JsonMod
Begonnen von Mickey, 06 August 2021, 01:55:33
Mickey
Hallo, ich habe da ein Problem  :(
Ich "möchte" versuche mit JsonMod die .json aus Nextcloud  in Fhem zu bringen
Ich kapiere aber readingList nicht, gar nicht ;D
single(jsonPath('$.system.freespace'), 'Freespace', '-?-');
Funktioniert leider nicht.
Kann mit jemand einen Tip geben könnte, wie ich es hinbekomme?
Anbei das json wenn ich den Link im Browser öffne:
{"ocs":{"meta":{"status":"ok","statuscode":200,"message":"OK"},"data":{"nextcloud":{"system":{"version":"20.0.11.1","theme":"none","enable_avatars":"yes","enable_previews":"yes","memcache.local":"\\OC\\Memcache\\Redis","memcache.distributed":"none","filelocking.enabled":"yes","memcache.locking":"\\OC\\Memcache\\Redis","debug":"no","freespace":56693563392,"cpuload":[0.14,0.2,0.18],"mem_total":997124,"mem_free":711584,"swap_total":102396,"swap_free":25752,"apps":{"num_installed":25,"num_updates_available":0,"app_updates":[]}},"storage":{"num_users":1,"num_files":3000,"num_storages":2,"num_storages_local":1,"num_storages_home":1,"num_storages_other":0},"shares":{"num_shares":0,"num_shares_user":0,"num_shares_groups":0,"num_shares_link":0,"num_shares_mail":0,"num_shares_room":0,"num_shares_link_no_password":0,"num_fed_shares_sent":0,"num_fed_shares_received":0}},"server":{"webserver":"Apache","php":{"version":"7.3.29","memory_limit":765791232,"max_execution_time":3600,"upload_max_filesize":10737418240,"opcache":{"opcache_enabled":true,"file_cache":"\/var\/www\/nextcloud\/data\/.opcache","cache_full":false,"restart_pending":false,"restart_in_progress":false,"memory_usage":{"used_memory":24639840,"free_memory":109427040,"wasted_memory":150848,"current_wasted_percentage":0.11239051818847656},"interned_strings_usage":{"buffer_size":6291196,"used_memory":3089152,"free_memory":3202044,"number_of_strings":55624},"opcache_statistics":{"num_cached_scripts":1347,"num_cached_keys":2545,"max_cached_keys":16229,"hits":44503477,"start_time":1626527979,"last_restart_time":0,"oom_restarts":0,"hash_restarts":0,"manual_restarts":0,"misses":43,"blacklist_misses":0,"blacklist_miss_ratio":0,"opcache_hit_rate":99.9999033784294}},"apcu":[]},"database":{"type":"mysql","version":"10.3.29","size":3031040}},"activeUsers":{"last5minutes":1,"last1hour":1,"last24hours":1}}}}
Schon mal 1000 Dank, liebe Grüße Michael
Zu mir:
Ich bin leider fast blind (EU Rentner) und nicht zu "faul" was nachzulesen. Bitte seht mir nach, wenn ich einmal zu viel frage oder auch mal Schreibfehler mache. Danke, Michael
yersinia
Es gibt JsonPath tester im Netz - einfach da mal rumprobieren. Du hast nicht den kompletten Pfad angegeben. Wenn du hier -> https://jsonpath.com dein Json-Code eingibst, siehst du rechts direkt das Ergebnis.
single(jsonPath('$.ocs.data.nextcloud.system.freespace'), 'Freespace', '-?-');
Ich habe jetzt kurz hiermit -> https://jsonpath.curiousconcept.com (und Goessner 0.8.3) getestet und du kannst ja mal dies als Alternative versuchen:
single(jsonPath('$.[system].[freespace]'), 'Freespace', '-?-');
viele Grüße, yersinia
FHEM 6.4 (SVN) on RPi 4B with RasPi OS Trixie (perl 5.40.1) | FTUI
Mickey
Guten Morgen yersinia,
1 Millionen Dank für die Hilfe.
Funktioniert einwandfrei, TOP  ;)
Ich bin mega Happy.
Liebe Grüsse, Michael
Zu mir:
Mickey
Hallo yersinia, bei mir kommt immer nur No match ich checke es nicht.
Mir fehlt nur noch num_updates_available
Kannst du mir bitte noch einmal helfen?
Danke, Michael
Zu mir:
Mickey
Sorry, hab es kapiert - ist soooo easy.
Zu mir:
