[eledigt] 98_version.pm - beim restart von fhem seit heute folgende fehler im log
Begonnen von the ratman, 25 Mai 2026, 09:03:44
Tom111
Auch bei mir, jede Menge Perl Warnungen nach dem Update:
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 219.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 222.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 225.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 228.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 231.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 234.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 237.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 240.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 243.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 246.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 249.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 252.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 255.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 258.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 261.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 264.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 267.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 270.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 273.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 276.
2026.05.25 21:53:29 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 279.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 282.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 285.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 291.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 297.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 390.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 394.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 398.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 402.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 406.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 410.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 414.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 418.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 422.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 426.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 430.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 434.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 749.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 792.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 834.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 993.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 1082.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 1108.
2026.05.25 21:53:30 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 1139.
2026.05.25 21:53:31 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 1990.
2026.05.25 21:53:32 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 3226.
2026.05.25 21:53:32 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 3254.
2026.05.25 21:53:32 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 3292.
2026.05.25 21:53:32 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 3356.
2026.05.25 21:53:32 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 3644.
2026.05.25 21:53:32 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 3664.
FHEM 5.9 auf Raspberry Pi - 3B+ - Stretch-5.10.88+ | Perl v5.24.1 | CUL868 CC1101 - USB - Lite module - V3 FW 1.67
Fritz!Box 7490 OS 07.29 / Fritz!Dect200 / Fritz!Powerline 546E
FS20ST-4/ FS20 DI-5/ FS20LS/ FS20 PIRI-2-KU/ FS20 TFK/ FS20S4A/FS20 SU-3/FS20 S20-3
HMS100TF/FHT80TF-2/ASH2200/S300TH
betateilchen
Entweder warten bis morgen früh zum nächsten update oder vorab die aktuelle Version aus svn holen.
Steht oben beschrieben.
the ratman
hab eben meine brille aufgesetzt: ich sehe heute keine einträge mehr im log nach einem restart.
dank dir für die schnelle arbeit!
→do↑p!dnʇs↓shit←
Tom111
Nach dem heutigen Update läuft alles wieder fehlerfrei!
Danke für die rasante Bearbeitung!
betateilchen
Zitat von: the ratman am 26 Mai 2026, 09:11:06dank dir für die schnelle arbeit!
Zitat von: Tom111 am 26 Mai 2026, 17:24:11Danke für die rasante Bearbeitung!
Naja, ich hatte es kaputtgemacht, dann muss ich es halt auch wieder reparieren :)
