Entwicklungs-Thread Modul 36_Shelly.pm
Begonnen von Starkstrombastler, 24 Februar 2024, 12:15:05
stobor
#195
wie bringe ich denn am besten einen Shelly Pro 2 zum Laufen?
Ich habe schon versucht, das Template des Shelly Pro 4pm zu verwenden, doch wenn ich den Shelly über dessen Web-Interface schalte kommt bei FHEM nichts an.
Angebunden ist der Shelly über MQTT and erzeugt über AUTOCREATE:
define shellypro2_TerrasseSued MQTT2_DEVICE shellypro2_TerrasseSued
setuuid shellypro2_TerrasseSued 6a66f6cd-f33f-2cfb-292f-2e4ed82ccbf83416
attr shellypro2_TerrasseSued devStateIcon {my $onl = ReadingsVal($name,'online','false') eq 'false'?'10px-kreis-rot':'10px-kreis-gruen';; $onl = FW_makeImage($onl);; my $light = FW_makeImage(ReadingsVal($name,'state','off'));; my $temp = ReadingsVal($name,'temperature','-100');; my $ip = ReadingsVal($name,'ip','none');; my $reb = ReadingsVal($name,'sys_restart_required','false') eq 'true'?'<a href="/fhem?cmd.dummy=set '.$name.' x_reboot&XHR=1"> ... Notwendigen Reboot durchführen</a>':'';; qq(<a href="http://$ip" target="_blank">${onl}</a><a href="/fhem?cmd.dummy=set $name toggle&XHR=1">${light}</a>$reb<div>Temp: $temp °C</div>)}
attr shellypro2_TerrasseSued devicetopic shellypro2_TerrasseSued
attr shellypro2_TerrasseSued getList in_mode:noArg in_mode $DEVICETOPIC/rpc {"id": 1,"src":"$DEVICETOPIC", "method": "Switch.GetConfig", "params": {"id": 0}}
attr shellypro2_TerrasseSued icon message_socket
attr shellypro2_TerrasseSued jsonMap switch_state:state switch_temperature_tC:temperature switch_temperature_tF:0 params_wifi_sta_ip:ip params_switch_0_temperature_tC:temperature params_switch_0_temperature_tF:0 req_result_in_mode:in_mode
attr shellypro2_TerrasseSued model shellyPlus_1
attr shellypro2_TerrasseSued readingList $DEVICETOPIC/online:.* online\
  $DEVICETOPIC/events/rpc:.* { json2nameValue($EVENT,'',$JSONMAP) }\
  $DEVICETOPIC/status/mqtt:.* { json2nameValue($EVENT, 'mqtt_', $JSONMAP) }\
  $DEVICETOPIC/status/sys:.* { json2nameValue($EVENT, 'sys_', $JSONMAP) }\
  $DEVICETOPIC/status/switch_0:.* { $EVENT =~ s/"output":true/"state":"on"/g;; $EVENT =~ s/"output":false/"state":"off"/g;; json2nameValue($EVENT, 'switch_', $JSONMAP) }\
  $DEVICETOPIC/status/cloud:.* {}\
  $DEVICETOPIC/rpc:.* { json2nameValue($EVENT, 'req_', $JSONMAP, 'in_mode')}\
  $DEVICETOPIC/status/input_0:.* { json2nameValue($EVENT, 'input_', $JSONMAP) }\
  fhem2shelly/rpc:.* {}\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/events/rpc:.* { json2nameValue($EVENT, 'rpc_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/switch_1:.* { json2nameValue($EVENT, 'switch_1_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/switch_0:.* { json2nameValue($EVENT, 'switch_0_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/online:.* online\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/ble:.* ble\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/cloud:.* { json2nameValue($EVENT, 'cloud_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/eth:.* { json2nameValue($EVENT, 'eth_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/input_0:.* { json2nameValue($EVENT, 'input_0_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/input_1:.* { json2nameValue($EVENT, 'input_1_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/mqtt:.* { json2nameValue($EVENT, 'mqtt_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/sys:.* { json2nameValue($EVENT, 'sys_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/wifi:.* { json2nameValue($EVENT, 'wifi_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/ws:.* { json2nameValue($EVENT, 'ws_', $JSONMAP) }
attr shellypro2_TerrasseSued room MQTT,Terrasse
attr shellypro2_TerrasseSued setList toggle:noArg $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Switch.Toggle","params": {"id":0}}\
  off:noArg $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Switch.Set","params": {"id":0,"on":false}}\
  on:noArg $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Switch.Set","params": {"id":0,"on":true}}\
  on-for-timer $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Switch.Set","params": {"id":0,"on":true,"toggle_after":$EVTPART1}}\
  off-for-timer $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Switch.Set","params": {"id":0,"on":false,"toggle_after":$EVTPART1}}\
  in_mode:toggle,flip,detached {fhem("sleep 0.2;; get $NAME in_mode");; my $val = $EVTPART1 ne 'toggle' ? $EVTPART1 : ReadingsVal($NAME,'in_mode','flip') eq 'flip' ? 'detached':'flip';; qq($DEVICETOPIC/rpc {"id":1,"src":"fhem2shelly","method":"Switch.SetConfig","params": {"id":0, "config": {"in_mode": "$val"}}})}\
  x_update:noArg $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Shelly.Update","params": {"stage":"stable"}}\
  x_reboot:noArg $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Shelly.Reboot"}\
  x_eco:true,false $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Sys.SetConfig","params": {"config": {"device": {"eco_mode": $EVTPART1}}}}
attr shellypro2_TerrasseSued setStateList on off toggle on-for-timer off-for-timer
attr shellypro2_TerrasseSued webCmd :
Internals
CID    shellypro2_TerrasseSued
DEF    shellypro2_TerrasseSued
FUUID    6a66f6cd-f33f-2cfb-292f-2e4ed82ccbf83416
IODev    MQTT2
LASTInputDev    MQTT2
MQTT2_CONN    MQTT2_192.168.179.24_59748
MQTT2_MSGCNT    14
MQTT2_TIME    27.07.2026 15:13
MSGCNT    14
NAME    shellypro2_TerrasseSued
NR    1899
STATE    set_on
TYPE    MQTT2_DEVICE
eventCount    26
Readings
IODev
MQTT2
2026-07-27 15:04:43
associatedWith
shellypro2_TerrasseSued_CH2,shellypro2_TerrasseSued_CH3,shellypro2_TerrasseSued_CH4
2026-07-27 15:02:51
attrTemplateVersion
20240627
2026-07-27 15:02:53
ble
2026-07-27 15:05:07
cloud_connected
false
2026-07-27 15:05:07
input_0_id
0
2026-07-27 15:05:07
input_0_state
false
2026-07-27 15:05:07
input_1_id
1
2026-07-27 15:05:07
input_1_state
false
2026-07-27 15:05:07
mqtt_connected
true
2026-07-27 15:05:07
online
true
2026-07-27 15:05:07
rpc_dst
2026-07-27 15:13:34
rpc_method
NotifyStatus
2026-07-27 15:13:34
rpc_params_cloud_connected
false
2026-07-27 15:05:07
rpc_params_input_0_id
0
2026-07-27 15:05:07
rpc_params_input_0_state
false
2026-07-27 15:05:07
rpc_params_input_1_id
1
2026-07-27 15:05:07
rpc_params_input_1_state
false
2026-07-27 15:05:07
rpc_params_mqtt_connected
true
2026-07-27 15:05:07
rpc_params_switch_0_id
0
2026-07-27 15:05:52
rpc_params_switch_0_output
false
2026-07-27 15:05:52
rpc_params_switch_0_source
WS_in
2026-07-27 15:05:52
rpc_params_switch_0_temperature_tC
34.5
2026-07-27 15:05:07
rpc_params_switch_0_temperature_tF
94.1
2026-07-27 15:05:07
rpc_params_switch_1_id
1
2026-07-27 15:13:34
rpc_params_switch_1_output
true
2026-07-27 15:05:40
rpc_params_switch_1_source
WS_in
2026-07-27 15:05:40
rpc_params_switch_1_temperature_tC
44.06
2026-07-27 15:13:34
rpc_params_switch_1_temperature_tF
111.30
2026-07-27 15:13:34
rpc_params_sys_available_updates_beta_version
2.0.0-beta3
2026-07-27 15:05:07
rpc_params_sys_available_updates_stable_version
1.7.5
2026-07-27 15:05:07
rpc_params_sys_cfg_rev
8
2026-07-27 15:05:07
rpc_params_sys_fs_free
208896
2026-07-27 15:05:07
rpc_params_sys_fs_size
524288
2026-07-27 15:05:07
rpc_params_sys_kvs_rev
0
2026-07-27 15:05:07
rpc_params_sys_mac
80F3DAC8B8A0
2026-07-27 15:05:07
rpc_params_sys_ram_free
111420
2026-07-27 15:05:07
rpc_params_sys_ram_size
260204
2026-07-27 15:05:07
rpc_params_sys_reset_reason
3
2026-07-27 15:05:07
rpc_params_sys_restart_required
false
2026-07-27 15:05:07
rpc_params_sys_schedule_rev
0
2026-07-27 15:05:07
rpc_params_sys_time
15:05
2026-07-27 15:05:07
rpc_params_sys_unixtime
1785157506
2026-07-27 15:05:07
rpc_params_sys_uptime
23287
2026-07-27 15:05:07
rpc_params_sys_webhook_rev
0
2026-07-27 15:05:07
rpc_params_ts
1785158014.19
2026-07-27 15:13:34
rpc_params_wifi_rssi
-72
2026-07-27 15:05:07
rpc_params_wifi_ssid
Quadratogramm
2026-07-27 15:05:07
rpc_params_wifi_sta_ip
192.168.179.24
2026-07-27 15:05:07
rpc_params_wifi_status
got ip
2026-07-27 15:05:07
rpc_params_ws_connected
false
2026-07-27 15:05:07
rpc_src
shellypro2-80f3dac8b8a0
2026-07-27 15:13:34
switch_0_id
0
2026-07-27 15:05:52
switch_0_output
false
2026-07-27 15:05:52
switch_0_source
WS_in
2026-07-27 15:05:52
34.6
2026-07-27 15:05:52
94.3
2026-07-27 15:05:52
switch_1_id
1
2026-07-27 15:13:34
switch_1_output
true
2026-07-27 15:13:34
switch_1_source
WS_in
2026-07-27 15:13:34
44.1
2026-07-27 15:13:34
111.3
2026-07-27 15:13:34
2.0.0-beta3
2026-07-27 15:05:07
1.7.5
2026-07-27 15:05:07
sys_cfg_rev
8
2026-07-27 15:05:07
sys_fs_free
208896
2026-07-27 15:05:07
sys_fs_size
524288
2026-07-27 15:05:07
sys_kvs_rev
0
2026-07-27 15:05:07
sys_mac
80F3DAC8B8A0
2026-07-27 15:05:07
sys_ram_free
110016
2026-07-27 15:05:07
sys_ram_size
260100
2026-07-27 15:05:07
sys_reset_reason
3
2026-07-27 15:05:07
false
2026-07-27 15:05:07
sys_schedule_rev
0
2026-07-27 15:05:07
sys_time
15:05
2026-07-27 15:05:07
sys_unixtime
1785157506
2026-07-27 15:05:07
sys_uptime
23287
2026-07-27 15:05:07
sys_webhook_rev
0
2026-07-27 15:05:07
wifi_rssi
-73
2026-07-27 15:05:07
wifi_ssid
Quadratogramm
2026-07-27 15:05:07
wifi_sta_ip
192.168.179.24
2026-07-27 15:05:07
wifi_status
got ip
2026-07-27 15:05:07
ws_connected
false
2026-07-27 15:05:07
x_reboot
set
Attributes
comment
Shelly Pro 2
deleteattr
devStateIcon
{my $onl = ReadingsVal($name,'online','false') eq 'false'?'10px-kreis-rot':'10px-kreis-gruen'; $onl = FW_makeImage($onl); my $light = FW_makeImage(ReadingsVal($name,'state','off')); my $temp = ReadingsVal($name,'temperature','-100'); my $ip = ReadingsVal($name,'ip','none'); my $reb = ReadingsVal($name,'sys_restart_required','false') eq 'true'?'<a href="/fhem?cmd.dummy=set '.$name.' x_reboot&XHR=1"> ... Notwendigen Reboot durchführen</a>':''; qq(<a href="http://$ip" target="_blank">${onl}</a><a href="/fhem?cmd.dummy=set $name toggle&XHR=1">${light}</a>$reb<div>Temp: $temp °C</div>)}
deleteattr
devicetopic
deleteattr
getList
deleteattr
icon
message_socket
deleteattr
jsonMap
deleteattr
model
shellyPlus_1
deleteattr
readingList
  $DEVICETOPIC/status/switch_0:.* { $EVENT =~ s/"output":true/"state":"on"/g; $EVENT =~ s/"output":false/"state":"off"/g; json2nameValue($EVENT, 'switch_', $JSONMAP) }
deleteattr
room
MQTT,Terrasse
deleteattr
setList
  in_mode:toggle,flip,detached {fhem("sleep 0.2; get $NAME in_mode"); my $val = $EVTPART1 ne 'toggle' ? $EVTPART1 : ReadingsVal($NAME,'in_mode','flip') eq 'flip' ? 'detached':'flip'; qq($DEVICETOPIC/rpc {"id":1,"src":"fhem2shelly","method":"Switch.SetConfig","params": {"id":0, "config": {"in_mode": "$val"}}})}
deleteattr
setStateList
deleteattr
webCmd
Intel NUC (Ubuntu 24.04.4 LTS)  mit CUL V3.2 (FW 1.57 CUL868) für FS20 und CCU3 für HM(IP) + Arduino Mega (Firmata) - FHEM Revision: 31515 - FS20, HM(IP), MQTT, Philips HUE, ModBus
JoWiemann
hier gar nicht. Das Thema musst Du schon im Bereich Shelly MQTT adressieren. Hier geht es nur um das Shelly Modul. Ganz anderer Ansatz.
Grüße Jörg
Jörg Wiemann
piet_pit
#197
Hallo Starkstrombastler,
vielen Dank für deine tolle Arbeit am Modul Shelly, ich nutze das bei meinen Shellys auschließlich und sehr gerne!
Ich nutze einen Shelly Pro Dual Cover PM (SPSH-002PE16EU) mit aktueller Firmware 2.0.0, den ich einfach nicht richtig ansprechen kann! Ich möchte den gerne wie auch alle anderen Shellys über Homekit bedienen.
Da das Homebridge-fhem PlugIn die beiden Kanäle eines Dual Covers nicht getrennt ansteuern kann, habe ich für beide Kanäle jeweils einen readingsProxy aufgebaut.
Mittlerweile funktionieren darüber sowohl Homebridge / Apple Home als auch AutoShuttersControl (ASC) grundsätzlich. Die getrennte Abbildung der beiden Kanäle über den readingsProxy scheint also zu funktionieren. Eine saubere Steuerung der beiden Kanäle ist aber leider nicht möglich. Es gibt bei der Positionsfahrt weiterhin ein nicht nachvollziehbares Verhalten.
Deshalb habe ich mit Hilfe von ChatGPT versucht, den Ablauf Schritt für Schritt einzugrenzen.
Dabei konnten wir folgendes ausschließen:
- Homebridge-fhem sendet den gewünschten Positionswert korrekt an FHEM.
- Der readingsProxy ruft die setFn korrekt auf.
- Das Shelly-Device erhält den entsprechenden Befehl (z. B. set DachgeschossRollo pct 65 1).
Bei der Analyse von 36_Shelly.pm ist anschließend folgende Stelle aufgefallen:
my $pos = ReadingsVal($name,"position","");
my $pct = ReadingsVal($name,"pct",0);
Zu diesem Zeitpunkt wurde der Kanal bereits bestimmt:
$subs = "_$channel";
Mein Shelly-Device besitzt jedoch ausschließlich folgende Readings:
position_0
position_1
pct_0
pct_1
Ein Reading position bzw. pct existiert nicht.
Meine Frage ist deshalb:
Ist das bewusst so implementiert, weil intern an anderer Stelle position bzw. pct gespiegelt werden, oder müsste bei einem Multi-Channel-Gerät an dieser Stelle position$subs bzw. pct$subs verwendet werden?
Es kann gut sein, dass ich den internen Ablauf des Moduls nicht vollständig verstanden habe. Bevor ich an dieser Stelle einen Patch ausprobiere, möchte ich deshalb lieber nachfragen.
Meine Umgebung:
FHEM Revision 31518
36_Shelly.pm Revision 31383
33_readingsProxy.pm Revision 31192
Shelly Firmware 2.0.0
Vielen Dank für jede Rückmeldung!
piet_pit
FHEM Latest Revision: 29615
Raspberry Pi 3, Rasbian-Stretch
FRITZ!Box 7690
HM-Mod-RPI-PCB, JeeLink
CUNO 1.47
cwagner
Nun habe ich hier ein Shelly Flood Gen4, was natürlich noch nicht durch das Modul erkannt wird (falsche ID wird als Error im State gemeldet). Wunschgemäß hier die Gerätedaten:
{"ble":{"addr":"**********,p","flags":["advertising"]},"cloud":{"connected":true},"devicepower:0":{"id": 0,"battery":{"V":6.33, "percent":100}},"flood:0":{"id": 0,"alarm":false,"mute":false},"matter":{"num_fabrics":0,"commissionable":true},"mqtt":{"connected":false},"sys":{"mac":"**********","restart_required":false,"time":"12:31","unixtime":1786962711,"last_sync_ts":1786962640,"uptime":72,"ram_size":310208,"ram_free":112052,"ram_min_free":101740,"fs_size":917504,"fs_free":544768,"cfg_rev":17,"kvs_rev":0,"webhook_rev":0,"available_updates":{},"wakeup_reason":{"boot":"deepsleep_wake","cause":"button"},"wakeup_period":43200,"reset_reason":8,"utc_offset":7200},"wifi":{"sta_ip":"192.168.178.163","status":"got ip","ssid":"**********","channel":6,"rssi":-65,"bssid":"08:b6:57:7d:1c:50","sta_ip6":["fe80::5ae6:c5ff:fe3f:3c20","2a00:6020:5554:9700:5ae6:c5ff:fe3f:3c20","fd75:f04e:de0c:0:5ae6:c5ff:fe3f:3c20"]},"ws":{"connected":false},"zigbee":{"network_state":"disabled"}}
{"ble":{"rpc":{"enable":false}},"cloud":{"enable":true,"server":"shelly-224-eu.shelly.cloud:6022/jrpc"},"devicepower:0":{},"flood:0":{"id":0,"name":null,"alarm_mode":"normal","report_holdoff":0},"matter":{"enable":true},"mqtt":{"enable":false,"server":null,"client_id":"shellyfloodg4-**********","user":null,"ssl_ca":null,"topic_prefix":"shellyfloodg4-**********","rpc_ntf":true,"status_ntf":false,"use_client_cert":false,"enable_rpc":true,"enable_control":true},"sys":{"device":{"name":"Flood Garage","mac":"**********","fw_id":"20260710-101150/2.0.0-g87fbfa4","discoverable":true,"eco_mode":false,"tls_check_cert_validity_time":true,"enhanced_security":false},"location":{"tz":"Europe/Berlin","lat":53.227700,"lon":8.801000},"debug":{"level":2,"file_level":null,"mqtt":{"enable":false},"websocket":{"enable":false},"file_log":{"enable":false},"udp":{"addr":null}},"ui_data":{"device_revision":"1-16","df":"DD/MM/YYYY"},"rpc_udp":{"dst_addr":null,"listen_port":null},"sntp":{"server":"time.cloudflare.com"},"cfg_rev":17},"wifi":{"ap":{"ssid":"ShellyFloodG4-**********","is_open":true, "enable":false},"sta":{"ssid":"**********","is_open":false, "enable":true, "ipv4mode":"dhcp","ip":null,"netmask":null,"gw":null,"nameserver":null},"sta1":{"ssid":null,"is_open":true, "enable":false, "ipv4mode":"dhcp","ip":null,"netmask":null,"gw":null,"nameserver":null},"roam":{"rssi_thr":-80,"interval":60}},"ws":{"enable":false,"server":null,"ssl_ca":"ca.pem"},"zigbee":{"enable":false}}
{"name":"Flood Garage","id":"shellyfloodg4-**********","mac":"**********","slot":0,"model":"S4SN-0071A","gen":4,"fw_id":"20260710-101150/2.0.0-g87fbfa4","ver":"2.0.0","app":"FloodSensorG4","auth_en":false,"auth_domain":null,"matter":true,"provision":"complete","enhanced_security":false}
Wenn ich weitere Infos beisteuern kann, einfach eine PM. Und ich teste natürlich gerne!
Christian
320 Devices in MariaDB: Lambda WP an Ecolink-Speicher, FBH, Solarthermie, kontroll. Lüftung mit WRG und Erdwärmetauscher
HMCUL, 1-Wire (FT232RL ; DS2480B), EnOcean (TCM ESP3), MQTT2, Shelly, SMA (eC2, PV, HM, HS)
DOIF (Perl/uiTable), PID20,Micropelt IRTV, SolarForecast auf PI5
cwagner
#199
Guten Morgen,
diese Meldung Fehler nach update kann ich bestätigen.
Die aktuell verteilte Version verabschiedet sich mit dieser Nachricht:
syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
Im Sys_Log steht:
PERL WARNING: Number found where operator expected at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
PERL WARNING:    (Missing operator before     0x1817?)
Meiner Meinung nach fehlt in der Gerätetabelle in Zeile 311 das [Komma] direkt hinter "Shelly Blu Gateway G3"
Damit läuft bei mir das Modul und zeigt auf den ersten Blick auch sinnvolle Werte beim neuen Shelly Flood Gen4, beim BLU Gateway G3, nicht aber beim Circuit Breaker. Der taucht vermutlich aufgrund des CB in seinem Namen weiterhin rudimentär als "Bulb" auf.
Danke für die Einbindung der neuen Geräte
Christian
Starkstrombastler
Zitat von: cwagner am 19 August 2026, 09:49:33near ""Shelly Blu Gateway G3"    0x1817"
da fehlt leider ein Komma.
Wahrscheinlich hat sich der Fehler eingeschlichen, nachdem ich bereits getestet hatte.
Korrektur ist eingestellt.
IPC\Ubuntu + Fhem, 1wire, Shellies, Siemens Logo!, Z-Wave, PhilipsTV, Vu+duo2, KM200
Wiesenfreund
Hallo Shelly-Nutzer,
ich habe soeben ein Update in fhem durchgeführt und erhalte nun folgende Meldungen im Log und auf dem Startbildschirm.
2026.08.19 13:23:27.558 1: PERL WARNING: Number found where operator expected at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:27.558 1: PERL WARNING:    (Missing operator before     0x1817?)
2026.08.19 13:23:27.585 1: reload: Error:Modul 36_Shelly deactivated:
2026.08.19 13:23:27.585 0: syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:27.870 1: reload: Error:Modul 36_Shelly deactivated:
2026.08.19 13:23:27.870 0: syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:27.941 1: reload: Error:Modul 36_Shelly deactivated:
2026.08.19 13:23:27.941 0: syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:27.970 1: reload: Error:Modul 36_Shelly deactivated:
2026.08.19 13:23:27.970 0: syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:28.002 1: reload: Error:Modul 36_Shelly deactivated:
2026.08.19 13:23:28.002 0: syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:28.041 1: reload: Error:Modul 36_Shelly deactivated:
2026.08.19 13:23:28.041 0: syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:28.079 1: reload: Error:Modul 36_Shelly deactivated:
2026.08.19 13:23:28.079 0: syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:28.124 1: reload: Error:Modul 36_Shelly deactivated:
2026.08.19 13:23:28.124 0: syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:28.153 1: reload: Error:Modul 36_Shelly deactivated:
2026.08.19 13:23:28.153 0: syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:28.189 1: reload: Error:Modul 36_Shelly deactivated:
2026.08.19 13:23:28.189 0: syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:28.263 1: reload: Error:Modul 36_Shelly deactivated:
2026.08.19 13:23:28.263 0: syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:28.312 1: reload: Error:Modul 36_Shelly deactivated:
2026.08.19 13:23:28.312 0: syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:28.344 1: reload: Error:Modul 36_Shelly deactivated:
2026.08.19 13:23:28.344 0: syntax error at ./FHEM/36_Shelly.pm line 311, near ""Shelly Blu Gateway G3"    0x1817"
2026.08.19 13:23:28.373 1: reload: Error:Modul 36_Shelly deactivated:
Kann mir jemand eine Hinweis geben, was ich machen soll, um die Fehlermeldung abzustellen?
Alle Shelly sind aus fhem verschwunden.
Danke für jeden Hinweis.
Proxmox mit fhem im LXC auf einem Mini-PC, Raspberry 3 mit fhem (FS20-, MAX-Schnittstellen), openCCU auf einer DS918 im Container-Manager. HM und HMW-Geräte (Heizung, Wetterstation, Fensterkontakte), Shellys , ESPEasy , MAX-Taster (CUL),&amp;nbsp; FS20 Taster&amp;nbsp; (CUL)
cwagner
Bis morgen nach 8.15 Uhr warten und Update machen, der Fehler ist gefunden und Starkstrombastler hat das gefixte Modul schon eingestellt. Falls Du solange nicht warten kannst: Drei Nachrichten vorher ist beschrieben, wo der Fehler liegt, in Zeile 311 muss ein Komma hinzugefügt werden.
Dann reload 36_Shelly.pm in der Befehlszeile und es läuft wieder.
3. Variante: Hier die eingestellte und korrigierte Fassung herunterladen und ins FHEM-Verzeichnis stellen: Repository
Christian
Wiesenfreund
Danke Christian,
ich habe zwischenzeitlich ein restore gemacht, da ich nicht warten konnte. Da fhem aktuell war, waren nur sehr wenige Module vom relaod betroffen. Ich hatte zunächst befürchtet, dass die Shelly-Geräte tatsächlich gelöscht waren, nach dem reload waren sie aber wieder da.
Nochmals Danke,
Eberhard
chrisse111179
ich habe mich gewundert, warum in den Shelly Action URLs der csrf-Token immer wieder angehängt wird und die URL mit der Zeit ewig lang wird. Ich habe Claude drauf angesetzt der ein paar Sachen bei mir im Modul geändert hat, und seither läuft es. Ich habe gebeten die Änderungen zusammenzufassen und möchte dir das nicht vorenthalten, vielleicht kannst du davon ja was gebrauchen. Im Folgenden das, was die KI sagt.
Danke für deine Arbeit und das Modul!
---Claude Zusammenfassung---
Drei zusammenhängende Beobachtungen aus einer laufenden Installation mit elf Shellys (Gen1 bis Gen4), Modulstand $Id: 36_Shelly.pm 31581 2026-08-19 10:32:57Z Starkstrombastler $, FHEM 31310/2026-05-28 auf Perl 5.38 / Linux.
1. Der eigentliche Fehler: fwcsrf wird bei jedem Lauf erneut angehängt
Nach einigen Wochen sahen die Action-URLs so aus:
http://192.168.1.2:8083/fhem?cmd=set+Licht_Bad_oben+triple_push&fwcsrf=1234567890&fwcsrf=1234567890&fwcsrf=1234567890&fwcsrf=1234567890&fwcsrf=1234567890&fwcsrf=1234567890
Ursache ist die Token-Erkennung in Shelly_webhook_update, Zeile 7124 und 7231:
if( $sh_url =~ m/fwcsrf=(csrf_[a-z0-9]+)/ ){
Das Präfix "csrf_" vergibt aber nur der Zufallsgenerator in 01_FHEMWEB.pm
(`$csrf = "csrf_".(rand($y)*rand($x))`).
Wer den Token per attr <FHEMWEB> csrfToken <fester Wert> festnagelt, hat kein Präfix. $sh_token bleibt damit immer leer, der Zweig
if( $curr_token ne "" && $sh_token eq "" ){ $sh_url .= "&fwcsrf=$curr_token"; }
greift jedes Mal und hängt einen weiteren Token an. Mit dem Default "random" ist der Fehler unsichtbar, deshalb fällt er wohl nur selten auf.
Vorschlag: die Erkennung nicht auf das Präfix stützen, und beim Entfernen alle Fundstellen erwischen:
$sh_tokenCount = () = ( $sh_url =~ m/fwcsrf=/g );
if( $sh_url =~ m/fwcsrf=([^&\s]+)/ ){ $sh_token = $1; } else { $sh_token = ""; }
und in Zeile 7160/7267
s/fwcsrf=csrf_[a-z0-9]+// -> s/fwcsrf=[^&\s]*//g
Damit bereits aufgeblähte URLs auch bereinigt werden, muss der "nichts zu tun"-Zweig zusätzlich $sh_tokenCount <= 1 verlangen; im Änderungszweig dann alle Tokens entfernen, die Trenner aufräumen (&&+ -> &, [?&]+$ weg) und genau einen neu anhängen. Bei mir läuft das seit gestern über 53 URLs auf elf Geräten sauber, der zweite Durchlauf meldet überall "no actions to update".
2. Das automatische Update bei "attr webhook" läuft für Gen>=2 ins Leere
Shelly_Attr ruft in Zeile 2011:
Shelly_Set($hash,$name,"actions","update");     # ohne Action-ID
Die Prüfung in Shelly_Set (Zeile 3696) verlangt für GEN>1 aber eine numerische ID:
return "$name: None or wrong identifier of action given"
unless( $actioncmd eq "update" && $hash->{GEN}==1 );
Der Aufruf bricht also sofort ab, der Rückgabewert wird verworfen, im Log steht nichts. Beobachtet beim Umhängen des webhook-Attributs auf eine andere FHEMWEB-Instanz: nur das einzige Gen1-Gerät hatte danach den neuen Port, alle Gen2+-Geräte erst nach einem manuellen "set <dev> actions update 0".
Vorschlag:
if( $hash->{GEN} > 1 ){ Shelly_Set($hash,$name,"actions","update",0); }
else                  { Shelly_Set($hash,$name,"actions","update");   }
Der "disable"-Zweig zwei Zeilen darüber (beim Löschen des Attributs) hat dieselbe Form und dürfte aus demselben Grund nichts tun - da kenne ich die gewünschte Semantik aber nicht gut genug für einen Vorschlag.
3. Warum mir 1. so lange nicht aufgefallen ist: host_ip
my $curr_host_ip = AttrVal($name,"host_ip",undef)//qx("hostname --all-ip-addresses");
nimmt die erste Adresse. Mein Server hat auf einem Interface zwei Adressen aus demselben Netz; "hostname --all-ip-addresses" liefert die auf, die *nicht* in den URLs steht.
Ergebnis: "ip not matching, skipping update" für jede eigene URL, das Modul rührt gar nichts mehr an. Kippt die Reihenfolge (Reboot), passt es wieder - und dann hängt 1. den nächsten Token an. Daher das schubweise Wachsen.
Das Attribut host_ip ist der saubere Ausweg und hat es sofort behoben, vielleicht wäre ein Hinweis in der Doku (oder eine Warnung im Log, wenn qx mehrere Adressen liefert) für andere hilfreich.
