIP-SWO-PL, 1xHMIP-PS, 1xDECT301,  2xHM-LC-Sw1-PL
Wernieman
Was für eine CCU?
Ist diese "da"?
Funzt die CCU oder nur die FHEM-Connecktion nicht?
- Bitte um Input für Output
LotharRappsilber
Wernieman
#3
D.h. die CCU2 funktioniert komplett, Du hast "nur" die Konnecktion verlohren?
Und was steht im FHEM Logfile bezüglich ccu?
Und bist Du Dir mit den Ports sicher?
LotharRappsilber
Jetzt startet der rpcserver. Danke für die Hilfe!
Wernieman
.. was war der Fehler?
und Btw: Warum machst Du 3 Threads wegen CCU gleichzeitig auf?
LotharRappsilber
Ich war der Fehler, hatte nicht richtig initialisiert.
