Blink-Kameras MQTT-Bridge
Begonnen von rabehd, 17 Mai 2026, 19:34:37
rabehd
Der Broker für blink2mqtt
define MQTT2Broker_Blink MQTT2_SERVER 1884 global
attr MQTT2Broker_Blink autocreate simple
attr MQTT2Broker_Blink clientId blink
attr MQTT2Broker_Blink keepaliveFactor 0
attr MQTT2Broker_Blink respectRetain 1
attr MQTT2Broker_Blink room Maschinenraum,Test->Blink
#   CFGFN
#   CONNECTS   1
#   Clients    :MQTT2_DEVICE:MQTT_GENERIC_BRIDGE:
#   ClientsKeepOrder 1
#   DEF        1884 global
#   FD         136
#   FUUID      6a0b1122-f33f-294e-cb9a-44512ff08883aa5c
#   NAME       MQTT2Broker_Blink
#   NR         632
#   PORT       1884
#   STATE      Initialized
#   TYPE       MQTT2_SERVER
#   eventCount 1
#   MatchList:
#     1:MQTT2_DEVICE ^.
#     2:MQTT_GENERIC_BRIDGE ^.
#   READINGS:
#     2026-05-18 15:46:55   RETAIN          {"blink2mqtt/availability":"online","blink2mqtt/blink2mqtt_151054202/availability":"online","blink2mqtt/blink2mqtt_151054202/binary_sensor/motion":"False","blink2mqtt/blink2mqtt_151054202/clip_count":"0","blink2mqtt/blink2mqtt_151054202/internal/discovered":"True","blink2mqtt/blink2mqtt_151054202/internal/last_snapshot":"61577.842535368","blink2mqtt/blink2mqtt_151054202/sensor/battery_status":"ok","blink2mqtt/blink2mqtt_151054202/sensor/last_event":"Timed snapshot","blink2mqtt/blink2mqtt_151054202/sensor/last_event_time":"2026-05-18T13:21:35.106283+00:00","blink2mqtt/blink2mqtt_151054202/sensor/temperature":"75","blink2mqtt/blink2mqtt_151054202/sensor/wifi_signal":"-61","blink2mqtt/blink2mqtt_151054202/snapshot":"/9j/4AAQSkZJRgABAgAAAQABAAD//gAQTGF2YzYxLjE5LjEwMQD/2wBDAAgKCgsKCw0NDQ0NDRAPEBAQEBAQEBAQEBASEhIVFRUSEhIQEBISFBQVFRcXFxUVFRUXFxkZGR4eHBwjIyQrKzP/xACjAAACAgMBAQAAAAAAAAAAAAAAAgMBBgUEBwgBAAMBAQEBAAAAAAAAAAAAAAABAgMEBQYQAAICAQIDBQQIBQIFBQEAAwABAhEDIQQSMQVxImFRQbGBEzJioVJykUIjBsEzNCQUc2OiQ/DRgjWyU+EVJYOS8REBAQACAQIFBQABBAIDAQEAAAECEQMhMTJxQQQSYYFRIjORsSNCE6FyQ8HRglL/wAARCALQBQADASIAAhEAAxEA/9oADAMBAAIRAxEAPwDJgHA4noFAAAAAADAAAgUAArQAAAiAAAjKAAVswAAEqVolRGiRApYABaQAAWZgADNIAAGQAAKgWAABmAAESwAC1LAAEQAABKgGArYUAAGwYAAkAAAWgAABgAAAFgACSVkDJ2QssMZyvhnL7zOHcrupnXu1+rKPjZxZX3aM3RjHD+UVKiQRmOz1FCMYViXFALYxOXdapaxaEGZWOPHljHzZI+Lr220lnbvSJusO321JRp1zOtwccLUVrRj6WLbxnm+I5N/l8u018+zP5Wdm2ni2klFSq5aVZrN1sHjTlDWP5l5Fxx4nxZMl46rhd2lfqbja7f4eKnk+Jxet2qJywxllx6flUyt7sOatDLRE+fHHDlnBNvW1foRehl1/LoU9SElZGwn6osIyNkjI2OJsUi5fKygb0or7MbHMd+3VcT8DXPmd+DUMu1dHG7sDrc4n4ozaSV6GC/Jkxvya9pnXl2L2GnDejP3MkkqDcxva5V9Fv8DDdu1WBvxWhnVcUZJ+sWjAYPhS+jkHzeFjweJvIPupD2QR0JTy85N7e3E65Dr07UQpsmT1RNyss7LkZX+3ZKO63kPVpP6zY9b7+1yxbvuy9ho+hSS6nkT/AD4tPwsyLqMLxO/Jr6ieS6zw69pIz1+zRbJRy9P27jyjHX3Mmef4UZRX5kcf7fi8mwyLm4SnFL38x55NtFNTvi0pHXbJlOm/X/Lmx492+ZoZIqCa0dGHdc7+6hJ69xG8z7uMMU41wzVV5M0fWJRnkx5IpV8JGmHXWWtfg+Ti+OKPo8uHfYtabjKP1GbRVRXgYB02XDvtrJulx1+J6BVSmvpM9DDrx4vH5J1WazqkW9pLtRszj3i49rlXhY8pqbZMZxVLHXaYJkbx5JdrM72+sTBN7FxzZF4mOOVuXm3xnSng1UmvU5YR48sb+0iXG6xzv3D7BLJu4RnotX+Bt8U9GUdQnDJ0+tO6uXYYxsMnDvYS9Kf1m9x43utluJcXyOUa86ZiuKXA4yXNMWMm7j6n/wDG3O9Ulmlfqa1aM3O+lHK8c16wVmjdqfvDDfWT8s71kd8VqmZd0h/2819IxSOioyTpD7uWK80VZ0sZ+fd3Zn+qZB0Z/wA77xot188ew2/RpfqZI+CftOfjvWw+T0ZWAAdGmJzFeur+UzKTHeux/t4S8pP6zHm8Lfi8TD0zWS0k14mwS1Vmvyp/FkcOo7iM5jumuXYcrLQjAADfXbLHENlf9gAeMW2Gx9TZM1uzdSa8DaM9HC/q4OTxUojJBGNhUM1cJ/dZ5hl0nLtZ6p6PsZ5fuI8OXJ94Um83Rh2cwABvtaaCN1jfco00Da4W3E5uWond2onRCr9SaJx5Os4ABBmLRRaKWlRKiNMkROWN9KSy0UWRq+qm7xfIjoo49s+4jtTMLjZbpeLt29cUe1HqcHeOD+ijybHzPU9o+PbY5eaPQ4euGTg9xP3lTgWUasQAABqAAAyMUkaFolNpChyiaUpGISMjJUoUcoY0xoAAPN3AAADUAAFNQABYKAABACwJBAAAUAAASAABgyJERolQ4ABYAAAAUSwABgAADTYcAAgwAAMgAFgAAAUFgAAawAAJQAAwYAAYUAFiCwACoAAAKgAAAQAAAFZAzoZAyksY37UM78UjWZJcUX4m16qqnjk1pJGjvurzIydGBRWUUcq1CgKx7NQAAlLJNrUd5jfmRCXKElKPoKGztyrG34GI7rFLNxyxYl5tv1r1Mg2m5x7jHw8Sb5NHbKoYpxWndl9Ztd9OjKxjWH/K3MsSlgUcXD+o2vmS5KjKMcIRglBcKXJeRwdPlOW2UZ6yj7CTdbqO3hw8nJaUK3f4+wxjQb+anuXqtFWnsOH0I2+Ljk9W2WcuV6uiKI2SMRiKomRMlZEy4RQYFMraHPdM7ds1fM4JEu3tSh2lZTo1w6NtJLm+Rm8JcUMb84oweeiTXlqjMtrJS22KS8ifb3rU+5m8ZXZE893DeN5o1TU7+s9DjWnaYHvofD3O5b7yb0X8Tq5ZPj1cvB4m3osjxu4Q8YolPGyvV7mHY6J48znRMmc9aN50tqHVcP0oNfUZdvlxQelmC7SfBv8AZz8a/E9B3aXBLwIz/wCNRellYD0RzjDdOLdR3ElS05s2mXY/Gb4ptXrSRo+n5v8AFz9QxU2vjRmq7P8Ar8DJY8eRfFlKcFr3UdvPvWOr6TX1Z8OXxzy82my9Pyy+KlBLirhbd6dhjfV8fCsT4lxOXC1HkoaGYxlx41k+Ll4XbVaPQ03WcMf/AMyGbHpeRXxVxanPh88bhvK6t12dGeUzxu2IYHWXDJP5ckfaelS0mzzHC0kq+2n9Z6e9ZX5qL+pHv8XTD7vnfceJZDnV4ci+iyYqS4oyXg/YaZdI5YwraukYd1G/8zIvEy/bppyTd6mL9Ui1vG/NWZT0b4Xu1SHwaZXLwYgyHb1O7ZJ06NbLNz/U4rMTjrOSWiRkcc8MXTZQTqU9F56mPY46qCeoXvu+s0c7ab3ZYfj4sq9Yd78TW5MbjM3HSssNpi3uXI/WMFF+unM4pSWWcpP15BlvG6jL6KXp2G/6RL9TKrvyRj9cJu+kyS3NaK0aY9rWdjfbt049h29IlW67YM5d58kWTdL03eLxTOfjsmd+q8+0Zx6AUnoMdTAxpOtR/svXSSN4azq0OPYZfCmY83grXDxR5zq0tTlyfO/E7VVHFP5rPM279FlyORnW+RzSNE1GUWUEqdFAsCth17SVZYrzs3Rotsqzw95v5HbxX9Y4ubujEY4rN3MEzzbfR4NxlX0r/E9HZ5/1ZVvcvi0Tejbi9WmKRYprF10RNntnoauJstuYZwse7ZImiQomicmTqhwAshRkORjoRymRKiNEqKtNIAAZ6U2e2rhO9Gs2rtSXkbSHI58sOvdeKeH8D0rpEuLY4/WrPNUeh9Bae0p+jZ3+18Gc+7j9z2xv1bkoZlF+rlAFgUCAWAgooYUmwEYo7EEaihqKAiMUdigbGAAB5O8AACCgAANQDAAUIOKMFAAKAAAIAAAAAAADOh0Ih0VErAAGkAAAawACgsAAkjAADCwACiWAAIAAAYWAAMgAABgAAuBYAAiWAACQAAWrYAsAsNQFgLQWAAQRJEDOhkDGhjnWOWJ+ToxpvsMr6vG9un5SRiPIzzrq4uyxbKFZi0AABKtLAoCKEgj1GFM400hjD4eTjho/M3Eeo54RS4VLxZqGtb1Gtvmb/wDZS+LZz6lld8KUb50a+UpyuUm2/EjaLtmfz6HoFgBn8lbURskZGxs6jZEyVkTNJSKUBQIrnnzJ8DSkiCfMbHpJF3sePduZckZT058Wzh4NoxXTg/BGSdKf9s4+U5f/APCODxVp7jwRt4mIdRj/AHma9FSf4mYLTUxPq/d30fpwX1I7OSbjh47rOGwPixY3R0mv2sm8MEvSTv8AE7m1bo8Tklle5x9kiHiRJkiJjZ1JtZdnK6ayRX1np+6g5xml4eyzymUuHHCXrDIn9Z64u/GOnOMX/wAKMeSdMUZvP9ttdxt93vZ/C7mTh4ZXq6v0O+WLJkuseSn4mXOEfIdY4v0HOfL1x2y9dsJXT5pUoSX/AJGv6p0+UenZ5cPycMr4rrU9KWNHF1TDx9L3sEtXif1B/wBuf4neH8pvX5eA49VL0PTcUuLFhld3jieZ4F3aerrXyPRNm+LZ7d/Q/ifQcHXevpXje5mr93f6AvmSBB62a5dXOwxLhzTS9JMxzrS4c2N6axMky93d5V9KzQdbjxLDK1+Y4/VtgxvQErkl4ir6gd+nM6Z3+yK2XUdrHbPAtaaTOHFX+Vota1Mg37/ytntcy/JpM0ezjx55S8iuu6r027ow4nNPlbYkqVJHU21CT8TVqUpZNfEWPXunu6lqbXpj4d5j56po1KNrsKjucL8asufhnWWbr+S/OxNi6z4X4tEm4V4ZdpybPXLif0jjxn+5r7jLrHoSQ6FTsdHfWCzj36U9lm8I39Z2EG4XFt80foM58/Bf8tMPFHl/oc2TRnT+X3nNk8zz69JH6HNIn9DnkCajAAKSAAByipMf8yHajIGY/BapmQ2d/Fd4uPm7kAANtOSleiMF63GtzfmjOZcmYb11Vlh2GOXeebbBi4AB0w4kid23epwxO7DzM8hO7bxJUQx5EyOF14pgKAlZwABEkRMiFEyIaHAAIN37NUpLxNtE0+0dSa8zboxzmr9jxTR5mddBl+lOPk/+5gSeqM2/b7TeRHZ7b/nPzi5PddcJPqytijsU6nIALAZlAAJpKKGKFaqlFJBSSIKOIw10JQoxRSmLgAEx6CgABEoCwAKAChGAKAogAACigAEgAADJQAAgZEiI0SIuEsAAZGAAAlAADM4AAJAAAGYAAAAABksAAYAAAwsAAZrAAEAAAUkFgWAAAAyWAAMgAACwAAQRWRMlZEy0NL1Rf2mTwp/WYS5+pn+8ipbfMufcPOvRox5G/D2S2KJYWc9dRwEsuxLWAAIzABQjKUAEGAKLAlllATo1sjYzI2NNhGRMkZExppbKsoCozqKQY33kEjnjpIdVh3ZDfd7vabvosrx5lJ6qfIx+FuGj5o3fRr480bvSLK4J+9jXl64RkyZjXW0ln2s/K+wyMx3riThgb9J0jtz7POw8bW7J/pyTduM708jYepr9sqnnh6qn+J3ni8uvlp7nF4Ytczoic/qTIzbRLlTe3ydqPVdpLi2m2f8AtR19x5XLvYckfCz0rpU+Ppm1f0K/Ay5PCnPwpd5u4bPHLJNcSSsx7efuN7T4f6C4citPi8zs63Dj2k1z7rMN38I5NpsJyj88OF+FM09vMLr5fll/1/pvb0Xp/UHu4xcopX5ehtt9Lb/4e5jxq5Ypr/hZ4xt9x1Dp7eTEnLE7u9VH6jJtn+4NnuI8GdSWScZpPtR3X2nHybyx6+V6/wCHJLZlPlLP/t5li4u96WveegdN12GD6PEn+JgF3lkvXvGddKbexWny5JI6uCbmU1rUcfuW4LQqLOr0ccYju1w7/J7vYaLrEf0cb+mZF1FNb1y80n9Rouqr+1vykcVbY92IPQE9S5J8EWl6hKMscqnpobSdd1Xxbvpcll/yNq388XOPajW7FuGScXztp+4jwTeLLjnHXhf/AFZ0Ko7yUk9G7/E1vTrJ6f6J6ayn3dGfJJYmlWjrkazG/wBSPvNluK+HPtNavQyxpa6O6ErcvA7dvKsuH76Rrsa9Ttxyanir0lZpOrHKM8zK4NGqwtxnB+UkbiesJ/c/gaPG6pv0kjl3rk0eXhenQ1S7CQhwu8cexEx1XuyxWDTcZV9lgMv4MrPw0Y+KPJ3cbUtGpM5cjtHZl/mZF9J+1nFLkeRp6vpED5EEid8iCRZIhiiyi0UCwDaDo38bq/SjH38pkEPkj2HZ7fwXzcnN3WKMKdFcYMN69G5Yn4MzIxXry/TxP/r0Iz9PNrx92GgWIaxtpNE7sXM4Yndi5k5IjZxOiJzxOiJx11YpiyizKtAWigICVEyIok5CjAADDqwLvo3NUaHE5OapG8Rhm0hlrJdpm3QNM0l5owhc0Zd0SVbtLzR0e08U8q5fceFnslqxCWREds9XD6AAADUAAKhQoxQjKUMUKQFEY4rCmUAASWKgADj0FAAEqUBYAClFlArSgLAZKAAAAAAggAAO0FAAGa0SIjRIhwlgAGiDAAEmBhRhpAAA1AAAAsAAYWAABLAAALAsBkoAAZrAAAABgEkAAFBYABRrAAITVAADUAAAQRkUiVkbRoTlnFSU15wkeZXpXrbX4M9Rq5I80zQcMmSNVU5e0w5Z0bcPqgAAOR2xQAA1GstClomq0YAAzJQAAGUAAAosoAC2IMIBFZEyRkbKTUbFLYppGdiOREuZLIiXMKePRusP8qL8Da9Ib/y8i9HDmanE/wBGn6Hd0yVbyHpafMz4unI2y/nWYml61BPawk/yzX1m7Tts1/VIp7HJpdOPtPTzvR5k6ZsX2s+Gc9LbS7dEbVo02BpZo6XxR/Bm5V0eHza+T3OPwwEqISVGFrZ1RT4ZV9l6GedBk59KxfRc19ZgWNtul62jM/23J/8A500/y5WvrJy8F/JZdnfv1xYXfijzLqm/c8e32m31cJNyb9H9k9R3ivCzxVwl/n5lFqVS11qtfE39nMflfox5N/8AX0Zn0KeWeDPgzSjcotLS+ZvP/wA7bwnj+HhjNxVcSRiGbPk2UIwwqPFOPemtUdPTOqb/ABTUeKWZXqq5HTcP+z9t6+m76eTDDOzpZtimaM47nIuFLvzX1mWdEb/xs8fs5l7DGN3X+dn1lfHxNO/UyPob7m7X0scjq9vvr9cXJ7r/APGRF6FFne85jnVP6iD84+w0vVFxbHIlejRvOrqp4H52abe97Z5exM4Mpu/drjdWMHjJ8OOn+bU3PU8cfgYcn5nSZo4/LHwaN91J/wBvt0/M3ymtX8Vd8TSQfDoTw+ZM5rJoPVDKuvK3RyeqO7Ku7+BrbdrtEK2EVRKnVfeQstK7C70948e7LJ6HHXH/AOP8DRr5febjC7wwfnBGna5+DOazXLNjX616Vt5cWHG/oo6TX7PXBj+6d56GTnxMiSOrojRJHR2ZZ+Grnd5duo/3OZL7T9prJG36guDeZ6+0aiXqzysd7u3q+kQM55HQyCQJqMAAEgAAGQab5G+xawj2GiN3ttcKO32/THX1Zc/ZMUWB2OGlMX66v7bF2pGUGh62r2n/AJIz5P8Aj5r4+7AQHcaFNWlNHmduP5l7ziidOP5kRSbZczqic0UdMTkrrxTlilmVUYsosk00UTIgROjMzAWgZJpMLqaN4uRocXzo36+VE5WKi4mSdFf95j7TGjIOkSa3eCvM29r05Z9Ue4x/275bemyIiWRGd0ebj2AABJqAsABGKOxaChRQ1CjChRxBEUoaiqBTFKChgMu0n1dyMCwKWoAAkigADUoCwGFAAAAAAIgAAAUAABgdCDocScAAsgAAAMAACQAAM1gAFGsAAErAAA1gACJYAAEBhRhiUAAAoAAAirAAGYAALCwABpUAATFAAAaFMjZIyNjVXPL5kee7+KjvNytefEvej0KWjMF6vj4N5ka/NGLrz0M+SfrWnF3aVWWKmMcrvgAoDM1gAEqMBQCI5VilEgAAEqUBQFkcjYxGwIrImSMiZUKlELEZpGdJJiJkjRD6jKNptXakn5nfs2473F96n+Br9r+f3HVhlwbnE/KcbfaRj/WV0T+dZ8ub7Tl3seLZbhevBf1o67VkeVKWHMualCVr3HoZPGvi+7AsLjGeFt6VV+Ju+WlmPx1WB1X6jN7Nq4+lM8flwlvf1r3fb+CHGTI7HRyWOt14mlNGV/teT/xtzC74cntsxCNWu0yj9tOsm/h4xkFk+NTWT7jXFJGCx2+0nLcxyRXE+T5O3Zn+SNwkee5sEpbrPXd5NLzMuPPHHeumyxnTTVbvFLb4VUU4L1i7oh6T1SGynPjjLJxNVw8zZKORvhScV627v3HX0fpccG9zZZK4ONwtfK9dDv4+XC43HLqw5OG/KWMW6nKP+fnnHiSlUkpc1aNr0KcXPcpO24RddjNf1rF8Dfzc225pS18Ts6Lwrd5I/axHoe1yx9PxXH7qMwjqhiKGkUhztryWk6uu5hb9G0aPcLi2uT7sn9Rv+rq8MH5S/wCxppR48E4+cJew4cula494878jc9Uf6e27L/E00YtSp+Zt+qNNYF9Czotnxmuqv+TTEsJOMlXmiJDJ00/Fe0WkVt9xoknzRrWbXdaza7DWyVJ6XQlO3J+XsK1US8mksfjFMoqX/VnrTPdo3Lb4vumurvSXabDpzX+Lh95xf86S+kzLkl/7Je6Z2rO+nyvbYn4UbM0/TNdrHwbNwdmX5/LLHXUyHEQyMsu1XL1ec9Vjw7/PFdpopmQdYVdSyPzS9hj07tnk26telj4YgZCyZkLGSMotlAhQAAyMbvaX8JPtNE9Ub7afyTs4GHN2TijCna89Rout29svCRvTV9VintJdpllV4XVec6gdPAi+EcrZDFHTjWovCSR5hexTu2keRPEgjyJ4nDe9dOKYsUtE3bc4AAglRMiBE6MzSAAEkfH86N6uSNDj+dG+XJEZqg5m86VOtzg+8aU22w0z4fvHR7b+mPmObwV6zISh5CnXe7yZ2hAABqAAAEQCygpgosBmoQcVmaSgABtTEgACHeQAAZqAAECgWAGoCyizUAASAAAIgAABqAAGSy0UWiySllIsEgAAZgAAAsAAowAANKwAABgABkAABJsWAAJQAALBgAABSyiyiMAAQFgAFgAAElAAAOEoAAYBGyQRlCueZhPXotZsE1ylCvwM1kYl16N49vPyk4k5T9V8fiYmrGsqq8yjgr0YYAASjAUBBLAAEoFABOiWAAAAAAlKEY4jGqo2RMlI2jRnUTFocAjKwjOdnQznkXGc7tjtXz7CebaprmpRf1nHtnTOqTVu/wAPIxu/lL9XZjN4PQ75ac0mPwpxkvOL9hz4neLE/OCOhcz1u828bk8bzqmoK/y5n7TdS19ORptzcXlqSXDO/wDiNvz18EeTy4/tXt+37GJIEQ8TjrrdSMk/b7Ud/uY/bx2YxE33QpV1ZL7eKX1Ii9r5Ez/nE172ePJO5RRs7foBy/rl1Zy6a9bLHHlFHR8HSq0OsdFTU66L515P+8sdbzBNaN4dPcazpEkt/C/zY5L6jI/3nFfG2EnG7jkRivTZKO/2/pxNr6j1vYb1jPrY5Pd9fjfzGcIcjXkSHs14zWdVV7TskjRwa4Pc/Yb7qf8ARz8HH2mO4NY+7+ByZf8ALyXj4owGXzu/Nnd1Hlgf0EcO47ubIvpM7N2+LBtX2p+4f/Geca9spWrQzVr3oUlRoTa5r4ovzikyKSrn6phGfFVhln3fEmdQl3WksP3EVHWIu9/mrwigh8tmk7bZZM36Xrs8PhaInpnkSdLl/aR8JtfWJkX9xIw5PF/gTtWYdLf9v/5M3aNB0h/oyX0n9ZvTsy9PJy+py0LYCNg3XdN6n5xXsRjuWrdGSdfj/dQf0f8AsY1LU8fLH969bDwYuN8yNkrImLRoiixSk1YCllRJzdbGV4X2mjNr0+/hSXidXB4r5OXm7NixR2IdbgBq+p/0k/cbM1+//pcnYZ59l492AFllBGlWNHmISR5ivYRs1yJIkUeRLE5L3deKZDIVDE1qYAAzVKkRKiJEiAJUWUizMGi6ku0yCPyox5G7x8l2Ijkm5FRMza7J/q4X9I1TNltNJY/CRrwb/wCzHX5hcvgr2D0XYhB18sexewT1PQy8deRj4f8AJQABrKBZQgsosoo1MUcQgKKGKFYClFgTomIgACeiCiwJBChyhmQCwK0W1FFgIbUAACgAASQAAKsMoAAgBkKOjQjllFgWlgADIAAADAAAAAAM1gAAhYAAAAADAAAKBwACgAACCAAAzWAAIqsAAstAAAkwAAUkoABQWIxxGIq52Y31xXtE/LIn9RksjS9Tjx7LOvJJ/gXex4XrGAeICrkuwY8zLu9THsAADLYAAAGYAAg1AADAFLFGo4FASsCssoYRABQ0Ugg7EGwyiJkMiZkMjWJdG2feR3ZFak/Wjg2+jRsZfK14GV7zzdOHhZts5cez278o1+B2w5o1XS3xbDC2mvm9ptY0eth4Xk8vTO+bAt7FRzbmNatpnbi/lw81Ei6kl/m5l5ovC7gua0PK9x0tj1fb3pHSWUWcDuTQN10p8HVdq/tRkv4GlgbDZz+H1HZS+m0T3/wb1P8A+/aAer7WBhe7np0OhEOVUsC/ecf0tlLylMwHaT4d1tJU9MiR6R+743sdvLyzV+J5lglw5cT/AN2P1s9L2HfD11mw9x1wxv0ei+r7WMgn88u0D3K8Sd64t+r2eZeCMZwPumXblXtc/wBxmIYH3E0c+d7xriwneJLdZI+vMdzU9jBrVwnX1jdRi473I2vykGJVscnhNMWGvh179m2XZzstMhlK2uweLHjOiLvGdersiW3xNR82QxZ0Y6+Njb5J2TREm6aeV+FL8B8fKjlyvjyTl9I7cTT4X5l49J53/CM/RlvR1/bau++/cS5tNw35nL0R3gnG+U2dWf8Ank8veFj2rJejP9Oa+l/3MjRjHRXpmXk79pk6NvSX6RzzvVgADJhf7h/qMNesDF5Iy79wRXxMDvmv+xibp8meLyb+Veph/OfdxyIWTSIWEoqNijsQvZgAAqJBttj8su01Jttj8su07Pb7+Tm5vC2IpbKO2x5uys4N6r22TsO9nDvb/wAbL2GOXZpi8+AFyAXXTemGXMQZCqY2EOR1ROPHyOqJzZOrF0IcREiMWyiywMzOiVERIhBKAAKmFzN7i+VdiNF6m9x/KuxE560EjZ27bnHtOFndtuce1GfFf9zHzPk8NezR+SH3V7BHzHh/Lh91CnsZ+KvGxvTXmoAAFbAoxVDUoosBU1CsYpiP1IKOLRJaUAAHX6HpiIABD0AAASFCgBoZQLAUMoFgBFAsCjUAAZmAAAJQAAAwAAiOhxESGqVAACIAAFEsAADAAABZYAUAAAAAAABYABekqAAGZwACSAAAJWAAIbAFAaKWAACFgUAAAACWoAAtnUEzW7uHxNvmj5wl9WpspnNJXfin9aoo53eTxenJ6aDIZrh4oy+1L2i6eh5XJ4r5vUx7GAoCItdhYoCM5YoEgwAAgoAAFQAUFiUsphZTYEjKLKZTOomIxmRsqIyKyKRIRSNYhJi+ZG3bj3b7DSw5m3ai4x9Tnz77dPH4WT9EnxbRr7M5I3aRj/RKWLcR8poyBNns4+GPL9x42IdWjw71uquGn4EG2lP4cbWnqbDq6/W27q+KDNdt7p+Vs873M6u/2tdhZQHmV6CeJ1QfDm2kvLLH2nGmd0JYo4oTySUVHMtX2hj3nnBk9dk9X2kY0vTxS9ghy3vWNHHFSipPht0bZbbA/wDm32NGP7hLhjfpJGy2U4vbQ8ZM6uLjmc3dsORj37x22P8A/Hc4Sd482N6vxpnjeNpJPylH/wBx7b+5ofE6HvdLacJf8R4VFxjhajztO/fZ28GEwz6b8U/8o5N/9M+71T1f/i/qASLtRfnCHsHPXeR60uRXhyr6EjCsGq95mz+SfjFmEYNLRz59zjF+prh3cvFaHJgfFt80fM2PV0v8hN6d1Gt2z1lG1y0Ixm8dbb7a5RHQ0tGxTSIqdMbjohLGpKjZYtFFGsR34nqipL+WWcZZ0jlm7Udu50zR7DX9Gf8APXijZbr+ZB+BHMyxvdt+jv8AVzdhliMS6M/1ci8DLFZ14z9cfJj6mAAKNin7gTf+N7/YjD0279NTM/3Ffw9vXpJ+wwxnjcvjvm9Pi/lj93PI55E0znkYnSMQcUZAAAuEtG22S+Y1Jtdj+c7Pb+L7MObwtmygZR2PL2VnNuv6bIvos6Tl3X9Pk+6Rl2bY93nkuRGWtUBPo2yMWKWNOndj5HXE5cfI6onHl3dWHZMh0RokM60OWiiyNLSIkREiVGYOBRZNgOkbfG+6uw1KNrj+VGXJ6KdCO7b1ce04jt2/OPajbj/ph5jk8NeyYv5WP7qArF/Kx/dRZ6ufirx8OwAAEoAACMpRZQEtiDsUgylDFFAoABC2IAAGXV3qAALBALKKCgACT2oAANEoAAFAoAA5QAAIgAAIAAAAdEhEiU0SAAAIAAFwLAAAKLKLKIwABOyAAAGsAAAAABkCyiy4SwAA0FAAFEYAAglAAGiwAACbAAAIwAAUAAACEMjnejXadEiCQi9XmG/j8LeZovRKbvws5L8Db9Zjw77I3/zFFo0yOLmmsnp8XXFYABzNFgAEmsAARrsoABcUAAUYKABaCwABEURjCMUZo2IxmRM2iQyJjNkbLQeHM2S0xpmrTo2WPXGiM2vHWR9F0e5jd2oy+syVGK9GkluMsbXex+wyeOh6XDb8I4fceJour6PBP0SrsNPt38y8Td9bXFhw/ep9lGiwNfEyV60cXu++23tXdYWUB5r1ki1Obqai+nZNV3M2OWv3joiS/Cx59vuMc4uafC65epGPSy/inXsGN8WLFLzxY39RepDtXe2wUtPhwVe4n4qOPPfyy/O6zvdybq+BfeNht4zhiioOlzNfupfo/wDlE6pRcttpNRVHpe3/AJ3fTr90cno5+tQm+i9Q11+Gmr8GeDw72KV6cqPcvh5V0nqEcjbTwtxvws8Lh8ir0R14eO4/+t258v436WvTsDg8OB+eOD+o6Dh2uu227b/5aR3HqV43rRVp/dZguH+ZNeivUzuOsvczBVJQy5PvNfWYcvoN6dEowy6TipLxNbk6bgVvFcPebOMkyRo5/jrt0a/Jg256fmxLiUXNVrJGm4qdWl2nqGq5HLn2W13S/Uxq/tJVRruy67nuerA8keHh8URmUbno88ij8KS7unkaDLtc2B1OLD5Sl3QxNhj9Ga9Jmxw/KjWWflOTJOjWp7h8uRt91/Mx9hqOk65ci+ijb7td7GyOX0Y4dd9Gy6O/7iX3TMUzCujv+6kvoMzM68fBGJwACzYz+4dMGF/Ta+pGFPzM4/cGu1w/fMJuLXl2ng8vTPLzepxfzn3ckiBk8iBkxaMUYUpkosUABzabHnLsRqUbXYc59h1+38Tn5vBW0KG8AZ6Tyto2ce6/p8v3TrZBljxYsi80Z5eFvPR5tHRakhuP8DC+cpC/4GHzl+Jnvove603FFc2huOD5am4jstrG+7faD22Cu7GhbmjjnxfKjpiQqPDoieJyW9XZilQ6I0OmRWujjkY5nYDIkRGiRC0ZwAAsM6Nvi+VGmNzi+VGWS3SdmD5o/eRxHbg5x7URw/0x808nhezYv5UPuoYXF/Jx/dQx7fL4nlY9vvSgAEgAAAFAAAAUWAtAhRZQgUAAAw8AAyr0gUWUPYUAAQZALAoaKBYD2CgAAYAAEAAASdUAAaAAAEEYkRGiRAlYABoQAAGRgABhQAAwYAAkgAAUFgACMAADRsAADMAAGhmAUsgjAAFJBRZQoAAAMKKLKGFgUUUDCi8aE49QIzIZExBMEsI/cCrcYZ/ahX4GNmV/uCC4MGR8k3ExFvy5HB7jvHo8V3iuyrI7KXMxabdBZcYTku7CUjpe13GOClkx8CfJtr2E66qljmAAJ0oAACXKUCgGRgFAGhyigEgrImSMjY4kjI2OxCmdRsRkjEZrMkA2WH+X7zWo2OH5TPJpg2fStOoNcrx0vEzOjB9jL++278pST8VRnD0bPT9vd8cc3uu8ajrEf7Jy+zOJjeFpZWl6xRlXVFxbDL2x9piOKVblrncPcc3u4ftWyLELs8d7SSJJNtbTeuLp/BbVOna8vxIo8mdOKCzRy42648co/iMV6R0ScsnSOnzbtvBFyfmzbmj6Fj+B0rbYk3JY042+fM3Zz8urnbPW7ZWObd18L3o2O04cmLh0fmjWbr+nfhKJN0xvin40dvtvDfNHJ6Nvlxx/xN1HzwZFX/iz5uh6rzT08qZ9KY38SOaL9YZF9R82QTU5pr7a/Bs2x8W/piw/+PL616FsK/wdq1y4K/A2BqOmv+w29O/m9qNstT2fx9niZeLLz0YxfddNyKU542nFu69VZlACyw2XZ56+PG6fFB+T0OiGetHqZplwYs6rJFP2mjz9H/8Agm7+y+X4nPcKrbijkjL1JDWTw58DrJBx9n4hDO0vMz+xRtYsbSd2k0ckM0WtdCa7Repe3Ve3Dn6Xt8qk4/pyfkav/wDK3OGNxXxY+a0f4GSqzrxyrmHx+P1Pc0xvpVx3c07XcrU3m71UGdrUL4klfYcW85QI5MtyXrCmrt1dIf8Ad+4zUwnpX9WvGLM2R2Yfzxc17mAAN0Vj3X3/AGkP9RGESdp3z4mZ1+4P6CP+ojAn6ni801nZ93qcPgjnkQSOiRzyObbRCyimyiwsBSy0LRtNj80uw1fobTY85G/tvFXNzeGtsUWUek8ywpDl+RkxDk+Ripxj4rLYphpdpRZchhJ8hWD8OP8A7kiIyRHPl3elilRIRokM6owyFGJUZEiIkSIg0g6I0SIFU6Npi+VGrRtMPyIypxOdmDnH70TjOzBzh96Jrwf0x808nhr2vHH9HH91AOm1ixr6Ih6fJd5V5OHb70oABKgAAAAAAjUAAAKBZRIIAAIMOAAE9EAUAqpQFgLaSAMA9KIAAGgAACSKAAMwAAPRqKLKCBYAAgsdEY6LJKAANAAAKIAACCwABgAACJYABRgAAYWAAJIAAGagACwsAAVQYAAgAAAcWoCgL2lYFALZbKyOT0JGRy5DJyXqOmQN6lcTf5WINhEjmPD5RJllYxnr0HPYNrnGSaMHfyxpeiPR+pw4tlnSVurXajzdPl2HL7nWsXb7ftUTIoksiGBz4tcnasmSqtrsLdSVPifa7EXIYzu/I52gGFAitYbUoAJaaWAoDGwAABrKKASVMiZKyJlQkTFGYpSapkbJGRsqMCndhehrm6O7AGXZth3bLavh3eJ/7iM6fzS7Tzvi4MkJeU4e09C/O2dvtfCx93Ojl3S49pnjX5TC8f8AMg/AzvLriyp+sGYHi04H2on3M6M/ad2xj5D0IOjyPk9s8TrwupvxRyInwv8AUXvJ0WnoH7eyvJ093zjkkvrMgTMW/bTvZ5o+WT2mUnLyTeX2RUOdcWNrsI8Lnivh9TrKquRrjzXj8P8AoeokxZc1ul6S9h8/riU8iapqeRe6z6Fxc/qPA86Ud1mj5ZMntNuDkueer3+LHPH/AG8mV9IfFsMf0Zzj9Zuo8jSdG02T+jmkvxN2j6O+nlP9HhZeLLzMhhUMaxhVAAAS5KM1UkpLxNVn6Vjy645cD8qtG1JEZZYS+h7YNm2G4wc4uS80c8Zzi+fuPRtOGjW7jpe23CvWEvomH/XZ2PbGIZ4vR8ztxyi/U58/S91g1S+JHw5o1tyj6tPyMpZ12voyK619Dm3f8tHJi3ckkpak24ywni05+RWXSbDq6b/V4vuUZujBOnv+7weJnR1cfXjjmy3vscYUs0sKNF1/XYR/1I+08+d+jo9B67r0/syR9p53xXpR5HN/S/Z6fB/OI5HPInkQSOeNkDFGYpbMFiljJKjZ7J02ak2ewesuxHT7efuw5fC3AAB6byykOX+WyYhy/wAuRjVtAyMk9CMmnsokuQ4k+QUerjXiSIjfMdHHn3ejhUo6Ix0ZrSAKWRpUSIlREiVEmYkIxwM6epuMP8uzSLmbrD/LMs+wSx5Gw23zw+8jWGz2SvNh++i/b/0x/wDbH/VXL4Xtr+SH3UIPLlHsQh6WWP7Xq8Tj7EKLKLk01MAAQFAAASgAAMjKGFGZQLKEbDwGFMHftRQwD2rZQLAegUAAnYIBYD+RkAAEAAAAAAABQAAzAAAiA6EHRpCSAADQsAADWAACQAAUAAAAWAAAUAAMzAAAQAABIAANBFAUBIMAAIlAAFiLKAAUAABAoAA0K4IeQUiwGZWRSJmQsaa488eLFlj5wZ5Tz9Kq1+B65VyPKcsXHNkjpcZyT/Ey5v5un217oWi8WFzTUU2KySGXPCM8cHFKVa+qrxPOl0685tK8fwlwu0/WxAeSU9Zu2URd7qp2iwKKCtYYAANDagAAEoAosQAAAKIxGMKwhVCygYpujKKKYFAypDtwa2cR07V/qJeYr2qsL1iefnfKUX+DPQ1yi/ox9h53m1g+HR2j0HDLixY7d9yOp1+0v61Pu+0TTqWOaavuvT3HnkG4yj2s9DWuno7PPsi4XJvmsr9oe58McvtrrLTapPhQxS5UB4nrXvzsv0JcX8yHgRLUlx2pRrzAmbftp/pbqPlkXsMuRhf7dbW430G/sSX/AHMzRhn369OkZ0xZQxFEqTG6ku1HhvUUo9U3av8A50vae4R+Zdp4l1qCj1fdqK/5vtRt7f8At/8AzUZ+Gt50Z8W1yx+zm/gb0xnoLuG8Xlkh7DJEfVzpjj5R85yeLLzpyQjHHGawACiMOhByiMhhUMZ5QzKTRyZtrg3CqUFfmuZ0jRMrhL6DemKbjo+WGuF8a8uTNLkjPG+GacX4npVtciDJgw501lgpe0xz4quVifT/AOqwdhnRjsOmLDuIZMeR0vymQp6HXhPjjJ+GOWMWWKMaFGl63p0//wDyRPPG36nonXFfT39+J52zxvc9OR6XB/OfdDI55E8zmZzxuURjCsqJUAAPaTehs9hT4vCjWG06dX6mnodPtfHv8Sufm8LbgAHp15ZSDPxLFJr0JyHL/LkZVTQNSdaIRjPia0JJ4+BRtNWvUj5KvXSEimrRMRT0RnV41r/UdCeo6Mcu7uxTIdCIdGFanLKLEZkTIhRKiKDFootCUdG7x/y0aWC7yN1HSNEZdlGNtsFe4wr6cTUG66Yr3eDxmjf239J5o5emFezz/L2IiJcnP3ER35eKvInZRRZQKWAAIigACMAAAahRhRkUosAUxAUsDmegoCwNAUAAjZlAsoNlpRRZQGoAAaygAAQAAEAAAAAAAlWAdCDoaDgAGiFgADJYAAKAABSQAAAWAAIAAAsLAAFKhQAA4ABQFnAAASpYAAaZgoCijWAABwAADSBRhQCwKACUyNjMjAIJOnZ5z1DF8Pebj0TlxV2no8zA+uR4d6pclOCMs/51rw+NoGVqP6lHnbeneqixSwNZZRZKtmAABJQAoRmAAA1gAEtCMRjsRjZ1CUMKaM6RijMous7ETJ9vpkj4ETJcT7yC9jx7uvJya8GZzsJKey20l6wd9qZhEv4My7pbf+DhXlxHR7a3rB7mfo2sdJGB7tVm3CqqmqM9j4mE76lut0n6U0b+58Dg4PGla4lGvJalxTS11CD7qfpXMa/wPBvd9Dj1iRDw+ZdpFZdpagpmHQJVv90vOEfwTM2ujA+h6dSyfSw/9jPDn5vFPIqkAosz0g0eaPHf3JHg6xua0ucJfUewrQ8g/cyvrO4jJ8NxhL6jfg/rPKlfBl5JuhKnvV445GTGKdDd5Nz/AKcaMqXJH1ONtxw8o+c5fFTjIjHRqxSAAAlZIiMkQEcBSxgxZQBoJSxUMKg5aKAWgkLFLKJp+uf+nz/1I+089PQeu/8Ap86+2vaed2eJ7j+l+z0fbfz+9JOjkkdEjmZi3RiDClIWAAXszm06dV5b8kas2fT/APme46/aeP7Vx8/gv2bkQYVnpV5yiDN8kkVjyTn80XETcS4YSfkY5dl4tNfnpqjrzyfDDsOSXp2nZnXdx9hlr9afeuMiyfKyZohyfKyNrjWEkSNEiOfPxO7FMAAZVcSFWBRWK0qJUQolROUCQZCoZGI0nh8yNqjVQ+ZG1QqEhkHSI8W7wfeMeRk3RNd7g+8dHsv6yfUuXwXyes5PmIyTJ8xEdjyJ2WBQDWsAAQUAAAUAAAKUWUBlAAAMPAsDHT0SgWUUFAAGZqKLAQKUMAwQAAsygMAjUAAQAAAMbKAAA2BkKMhipAADRmsAAoLAAElYAAjAAA0AAAFLAAGFAADJZQABqAAKgWAAAqgABs1FFijM4ClWC9nAjsuwQuxbFsWxhJYWJZVgRxQLKCCRhP7hxd/bT170XG+wzV8zFuvx4tpidN8M67LFe1VxXWcYaULFUqGPIs1ler11AAAkwAALWAASIAABAFilguVZQABlYrLZQ01ExB2IVGVAABoyqJhi+ZAwx/MgXi2Ldp6ehlPRJN7OpatTlqYtKKl2UZD0Rtx3UVooZI1b80b+065X7nzzfHWQoxDqi/uM3ikzLaMY6xFLdfex0dHP1wefw9M3PhaeKJIQbddxWdDPBy8Ve/h4YodCDpkNWUdGl/8A08enz46X4GfannPTJ8PVNlf2WmvcejmPL0uN802HAAM9p0s8t/dSi+q8vmxQ5+B6ijzL92qMd9ilfPFE14rrmwT/AMa1/QpRWbNDn+knfvMsXJGH9Gkv8yUEmv0Ja+Zl0eSPquOfpjfp/wDdfM8vjqQsos2ZSmsLKLAkiGQiHQwcsUYpKwAAI6HQg4gYCgJCREhCiQmhput69Pnf/wAkfaeepUj0Prf/AKfP/Uj7TzuejPJ9x/Wz6R6fB4EMjmkdDOeRk0qIRjMjZWlLsYiLQkJjadOr9Sn6o1ZtunLTJ2o7Pa+O+Tn5/BW1AAPTry4pnFuX+lL3HYzi3ELg+8l2meWtLxal+nI7dxqsdeRwQjBTSUl2HZvZcHDXkZXXx+6u2UQNaEE/kk/Ii+M2cmXLkqlyfoZ5HN41ESIiVtWx0c1ejj2idDkaJUZmoZAMJZhkKMRTSoYRDkHE2H+Yjbmpw/OjbLkZZK9TpamWdAjL/wDRxr0q1+BiSu0Zt+2VxdQbf5YHZ7L+vlLXL7jwV6RLmIPIQ7fR507KAAGpYABJgAARAUYUDKAAAUAASGHgAGe7+HogoAAygAEjSgAACgBihowBQAYKLKGQAAJsAKLKGoCjCgQGFGNAYkIyQpIAABIAAESwAAMAAAjQAAGYAAAACgsE3SwFAZyrKKsUqGawsSxZSBO0vEHEcvGU5FQnVxCuRzJsinljHnJL3gWq6+IrjNVPfYIunI5ZdTxpaJsW42+FvZvPiF8dmKvqcpfLGK7WcuTqE672VrwirH/2YT1H/VkzKUq9Ucs9zjhdyXuMJnvFL1m/Kzklnm3o0u1GV5sYucVZxLqm3VpNv3HTttzHcw448ro87+JltNu+wyjoeTihmh5NSFOeZXUlF4ulrLIgyKJIzojGoWaXq0ePp+f6LU/wZupGv3UePb54+cJewL2Tj4pXmy5CsqN0vwBnlZeKx686woxRQj0cAADMAASagAACiygFFRYAAjDI2OIyoURsQdiFRlSlFlGjOlYIGCAmzi/04m86Fa/ylKtZQlp4WaGGuNe83PRHWbMn6xTX4le28daZ3/byZVzMb6zFPLifO46GReZj/WKX+M6+0n9R6HL4Hk4eNqtu38PXzZ0nJt33ZfeOs+f5PHX0fH4YAABNG62TrqWyt+tX7j0/1PJ9vpudjN6tZFfpzaPVpOpMz5pJMNXe7fsZwFLOeIp1yPNv3hGL3u14lo8XsZ6RdHnH7wt5tk/9uS/A147vlx/JfnyrQ9Hk477HxfmxZDNIfKjCOkf1+3v7E19Rm0D6jj/lh5PnOfxJAADaVzWGHQg6BKxhC0WaVMsUtEpOAAUDokIkSCCwAABrJUzlciaMhE0/XP6B/fiefc77T0Hrumwrzmvajz2WjPH9x/XL7PT4P5z7oZHNI6ZHNI52yJkTJWRs2iFDIQdCJIbvpv8AKk/pGkRt9jNRx1wydyfI7Pa98vJye47NuUQ8U3+V+8vU69OEPma3qL4cB2uD9WzW7+H6VW7sfJ2GHiajZJSzQd6UjadUgk46u69DR4oyxsny5HPm2yLqyfRre7lFbCTohUrZNVNVOWhUOjkrux7JkSIjRIjJRhkKWiNKOMKMBJEORoclTqwK5G0T095rdt8zNijDLuqdTL5keg/teC/yczS5RWp5/H5kelftZaZ59i9p3+zn75X8Yub3N1h/hmchB5CHb6POgAABQAAEQAAJNQAAjUxRhSQoAACYgAwGMyr0CAWBe1kAsok1AAAnaigKBSgLACUAAM6oAAkwAAIKAAAlAAFSmskRGOgI4ABogAAAQAAA1gAAQAAGSgAoAooCik2GsuyNsTiAHbFbEshlNR5smHO6Xis4s+6x4V3pK/L1NNu+ppRcca1vmYy80pyuV2Xllji0x4/kyiXV8adRg348jin1TNL5eGP/AF5mmuTRaObLn69I6Jxu7JvM8+eSSXgzmeWUucm/eyN6imV5cr6tJhDW6ElyBkZFzt9aegUAE7ChGOLoSarZvui5H/kZYfQRokr9TZdKnwb/AB+Uk0zfj8RXtWfxJBBz0Y87LuiZClbafrGS/Enkc75opG3l0lwSlD1jKSf4iNGx6jH4O63Kr81/ia2zzeXpyX6vUw64xQABk0MAAIlgAEGAABqUAABrAAEpQjHEY01GUWBcZ1GxCRiFxNRSERJIjXMuG2mL5DbdKf8AeTS5PFf4Gnw/KbTpcuHf4l9qDQuK/wC6rLrx1l0bd+Rpusr9PA1zUn7DeJGq6uv7WPhNHq5+B5OHTk+7Hdv8sl4nVZx4H3p+DOlHz/J4q+gwn6w4wg6MGruwtqe1l5ZY3+J6zI8iuo439nJD2nrTldeKT+oz5e2PqDjCJjGd6QlmBfu+Omzlyl3kjPDBf3h/J2UvKc0PC/7uHmO2/JiXSJJdQ26f0/YZtFmDdM03+2b+3JL8DOV/E+p4v54zzfOe48aUsSyzVzU46IxkNJwAC0nLKLA0hYpYyOOiMkQJWLLkMLLkRVOVs7cGqOF6I7sHy2RPUNP1/wDoV/qL+BgM+Zn3X/6OK/3EYBLmeV7j+t8o9Dg/n/lzyIGTyOeRhtqRkTJGRlEUdCDlBLXcZv8AYqPwF4mPXUJeCsyLpsXPaxaXqzv9rj1yv4ji9y6ihpKnQh3vPBqeoNcEfNyNrZoeqTUfh2Ycmrra8J1a0jYiyJ+pKpIy1W+rO7iyaHJiffNy4wnzOZ7VYm5XzJvSKxnVaGRGpReiZIc9dWJkTIhRMiK2MWUMSa0MUOKgyJERokRmHbt13juOLbNcXJs7dPQxyi8UkOZ6n+2Y/wBrln5yo8sx/Meu/t2PD03tkz0/Zzpnfo4feX9Z5xvygLN8nF61QAA5QAABnAAAZrKyi2UUAAAQFFFlE7DEgLAyj0SAWUMygWAhsgFgMtFAsAMgFlCJQAAKKAABrAAElQAAzAAAjAyFGRqk4ABaVgUBJKKAAACygGD2AoCJYoCNjgOVZFYjloBnkyFyOaeZY9Z6Ix3d9TvijjvtLvQv29I3O53uPAm7TfkYtuN3lzv5tPLyOKUpTfe1FObPl9I6seH8j1GFGMK11owAGgWHCociuiWF5LqMn7h/FNpW0RuzYx2G5yco12nXDpOR2pziuwqYX8Jucnq0IJMWeKbyShKSjTa0fMieLht8Um14k3FW+m0veXLU6se23WX5cE32ql9ZvuiqLwuVJvk71Mji2a4ccyZZcjDF0PfTafdxxs22DonwcmPJPK3KDvT1MjVj8zonHjJ2Y/8AbabQsos1nRl3RyIHzJ5EEgJgnXLXUJKu7KCkaIyjr8Vx4Mn2ouH4GMNHFzz9tvR4b+kRgAGDYxIRjiM5ZGOQShRmKIwAAMKAAE0BQCjKkYg7ELZ1TEJGRsuMqUjHKNDd2D5Ze42Gwv8AzsD7TVYbO3by+Hu8D1+dL8RcU1yN+/HWfq+Jo1XVv6SX0ZRZtPzvtZw9SjxbPLzdU3+J6uXgrxd/vPNiWD+ZL7qOxcjixP8AUT84nb60fPc1/avoOLfxih0IOjJsmk38F16TjZ63Bp4sb84R9iPJXpgl2x9p6vt3e3wv/bj7Dl5OynQuRYpZlP8Awk5hn7uhxbLba1+qzMjEf3Wm9hgfllNJv542f/6hX1YBsXKO72tOv1dfwM+Xr2nn+003W2b/APlij0HlKXafU8PXixv1r533Pj2sZCjI2chyxSxlTAAFQjlijFA4wgyAHHQgyAkpT1BFkk4p45Qt80dO3kqokI3BcfEtCoGs6+62kfvfwPPnqZ115/2+H/U/gYG+bPE5v65+b0eD+c+6GRzyJpHOzLTcoABSCgABKRZyrHk+6ztwdQUNnjioZXNaVFaS95wZIOUHRkuxXw9tCPLTU9P2nbL7ODn9EuB5HhTyR4J38t20u0mskZGdndxUGL9alrjRk9GJdZd5ox8ooxz9PNtxTeU00sZk8ctHFZdhlXbcK3UXFqyPNluFWaiUnTVtdh14dphlBSluuD6LVsxyk0zk0i27vK7NnRB8DFikuDJ8Rv1O6O3xVbyy7Dlysk23wQIctwgvldgRvbUyJERkiMtA4wowlxaJERokQFXft7SZ1JkGL5SdGOXdeHZ0Y+Z7L0iHB07D9JWeOYj27YR4NjgVflPT9r/LPzeb7u9cZ9XUBQHQ5gAAZqiwACzAABNTFAACWQAAg1AAAliIFgJ6IEHEBSgACbCUACkhYAA9jagABAoAAoooAAAAAAagABhQAAgCygHCOAAXELAAGSgABmbQQsRgVNYWR2I5UCdJrIpSI5TRwZs8cerdFI07ZSpeRpNz1KGFVDvy9TUbzqU8lwjovA093RNzxxn1dOPGmzbnJufncvxIkqRfMujkz5Lk6sZqF1oBi9DHatlHirpU236JWd2DZZty013YJ6t/wMrwbbFt13Vr5vma443bHLNj2DpM5rinNxXkbGHS8C+ZyfvN1wl8J2zH6OS8t9HFHabeHLGrJ+FLRUuxE3CU0aTFnc7XNw9o3CiQostsF3sfh7vKl6SX1nLNXGS/A2nXIyjnjJaucE37jWJaHDzeLb0ePwt70J93Lj9V3vrMrRhnRsnDupR9JqmZqq5GnDfrtly4pBxBjqclWAAMbUznkdDIJCSxfrkb2uOVfJMw+fdrxM/6rj+Jsc6q6Sf1nn/5Y35HL7ifrHf7fLpopYAcbrgGFGJMAACCwABAAADCgABqKAAJKMosC4ViNiDsQuMSkfqSETCUnZglzROv5uN+U4tficmHR2dUny8Gn9ZOOWuSOnHrL5PRW1dnLu7ls86i0m4+vaT2pKDXJxj9aI8sbw5V9Bnr3rg8XLx2fVguG/jQv7JsV69prsX83H4o2KPD5/E+g4r+qyygOdrt1RSeOd+R6dspcWz27/24nl0dceTsPS+nO9ht/ukckk4+v5imyLFGOcGsxn9z/wDpkX5ZUZIY1+5f/S34ZUKdcsf/AGgvZ5phl+pt29KzQf1nosn33oebRk4vHX/yR9qPSpfMz6vgu+KdPWvnfc94AADZxmQ4iHGmmAoscBwACgcsosaUhaKLQA4woyAGAAAMY/cD/R2/jJv6jC3VMzP9xfJt194ws8Xl8Wd+r1OHpx4oGc8jpkc0jGNKjAoC4UMAAOIVJ1BmUbfTDDxijEczrG/cZjitYoL6KPT4J+rh9x3g4mOUWdFcKrMN6q+Ld+HCjMPUw3qbvdS8bObPp1dXt5+zTOiMeiipq/l6dLLUSM5IloZRS1IsY5YmwSlLJ2GzabfM122/mSdGxvUwz6+uz4+6ZFlJlmDRY4gwrAkQ6EQyEo5a5lFVbRMvdVbjGmkidakadJDxZy9bTnZ2YF+HEl+J7lgXBt8UfKCPE9pHizYl6OaPcZKqXgj2+DWPB515XuOvJj9CgAC0woAoDRW1gUBAWAAAKAAI1AACNQAABiQAUzF6QFLKKCgAAChRgM9DagKArR6BQFCJRRZQzAAAjAAAgoAAEqAABRSygBNPZdillwjALYWUlYCi2AXYnERuRC8i8yyTN6EEppK2ziz7vHjWskjGNxvp5ZNRen8BdIuY2tvuuoqK4YauvwMdyZZ5FrK/PU5lfEy0tTPk5L6dG2HHoxYFnNerXsYvtFXFao3G26bkztOa4YfWyPiVvRrcMJZ5cOLXz8kZPtelwxq8juX1Gzw7fFgVQjR0cJ04cPrty5ZF4UuQyQ9BRtj0R3UBZRbPShCUUcpIQGKLlJj/AFnGpYsc/VOjGIsyfqv/AC4vWLb0NQoR105HJz+jv4ukc+3yvDusUq7qkm3XIyx9X2/GoxhJ29X5WYpVZl2HRK6bXMxxz+E6NcurPvFcnqWc23yfEwYpfRp+46D0cPDHDfU4AA0KZBInZBIbOuPPDjw5ovXixyVe48yV8K/65Hqla+48wyx4J5I+U5L6zn5/B946fbXrYgAAOJ6UWAAQDIAAg1gAAFgKAwAAoSlCgxRigAApnSMQdkdlSslEbJCKRW2fqmxMnyuoSXgcuLSSJs2qkxanyjt4+1ei4pXhxNeuOPsGbuE/us59rJS2uB/7a+o6lWq8Gev/AMPs8bP+l82AXUoeEmjZPmjWzXDJL/ckjYVSs8Tl717fB0wMFilnM6NuiOuPJ2Ho/SpN9P2/Y0ec4VFqdq9GZ90SSl0/HXpKRHJ/O+cU3tjkIyOYJTHf3GuLpGZ+WSPtN/xGi/cL/wD5G47Yv6xTvPM72ryvFXdf+5F/8SPSL1l/4+w8zSaimlqnCv8A/Y9I14u1R/8Aaj6n2/XD7vnvc90oFFnQ4DIcQYCWOIMXAsCixhIi7FRYySpjkSHJoSFiFjQlLI7LTDSmMfuGX9OvTX2GHNGWfuB97CtdF6e4xCUjxOW/tl/7PV4v54oJHPJksmQMz0qgBCi5AexiKxzTSEWe/wBNLW5IzKL7iXgYi4p8F+kjLz0uDwvO9x3hQFKtHQ5DmC9Rle5kvIzN5Yxfq+ZgOaUcmXLP6RzZu/2veoddRQAT0dCxnLu0LQUK1GTq2q0bOx6anLhVROm2cmd6sceiREiIkSIzWay7KoKCqSodCokI2sxa5ootc0BtwrpDIVckMuZzqnhZH0aHHvcEfpHsc+Z5V+3MfH1KD9IxbPUXzPW4/wCGH1trx+b+uvwsAAplFFAUUrSwABFswABAhSiyhqAAAGUosogmKAACeipijMUjZyAAAkygUA9moAAexsoAAAAACCgAAIoAAGCgADKAAIFAoBkay7IizRJrKsQqykpGyJtkTnXqcW43ccKuxHHTLJw3rVGh3fUErUGm2azcb55nSbjfrzNZfd7GLPk+M7b8muOKTJOWV3JiKkKi0c1tt3XTMQMUWk3yIvULaOjDt8mdqMU/F+Rttn05yjxZpNJ6pGTY8eLHFLGqKxl2xuTX7XYQwq5JOTNrGLQw50zD4ue5KLLA1nRneoACxhQFlCJQowpZUrFHYg0tP1SN48cvsyMfvXt1Ml6lG9s+1GNr0OPm6Tbs4e1c7dZIvzOxHJkXC4PxOn0OOOllPTJce3r7Lo2ZjvSJ088H+amvrMhPQ4stxx8nSmAAN4wUxGOxBxNQPRnnnUo/D3mVeb4l7z0OZg3W1W9g/SWMnkm8K39v4mjEHEPPj0rTIspFkURYFFkqoKAAKAAAZgAKIMgFlFEBRhChVMjJGRsuMCsiZIyNjLSTH8yOzIu5LsOOHNHbL2oWXeN8PwzPYS49lgl4NfgbGOkkafpD4thiXlKS+s2y5/getj1weTydOXJgee1kl4TftO/RHHurW4zWvlkTrkeLz+J6/t/CcCgOR2uzD83uZmv7e/8AT0vKcjBsT767JGa/t3+jn/qMWeO+PL7f/QZOWIBy9gY0vX9ek7n/AMOfabo1fWVfSt39z+Ib1rzhTv8A5eSvTG+1Hovk/ox9iPNOJyxvWuT08D0q9Ifci/qPpvbdOP7vC934zjCjHXtwGAAERhiIZFhIMKWBGQ4g4UzFlFiiEiGFQxUEAy5ilrmAYj+4ZfrYV9ExKZlH7g/qsfkofWYvM8PLXzy83q4fyw8nNIhZNIhYGURjiM0gUiVESJUFStfPBfSRlN61RjeFN7nG/GzJ3zs9Ti8Dzvcz9oQWiQo1rjRtUm/BnnM/5uT7zPQ8z4cc34M82tuTl4mHX5d3p+0niqQUGUJ3pEXNdyyo8zpauNCy0zyPi/lnQiHHpElRyWbrNKiREaHRnYcOMRjIlSZDiIcSodE+L5jnR04vmIyU70PHmIh48zHvdBn/AO1sb/yMs/RQr8T0F8zDv2rD9LNN+ui9xmJ7vbj459HiZf0z8wAAZUgAFCWYCgAAAAAAAoDBQAI9FsqwKA2MAAGVd6gACZT2QAADIBYCPZQABggABewsAAgigAFaCgABWGAAABAACQQVjCSAEbK4hJPRnPxKnLyNYl0SmRPJ4pI0ebqePWo3Wl2aTPvpZW4LRDt0Jhla3O46go3GLTXK+ZjuXI8nOV1yIWlL1CkuXIxy5fw6McJoxQFnOvWilpy8C0uKSSVsyLadNbd5Pl8q1H1TctNTt9rl3DVJter5Jf8AcyzbbHHt/py+0zux4lCPCqSXgSxgkzbDj258szKA9DFmk6J2qh0gQxcQoAArY0AABIUyi2UMylFlGsIgowoBx71N7XLXkYvEy/KnLFNeaMSjFxu/NnDz+B28PaufOu79Y9tRWgZ48WPJwtp8L93YQ7ebnhx3r6N9hyY26b1t+nT4NzHznoZazBcc/hzhJekr9xnT5+5M7OLLq4+b8gAA7I5lMUYUoIZmH9fg/wC3n6apmYTMc60lLacT/JMr0q+O6zjC3asQeXr7hDyv/wBeoZFlFi0QAAJ0pYAAgAFsqyTMKAoGkKKKGYEGFGikYozFZcSRkbGYhbJJD5kd0v4HBF0zukvYTl6N8O+2V9Ff9nX2ckjcGg6HK8GVfZye1G/vkenhb8Hm8/8ASsM6jS3G4XjYqfLsR0dRX91mrS0c8I9yPYeVz63dvT9tl+hyyizldsqbH8xmf7dl/bZl5Zf4GFY/mRl37fncN0vLIuRN8NG2W2MmIMjl/wDISGu6tT6Zu7f/AC/4o7nOK5s1HU8+J7Hcxb5wr6xXHLLpoWvI1/LPSl8sP9OH/tPNf+U/celRr4eKv/jh7D6nh/nft/o8P3XjSocjQ5q88wAAADIQdGhHLKACOhyMkFQsZCDoUSdDiIcAstFAVKTCuua7qvKMTGpm/wCtv+/mvRRj7DQZOTPCvjy83rzw4/8ArHMyJjsiYzsKIMxDSGZEiIkSorTJ07S3uoLyMnnLHdcWvMxSGTJDI3ixvJKuRsdpg3Fyy56Tk9I+qPV4evHHn+48TaAABXG4t3Pg2+R+B5/pzM46pKtpPxaMG/MkjD1r1PbT9L5rAsuinbTxOmJyxOiJnmmugsoDCoSokREiVGajliIYk0iJERockkyOvB6nJE7sapGOS3QTwVtHOdOImdctJy6Y163+3sfw+n39ubZvrZr+lQ4OnYF4X+JsD3c/SfiR4mPfK/UyLFLMav0BQAI1gAAYAoACwAABQAABSiyiTYwAAZR6BWUWygOUoAULRKKAAGwAAA2UAAkwAAWZQABwAAAkylFikgCllDBSNkjI5AHLkejNRLMvh5FytNGx3EuGLMUlPu1eprEXxSNXulH4DatcvU548lfkjo3HyUceJ2mc+We5vTsnR1ICLir5tDohctIW2zOxKjq2+1ybl1FaefobHHsXiXFl730UuXabvBxKnHHwxXIJKyuY22ww7dXVy8TaRTLgrVkx06Y72jHQUMaTommAAAgWii0AMAANQAABChRmKBKKLKLChWMKwDV73draw1/NojHr0Nj1uFxwyS5OjW3cEcXuO0dfFOgXe0fqa/Y2oSg/yyZ2rRpmvwXDd7jG/lfeRnMf1vX6tq2TrhZmW3yceGD8DDG9GjJOmTvC4+sP4j4emTLObxbYYUY9GOJQrLYowjkajqUFk2O4jTb4bVeBtpHPOKlGcftRaNKc7x5k+T931EZI/wAy8m1+DIzyr3y869NRQAQoyLFQwVRgAoRFAABYAAJAAChpI2KWyjQqURjMRjjLZGKMKWgyNg33V2GuR2R+VE30dHGyPomi3MfXuuvcZF76MT6RljizbjjlwqSjXus3GTf7aFpNyfgtD0uLKa+zh9x47PJrep/1kqejgn9Rwwb4I+VC7zdLLuIySrSqDHLixp+To8v3Mu/u7fbdMU4FIs4nZsy0aZkXRd1DBLdxl5xaMeR2bZN5cqXkitSisyn1FelnHPeznybRwqFpehIsSXO2LWM/yw+Vv5M8036nJuHKWDIr/Kdigvs/iPlhF7fLp+VhLEav1efuuGSXkejQd48TXrjj7DzeWl15M9Fw/wAnB/pR9h6/tt/9V3+XB7nxJx0RjHbK4qewFAlG0gyEGDQ0YcjHRYOSEaHFSMMhRgKww5GOhEYaPNCDw5oL2pvP+ru9/nT9HFGhmbbqMuLe7h/TNTkPB9XqTwxytkLZMyNo1laRHYozERoDIkQqQ5oz3ptOnycZyr1VG34mzU9O5yNselx3WEeRzbuaygKDbBperOtul5yRhzSTMr6y/wBKCXmYro+fMxne37PY4Jrj8wAAU3SROmJBE6InPmmpCxSzIJkP6iIckzlipjEgyHQiJCAdGyx/LE1seZs48kZ5HEp24YuXCvOSRwm76djc91gjV3OL+sv2uPy5cfNPJdYV7Jih8LBigvyxXsJC5aS9yRR6vJd5PFx7fdYABmsAACVABRQGYCiydqUAFFVKii2UMKAAINjAABnXoEKLKKAYo4rD1BQADMAAAAUosoDAAAlKAAKgUAAQFAAAahGOIwJGRsdkbGGr3cqi+wxObMj6hKlRjD1bL7Y3aMJvJy533TgxyUbt9j8zb8ClzO3Z7HFlyq+UVyMZZrq7d9HFt9pl3ElSbT9WuRl212GLFT/N7DYQxwxpRiqRKkkVrbluSNx89RYxfnodNDUadmdVBNIctIsNpgLAsogAAMLAAGDAKAHDAAARCiyiiUAAJKhWDZQw1PVI3t7XNMx78qMq3kePb5F60YouRzc06R28ARw5O7u4y+0qfsO44d2uF4p/Sr2HHL3ja93e13Wkbjpk6yTj9pL6jTM69lk4dzjXaTx2/KF6VlvqOKMezHm3uBBxA2CyOfkzoZyzV14Mei9Y843cPhZ88PVTv8TjNz1iHBvpv7dP6jTs4uaSZ9fXq9biu8IUAAyUCxRhWGLLFGJsAKAov4p2uyrLoOFkp+cUK2S8DL+GWr5oBSfgHWNepUZ3PbjA7PhRD4UQS4eGw4Ts+GvQpwK2mOOjpjyF4dSWMGR3bY0+KTi+ZLJ27IeBplytehWN0w5Ju7QT/mRZ2YtMbXicvDJu6O/DFtUou/EjkvR08HYJjJk6wS9dDojto+pxurbib0XabjZK8+R+cULHBii0/U74ZniioxjF16vmO5dGdybKMNB/h+KRrfjZJ+ovDOXNv8TKT5d7r/yU6tteKK1lZDm3GF4csYRt8L5nIoRXoLNUpuvySHJ+V7YM9FJdrPRMP8nB/pR9iPPH/Lb9a5noWDXBt3/tR9h7Pt7+mXT1jyvdeL7ugYUY65XAssQYktJBhUMUR0MIhwC0MIWUUOmORocQOMIMCTDw+ZEZJD5kPLw1TzXeu93uPGbNblO7cNS3GWSfOcjW5XbPDvd6vpPKIGUBRU6CVHIjRIxEipT2lLKLfIJOrPbb7Bd2bNma/Yxawu/Vnce3j4Z5PJ5OudMKWKZs2L9Ym/iRiaJI23U5cW6r7JqUTOv+Xr8XXCQAAA2SROiJzxOiJy5oqQYoZGZHHEHIGwOhB0StIMIMidB0QO+BwYzviZZND07ozH9u4/i9QxX+RWYjFW1rR6J+1sX62fJ6KKVnZ7Kftb+Ja4/dZf7V+zPpc2UU2Fnbe7gnhMUAEBZYoE7UAAC9lFgAGSlAAARWUWUCYoAAFMZAAM5t6BAABACligagAokLAoCtKUAASSgAAUAAANQowozgAAJIoowoERkM+RKzny8iksa38tTSJGy3rg5SSNZHVD5PCri71LFG76ZHvzZqI8tTIumY6xt+bOSdejatpQ6GoZI7nKEOBY0gAAkQDCjCpKAAESwKAqNDAUBSABQDAFLFGlYAAERlFlFAj1TMMlHhySXk2ZlKzGN7FrdNctL7TPk64108OWsnGcm8/lJ/ZdnWR5IccJLwPM9XZTQdwi36pDJqL4ou69VyOPbNSwpP0tHT3YwcYxSVegb1dIZzjlxY4S58UU9CU1/T58e1h61ZsFZ6PF1xcN7kYo7ENk2KZzs6Gc8glSxHrsO/hyeDTfnyMXbMw69jb20JL8s6MPTTRly4fL43fo7uC/qWyy6Ho5GlqMZDUSRRado+EZRJqGSJVtBwlqJPRVDRsKJdC2GotKOKxWVQBY1lcJIoiGiUDROkFCGnPFWP8NvkjpikSp0SNOOOBv0OlbbTyJeKi7lLwFujRFgS9bGWOIygyVRFdq0jUYx9CTnyobgHUTO7veriNLUk4SVRJFEleyKJKokiiSqJBoqHVk3AMoIZGihp47xz0/KyeMCScXGE/uS9hE3Lva9vMmv05dhnu2/p9t/pRMDn3ccvCJne1d7XbP8A2onue3v6X/2x/wBHle68V866rHI0SHU4VgACCRDCIcQOhhENZSTFilgDjoQdAaxkKMBJS7pSfkmRiT/lZfuMx5PDfJc7x5g64pu27k/acuRa2TakEjyvV6d7Tyc7EHZGURhSxSokwPlRSKkacfihZMh2qrbwOoiwqsUUSHrztHkZeK+aygAzqPWMQ39vdzl/1yNZ6G+zxjNvtNfPBp3SJXqcXJjOjXaghssMkFzIYy11G2tk9XZEniQRJ0cuaTjoQdGSossosmqSIcjHQA5YFomB1Ykdi0OWB0mOXc468NuSPVP2zh4Njkn65JfUeW4LPZuk4/hdPxLXVWej7Xw55fZwe56yT6tmBQGzmhiygIMF2KAFpYAAzBdlAZmCgACBQFDMClisQY6AARHoFZQwotKUKWUPSVAWUG1gospkbBAAAIAADMAADAAAJBAABmoplgIIWcuZ6M6mcOd1Fmkm6msS3bXG+04IE+dt8V+siHGyOWdG/Fj3qdqLWplvTl+gn4mJ6VqrMz2MeHBE5sZ1h13AAHX8nJVgAC2WwAAUawACUgAAJSAABawAANAAoBmoAACUAAMlCDCtpc2hbSpmP9Ui3LFk5Vo/E3OTLjitZxNRvs+HJh4U7aa9BXtY2w8UagCizzcnoX0a/aJx+NH7MuR3UcUe7usnlNfWdtsV36fRLc9O3WPbwnGdvXSjtl1OvkxJ9r/+jG8d8evqdclTOviz1NOXKMgxbyGSDeThx6+V0c8+obeHyvj8KMczOUVdnHxvzNt3uysZFPq65Rxx95wZeoZ8i0lw9iNbzKD5wtINzlnkg4yk34M09am3nBs5/wDGk/Awzy26+L9Y54qyZQOmOBRJuBGdqrXDwMkWM6KLH3LaNQG4CRF2RS2i4UQuJM5C3YbWiouh6LorZoqLokoKI2CJEqQhKjS0FobhJEOQESxSJo4yZciyCLwodRQEiINSiSqA6iTKAKQqA3AdCiPwh9zjnUSRRJqHSFbtZFHU6VCiHjiuboP8iC8TLqqOpQJXFVpSZrXu5O1CCXi0L8TPLm0uwXxobOMlG1NpUEs2LgnTvus0/wANX5vxBQk1LvVo/YaZYzVuzYPnV45+CM/21f4u2r/4kYJJ3Gar8rM72tPa7b7iPX9t0wvnK8z3XidKJBBzpcAAAGDjiF2AOWKWNNOWUABIOhBkASFlFkpMc+4fBt8svos6Dg6lPh2ObxVfWZ83Tjy/w24/FHnP5U/OzllzOhvRdhzS5nmT0r0r6IWRMlZGzQlAADI6CraXm0KS41eSC8TTin7ozvRkvJR+6himUeq8X1MJLSLYxBmdQZGS40Mn3gqxGryIlSM2mtOeWNS5mty4eGS9puWqOWasitMc65ElRKiMkRzZO3ExQFktF2SIQdEr9DokQiHFpJgXMUkitSey9thj+VEi5iR+UkRzXxKjY7dXKMVzk0ke44orFhxw8oo8g6Tg+NvMEfKXF+B7DLmexwzXB53byefL99FGEGHpjpYFASNLLFAZrAAAwWUBJgCgAgUWUTTKyi2UGjY8AAZPQIUWUNKgACtmoosoVNRRZRJlAoCoSwAApgAAk1AAACgAACijCiCNms3kqxNmykaneuscn5Dx7isQyvuorGXk0aXmXBEc3StuPwp466GbYdMcOwwzHzXajOILux7Ec0FiUBQOuOOmAAGNKAAKhLAAEFAAFgAUBWjMBQAQACgJdkcsuOPOSKn8rXmY7JLiaZnFt1LeY48tTil1B/lia60uRG2T8lOqW7zS5M45TyS5zFTBs2+SdASVNUVYrZhlkePTJGWAHFk7Gvzd3NjfuNg2q0s4t4qhGXlJHWnaDLtO4XC+NM2bS5mrbaNtGSnCNIWGXVOU25MmPii6NMtdTIWqRpZRcJSXadvyYaIkPRVi8Rn8jmKQGR8QjmHX8r2dsVyIXIW2TpRuMOISiywey2xBHZlQcdEaJB1RgAsQUFEqQ6QqTmePiJVh4deJsloOFkLRPukcZyk6o61jsk+GVsipl2Vw0MkTtUpiRAkOkQHXBxkuZNaicMYcPL3kyivU0Erp4o+YnG2RrhQ1r0J0Zu8NQqZJVk2KRyxxerfI5ax8XLU2KxeYs8MXqQECfkSoRQo6EjSq0jSKnpjn91k6Kku7L7rM/Unnk3Ucnny+sznZ2trtv9MwbLHSXvf1mcbN3tdv/po9f2/868/3XijuHsjGR0OKnAoCkpAKLAHRYiGGZyxSwSkGEQwBIhyMZCJIanq7/scni4mys0fW58Ozr7WRewz5uuDbi8TBfQ55czo9DnlzODUld5CMdiFKUAASzWdG1V5l4HOjr2VPLKzo4fFGfL4b5N+Aelgei8kHNuPkJ26OLcyqPaZU41cVcmx/USOhIZj1RyOSbOqRyTIdGKEsUsxrtx7JC0UWiWhhkKMhKOiREZdkUjnTjRzI6cbIqnauQ6Wq7SNHRiXfT8vwMu/3VezOv21jUt3LJX8uPu1PRGYj+2Majts+X7cq/DQyuz2dSceGP0eNl15MljCIcjWgsAAWgAABHoAADCixSyQAFKCA5RRRIFlAUM2gAAM+rtIAAClAACoUUWUAKyi2UMyAACAAAGFAACUAAACgABGoQYUAhkzS7993tN20Y71GXJGmE6pyvRjOW+OFa6EseQsnTHRhyXd02wv6uvbriyQXm0ZsjDNmrz4+0zLkZ4z9vtsr2NYWUB0OawWFlAMzAUAFswCgUkAKA9hIAhY9jYAAAwUAAkWY9uVKGVvk37Gb5ms3y0jP3AGpFKGWphWiOhXFs6eEfhEpxcDK4Gd/CXwkq01zVFHZuIpJUcZz5OiINwuPBNeFi45fEwwleto6au15o1210UoeT/Anvj5UNjao2GBrgS9UzWI6dpL9Rp+RGOO9prZ0abeR4JKXo1TZvUuRxb7AsuCf0dTqx6MdMfbEsaClkdqMq8SZYZdhfT0EcMuLyZaTZs4bfW3qX8CCekSGjV/Dcn6k/wANmyUIr0LpC31NqvAU6MuNcTaIoxEBRVEtBwiCGiybhDhKNGkSJF0SqNiMqRKkSLHRJRJoqLSJAAKGKoamRQuhRqfkSRhb1IMtoZakyxr1C8cfUDIk/EepDfFj6CfEsv5Eb4cmMoVzaZH8Ri8ZPcOu4ob4qRr+IZSCRrK7/iMriObiL4haJ06EmhyWSWI03EkW8ip/dZBwth8Ju78mTfQMFy/n7GZrsv6Pbf6f8TC83y5PeZnsv6Pbf6Z6/t/5Zeced7nxR2DCjHS4zliljOmLKApKRDIRDolJxhRhhaGFQwA5ZQDMGg6418DHHzlf4G/MZ69Lh+DDzTZy89/Vtw+OMSd0zkZ1SOVnE7iMQdiFymAAA0zWbDp8Vxyka70ZtunL9OT8Tr4e+2HN4a2oFasWUornJI6nmxZrd5KnFLyJcm4xrRNN+ZrMs/iSsm1ULYWIVZOgts458yeTOaTIyb49xEsREhg7MUi5DEZZCzDoUdCNYAWTYZ0deOJyHfi5E5dItOjqxa8jlR27WMnkgl+aSX1ofBj/ANnJOieTphXsPSMPwOnYl9rvfibIWEeDHCH2Uhj1culeLh16/lZIRl2ZZLtWBQEjZgFLErYsCgJGjgIAwsCgGagAogKKLFFsNGAAHV3EKLKFoRQAAKAABBEKLKKsNRRZRKSgADUoAAZmAAINQowrGRAAANDIxrqHzUZHMxbfa5DXCdUZVpZfMSRI5/MSROTk8db4eGNlsdc0fAy0xTp1PcRXhr4GVCx8QyFhZRVnQ51hZHZQySWXZEFhC0msLIrCwNKAoD2gwAAbBirKChymLKB0QvJihzmgCVnJuY8WF+Ast9t1erl7jknvk00oadv/ANE/I2pBS7yEb1YpFXK2sXFrQvmceDIn3WdvDRnfwpYDUFAbk3C0s4DaZVcGas5s+unRjVo1DyfAzzitOI2xpOoQ4JwmtdfQrDr0LJN8aR27HJ+uuJ89DVrVX5olwNQnBt8nZXx7xFZtRdJxkn6qi1rFMUMbsmijac8f2JV7h9CTdr4edSvSa9hyykou7LqU1tFNkXxkI8rI0vboEbOfil5iOUvM0pGyLiIeEkciNshYckvUkTIeGyVImkYLAKGazohyIkiuNwklV2/T0AnT3nyQyhL1JuOC+XvFPJfpQKJwlcI5QjP3fR2WnQiRdAR+OvQhyZZejoaS0OVsRrSb5tkiVCIcQOFiACj2yrYyQ1DiEeoVP0OpRJYxRDWVBGF8212E6x0TpIk0QBCoEiiXfgSKL8ibDCRNS4ZeMWUsZIoaSb9IsefoTzDO/m9E7M02i/tNv/pr2mF7nvxk36XRmWxbe0wX9j+J6vB/O+ccHuO8dyHFLOhyVYwg4kmLFGGDIdCDDSkGEGHDMMmIWGglLEGAjow3r8r3GNeWNGYmC9ZlxbyS+ykjh9xezp4J+zRM55HRI55HPi7kYpYpaFgADQqSbWhtdrmjixcPqazUlR08TLm7V3T3UmqWhzObfqRNi2bbedswAAqqUEY4gthHI5jpnyOUzrbFZaKLRm7cUoFFmZpESIjQ6AHAAEcSJHdj5HFE74mWS0seaMo6Hg+JvcHlBtsxiK1XaeiftvF+plyeiSSOv2n9d+bn9xlfh0Z5LmKUBvfFa8/HwrLKAAssUCdnDAKAGAKANgwCgQFgUAzWUBQiUAAQrbRgAA7MVMQcQZxRRZQlAAAQIUMKBRQowoBQFFAowFAClgAAQAAEEZRYAbnnyMU3n8z8TKclmJ7zXKbxnk1M74iSPISXzcxlyOTO7v4dWM/WNp0tf3EuzQywxfpSXxpedGUBPFWeZGIWyNs22xMJZXEceXK4qXDzRpq3sl2Ngma3DufiRi21q/OzqjP1I7XSXTZaZr3vsSbXBJ17iB9Qp93H9dkxbepPyst16tLtMblvc0+T4ew5nOT5yYqGUSz4Y85rQ55b3AvlbbMcAmFY3kuoyruwXv1OSW93MlXyo4OJl22TtqklknLnJv3kLd8wYo9koCgNNpMKxWKyNlpafD7jdYpccEzQs7Ntk4XTegqqNsWL2DCqlSXdl2M0KTWjMi9DRT+eXaYZbs03hTg3qjLHfkdxBmipYZdhGHSi+GtRF3FF1ZDil3aJ1qaZTqy0zfaz+Jhg1r3VZ0s1fS58WCvWL+o2hpjN+pVr9/BzwaaODuzGlNz5pmaNcXFeqaar3GKcDUpRfoxzw+REGLrUaiWkKKS0I9CAqh+EpaktDgR8I1D0MkFNDwsOFnTQUIkKRIoJ8xqHSKBVFImIyyDMNQllcQiSWFkHEFjNMyFoHIqwChkKMgM4AASJWh0UMCjpk0WcxLGVB0OV1pMfhIPi6EbyyI0e3enFA8qXJmucrFsnQ22H+QRz3ElCev5Wa9yr1Nfusvd7sn62afGfgvmx6clJdrbN5tdz8PhXp6mi4EuRPGXDR3YfrHLy+JnqlxJMsx7abvgVSenn5GQLVWjRzrAANmRiyixmZDkaGGSQdEYyAkgwowwZDkaHER09Ujz7qcuPeZX41+B6DF69h5juZ8efM/ps4fc7+Udft/VySZztkrZBIxdVKAAUWwAADMEiIyRHVg5uYwABs5gBYElorEJCMSkOTkcx0ZXyOUztdHHickIiQzroxiRAUhhU4CREdEiJUZEiI0SISk0EdsTlxo60YZKjoxayPVug4vh7Lj9ckrs8twRt8rtpfWe1bXEsG2xY/KKvto7/AG+Px47l+XF7nLfxxdBZQGrlOAhdgmmLIy7JpmAADZgAAkACrKsFHAWyyyBQWKZnpQAAxppxBxTLq7SgAD3sooosoDKyiyhGBRhRAoo4gyKWKWClgACMAADNYg4ggUAKYEgyGJbl3kZleQxHP87NcPVnfRq5/MC5Fz+ZinJnf2dk8Mb7o/zzfgZJZjnR+czIiuK9ajMrI2xmRNmzBRqd9KUKS/MbLj1NFv8AMpvhi7aKwRk40oR7fU223zqUK5UY5qyWPEvUdnXaZWwz0smnqc3qUUwvrVbTpjWR46dHYoJI5bWsqCxkScI3CUkiQzQ6RdAaFoWiehGghIqCh6AZomiNo6GiNokkFFqx6Chk2u3m3FJvU63Zo8c3CSdm7g+KKZnlOq1mozx4ZvxNyaveKnD3l2LxcIABw+roY3pGcl4s6Y0R5oOOXlzHUWkdd1ZGLfdIm080LeveXlp6GRRk2tUYn06fBuY+KaZmGlEzoBZoN7jcNwmtVkVm/Nfv4t4lJc4NP3Dxvcq09F0OWLeyR0I42ycX1Ho4XhSLoOIpyHDWWRcQcQ7A6AIeMic2Z6DqsOI5OJjoaEjyB8QSgoejPxsOIUsWhtYAAjlNRaRVhYDZyxLGso6ssoCUpLLsiAapUpdkRY4cqSwsULEWz2K5ELkQOY9HUk52mavM2yeWRnHJtlSM65mRkrIfU6MfCyy7uiEqMi2O7fySar8r/gY1EmhNR08TSVhYzmy7NVs918X9OT1S/E2hcSssUYtB0OIhxmYAAaDpjkaHEaRDCIcRC6t+Sb+o8unrkyPznL2npWaXDgzS8oM8wbtvtOLl8c+kd3t50pWc7J2QMxjSlAALUVsqwYDQmirJ3GiGB0M6p2cXKQBgNIxhALAolETJSJmZuTI9SEuWrAxrswWiQjJCG5kOhEOgBhhRkSvZ0SIREiJDsgtDoRDEnRz5bt0G76Xh+Nu8EK5u/A9e8PLQwD9s4OLPPI1pjSXvM9b1PX18ePHH7/5eVnfnnfouxiMZEkYAAYWApYzNYWKBmpdhZRYkgCgKCyygJAZQFCAKsoBm1IABFdxALKEFAAEmjKLKGAAAIEYozFGIoUYUAAABGsCgGAUBRCwUWKUlzZHoYjm+dmW5OTMUyq5yNYzveNRL5mKK2+J6FnPlrd6O/HwxkfR+czIzHOj/APMZkRHFrdY5o5HBlyqEqZsGazdenI1xY5OPdO8bcW0/A0XOnJ236m6ffXCa7Fi45y+i6NNz49PRh6qWOLrmS/DXoSz4IfmSdcjm+L3u7qEo11S/485fKjjn3XR08WV6qfD4Lmc+TRW9dR/I0VnVj3FUpHERTTMbGsZGteRZp9tuJRai3oblcMvldkXooFjUWG0kaEJqEoraiURk7RHRSC0KS0K0BoaKoeiqESJo2O1n+VvsOIuNp2Z5Kb04N9HuKXkzqxZFOPiVnjeGXuJaY1ogLZRyXxOuODPG5Rl5EbVo69wu6cvoi5f9WelwXBkhNaNNGcrhnqnfJmDJo3u1y5vhy+E+KWlI6scd+umOTe0JKKnCUX+ZUSRvhV8/UQJ0Qxtd24vmnRdjZ4fDzO+UiLkKmpyYlg2JZIlXYFAMtqAoNQbChlEkUGSKArEouEtI6OAZQGEBfCdXw4eRVIXQ3P8ADkRPQ73JI4ZxuQ/EgWFiUXQfEGsuyqGGFgABSNYWR2VZGj2msLOfiCytB18UUK8uNHIVwxbVq6I+KnS83gRPJIRiD0UHFb5sRsBSj2jZEyViNGkrKudkdHS0JwmkSjLGoKKlZ6T48nDXp7TJsGdZkvtVqYnR14MrhJO6r18/A0xqLGXIc5sGaOaHEvTRnQuZaDjIUZAzMMIMXKDjkY6J9QcYQYQcPUp8GwzedL2nnCujP+tSrYyX2pJGBW6OTPxV38XhRshY7ZEzNYKAUoAALRSKmidC5EUDoOvHs4OTujAsKGxhQLoKKBCOekWyUiyvuGd3pUnVrXzGELM3dIYkI0SIhpDDFDIhZh0KMhUHRNFakSOjGvUi1ToR04tZI50de3i+fm6XvDDH5ZQ8rJjXp37exfC2jyNa5Hz9dDIbOTa41h2uKC0pHQj08tb1+HjTrupBrFAiqPYFAIzgUAjWAoEkcBQKUYsUCSMAtlWLYWULZVlEYAAy2GpAAHXYUAAStlKLKEW1FFlBVEAAJNQowo6ShBxAAAAAFAAKUsAAlQFGFGHJl5PsMTyfNIyzNyfYYpL5pF4M76NLJ95iNkjj3n2kTic+Wvk7cfDGUdFaayVryMjZjXQ5V8ZeJkhHHOuTLP0IazdRqNmzZx513JdhvizyjH1Nr1Kkldrk/cRT0Y7yqOHX1dGlk3GTnzZlhaiorVXqcL3Eq9EvAn3WJ5IX6x5Gvx7bLJaqhzV+zNPDN+orel6mymn3l6LkcMNstFKXD4jZc8MapNzZF73oeON9VLkLPVBGXErLZmbmTpmww52mtTXyVFxeoWdGkZVimpLUmMehkap3zNxjzJ0mc9U6SqLA1kMrI2SsRovsggo4obBBRymRsIShxRhNhlwyRtZd+DXgaQ2O3y+kmZ2ddnGqZRLkXDkn2kZz593ZCTjaNXG2nfozbvkalqpzRGAsUbTY5fhzVujWE+3263WZY+Nw8fM3x0zynTTNNeYtsjxxcIRi3bSqyU0ZtX1CDljU/sPU1Ck3GzJs0FlxSj5o0UIJwTfYWlzFqFnaoQXoSaeRC3EsTH+F5nRxIXjEZVhS9SSOOJDxsE2Sl0vgiLxRfIhaBKgG03EirfoRhxFKhrY3Mj4kK5iJNQjRF8QjeRgR2gIeIXiYw6AIbLBKSwsjCgOLFaGAIZKG0FEsKekopVgAUKWI2NCxGK50RfESYTuaai6HTT5aosfqlBwiOJ0CM2iENIqiQQE1VEeqJLI3IcqLHdt8/wAKXFbr1XmjKoTjkipRdp8jBba1Rtdru/htfZ5S8PE6PknTKBkKmpK1qmMgZJBhEONJgAAUkQwgyETQdenWPBDzcmYbIyfr+Tv7eN8k20YtJnn3rlfN6M8Mc7EHYhcMoABUSoZCjIuCuuC0JSoRaiNR0x5+XUgDgaM4osAJhFo4N01GvM2Jqd408tL8v8TGtcPE5kORjoTsOhhRiao46EHRnpZyyixGlidmPRHJA60Z5KSpmQ9Jw/H3eDH9K2Y/CNtGfftzCvjTzeUaR1+2n7/L8SufnusazZ6aLktBhfUY2efDgUBKjFilgDgJYWIzgJYWGgYBQGZirKARHKFsLIC7KsoofSkawsUCPjC04SiwJruIIOIBqAAAEYozEGoABQwAABEQVjisQRgAAFAADNRZQAoxQFCNy5tYy7DEsnzSMsy8n2GKZPmkVj2sZ5d41UvmZEyWXzMikc9n7V149mR9Gq8nuMlZi3R335rzRlXoLHvUciMhmk1RPRDI3jDLqxbPBqTNVvZOMYRXnZkO7i9TGd8/1YL6JtGHWVs8MuPGuw1GbLnxyafdj6UdG1yU+ErOoRn+o5NGeG/lWla74l/ms7MGBTuU4tP08RPjY1/Lxq/MkxbjK8iUnobWbnTp/wCEbdORKCVKjnuzumuJe50a6F63zsx0WjUFD0XRFbaXE64M5kiRGbRtcWX0Z3xafqaBSOrHPhldkDbaMoSMrHNJEo2RkkkR0WFAACCNijsUQINF00VQEpi8zuVkS5DyCjjz7uzDrCmtzpKV+ZsTi3UbgRjdVdnRy6eh1baSxZoSv1o5PRdgj9H5NM2RYz1/N2pFEOLLeHG+dxQss+JVcjTrqT8OdMnTNHO8WacPRvQ7Xu8N1CMpP0vQ4sknlyRyVw0uRpKarZVsLKsglOxRmyNspSWgujneQXiJDp4w4zmsCqSW5egc/U53YvDb1bFonRxxXNlOa9CPgRdL00J0uqsYShx6RIoYUYF2rAAGRwFsLAlgJYWAMIy7EbAlWJYompWgdzIpTARjkFquYvAOhhaLaTF3dPQ6XJM4xrCpTMRkTkRubNInaRsjchHIjbKSdyE4hWJ3rGbosuL18BaCgZ1kex3fA1jk+69F4G/owTHKuZkuz3Ll3G/Tum0u2djcDCJjlJAwowgYtMoF8yIvajTCuuy496l9mCNAzbdSn8XeZ35OvwNQzm+W9vRw6YSFYjGEYaIpQAMlE2PV0Rk+Jd5F4oyybCiywOhwo6CiSgoe2ekYF0FCWR6GknLim3RuptKLZpeZFrTinUowDImu0yLAsgzFootCM5aKLEbogdSObHyOpGWSo68dcz0/oeL4WxTfOcnJnmu1xvK4x+1JI9ihBYscILlGKR38X64W/no4PcXdmKQdCDIbCTSQBSxbMwCgGwssoBBYAAgAKAegsAAZACijKq3VgUBZACgszJwgAEvQUUWAJ2jFGFGahBxBKAowoAAAAnahGOIxCEYozFKhgAKGawKARwCssoknNl+VmKZed+bMty/KzE83zNeT0KwLLxRqpfMyFk8vmZzvnRhn49OrHsyHor78+wyow/o/9Q+wzJk4+Kp5J2RshkTMhkdDFw5cfGmjBt8v7ia7KPQXoYHvUnlbRph2qMp1QYnw8LOvdpSh5+pxI2kVeJEzLVZejS4ttlk/I7o7ZrXi1O1ShHnJe4t5L+WF+4q53Z6ELXPUgeNRZNWV+SX1knw75hvSsXLwl8J08IcJG9rRKJdEyRdGZOcdD0JQbVHRF62dkJmvRLGRmbYiMSMxuY5tKihiiwjFJaKoAjFJaEaAI2UMKc3J3dPEogyR4okwS5HJGtacop6NrxKOkVsMWRPHVsq6OWOh0o1x1GFMpzTtMZSl6igUhJxC8RGxBwWpHkj6i8VkTgnzJkikFGokoczUjouiUXQTRXCXwhZXENK6CiuIriBK6LInIXjGafQNDk+IHxGCnRYHMptslsqoMUAC0QAsCjUUywMyQgMBsCNEbJ9PMgcoiBSyrLsSVgADBSMlKAkDRXCT8IcJTOouEKJqCiiRAPQUUQHg6lF+q5e8qgomX4lYy7aZ1lj3n3l9Z3mF48ji7XNGWbfNHcQTWj9Y+qNJdsXUMIhy9gDrzEFyPhx5H9Fk5dl4d3nWeXFlzS85M45DN6y7SNs5NPQ/BRWMIyiKAAUQNhtYXqzgNtt4v4af4muO/wAObkqZlD0FG3b0ri2Qocoa9kAagIDh3WkNDVpGy3L5HERXRxloqiaiqM9tpS0WNQ1CVKUsoslokRIkRomQhE0VoTohidEOaM5N2L9GU9BwPJuoKr4FxM9JbsxT9u4eHBkzPnLRPwMoR6eXTGR4+X7Z2nGQhZkaUBbCw0owFFiCwFsLHsLLFARGAoLDalgUAkrAoWxWK2YBAGQZQAQHMKMKTt3AAACRijFFACjFEggowoBQAAAgABRoyiyggKBRZZlAAIJQABmaDL8r7DFMnzSMry/KzE8vzM1x7VOXeNdk+ZnLPWV+B15V3mc0kc2XjdOHZt+jP+6a+j7jMjDekf1S7GZkVPFRmpkTJWRM0Yocmib8kYbNLLbozSUVNNWYlKElllGqpvQf/CnpzR22h0wx8KafImpjIjdZ/FD8GL5LUkWEmSJERu+o+JFig1qiFwo6yJocp60g4S6JqLoZOehaOhojooIqFoloWiFIykyWhGhg0ZHSpHEtCVSJodllkKZKmMLAAK2RRGOKSSJijMUz5G/GQoAOF1NXmVZO0Q6M69TmOmeGMjImic6Jol49mdTgAM1Z0jZdojcbBRoAl0HIR0mSR7LsXhZKogordi6k1IvhQBBTF1OprQj4QJCVqSUFCNA0xas6NCGbaVlkpQGSTIsWVz5nUSFUKORssjAJYWBGAUBGawsUBEBBxCjQzTZHHEdIGgUohQAZkCMkChoRATfDkXwMfQ0VMKJuEvhEhFwl8JNwjUWWkHCHCdFBQg56KonoWh0nK3w+B2bXM8c1KOr9dTmkkRp8GqHKjTOceWOSMZJ8/TyJzFtpn+HTvR1fgZQqatOzVmY499Pg2uV+FHWafrE+DYyX22kTn4W2HXJgojGXIpnM7L3pWR2WxDRJgKLBFSRVs2+JUkjW4lbRt4RaOnj7OflMFDUXRbm0joqiSiqAyCvREjEl8rM6Goyvikzn9SZ8yqMbdurGaTxh3bIWjpjyoqSJpuWgGKBrCjCjCaLJ4EKR0wRORp0dGGMpS99EETIekYHl3UFwqlq/HwRfBj8soz5cvhi9E2eJYNtjgvJM7LKA68ruvNhyxUMSZixSxKMFigUFgUBAPYWIAgYsoBkYBShbCygFAHASwszMwCgM3OAAS7VABQEUAAQKUWUAKxB2IMKKLKAKEHEAKFGFKgKygYAAUACMCjCiUgycmYzm+dmTz5MxnP8AOysPVnl6NXm0kyGStEmb5kxGzDmx6yujDs7umvh3cPejN2YDs3W5g/Ez6Rnh3XyehGRMlZEzpc6NumaLqEHGfxF+bmzdvU4N3iWTbTXrHVG2PcttNDKmqZ1xVmPwlJo2GDJwrVs5sprf0G56tkWRRnF8mdCRFqiBQwEkWgGAoIxSShKKJC0VRI0VQFtGBJQtCUjaEonEaAipktkDGQzdaY6OVSOiLJBxRhQhIWiNk7RC0PNrxowADzsu7plQZ43Bmrs3EtUaeWjka4djFnTjOM6sPibxjnHUFElL0LpFs0XCHCS6FaFoVwjgnH1kg+Lii6bt+AtEbUBPjLkkHELSjlkaZTdBoJLFsichOINBLZVkPEVYglKpMjsLBK+FLkBQAo9kbYwgEUBqACWAAAVxIqxuFF0BkGAWykrG4RSZCInCHCTBRopDwF8JJRaQIKXQ9F0IqjoqiUXQaSDCOSI3OgOxKxOJL1OaUpPkL2j10JO8q9BeMi0KsLIKHIjepZQRmaEnFmRbTccL4W7i/qMbOjHPhLl6lYzox3rk6xYoebb9h27PdKceCT1/K/DyND1yf62KHkmxZ9WnDP2Y6Uy7QrMnXSMUtilksdCEi5mkjOuzba5kbpGp2UG5yl6I3VGvZx59y0FD0XQIQ0FElBQ9hHRyZ24wZ3pJnLuovgVGGVNpGWimWiXRHREaXIWI7FTc7iJRPRGxaWjAeiqG1lNE6YkMToiZ5BLFa+Bn37dwyrJkaqtImC4+GXO/LTxPWNhi/wAbawivVJv3nZwz442uXnvaNhZYi52MNzHGELJCQBLLsezMAtgBmAoCdksBSxA4FAI9LKAA0SiixSthYC2VZAOAlhZPl1UiAAJdpQAB0lAADBSiygBWIOxAIFFgI0YFlGkBSiwHDIUMUFCNikjIjMAosoDc8+RoM67zMikY9uPnYYpz7tPm9DkZ2Z/Q5SMu8b8fZ0bZ8OTD95noJ5v8RQljl5SPSIu4pmGPi6rz6kZGyVkbOqMKikcz8nyZ0yOWatUEFYlucTw5pr0eq0IUzv6hpOPYa0rk66Zx0qR148k1o2a9HQmY6aNnGd8yWLRrVImjKmQTYUURKZImAWUWBQRtCErEoAQQlFoqUkYF0AGjoqiQoRELUgorhEHQpDnNZImCkpDJEyLktB08a4ii2UcFdsJI0+S3Jm7NXnhwyNOK94WTkOnE0uZzDxNOzPLq2azY0I9wvRWc+naOpJehrjHPYf4jl6UV32DkLxMokjwxfNirFDxK4iuIo3TpWhV0ctyFqT9SQ6HkQvFZFwr1GqgJZQAMLAui6JG10XQyACIWMAWEjAtlDUsQcjIJaGFACNYWKWBqFGFAgSITiKUig7YoeiKErHckTDNQvIjllSE47KJ0iSlHzOKWVq6OZTnKVOJoTY8ViO2VFMkBmgZGzpaIJIDRgKWSQEHEA7FkYCMpJrGsgstSFDbHBl1pnBvsrzZ5Sk7pUX4nDJ22PW1YdLtELZbFZTfutiBYoJSIYRMkxQllk16GkTezd7GLWK/tM2iRzYMc441GmdUYe9mtcV7gKJaK4TNJaChwAac7i4u0lXqSd3JjaWpLWlENcGv5fUz9KpjOSPDkkhTv3mLhyca5So4CW+KVEiI0SImtNGa0IGjpI2hltBRYxRLU8SeKIok8OZmpvOl7f4u5hFrS0z0/RKvJUYj+38CcZZZemkTLXqej4cMMfvXmZ35clp1yLFQxBLLFANg4FFjNdhYoCBgFAQOAthZBrsLKAozFi2Fk7SLKAogAoAKhgBQJ2WilgArr0ruAAAgQAAZKKZZQgQosouGoAAAUAACKUWAKRgWUPYIyJkrI2IEAAA0EjR7j5mbyRo9x8zKxTm0+4SpM4ju3K7nvOBHPydG3H2H8D0bDK8WP7q9h50jP9lPj22N+FfgYZXrjOvWtvR0sjJWI0dkc1QSIGdDRA0UljPUf51eBrkjZ7/XK6OBIus4VEiBIdI52kBMiKiREaCZSJlM5R7FTdfGOmcaZMmWboKoSwsCBRYAC0USCgCCklFUARgAAkpYFEGkUiTmcvqScRVaQTjTImO9RGcWXfTpijl3EbR10U4pp2vQjC6rTLqx8tFvnLtBHZthUnEMmIlqdEYl4saWyyZQG4UUlCkPQ9IYNmi4S6JShbJHwhRIAfI0VD8IwwbSSi6LLslJCwKKMFFBYzUUBQEsjBsSwG12FigMHsviRHVlqJJGAYugLaOhlEl4B1EdKVGkw4bJqGSM1bRcAcJOWUSDgXkWopckTUhaLLRaKJBWmCSiSha0JV4g5wh6lRW2tkqZQ85p8iGwGzWJZVitiG1NiNlMBxNRsIqiai6KStcjhlzZ3+hySjqS2lc4jJmhKGvaAtKydQsfgSBn8kChZPHijSTEboItstnbtvtjvE3/j5H3ucX5m74KMJ5yu6a9TJdjvf8iLhLSUf+LxQeTKzTvAYBJRMByqH1MANQUFS1W7xvg0XI0tGWuKaoxvPDgm4mTqxqBEyIkSIZ2JUJLkOimCXM4sEiZiohtFxR24o3JLnbo5o1ZvulbdZtytLS1Di/fOeg5ctY9HoGxxfA28VSTdM7UIhjs5LuvMxOWUBMWkASwsR6OWR2XYiMAthY9FswFASrZwFLsQMAoBoLAUA0ayigEnYAoqxqWAoCCQAAx6OwoABoClFlASgABggowogAABmooAAlAAAZQABGjZEyZkbGSIQkEGZJGk3SN3I1G6Wg8U5NFm1xtGt5I2s0qkvA1KdqyOTs34+wtGddNae1gvKzAZW+RmfRne3a8nRy+sv4q29YozFOqMUbImiViWV8qKxLeNfFlRxxOvcLinL7zEUKIyvx0WkVDpDcI6ROyLRY1F0ALRY1Fk2KRjpg0KiiTWMmRFgHRYxz2SJmZpKALCx7SoBgooIiiQoZIqKJBQWQoYUgKLADn5PE6MFlFgYxptpNwqmc53blUzhTR0/hFPDmdZwxdM7OOPmbYsae6CyuY/CNJLHsOAOGhaBrKELFQuwsoCoR7KchLI5SURkksviOdSskHSNxF2LRIkB0oD0XQrCQgS0FC0SCi+A6VAuqK2HLweAvCd2gvCGwgUS+E6OEbhI2EKgS8KHACRUXQ9FjSUsugESgGdLmRPLBeo9xUlPQr0IHmfoRubZStJnMjeQ53IWySSPIyKTvmKLZSFFF0XRStEFHoug2SKiqJ6ChwIqLHooRKI2iQWhhC0hHFEzFoJT2hZBJtHZQcIbKuJJs6FEkUSRRL2hBwh3oOM43ca5HRQUIVkO13MN1j8si+aJ1U0YjLiwXlxLvrV+Jk2Dcrd4Fliq+1H1Rets9J6Ch0WRsEAAsR6VTNPv4VUvM3V2q5HLmwwnB2rYtNYx2qRRYULba1IhiOyQlmRijMVEtMTrmZ/+38FY552ufdMHwwcpo9U2eFbfbwh6837zp458Za5+bL0dvqMRDl1icsUsQWApYAwCgSRwKAQOUKBIOAoWMzgLZRIOULYDBhbKADBVlAGyMLYFBtToAAMnYoAAZEYozFGXqAAAMpRZQBRQwowoAAYUAABKKLKBSNkTJmRsehpCxGSsQegikazcfKbSRrdwu6Ca0jjfF4o0a9V5M3srvQ0c1U5E5b7WN8MuqjJuiz/AJkU/ExmS0N30SdZZR9WjkvhrVmQABvHNSMi8+xkrI5aRk/JMo2IZPnl95kpC+b7WTIqgyiVwkyQUZJR8JfCS0FBs0LFJWhKAylElCjIpQ4oBYABBLTZKiNFoWzSjkI1mhnoqg4i7ERGiOjooXhJCCgJWiOgIoABjyd2+CgADkdTh3ULhZpnoZDmScTQzjTOrj64ssu6M6MeF5NbIDt275m2LCp4YXH1OhIK1LNU0pUhkDETnKHnHhlQpBAAAoyshlj42icAShUKH5DFMokfxop0dUVas5eBPmdmNpKiYo3CXwkhQ07R0FElBQgWiqJqK4QIlBQ9AUoowF6GaSFBKcF6kbyx9CzdCRd41zZwSySfJ0c7TjJycrsJA2Ms0fQ55ZZehyuXkRObI+H1U6PiN8xXI5+Y1F60EnEVYUXQ2agJKLoaUYlEzQtDWWixihDZCwASCjaeZFIhlctBw0zaKs54Y2nqdSiUopQ9BRKULCi2iykkoKHLAEosACUAooASuxMeSWzyrNjuvzwvutdhII42qHKGU4csM8FPHqvZ4MmcormzEMWbJsZXDWL+Zei8TKsXw5xU0+O9S8rPRK9XyLjCvUcsz2nSqQOKaYwAuMWzY3jyNUQs3G+g9J+40tmett4CZERImBlZVgwWrFFxknSdv8fPBVajTl2Hoj5/UYz0Xb8GL4tayMkOzw4zF52f7Z7OAALYWMKWCjAJYWSlIAlhYBIUUAjMAoFDRgKAzBgFANgxRQDNYC2FkksBLCxBbYll2UOG6wACHYAABSiEKLKGVAAAzKUWUAUBZRQKAwAAUWAgQosoZlZGyQRgaFkbJmRMaUbODOtGbE5My0JluyY3LSTNNuF3/ebzLozT7mMlK2q8jTKdBggfI6uk5r3Sq1rw6nJr6ku3lwZ8bWneVnFqWXfruOqdnpDYpfoUaYeGMqDny6Ysn3WTkGbTFPso1iGK8JJFCkqRnb1qkqKLRQtkcAANgUJRIAjQiNakxVD2SKhaJqKoDRgXRQkgAAQMAAMpVWSIiJEC06YENl2IJKKoLLsAicSBpnfZBJGebXFzgWyjlrogatGg3PdnRvzVb2H5jTivWFk1qOzBJXRwWNGTTR1Towrf+hVnNHJaHL2yqWyrIgGUWygANKKAATol0KNYlj2kClNiARyWLOVSkSO6GTY0x0hcT0HckKiLEL4oiylGtDOGay7RyPIRvKbB2OSI3NHC8hE8gG2DzI5HJ+bZzt2NEjRpgLLoegisVpsm4RqKRXPwMvgJuKiH4kboEii6JUiwWjosf0E4kgBgIrLspmcAASyAADZkAsBKLwlcJIAyR0MWWNUIAASSMoZlFEUAAQRsoeg4QitELSJeEKGgpZdBRJKq79bH2WeOznw5L4Jvhj4NlEc4LIqkrQBlv/XgWY3st08ElhztuL/ly8vBsyPSytdC0sAAkOfPj+JjarsMYpmYGM54cGRona8a4i7KfMsK27rOva4ZZZUuZy6+ZlfRMHFk4mtF6+JfH1vkjky+ONZlij8PHGHkkidCsZGt7uKJAKsLKPSyxCwIwFAIbBYATtZwELIQYAAqULAWwsNGcBLCydFpYC2Fj2agKAlWllAUNKygKEbuAAIdYAAKMgAABQFgItqAABSgACyKAABQAWUCkZQ9FCBRRxWBoWRMmkQsREZzZVodRDNaCDG88dTT7haG+3enI0edXE00jHu4NaBPhafky/QRowynWuv0ek4ZcWKD591Epr+nZFk20PBV+BsDLDtfNFKQZ1L4M0tbJ/UdP08zojPTDFfqdCJt1g/x8mvyv5TnTT+XUzzvXf5UnRZURhJADABlAAAKAAAilFgNSMCwBJQACSAAAwUsKCgNZZQBC2cBQESWymJYWFaY0rKoYo4L6uvEhw7uPFDQ76I5xuL7C+O6qqxN8xkPmXDJnOmejP2cv5bSEtDoUjW4J3afodljsZpuIOIg416h8SD5McCexeIh4hiNaB+IOIWg4RSJquINWHCPFUOwlJDpFjoooThRdFWFgaaMqFeQgsVuxHDuYvGRlCMzYjYClpU2QuyeheEoLjEmURokpAIiRIKJEBxVFUSAQTnlCzke07/FbXgbOgoNlqIlGgaHEZUBXyOX4bOoURaQcLjzLJWLRWyCLAASCiwBSMCWgoYRgSUFCJGUSNCNAEbKLaKoo1FD0FCSSgosBmALKEQACx7SYsChbMrELkxBGjyRjJU0bPYbvimsGV6r5Zefga5sjeJZOTqS1T5cjXtNF3ZpyvwKNZ0/eLND4U/5i/4q9TaC+JLRq99i0UvxNoRZoceOS8DKzRxiMihpc2KO9nRimhH/AOn4npXTdv8AA28fOWrMK6bg+PmxxrRO2/I9FWmiN8emE+rk5r++koCgNmey7EAk4kLIxh7BwFAnZGAoBAwFASezAUBUSsBQAbMAlhYGYooonZmAUBgAKUANZTYpQzbQAAwrrUAAAAABoCgAEkoCwGagACoFAMUBaIA9BQ1EAsCTIxCRiDJFIgkdEjnkI0JbRE8nCMp2Zhpd4vI0mSLcWZHuo91sx+TbTOnvJWWPiadaSourLku+xTHLHfq7Iy3ok4ywTi7TjJ6P1N+Yj0WTWWUPNGXHLPFSyKKMUdG2Di3mD/
# ... truncated to 50k, original length 1427499
Auch funktionierende Lösungen kann man hinterfragen.
rabehd
Der "normale" Broker
define MQTT2Broker MQTT2_SERVER 1883 global
attr MQTT2Broker autocreate simple
attr MQTT2Broker keepaliveFactor 0
attr MQTT2Broker respectRetain 1
attr MQTT2Broker room Maschinenraum
#   CONNECTS   4920
#   DEF        1883 global
#   FD         54
#   FUUID      677ac038-f33f-294e-fed4-55f0ab6b71b0a5c4
#   NAME       MQTT2Broker
#   NR         128
#   PORT       1883
#   STATE      Initialized
#   TYPE       MQTT2_SERVER
#   eventCount 9841
#   MatchList:
#     1:MQTT2_DEVICE ^.
#   READINGS:
#     2026-05-18 15:36:57   RETAIN          {"Energie/Shelly-01/online":"true","Energie/Shelly-02/online":"true","Energie/Shelly-03/online":"true","Energie/Shelly-04/online":"true","Energie/Shelly-05/online":"true","Heizung/Bad/online":"true","Heizung/WC/online":"true","Klima/Innenklima_WZ/LWT":"Online","Sicherheit/Zustand/Fensterunten":"offen","Sicherheit/Zustand/allesLicht":"aus","blink2mqtt/availability":"offline","blink2mqtt/blink2mqtt_151054202/availability":"online","blink2mqtt/blink2mqtt_151054202/binary_sensor/motion":"False","blink2mqtt/blink2mqtt_151054202/clip_count":"0","blink2mqtt/blink2mqtt_151054202/internal/discovered":"True","blink2mqtt/blink2mqtt_151054202/internal/last_snapshot":"52174.957203944","blink2mqtt/blink2mqtt_151054202/sensor/battery_status":"ok","blink2mqtt/blink2mqtt_151054202/sensor/last_event":"Timed snapshot","blink2mqtt/blink2mqtt_151054202/sensor/last_event_time":"2026-05-18T10:45:00.463880+00:00","blink2mqtt/blink2mqtt_151054202/sensor/temperature":"75","blink2mqtt/blink2mqtt_151054202/sensor/wifi_signal":"-60","blink2mqtt/blink2mqtt_151054202/snapshot":"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
# ... truncated to 50k, original length 1592067
Ist das was anzupassen, so dass alles über einen läuft?
Beta-User
Eigentlich hätte mich erst mal interessiert, warum mehrere Instanzen m2-Device angelegt werden...
retain ist mir übrigens zunehmend suspekt. Könnte zu Verzögerungen führen, wenn sich Clients sehr häufig neu verbinden.
rabehd
Zitat von: Beta-User am 18 Mai 2026, 16:19:19Eigentlich hätte mich erst mal interessiert, warum mehrere Instanzen m2-Device angelegt werden...
Das war das Startproblem
JWRu
Bei mir läuft's jetzt auch mit zwei Servern.
Hat schon jemand herausgefunden, wie man "ARM" bzw. "DISARM" sendet?
ZBox; RasPi 3B; RasPi Zero W; Homematic; Z-Wave; EnOcean, Shelly; DuoFern; Oregon- und Bresser-Sensoren; Steuerung Viessmann-Heizung; ESP32 für Strom-, Wasser-, Gaszähler, Arduino für Rauchmelder und FI-Schutzschalter
rudolfkoenig
ZitatIch muss also einen Weg finden, dem Entwickler von blink2mqtt folgende Wünsche zum Einzubauen zu übermitteln:
 - festes Topic (bisher sehe ich da nur einen prefix zum eintragen)
 - ClientID
Welches Problem sollte ein festes Topic loesen?
rudolfkoenig
Der Ansicht bin ich auch.
Und ich verstehe noch nicht, warum man das Bild im MQTT-Server speichert, um es jedem "Neuankoemmling" auf die Nase zu binden.
JoWiemann
#22
Zitat von: JWRu am 18 Mai 2026, 17:12:00Bei mir läuft's jetzt auch mit zwei Servern.
Ist eigentlich in der Anleitung sauber beschrieben:
<BlinkName>:arm,disarm blink/sync/<BlinkName>/cmd $EVTPART1
<KameraName>:arm,disarm blink/cameras/<KameraName>/cmd $EVTPART1
Meine Umsetzung:
FamKamSys:arm,disarm blink/sync/FamKamSys/cmd $EVTPART1
Haupteingang:arm,disarm blink/cameras/Haupteingang/cmd $EVTPART1
Nebeneingang:arm,disarm blink/cameras/Nebeneingangcmd $EVTPART1
Rundumsicht:arm,disarm blink/cameras/Rundumsicht/cmd $EVTPART1
Wohnbereich:arm,disarm blink/cameras/Wohnbereich/cmd $EVTPART1
Grüße Jörg
Jörg Wiemann
JWRu
ZitatIst eigentlich in der Anleitung sauber beschrieben
In welcher? Ich habe bei blink2mqtt nichts gefunden.
Ist das der Inhalt des Attributs "setList" des MQTT2DEVICE?
(Sorry für die Frage - ich nutze zwar MQTT, bisher aber nur als "Empfänger".)
