Hallo Jörg,
leider habe ich seit Kurzem das Problem dass FHEM abstürzt, wenn ich ein lockLandevice on oder off ausführe.
Hier der zugehörige Log:
2022.01.27 11:28:08 3: FRITZBOX [FritzBox: Web_OpenCon.5264] - INFO: using old SID from 1643279231.85275
2022.01.27 11:28:53 3: FRITZBOX [FritzBox: Set.779] - INFO: set FritzBox lockLandevice landevice1234 off
2022.01.27 11:28:53 3: FRITZBOX [FritzBox: Set.809] - INFO: set FritzBox lockLandevice xhr 1 dev landevice1234 block_dev lang de page edit_device
2022.01.27 11:28:53 5: FRITZBOX [FritzBox: Set.825] - INFO: get FritzBox lockLandevice 'xhr' => '1'
'dev' => 'landevice1234'
'block_dev' => ''
'lang' => 'de'
'page' => 'edit_device'
2022.01.27 11:28:53 3: FRITZBOX [FritzBox: Lan_Device_Info.5853] - INFO: LanDevice to proof: landevice1234 for lock: off
2022.01.27 11:28:53 3: FRITZBOX [FritzBox: Lan_Device_Info.5884] - INFO: set FritzBox off xhr 1 xhrId all backToPage netDev dev landevice1234 initalRefreshParamsSaved true lang de page edit_device
2022.01.27 11:28:53 5: FRITZBOX [FritzBox: Lan_Device_Info.5900] - INFO: get FritzBox off 'xhr' => '1'
'xhrId' => 'all'
'backToPage' => 'netDev'
'initalRefreshParamsSaved' => 'true'
'lang' => 'de'
2022.01.27 11:28:53 3: FRITZBOX [FritzBox: Web_OpenCon.5264] - INFO: using old SID from 1643279292.1976
2022.01.27 11:28:53 5: FRITZBOX [FritzBox: Lua_Data.5474] - INFO: Request data via API dataQuery.
2022.01.27 11:28:53 5: FRITZBOX [FritzBox: Lua_Data.5478] - INFO: URL: http://192.168.180.1/data.lua?sid=1a508f8fd4767e53
2022.01.27 11:29:01 5: FRITZBOX [FritzBox: Lua_Data.5483] - INFO: Response: 200 OK
{"pid":"edit_device","hide":{"faxSet":true,"shareUsb":true,"ssoSet":true,"liveTv":true},"time":[],"data":[],"sid":"1a508f8fd4767e53"}
2022.01.27 11:29:01 5: FRITZBOX [FritzBox: Lua_Data.5528] - INFO: Response: {"pid":"edit_device","hide":{"faxSet":true,"shareUsb":true,"ssoSet":true,"liveTv":true},"time":[],"data":[],"sid":"1a508f8fd4767e53"}
2022.01.27 11:29:01 5: FRITZBOX [FritzBox: Process_JSON.5553] - INFO: Decode JSON string.
2022.01.27 11:29:01 5: FRITZBOX [FritzBox: Process_JSON.5569] - INFO: JSON: $VAR1 = {
'sid' => '1a508f8fd4767e53',
'time' => [],
'pid' => 'edit_device',
'data' => [],
'hide' => {
'shareUsb' => bless( do{\(my $o = 1)}, 'JSON::PP::Boolean' ),
'faxSet' => $VAR1->{'hide'}{'shareUsb'},
'liveTv' => $VAR1->{'hide'}{'shareUsb'},
'ssoSet' => $VAR1->{'hide'}{'shareUsb'}
Not a HASH reference at ./FHEM/72_FRITZBOX.pm line 5904.
Vor ~1 bis 2 Wochen hat es fehlerfrei funktioniert.
