Eltako FL62-230V Anlernen
Begonnen von Damu, 29 März 2025, 14:59:01
klaus.schauer
Habe die REF-ID 00000484 überarbeitet. Steht morgen per update zur Verfügung. Bitte nochmals testen.
Damu
#16
Hallo
Hab es mit MSC versucht (2x)
Kommt immer das:
define EnO_042061B1 EnOcean 042061B1
attr EnO_042061B1 IODev POE_EnOcean_UG
attr EnO_042061B1 creator autocreate
attr EnO_042061B1 manufID 00D
attr EnO_042061B1 modelVersion 0104
attr EnO_042061B1 mscRefID 00000484
attr EnO_042061B1 room EnOcean
attr EnO_042061B1 subDef FFFCB081
attr EnO_042061B1 subType MSC
#   CFGFN
#   DEF        042061B1
#   FUUID      67f13275-f33f-d169-2fa6-d08b465d82cf998c
#   IODev      POE_EnOcean_UG
#   LASTInputDev POE_EnOcean_OG
#   MSGCNT     5
#   NAME       EnO_042061B1
#   NR         573
#   NTFY_ORDER 50-EnO_042061B1
#   POE_EnOcean_OG_DestinationID FFFFFFFF
#   POE_EnOcean_OG_MSGCNT 5
#   POE_EnOcean_OG_PacketType 1
#   POE_EnOcean_OG_RSSI -46
#   POE_EnOcean_OG_ReceivingQuality excellent
#   POE_EnOcean_OG_RepeatingCounter 1
#   POE_EnOcean_OG_SubTelNum 6
#   POE_EnOcean_OG_TIME 2025-04-05 15:39:47
#   POE_EnOcean_UG_DestinationID FFFFFFFF
#   POE_EnOcean_UG_MSGCNT 5
#   POE_EnOcean_UG_PacketType 1
#   POE_EnOcean_UG_RSSI -63
#   POE_EnOcean_UG_ReceivingQuality excellent
#   POE_EnOcean_UG_RepeatingCounter 0
#   POE_EnOcean_UG_SubTelNum 5
#   POE_EnOcean_UG_TIME 2025-04-05 15:39:47
#   STATE      BI
#   TYPE       EnOcean
#   eventCount 6
#   READINGS:
#     2025-04-05 15:39:01   IODev           POE_EnOcean_UG
#     2025-04-05 15:39:47   buttons         pressed
#     2025-04-05 15:39:47   channelB        BI
#     2025-04-05 15:39:47   state           BI
#     2025-04-05 15:39:03   teach           4BS teach-in accepted EEP:  Manufacturer: Eltako
#   helper:
setstate EnO_042061B1 BI
setstate EnO_042061B1 2025-04-05 15:39:01 IODev POE_EnOcean_UG
setstate EnO_042061B1 2025-04-05 15:39:47 buttons pressed
setstate EnO_042061B1 2025-04-05 15:39:47 channelB BI
setstate EnO_042061B1 2025-04-05 15:39:47 state BI
setstate EnO_042061B1 2025-04-05 15:39:03 teach 4BS teach-in accepted EEP:  Manufacturer: Eltako
Ist nicht das was mann will.
Wenn ich die fehlenden Attribute noch ergänze:
attr EnO_042061B1 IODev POE_EnOcean_OG
attr EnO_042061B1 comMode confirm
attr EnO_042061B1 eep A5-38-08
attr EnO_042061B1 gwCmd switching
attr EnO_042061B1 model Eltako_FL62
attr EnO_042061B1 subDef FFFCB092
attr EnO_042061B1 subType gateway
attr EnO_042061B1 webCmd on:off
#   CFGFN
#   DEF        042061B1
#   FUUID      67f13e05-f33f-d169-e2b7-b523964660458725
#   IODev      POE_EnOcean_OG
#   MSGCNT     53
#   NAME       EnO_042061B1
#   NR         587
#   POE_EnOcean_OG_MSGCNT 53
#   POE_EnOcean_OG_SubTelNum 9
#   POE_EnOcean_OG_TIME 2025-04-05 16:37:42
#   POE_EnOcean_UG_MSGCNT 53
#   POE_EnOcean_UG_RSSI -61
#   POE_EnOcean_UG_RepeatingCounter 1
#   POE_EnOcean_UG_SubTelNum 3
#   POE_EnOcean_UG_TIME 2025-04-05 16:37:42
#   STATE      off
#   TYPE       EnOcean
#   eventCount 65
#   READINGS:
#     2025-04-05 16:28:21   IODev           POE_EnOcean_OG
#     2025-04-05 16:37:41   block           unlock
#     2025-04-05 16:33:41   buttons         pressed
#     2025-04-05 16:33:41   channelB        B0
#     2025-04-05 16:37:42   state           off
#     2025-04-05 16:30:07   teach           4BS teach-in accepted EEP:  Manufacturer: Eltako
#   helper:
setstate EnO_042061B1 off
setstate EnO_042061B1 2025-04-05 16:28:21 IODev POE_EnOcean_OG
setstate EnO_042061B1 2025-04-05 16:37:41 block unlock
setstate EnO_042061B1 2025-04-05 16:33:41 buttons pressed
setstate EnO_042061B1 2025-04-05 16:33:41 channelB B0
setstate EnO_042061B1 2025-04-05 16:37:42 state off
setstate EnO_042061B1 2025-04-05 16:30:07 teach 4BS teach-in accepted EEP:  Manufacturer: Eltako
Funktioniert das Teil.
Damu
#17
Mit EEP N5-38-08
Kommt das:
define test99 EnOcean 042061B1
attr test99 IODev POE_EnOcean_OG
attr test99 comMode confirm
attr test99 eep A5-38-08
attr test99 gwCmd switching
attr test99 manufID 00D
attr test99 model Eltako_TF
attr test99 room EnOcean
attr test99 subDef FFFCB092
attr test99 subType gateway
attr test99 teachMethod confirm
attr test99 webCmd on:off
#   CFGFN
#   DEF        042061B1
#   FUUID      67f13401-f33f-d169-0b5a-072a67a14a5b132e
#   MSGCNT     5
#   NAME       test99
#   NR         575
#   NTFY_ORDER 50-test99
#   POE_EnOcean_OG_SubTelNum 5
#   POE_EnOcean_OG_TIME 2025-04-05 15:48:50
#   POE_EnOcean_UG_RSSI -71
#   POE_EnOcean_UG_SubTelNum 2
#   POE_EnOcean_UG_TIME 2025-04-05 15:48:50
#   STATE      off
#   TYPE       EnOcean
#   eventCount 8
#   OLDREADINGS:
#   READINGS:
#     2025-04-05 15:48:03   block           unlock
#     2025-04-05 15:47:55   state           off
#     2025-04-05 15:46:40   teach           4BS teach-in sent
#   helper:
#     timer:
setstate test99 off
setstate test99 2025-04-05 15:48:03 block unlock
setstate test99 2025-04-05 15:47:55 state off
setstate test99 2025-04-05 15:46:40 teach 4BS teach-in sent
mit FHEM nicht schaltbar.
Und mit EEP M5-38-08
#   CFGFN
#   DEF        042061B1
#   FUUID      67f135cb-f33f-d169-587a-176b9a3bb401f3a6
#   LASTInputDev POE_EnOcean_UG
#   MSGCNT     28
#   NAME       test99
#   NR         577
#   POE_EnOcean_OG_MSGCNT 28
#   POE_EnOcean_OG_SubTelNum 4
#   POE_EnOcean_OG_TIME 2025-04-05 15:55:42
#   POE_EnOcean_UG_MSGCNT 28
#   POE_EnOcean_UG_RSSI -52
#   POE_EnOcean_UG_SubTelNum 6
#   POE_EnOcean_UG_TIME 2025-04-05 15:55:42
#   STATE      on
#   TYPE       EnOcean
#   eventCount 39
#   OLDREADINGS:
#   READINGS:
#     2025-04-05 15:54:49   block           unlock
#     2025-04-05 15:54:50   state           on
#     2025-04-05 15:53:43   teach           4BS teach-in accepted EEP: A5-38-08 Manufacturer: Eltako
#   helper:
setstate test99 on
setstate test99 2025-04-05 15:54:49 block unlock
setstate test99 2025-04-05 15:54:50 state on
setstate test99 2025-04-05 15:53:43 teach 4BS teach-in accepted EEP: A5-38-08 Manufacturer: Eltako
Mit FHEM schaltbar.
Hab den Fehler gefunden.
Das geht nur nach einem Reset der Aktors.
Hab immer: RESET, Taster angelernt, Statusmeldung Ein geschaltet, FHEM anlernen.
Richtig ist: RESET, Taster anlernen, FHEM anlernen.
Flachzange
Zitat von: Damu am 05 April 2025, 15:50:23Hab immer: RESET, Taster angelernt, Statusmeldung Ein geschaltet, FHEM anlernen.
Du machst ja in beiden Fällen einen Reset. Die Bestätigungstelegramme brauchst Du gar nicht aktivieren, weil es automatisch beim Anlernen von FHEM passiert. Den Taster lernst Du an, weil Du ihn physisch brauchst? die Aktoren starten ja eigentlich mit offenem Lernmodus, wenn noch nichts eingelernt war.
Ich habe noch keine nachhaltige Beobachtung gemacht, dass man den Aktor resetten muss vor einem Neuanlernen.
klaus.schauer
Was geht denn nun, anlernen per MSC oder per M5-38-08 oder beides?
Damu
#20
Per MSC geht nicht. Es wird (bei mir) nicht alle Atribute erstellt. Wenn ich die fehlenden Attribute ergänze funktioniert es.
Per M5-38-08:
Funktioniert. Bei mir war der Aktor aber (nach komplett reset) mit einem Funktaster verbunden, und das Bestätigungstelegram aktiviert wurde
ZitatBestätigungs-Telegramme ein- bzw. aus
schalten:
 1.  Die Versorgungsspannung ab- und zu
schalten.
 2.  Einen bereits eingelernten Funktaster (nicht
 Zentralsteuertaster) oder den örtlichen
Taster 7-mal kurz plus 1-mal lang
(> 2 Sekunden) tippen.
Mit einem 2-maligen kurzen Ein- und Aus
schalten der Lampe wird Ein signalisiert.
Mit einem kurzen Ein- und Ausschalten
der Last wird Aus signalisiert.
Per N5-38-08:
Geht nach einem kompletten Reset, und Ohne eingeschaltetes Bestätigungs Telegram. (Das wird aber beim Anlernen eingeschaltet)
Im Forum hab ich Beiträge gefunden bei dennen es nur mit Verschlüsselung klappt. Ohne Verschlüsselung keine (Hat nicht geklappt haben dann mit Verschlüsselung angelernt).
Also MSC klappn nicht.
N5-38-08 nur nach Reset.
klaus.schauer
Zitat von: Damu am 06 April 2025, 09:58:26Per MSC geht nicht. Es wird (bei mir) nicht alle Atribute erstellt. Wenn ich die fehlenden Attribute ergänze funktioniert es.
Wurde die aktuelle Version per Update geladen, das alte Device gelöscht und ein restart durchgeführt?
Falls ja, kommen wir eher weiter, wenn das MSC teach-in mit verbose = 5 am Transceiver vollständig geloggt würde.
Damu
Damu
Mach ich, wird aber etwas dauern.
Habe dieses verbaut aber noch eines zusätzlich bestellt.
klaus.schauer
Zitat von: Damu am 06 April 2025, 10:09:40Bei Wibutler steht auch:
A5-38-08 (nicht in allen Punkten EEP-konform)
https://shop.wibutler.com/beleuchtung/schaltrelais/402/eltako-funk-lichtaktor-fl62-230v
Was soll denn konkret nicht passen? Mit den allgemeinen Aussagen kann ich nichts anfangen. Leider musste ich für die Eltako Geräte schon reichlich firmenspezifische Anpassungen vornehmen.
Damu
Bei mir passt alles.
Es sagt nur das Eltako es leider nicht so genau mit denn EEP Vorgaben nimmt.
Flachzange
Zitat von: Damu am 07 April 2025, 22:50:27Es sagt nur das Eltako es leider nicht so genau mit denn EEP Vorgaben nimmt.
Das sagt es nicht. Es sagt, dass dass EEP nicht vollständig abgebildet ist und wenn man sich das EEP A5-38-08 anschaut, weiß man auch warum. Es scheint ein generisches Gateway EEP zu seinm, was noch ganz viele andere Dinge machen kann außer Licht ein- und ausschalten.
Damu
#27
Der Aktor ist Heute gekommen:
define EnO_042CC990 EnOcean 042CC990
attr EnO_042CC990 IODev POE_EnOcean_OG
attr EnO_042CC990 creator autocreate
attr EnO_042CC990 manufID 00D
attr EnO_042CC990 room EnOcean
attr EnO_042CC990 subType MSC
#   CFGFN
#   DEF        042CC990
#   FUUID      67f80738-f33f-d169-1a5c-bbffeaf0dd3b7721
#   MSGCNT     4
#   NAME       EnO_042CC990
#   NR         615
#   NTFY_ORDER 50-EnO_042CC990
#   POE_EnOcean_OG_MSGCNT 4
#   POE_EnOcean_OG_RSSI -51
#   POE_EnOcean_OG_SubTelNum 8
#   POE_EnOcean_OG_TIME 2025-04-10 20:03:24
#   POE_EnOcean_UG_MSGCNT 4
#   POE_EnOcean_UG_RSSI -57
#   POE_EnOcean_UG_TIME 2025-04-10 20:03:24
#   STATE      ???
#   TYPE       EnOcean
#   eventCount 1
#   READINGS:
#     2025-04-10 20:00:24   IODev           POE_EnOcean_OG
#     2025-04-10 20:00:24   teach           MSC teach-in REF-ID 000004B8 not supported Manufacturer Eltako
#   helper:
setstate EnO_042CC990 2025-04-10 20:00:24 IODev POE_EnOcean_OG
setstate EnO_042CC990 2025-04-10 20:00:24 teach MSC teach-in REF-ID 000004B8 not supported Manufacturer Eltako
Zitat025.04.10 20:00:16 3: TCM POE_EnOcean_OG set teach 60
2025.04.10 20:00:16 5: TCM POE_EnOcean_OG sent ESP: 5500100001A5D0114F06FFFFFFFFFFFFFF0425BA220015
2025.04.10 20:00:16 5: DevIo_SimpleWrite POE_EnOcean_OG: 5500100001A5D0114F06FFFFFFFFFFFFFF0425BA220015
2025.04.10 20:00:16 5: TCM POE_EnOcean_OG received ESP: 5500010002650000
2025.04.10 20:00:16 5: TCM POE_EnOcean_OG TCM_Parse 00
2025.04.10 20:00:16 5: TCM POE_EnOcean_OG RESPONSE: OK
2025.04.10 20:00:16 5: TCM POE_EnOcean_OG received ESP: 5500010004770838
2025.04.10 20:00:16 5: TCM POE_EnOcean_OG received ESP: 5500100701CED0114F06FFFFFFFFFFFFFF0425BA220105FFFFFFFF33006A
2025.04.10 20:00:16 4: TCM POE_EnOcean_OG received own telegram from 0425BA22 blocked.
2025.04.10 20:00:24 5: TCM POE_EnOcean_OG received ESP: 55000D0701FDD100D0FF000004B8042CC9900104FFFFFFFF340091
2025.04.10 20:00:24 5: POE_EnOcean_OG: dispatch EnOcean:1:D1:00D0FF000004B8:042CC990:01:04FFFFFFFF3400
2025.04.10 20:00:24 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:D1:00D0FF000004B8:042CC990:01:04FFFFFFFF3400
2025.04.10 20:00:24 1: EnOcean Unknown device with SenderID 042CC990 and MSC telegram, please define it.
2025.04.10 20:00:24 2: autocreate: define EnO_042CC990 EnOcean 042CC990 EnOcean:1:D1:00D0FF000004B8:042CC990:01:04FFFFFFFF3400
2025.04.10 20:00:24 2: EnOcean define EnO_042CC990 EnOcean 042CC990 EnOcean:1:D1:00D0FF000004B8:042CC990:01:04FFFFFFFF3400
2025.04.10 20:00:24 2: EnOcean define FileLog_EnO_042CC990 FileLog ./log/EnO_042CC990-%Y.log EnO_042CC990
2025.04.10 20:00:24 2: EnOcean EnO_042CC990 MSC teach-in REF-ID 000004B8 not supported Manufacturer Eltako
2025.04.10 20:00:25 5: TCM POE_EnOcean_OG received ESP: 55000E070140D100D0FE0303010076042CC9900108FFFFFFFF33007E
2025.04.10 20:00:25 5: POE_EnOcean_OG: dispatch EnOcean:1:D1:00D0FE0303010076:042CC990:01:08FFFFFFFF3300
2025.04.10 20:00:25 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:D1:00D0FE0303010076:042CC990:01:08FFFFFFFF3300
2025.04.10 20:00:25 2: EnOcean EnO_042CC990 MSC data: 00D0FE0303010076
2025.04.10 20:00:49 5: TCM POE_EnOcean_OG received ESP: 55000A0701EBA57900000F01A4EAA60104FFFFFFFF3300BE
2025.04.10 20:00:49 5: POE_EnOcean_OG: dispatch EnOcean:1:A5:7900000F:01A4EAA6:01:04FFFFFFFF3300
2025.04.10 20:00:49 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:A5:7900000F:01A4EAA6:01:04FFFFFFFF3300
2025.04.10 20:00:53 5: TCM POE_EnOcean_OG received ESP: 55000A0701EBA5D22C000F052627780103FFFFFFFF330080
2025.04.10 20:00:53 5: POE_EnOcean_OG: dispatch EnOcean:1:A5:D22C000F:05262778:01:03FFFFFFFF3300
2025.04.10 20:00:53 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:A5:D22C000F:05262778:01:03FFFFFFFF3300
2025.04.10 20:00:57 5: TCM POE_EnOcean_OG received ESP: 55000707017AD509059980490107FFFFFFFF33000B
2025.04.10 20:00:57 5: POE_EnOcean_OG: dispatch EnOcean:1:D5:09:05998049:01:07FFFFFFFF3300
2025.04.10 20:00:57 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:D5:09:05998049:01:07FFFFFFFF3300
2025.04.10 20:01:16 3: TCM POE_EnOcean_OG set teach 0
2025.04.10 20:01:16 5: TCM POE_EnOcean_OG sent ESP: 5500100001A5D011BFFFFFFFFFFFFFFFFF0425BA22000E
2025.04.10 20:01:16 5: DevIo_SimpleWrite POE_EnOcean_OG: 5500100001A5D011BFFFFFFFFFFFFFFFFF0425BA22000E
2025.04.10 20:01:16 5: TCM POE_EnOcean_OG received ESP: 5500010002650000
2025.04.10 20:01:16 5: TCM POE_EnOcean_OG TCM_Parse 00
2025.04.10 20:01:16 5: TCM POE_EnOcean_OG RESPONSE: OK
2025.04.10 20:01:16 5: TCM POE_EnOcean_OG received ESP: 5500010004770838
2025.04.10 20:01:16 5: TCM POE_EnOcean_OG received ESP: 5500100701CED011BFFFFFFFFFFFFFFFFF0425BA220103FFFFFFFF3300F9
2025.04.10 20:01:16 4: TCM POE_EnOcean_OG received own telegram from 0425BA22 blocked.
2025.04.10 20:01:19 5: TCM POE_EnOcean_OG received ESP: 550009070156D20400000185CD750006FFFFFFFF3300C8
2025.04.10 20:01:19 5: POE_EnOcean_OG: dispatch EnOcean:1:D2:040000:0185CD75:00:06FFFFFFFF3300
2025.04.10 20:01:19 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:D2:040000:0185CD75:00:06FFFFFFFF3300
2025.04.10 20:01:19 5: TCM POE_EnOcean_OG received ESP: 55000A0701EBA5D7F5000F05261FC40107FFFFFFFF33007C
2025.04.10 20:01:19 5: POE_EnOcean_OG: dispatch EnOcean:1:A5:D7F5000F:05261FC4:01:07FFFFFFFF3300
2025.04.10 20:01:19 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:A5:D7F5000F:05261FC4:01:07FFFFFFFF3300
2025.04.10 20:01:23 5: TCM POE_EnOcean_OG received ESP: 55000707017AD50901A0EFF70108FFFFFFFF330027
2025.04.10 20:01:23 5: POE_EnOcean_OG: dispatch EnOcean:1:D5:09:01A0EFF7:01:08FFFFFFFF3300
2025.04.10 20:01:23 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:D5:09:01A0EFF7:01:08FFFFFFFF3300
2025.04.10 20:01:23 5: TCM POE_EnOcean_OG received ESP: 55000A0701EBA500006A080581CF890103FFFFFFFF3300E0
2025.04.10 20:01:23 5: POE_EnOcean_OG: dispatch EnOcean:1:A5:00006A08:0581CF89:01:03FFFFFFFF3300
2025.04.10 20:01:23 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:A5:00006A08:0581CF89:01:03FFFFFFFF3300
2025.04.10 20:01:25 5: TCM POE_EnOcean_OG received ESP: 55000D0701FDD100D0FF000004B8042CC9900108FFFFFFFF330065
2025.04.10 20:01:25 5: POE_EnOcean_OG: dispatch EnOcean:1:D1:00D0FF000004B8:042CC990:01:08FFFFFFFF3300
2025.04.10 20:01:25 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:D1:00D0FF000004B8:042CC990:01:08FFFFFFFF3300
2025.04.10 20:01:26 5: TCM POE_EnOcean_OG received ESP: 55000E070140D100D0FE0303010076042CC9900104FFFFFFFF3300E1
2025.04.10 20:01:26 5: POE_EnOcean_OG: dispatch EnOcean:1:D1:00D0FE0303010076:042CC990:01:04FFFFFFFF3300
2025.04.10 20:01:26 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:D1:00D0FE0303010076:042CC990:01:04FFFFFFFF3300
2025.04.10 20:01:26 2: EnOcean EnO_042CC990 MSC data: 00D0FE0303010076
2025.04.10 20:01:35 5: TCM POE_EnOcean_OG received ESP: 55000A0701EBA57F5989080191F1E10107FFFFFFFF3400D3
2025.04.10 20:01:35 5: POE_EnOcean_OG: dispatch EnOcean:1:A5:7F598908:0191F1E1:01:07FFFFFFFF3400
2025.04.10 20:01:35 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:A5:7F598908:0191F1E1:01:07FFFFFFFF3400
2025.04.10 20:01:36 5: TCM POE_EnOcean_OG received ESP: 55000A0701EBA552022A0805823BDC0108FFFFFFFF3300B2
2025.04.10 20:01:36 5: POE_EnOcean_OG: dispatch EnOcean:1:A5:52022A08:05823BDC:01:08FFFFFFFF3300
2025.04.10 20:01:36 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:A5:52022A08:05823BDC:01:08FFFFFFFF3300
2025.04.10 20:01:53 5: TCM POE_EnOcean_OG received ESP: 55000A0701EBA535309D080520B3000008FFFFFFFF31005F
2025.04.10 20:01:53 5: POE_EnOcean_OG: dispatch EnOcean:1:A5:35309D08:0520B300:00:08FFFFFFFF3100
2025.04.10 20:01:53 5: EnOcean received via POE_EnOcean_OG: EnOcean:1:A5:35309D08:0520B300:00:08FFFFFFFF3100
2025.04.10 20:01:53 5: TCM POE_EnOcean_OG sent ESP: 55000A0701EBA533720008FFFCB08E00030520B300FF00F5
2025.04.10 20:01:53 5: DevIo_SimpleWrite POE_EnOcean_OG: 55000A0701EBA533720008FFFCB08E00030520B300FF00F5
2025.04.10 20:01:53 5: TCM POE_EnOcean_OG received ESP: 5500010002650000
2025.04.10 20:01:53 5: TCM POE_EnOcean_OG RESPONSE: OK
2025.04.10 20:01:53 5: TCM POE_EnOcean_OG received ESP: 5500010004770838
2025.04.10 20:01:53 5: TCM POE_EnOcean_OG received ESP: 55000A0701EBA533720008FFFCB08E01050520B30033003B
2025.04.10 20:01:53 4: TCM POE_EnOcean_OG received own telegram from SenderID FFFCB08E blocked.
2025.04.10 20:03:24 2: EnOcean EnO_042CC990 MSC data: 00D0FE0303000000
@klaus.schauer das MSC wurde nicht Fertig erstellt.
Hoffe das reicht.
klaus.schauer
Ich habe letztlich REF-ID 000004B4 eingepflegt. Es wird (jetzt) aber REF-ID 000004B8 benötigt, merkwürdig!
klaus.schauer
Habe die REF-ID 00000484 nochmals überarbeitet, REF-ID 00000488 neu eingepflegt und das teach-in für FL62 geändert. Steht morgen per update zur Verfügung. Bitte nochmals testen.
