HM-LC-Dim1T-Pl-2
Begonnen von Banana_Joe, 03 Dezember 2013, 13:09:40
Banana_Joe
Hallo Zusammen,
ich habe einen neuen Phasenabschnitt Dimmer vom Typ HM-LC-Dim1T-Pl-2
Config is folgende:
define wzLicht_Stehlampe CUL_HM XXXXXX
attr wzLicht_Stehlampe devInfo 110100
attr wzLicht_Stehlampe firmware 2.2
attr wzLicht_Stehlampe hmClass receiver
attr wzLicht_Stehlampe model HM-LC-Dim1T-Pl-2
attr wzLicht_Stehlampe peerIDs
attr wzLicht_Stehlampe room Wohnzimmer
attr wzLicht_Stehlampe serialNr XXXXXXXX
attr wzLicht_Stehlampe subType dimmer
attr wzLicht_Stehlampe webCmd pct
define FileLog_wzLicht_Stehlampe FileLog /var/log/fhem/wzLicht_Stehlampe-%Y.log wzLicht_Stehlampe
attr FileLog_wzLicht_Stehlampe logtype text
attr FileLog_wzLicht_Stehlampe room Wohnzimmer
Log:
2013-12-03_12:05:19 wzLicht_Stehlampe set_on
2013-12-03_12:05:26 wzLicht_Stehlampe set_off
2013-12-03_12:05:28 wzLicht_Stehlampe MISSING ACK
2013-12-03_12:05:48 wzLicht_Stehlampe RESPONSE TIMEOUT:StatusReq
2013-12-03_12:09:30 wzLicht_Stehlampe set_on
2013-12-03_12:09:32 wzLicht_Stehlampe set_off
2013-12-03_12:09:38 wzLicht_Stehlampe MISSING ACK
2013-12-03_12:48:50 wzLicht_Stehlampe set_27
2013-12-03_12:48:55 wzLicht_Stehlampe MISSING ACK
2013-12-03_12:48:58 wzLicht_Stehlampe set_
2013-12-03_12:49:05 wzLicht_Stehlampe MISSING ACK
2013-12-03_12:49:12 wzLicht_Stehlampe set_14
2013-12-03_12:49:17 wzLicht_Stehlampe set_0
2013-12-03_12:49:21 wzLicht_Stehlampe MISSING ACK
2013-12-03_12:49:34 wzLicht_Stehlampe deviceMsg: off (to broadcast)
2013-12-03_12:49:34 wzLicht_Stehlampe dim: stop:off
2013-12-03_12:49:34 wzLicht_Stehlampe overload: off
2013-12-03_12:49:34 wzLicht_Stehlampe overheat: off
2013-12-03_12:49:34 wzLicht_Stehlampe reduced: off
2013-12-03_12:49:34 wzLicht_Stehlampe off
2013-12-03_12:49:45 wzLicht_Stehlampe set_41
2013-12-03_12:49:56 wzLicht_Stehlampe MISSING ACK
2013-12-03_12:50:12 wzLicht_Stehlampe set_100
2013-12-03_12:50:19 wzLicht_Stehlampe MISSING ACK
2013-12-03_12:50:55 wzLicht_Stehlampe set_80
2013-12-03_12:51:04 wzLicht_Stehlampe MISSING ACK
2013-12-03_12:57:53 wzLicht_Stehlampe set_
2013-12-03_12:57:59 wzLicht_Stehlampe MISSING ACK
Fhem Version 5.3
Hat jemand erfahrung mit dem Zwischenstecker?
1. Falscher Forumbereich (richtig wäre wohl eher das Unterforum Homematic)
2. Fhem Version 5.3 -> das ist nicht Dein Ernst, oder?
Erfahrung mit dem Zwischenstecker: JA, der funktioniert mit einer aktuellen fhem-Version recht gut.
Wuppi68
hast Du den Dimmer auch an FHEM angelernt?
FHEM unter Proxmox als VM
Banana_Joe
@ betateilchen sry evtl. kann ein admin in den richtigen bereich verschieben. Da ich anfänger bin dachte ich es muss hier hinein.
Bisher bestand kein grund upzudaten weil alles lief. Ist der zwischenstecker etwa neu auf dem markt? Ich meine doch das es diesen schon zu zeiten von Fhem 5.3 gab.
@ Wuppi68 ja angelernt ist der stecker mMn, da er ja auch vom COC erkannt wurde.
Zitatangelernt ist der stecker mMn, da er ja auch vom COC erkannt wurde.
Das hat überhaupt nichts zu sagen. Ob er mit fhem gepairt ist, erkennst Du nur in den Informationen zum Device selbst, die Du in fhem findest. Solange da nicht "PairedTo: " mit der korrekten HM-ID Deiner Gegenstelle steht, kannst Du den Dimmer nicht wirklich über fhem nutzen.
Und zum Thema 5.3: Es ist sehr schwer, Supporthinweise für eine so alte Version zu geben. Gerade im Homematic Bereich hat sich innerhalb fhem in den letzten Wochen so viel geändert, dass eine Beurteilung, was in 5.3 funktionieren sollte und was nicht, nahezu ünmöglich ist.
Banana_Joe
OK danke, ich habe den rat beherzigt und siehe da nach Fhem update klappts. Ich bin aber auch ehrlich gesagt immer ein wenig ängstlich wegen updates.
Mir hängt der spruch "never touch a running system" hinterher.
