Hauptmenü
weekdaytimer zusammenfassen
Begonnen von mfeske, 09 Dezember 2025, 08:46:33
mfeske
ich habe in meiner alten Installation zwei weekdaytimer.
define ElchMorgends WeekdayTimer Elch 06:45:00|on {sunrise_abs('HORIZON=-2',0,"07:15","08:40")}|off
attr ElchMorgends commandTemplate set $NAME  $EVENT
attr ElchMorgends room Garten
define ElchAbends WeekdayTimer Elch Mo-So|{sunset_abs('HORIZON=-2',0,"15:30","22:30")}|on Mo-So|23:30|off
attr ElchAbends commandTemplate set $NAME  $EVENT
attr ElchAbends room Garten
Für die Neuinstallation dachte ich ich könnte diese zusammenfassen mit:
define ElchTimer WeekdayTimer Elch 06:45:00|on {sunrise_abs( HORIZON=-2 ,0, 07:15 , 08:40 )}|off Mo-So|{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}|on Mo-So|23:30|off
attr ElchTimer commandTemplate set $NAME  $EVENT
attr ElchTimer icon time_timer
attr ElchTimer room Garten->hinten
aber so richtig zu funktionieren scheint das nicht, das log wirft mir Fehler wie diesen:
2025.12.09 00:00:05 3: [ElchTimer] Can't modify constant item in scalar assignment at (eval 220172) line 1, near "2 ," syntax error at (eval 220172) line 1, near "07:" Illegal octal digit '8' at (eval 220172) line 1, at end of line >>>{ my $date=1765580405;{sunrise_abs( HORIZON=-2 ,0, 07:15 , 08:40 )}}<<<
2025.12.09 00:00:05 1: ERROR evaluating { my $date=1765407605;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}: Can't modify constant item in scalar assignment at (eval 220173) line 1, near "2 ,"
syntax error at (eval 220173) line 1, near "15:"
2025.12.09 00:00:05 3: [ElchTimer] Can't modify constant item in scalar assignment at (eval 220173) line 1, near "2 ," syntax error at (eval 220173) line 1, near "15:" >>>{ my $date=1765407605;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}<<<
2025.12.09 00:00:05 1: ERROR evaluating { my $date=1765321205;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}: Can't modify constant item in scalar assignment at (eval 220174) line 1, near "2 ,"
syntax error at (eval 220174) line 1, near "15:"
2025.12.09 00:00:05 3: [ElchTimer] Can't modify constant item in scalar assignment at (eval 220174) line 1, near "2 ," syntax error at (eval 220174) line 1, near "15:" >>>{ my $date=1765321205;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}<<<
2025.12.09 00:00:05 1: ERROR evaluating { my $date=1765234805;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}: Can't modify constant item in scalar assignment at (eval 220175) line 1, near "2 ,"
syntax error at (eval 220175) line 1, near "15:"
2025.12.09 00:00:05 3: [ElchTimer] Can't modify constant item in scalar assignment at (eval 220175) line 1, near "2 ," syntax error at (eval 220175) line 1, near "15:" >>>{ my $date=1765234805;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}<<<
2025.12.09 00:00:05 1: ERROR evaluating { my $date=1765321205;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}: Can't modify constant item in scalar assignment at (eval 220176) line 1, near "2 ,"
syntax error at (eval 220176) line 1, near "15:"
2025.12.09 00:00:05 3: [ElchTimer] Can't modify constant item in scalar assignment at (eval 220176) line 1, near "2 ," syntax error at (eval 220176) line 1, near "15:" >>>{ my $date=1765321205;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}<<<
2025.12.09 00:00:05 1: ERROR evaluating { my $date=1765407605;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}: Can't modify constant item in scalar assignment at (eval 220177) line 1, near "2 ,"
syntax error at (eval 220177) line 1, near "15:"
2025.12.09 00:00:05 3: [ElchTimer] Can't modify constant item in scalar assignment at (eval 220177) line 1, near "2 ," syntax error at (eval 220177) line 1, near "15:" >>>{ my $date=1765407605;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}<<<
2025.12.09 00:00:05 1: ERROR evaluating { my $date=1765494005;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}: Can't modify constant item in scalar assignment at (eval 220178) line 1, near "2 ,"
syntax error at (eval 220178) line 1, near "15:"
2025.12.09 00:00:05 3: [ElchTimer] Can't modify constant item in scalar assignment at (eval 220178) line 1, near "2 ," syntax error at (eval 220178) line 1, near "15:" >>>{ my $date=1765494005;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}<<<
2025.12.09 00:00:05 1: ERROR evaluating { my $date=1765580405;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}: Can't modify constant item in scalar assignment at (eval 220179) line 1, near "2 ,"
syntax error at (eval 220179) line 1, near "15:"
2025.12.09 00:00:05 3: [ElchTimer] Can't modify constant item in scalar assignment at (eval 220179) line 1, near "2 ," syntax error at (eval 220179) line 1, near "15:" >>>{ my $date=1765580405;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}<<<
2025.12.09 00:00:05 1: ERROR evaluating { my $date=1765234805;{sunrise_abs( HORIZON=-2 ,0, 07:15 , 08:40 )}}: Can't modify constant item in scalar assignment at (eval 220188) line 1, near "2 ,"
syntax error at (eval 220188) line 1, near "07:"
Illegal octal digit '8' at (eval 220188) line 1, at end of line
2025.12.09 00:00:05 3: [ElchTimer] Can't modify constant item in scalar assignment at (eval 220188) line 1, near "2 ," syntax error at (eval 220188) line 1, near "07:" Illegal octal digit '8' at (eval 220188) line 1, at end of line >>>{ my $date=1765234805;{sunrise_abs( HORIZON=-2 ,0, 07:15 , 08:40 )}}<<<
2025.12.09 00:00:05 1: ERROR evaluating { my $date=1765234805;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}: Can't modify constant item in scalar assignment at (eval 220189) line 1, near "2 ,"
syntax error at (eval 220189) line 1, near "15:"
2025.12.09 00:00:05 3: [ElchTimer] Can't modify constant item in scalar assignment at (eval 220189) line 1, near "2 ," syntax error at (eval 220189) line 1, near "15:" >>>{ my $date=1765234805;{sunset_abs( HORIZON=-2 ,0, 15:30 , 22:30 )}}<<<
2025.12.09 00:00:05 3: CUL433 IT_set: Elch off
2025.12.09 00:00:05 3: CUL433 IT_set: Elch on
auch würde ich gerne über ein reading vielleicht ein symbol setzen devstateicon um zu sehen ob ein oder ausgeschaltet.
Micha
Hardware:
1 x Raspberry Pi Mod. B 512 MB
eq-3 2 x MAX! eTRV Heizungssteller, 1 x MAX! Fensterkontakt, 1 x MAX! Cube - LAN Gateway (ausser Betrieb)
Intertechno 1x ITZ-500, 3x ITT-1500, 9x ITR-1500, 3 x ITDL-1000, 2 x ITL-500
1 x CC1101-USB-Lite 433MHz (CUL433)  V3 1 x CC1101-USB-Lite 868MHz (CUL868)
Beta-User
Ungeprüft fällt auf, dass in der neuen Fassung die Anführungszeichen fehlen...
mfeske
Dankeschön ;-) das habe ich dann gleich mal ungeprüft korrigiert :-(
sieht jetzt auch besser aus, allerdings wird mir das abendliche Ein- ausschalten nicht angezeigt.
DEF
Elch 06:45:00|on {sunrise_abs('HORIZON=-2',0,"07:15","08:40")}|off Mo-So {sunset_abs('HORIZON=-2',0,"15:30","22:30")}|on Mo-So|23:30|off
DEVICE
Elch
FUUID
6925705a-f33f-be1a-9b8e-450e3bf9854ee7eb
GlobalDaylistSpec
LANGUAGE
en
NAME
ElchTimer
NR
185
Profil 0: Sunday
06:45:00 on, 07:55:44 off,
Profil 1: Monday
Profil 2: Tuesday
Profil 3: Wednesday
Profil 4: Thursday
Profil 5: Friday
Profil 6: Saturday
Micha
Hardware:
Beta-User
Vielleicht schaust du dir das noch mal selbst kritisch an...
mfeske
Vermutlich willst Du mit dem Torpfosten winken https://wiki.fhem.de/wiki/WeekdayTimer und mir sagen das was ich machen will geht gar nicht und ich muss es wieder in eine morgens / abends Variante auftrennen ?!
Hardware:
Beta-User
Zitat von: mfeske am 09 Dezember 2025, 11:27:49Vermutlich willst Du mit dem Torpfosten winken https://wiki.fhem.de/wiki/WeekdayTimer und mir sagen das was ich machen will geht gar nicht und ich muss es wieder in eine morgens / abends Variante auftrennen ?!
Nein. Deine Syntax ist offensichtlich falsch...
Prof. Dr. Peter Henning
Tipp: Einfach mal das Modul YAAHM ansehen.
pah
Beta-User
Zitat von: Prof. Dr. Peter Henning am 09 Dezember 2025, 14:37:32Tipp: Einfach mal das Modul YAAHM ansehen.
pah
Korrigiert das offenkundig kaputte Syntax automatisch?
*duckundweg*
ZitatKorrigiert das offenkundig kaputte Syntax automatisch?
*duckundweg*
Nein, aber da braucht man so etwas auch nicht. Allerdings besteht dann immer noch das Problem der kaputten Rechtschreibung "Morgends"
*duck und Beta-User nach vorne schieb*
pah
