[gelöst] NetAlertX - MQTT Readingslist TOPIC verwenden
Begonnen von GunterB, 19 November 2025, 13:08:22
GunterB
ich überwache in menem Netztwerk sämtliche Geräte mit NetAlertX (https://jokob-sk.github.io/NetAlertX/).
Die MQTT Ausgabe ist für mich jetzt erst mal ein Problem.
Meine Readingslist sieht erst mal so aus:
netalertx:system-sensors/sensor/netalertx/state:.* { $EVENT }
netalertx:system-sensors/.* { $EVENT }
Jedoch hätte ich gerne eine ordentliche Auflistung der Devices als Reading und nicht nur durchlaufende Werte.
Gibt es eine Möglichkeit, diese JSON Werte sinnvoll auszuwerten?
Code (Mitschnitt) Auswählen
Client mosqsub|28500-raspberry received PUBLISH (d0, q0, r0, m0, 'homeassistant/sensor/mac_9c_83_AA_BB_CC_DD/last_ip/config', ... (333 bytes))
{"name": "last_ip", "state_topic": "system-sensors/sensor/mac_9c_83_AA_BB_CC_DD/state", "value_template": "{{value_json.last_ip}}", "unique_id": "mac_9c_83_AA_BB_CC_DD_sensor_last_ip", "device": {"identifiers": ["mac_9c_83_AA_BB_CC_DD_sensor"], "manufacturer": "NetAlertX", "name": "Android_AABBCCDD"}, "icon": "mdi:ip-network"}
Client mosqsub|28500-raspberry received PUBLISH (d0, q0, r0, m0, 'homeassistant/sensor/mac_9c_83_AA_BB_CC_DD/mac_address/config', ... (353 bytes))
{"name": "mac_address", "state_topic": "system-sensors/sensor/mac_9c_83_AA_BB_CC_DD/state", "value_template": "{{value_json.mac_address}}", "unique_id": "mac_9c_83_AA_BB_CC_DD_sensor_mac_address", "device": {"identifiers": ["mac_9c_83_AA_BB_CC_DD_sensor"], "manufacturer": "NetAlertX", "name": "Android_AABBCCDD"}, "icon": "mdi:folder-key-network"}
Client mosqsub|28500-raspberry received PUBLISH (d0, q0, r0, m0, 'homeassistant/sensor/mac_9c_83_AA_BB_CC_DD/is_new/config', ... (338 bytes))
{"name": "is_new", "state_topic": "system-sensors/sensor/mac_9c_83_AA_BB_CC_DD/state", "value_template": "{{value_json.is_new}}", "unique_id": "mac_9c_83_AA_BB_CC_DD_sensor_is_new", "device": {"identifiers": ["mac_9c_83_AA_BB_CC_DD_sensor"], "manufacturer": "NetAlertX", "name": "Android_AABBCCDD"}, "icon": "mdi:bell-alert-outline"}
Client mosqsub|28500-raspberry received PUBLISH (d0, q0, r0, m0, 'homeassistant/sensor/mac_9c_83_AA_BB_CC_DD/vendor/config', ... (323 bytes))
{"name": "vendor", "state_topic": "system-sensors/sensor/mac_9c_83_AA_BB_CC_DD/state", "value_template": "{{value_json.vendor}}", "unique_id": "mac_9c_83_AA_BB_CC_DD_sensor_vendor", "device": {"identifiers": ["mac_9c_83_AA_BB_CC_DD_sensor"], "manufacturer": "NetAlertX", "name": "Android_AABBCCDD"}, "icon": "mdi:cog"}
Client mosqsub|28500-raspberry received PUBLISH (d0, q0, r0, m0, 'homeassistant/sensor/mac_9c_83_AA_BB_CC_DD/first_connection/config', ... (393 bytes))
{"device_class": "timestamp", "name": "first_connection", "state_topic": "system-sensors/sensor/mac_9c_83_AA_BB_CC_DD/state", "value_template": "{{value_json.first_connection}}", "unique_id": "mac_9c_83_AA_BB_CC_DD_sensor_first_connection", "device": {"identifiers": ["mac_9c_83_AA_BB_CC_DD_sensor"], "manufacturer": "NetAlertX", "name": "Android_AABBCCDD"}, "icon": "mdi:calendar-start"}
Client mosqsub|28500-raspberry received PUBLISH (d0, q0, r0, m0, 'homeassistant/sensor/mac_9c_83_AA_BB_CC_DD/last_connection/config', ... (388 bytes))
{"device_class": "timestamp", "name": "last_connection", "state_topic": "system-sensors/sensor/mac_9c_83_AA_BB_CC_DD/state", "value_template": "{{value_json.last_connection}}", "unique_id": "mac_9c_83_AA_BB_CC_DD_sensor_last_connection", "device": {"identifiers": ["mac_9c_83_AA_BB_CC_DD_sensor"], "manufacturer": "NetAlertX", "name": "Android_AABBCCDD"}, "icon": "mdi:calendar-end"}
Client mosqsub|28500-raspberry received PUBLISH (d0, q0, r0, m0, 'homeassistant/binary_sensor/mac_9c_83_AA_BB_CC_DD/is_present/config', ... (343 bytes))
{"name": "is_present", "state_topic": "system-sensors/binary_sensor/mac_9c_83_AA_BB_CC_DD/state", "value_template": "{{value_json.is_present}}", "unique_id": "mac_9c_83_AA_BB_CC_DD_sensor_is_present", "device": {"identifiers": ["mac_9c_83_AA_BB_CC_DD_sensor"], "manufacturer": "NetAlertX", "name": "Android_AABBCCDD"}, "icon": "mdi:wifi"}
Client mosqsub|28500-raspberry received PUBLISH (d0, q0, r0, m0, 'homeassistant/device_tracker/mac_9c_83_AA_BB_CC_DD/config', ... (524 bytes))
{"state_topic": "system-sensors/device_tracker/mac_9c_83_AA_BB_CC_DD/state", "json_attributes_topic": "system-sensors/device_tracker/mac_9c_83_AA_BB_CC_DD/attributes", "name": "is_home", "payload_home": "home", "payload_not_home": "away", "unique_id": "mac_9c_83_AA_BB_CC_DD_device_tracker_is_home", "icon": "mdi:home", "device": {"identifiers": ["mac_9c_83_AA_BB_CC_DD_sensor", "mac_9c_83_AA_BB_CC_DD_device_tracker_is_home"], "manufacturer": "NetAlertX", "model": "Android_AABBCCDD", "name": "Android_AABBCCDD"}}
Beta-User
Schritt für Schritt zu MQTT2_DEVICE im FHEM-Wiki ist bekannt?
Und im "Workshop" im korrekten Forenbereich für die Anfrage findet sich Baumaterial...
GunterB
ich finde keine Hilfe dazu, wie ich Teile, bzw das ganze Topic mit als Information verarbeiten kann.
Mit netalertx:system-sensors/binary_sensor/.*/state:.* BINARY_SENSOR bekomme ich das Reading BINARY_SENSOR    {"is_present": "OFF"}
Mit fehlt jetzt jedoch die Identifikation des Gerätes über das Topic.
Wie bekomme ich das ins Reading mit rein?
Beta-User
GunterB
#4
Danke Beta-User,
du hast mich in die richtige Richtung gebracht!!!
netalertx:system-sensors/binary_sensor/.*/state:.* { my ($mac) = ($TOPIC =~ m/mac_((?:[a-fA-F0-9_]+))/g);; ($mac =~ s/_//g);; json2nameValue($EVENT, $mac) }
Ich mache daran dann noch weiter...
Rückmeldung folgt.
GunterB
#5
Device für NetAlertX:
define netalertx MQTT2_DEVICE netalertx
attr netalertx autocreate 0
attr netalertx readingList netalertx:system-sensors/.* { my ($type, $sensor, $val) = ($TOPIC =~ m/\/(.*)\/(.*)\/(.*)/);;;; fhem("setreading $NAME ${sensor}_${type}_${val} $EVENT") }
Erzeugte Readings:
Code ("MAC Sensor") Auswählen
mac_aa_bb_cc_dd_ee_ff_binary_sensor_state {"is_present": "OFF"}
mac_aa_bb_cc_dd_ee_ff_device_tracker_attributes {"last_ip": "192.168.111.103", "is_new": "0", "alert_down": "0", "vendor": "Unknown locally administered", "mac_address": "aa:bb:cc:dd:ee:ff", "model": "proxy020local", "last_connection": "2025-11-26T00:00:00+01:00", "first_connection": "2025-11-26T00:00:00+01:00", "sync_node": "", "group": "", "location": "", "network_parent_mac": "aa:bb:cc:dd:ee:00", "network_parent_name": "EAP225"}
mac_aa_bb_cc_dd_ee_ff_device_tracker_state away
mac_aa_bb_cc_dd_ee_ff_sensor_state {"last_ip": "192.168.111.103", "is_new": "0", "alert_down": "0", "vendor": "Unknown locally administered", "mac_address": "aa:bb:cc:dd:ee:ff", "model": "proxy020local", "last_connection": "2025-11-26T00:00:00+01:00", "first_connection": "2025-11-26T00:00:00+01:00", "sync_node": "", "group": "", "location": "", "network_parent_mac": "aa:bb:cc:dd:ee:00", "network_parent_name": "EAP225}
Code ("Internet Sensor") Auswählen
mac_internet_binary_sensor_state {"is_present": "ON"}
mac_internet_device_tracker_attributes {"last_ip": "99.9.1.240", "is_new": "0", "alert_down": "0", "vendor": "None", "mac_address": "Internet", "model": "flood", "last_connection": "2025-11-26T00:00:00+01:00", "first_connection": "2025-11-26T00:00:00+02:00", "sync_node": "", "group": "", "location": "", "network_parent_mac": "null", "network_parent_name": ""}
mac_internet_device_tracker_state home
mac_internet_sensor_state {"last_ip": "99.9.1.240", "is_new": "0", "alert_down": "0", "vendor": "None", "mac_address": "Internet", "model": "flood", "last_connection": "2025-11-26T00:00:00+01:00", "first_connection": "2025-11-26T00:00:00+02:00", "sync_node": "", "group": "", "location": "", "network_parent_mac": "null", "network_parent_name": ""}
Code ("NetAlertX Sensor") Auswählen
netalertx_sensor_state {"online": 87, "down": 2, "all": 139, "archived": 0, "new": 2, "unknown": 7}
JSON für jedes Gerät entpacken:
attr netalertx readingList netalertx:system-sensors/.* { my ($type, $sensor, $val) = ($TOPIC =~ m/\/(.*)\/(.*)\/(.*)/);;;; fhem("setreading $NAME ${sensor}_${type}_${val} $EVENT");;;; $sensor =~ s/mac_//g;;;; $sensor =~ s/_//g;;;; json2nameValue($EVENT, "${sensor}_") }Du darfst diesen Dateianhang nicht ansehen.
