MQTT2 publish mit Warning
Begonnen von Damian, 21 März 2022, 18:13:59
Damian
Ein publisch Befehl
set MQTT2_FHEM_Server publish ebusd/bai/FanSpeed/get
führt neuerdings zu einer Warnung:
2022.03.21 18:09:38.811 1: PERL WARNING: Use of uninitialized value $a[0] in string eq at ./FHEM/00_MQTT2_SERVER.pm line 233.
2022.03.21 18:09:38.811 1: stacktrace:
2022.03.21 18:09:38.812 1:     main::__ANON__                      called by ./FHEM/00_MQTT2_SERVER.pm (233)
2022.03.21 18:09:38.812 1:     main::MQTT2_SERVER_Set              called by ./FHEM/98_apptime.pm (178)
2022.03.21 18:09:38.812 1:     main::apptime_getTiming             called by ./FHEM/98_apptime.pm (138)
2022.03.21 18:09:38.812 1:     main::CallFn                        called by fhem.pl (1955)
2022.03.21 18:09:38.813 1:     main::DoSet                         called by fhem.pl (1987)
2022.03.21 18:09:38.813 1:     main::CommandSet                    called by fhem.pl (1272)
2022.03.21 18:09:38.813 1:     main::AnalyzeCommand                called by fhem.pl (1123)
2022.03.21 18:09:38.813 1:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (2803)
2022.03.21 18:09:38.813 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (1025)
2022.03.21 18:09:38.814 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (608)
2022.03.21 18:09:38.814 1:     main::FW_Read                       called by ./FHEM/98_apptime.pm (178)
2022.03.21 18:09:38.814 1:     main::apptime_getTiming             called by ./FHEM/98_apptime.pm (138)
2022.03.21 18:09:38.814 1:     main::CallFn                        called by fhem.pl (780)
Das Reading wird korrekt aktualisiert.
ZitatVersion $Id: 00_MQTT2_SERVER.pm 25849 2022-03-16 15:51:57Z rudolfkoenig $
Danke fuer den Hinweis, habs gefixt.
