MAX! dummy Synchronisieren
Begonnen von Himi, 22 Januar 2015, 15:48:41
Himi
Hallo elfrinjo,
deinen Beitrag habe ich im Prinzip verstanden...
den Code von fruit habe ich angepasst von DEF=HeatingThermostat.* in ---> DEF=MAX_0b2632.* Das ist ja mein Wohnzimmer Thermostat.
Beim abspeichern der fhem.config erhalte ich nun folgende Meldung.
ERROR:
IF: no left bracket: Unknown command {, try help. Unknown command my, try help. Unknown command foreach, try help. Unknown command {, try help. IF: no left bracket: Unknown command {, try help. Unknown command fhem, try help. Unknown command }, try help. Unknown command }, try help. Unknown command }, try help. Unknown command elsif, try help. Unknown command {, try help. Unknown command my, try help. Unknown command foreach, try help. Unknown command {, try help. IF: no left bracket: Unknown command {, try help. Unknown command fhem, try help. Unknown command }, try help. Unknown command }, try help. Unknown command }, try help. Unknown command elsif, try help. Unknown command {, try help. Unknown command my, try help. Unknown command foreach, try help. Unknown command {, try help. IF: no left bracket: Unknown command {, try help. Unknown command fhem, try help. Unknown command }, try help. Unknown command }, try help. Unknown command }, try help. Unknown command }, try help. Unknown command my, try help. Unknown command my, try help. Unknown command my, try help. Unknown command foreach, try help. Unknown command {, try help. IF: no left bracket: Unknown command {, try help. Unknown command $eco++, try help. Unknown command }, try help. Unknown command elsif, try help. Unknown command {, try help. Unknown command $auto++, try help. Unknown command }, try help. Unknown command }, try help. IF: no left bracket: Unknown command {, try help. Unknown command fhem, try help. Unknown command }, try help. Unknown command else, try help. Unknown command {, try help. Unknown command fhem, try help. Unknown command }, try help. Unknown command }, try help.
Da stimmt noch was nicht ganz..
Danke im Voruas für die Hilfe!
nesges
Das sieht nach dem Ergebnis einer Mischung von Perl- und fhem-Code aus und ich vermute du hast "IF" geschrieben, wo du hättest "if" schreiben sollen. "IF" ist ein fhem-Modul, "if" ist Perl. Aber um das genauer zu sagen, müsste man deinen Code mal sehen.
Himi
anbei der Code den ich im Beitrag weiter vorne von fruit übernommen und in DEF=MAX_0b2632.* abgeändert habe.
define ecoSwitch_dummy dummy
attr ecoSwitch_dummy room Heat_Control,MAX
attr ecoSwitch_dummy setList auto comfort eco
define eco_Switch_notify notify .*ecoSwitch_dummy.* {
if ( Value ( "ecoSwitch_dummy" ) eq "auto" )
  my @@MAX_HT = devspec2array( "DEF=MAX_0b2632.*" );
  foreach ( @@MAX_HT )
   if ( ReadingsVal ( $_, "mode", "off" ) ne "auto" )
    fhem ( "set $_ desiredTemperature auto" );
elsif ( Value ( "ecoSwitch_dummy" ) eq "eco" )
   if ( ReadingsVal ( $_, "mode", "off" ) ne "eco" )
    fhem ( "set $_ desiredTemperature eco" );
elsif ( Value ( "ecoSwitch_dummy" ) eq "comfort" )
   if ( ReadingsVal ( $_, "mode", "off" ) ne "comfort" )
    fhem ( "set $_ desiredTemperature comfort" );
define eco_Switch_state_notify notify .*(mode|valveposition).* {
my $eco = 0;
my $auto = 0;
  if ( ReadingsVal ( $_, "mode", "101" ) eq "manual" &&  ReadingsVal ( $_, "desiredTemperature", "30" ) eq ReadingsVal ( $_, "ecoTemperature", "30" ) )
   $eco++;
  elsif ( ReadingsVal ( $_, "mode", "101" ) eq "auto" )
   $auto++;
if ( ( $eco == 0 ) && ( $auto != 0 ) )
  fhem ( "set ecoSwitch_dummy auto" );
else
  fhem ( "set ecoSwitch_dummy eco" );
elfrinjo
#18
... bitte ignorieren ... hier stand viel Mist.
nesges
Zitat von: Himi am 29 Januar 2015, 16:50:52anbei der Code
Hast du den Code direkt so wie er hier steht in die fhem.cfg eingetragen? Dann hast du das gleiche Problem wie der Nachbarthread: Zu wenige Semikolons. http://fhem.de/commandref_DE.html#command erklärt's.
Harald
Wenn ich das richtig sehe, hat Himi ein paar geschwungene Klammern zu viel. Ich meine, dass jeweils in der Zeile mit dem "define" ans Ende keine solche Klammer "{" gehört und am Ende jedes Blocks ist dann "}" auch zu viel, oder?
Harald
Router:AVM7590 1&1 FW:FRITZ!OS 07.56 Anbindung:1&1 50/10 Mb/s, WLAN-Repeater 300E
ELV MAX!Cube, 7xThermostat, ECO, RasPi 4B mit bullseye auf Festplatte,
CUL V 1.67, JeeLink v3_10.1c, nanoCUL, 1xS300TH, 4xHMS100T, 4xELRO, 1xTFA, 2xMAX_FK
ELV MAX!1.4.5, FHEM 5.7 auf RasPi, Kostal PIKO plus
fruit
I have no idea what is causing that error but...
"DEF=HeatingThermostat.*" matches HeatingThermostat + any further characters eg. HeatingThermostat MAX_0b2632
"DEF=MAX_0b2632.*" matches MAX_0b2632 + any further characters - there are none! There is no DEF HeatingThermostat MAX_0b2632!
It should be
DEF HeatingThermostat 0b2632
Try "DEF=.*0b2632"
Feel free to follow up in German if you prefer
elfrinjo
#22
Sorry - meine letzten Posts sind leider in eine etwas falsche Richtung gelaufen....
Wenn du die fhem.cfg direkt editierst, versuch mal bitte Folgendes:
define eco_Switch_notify notify .*ecoSwitch_dummy.* {\
if ( Value ( "ecoSwitch_dummy" ) eq "auto" )\
  my @@MAX_HT = devspec2array( "DEF=HeatingThermostat.*" );;\
  foreach ( @@MAX_HT )\
   if ( ReadingsVal ( $_, "mode", "off" ) ne "auto" )\
    fhem ( "set $_ desiredTemperature auto" );;\
elsif ( Value ( "ecoSwitch_dummy" ) eq "eco" )\
   if ( ReadingsVal ( $_, "mode", "off" ) ne "eco" )\
    fhem ( "set $_ desiredTemperature eco" );;\
elsif ( Value ( "ecoSwitch_dummy" ) eq "comfort" )\
   if ( ReadingsVal ( $_, "mode", "off" ) ne "comfort" )\
    fhem ( "set $_ desiredTemperature comfort" );;\
define eco_Switch_state_notify notify .*(mode|valveposition).* {\
my $eco = 0;;\
my $auto = 0;;\
  if ( ReadingsVal ( $_, "mode", "101" ) eq "manual" &&  ReadingsVal ( $_, "desiredTemperature", "30" ) eq ReadingsVal ( $_, "ecoTemperature", "30" ) )\
   $eco++;;\
  elsif ( ReadingsVal ( $_, "mode", "101" ) eq "auto" )\
   $auto++;;\
if ( ( $eco == 0 ) && ( $auto != 0 ) )\
  fhem ( "set ecoSwitch_dummy auto" );;\
else\
  fhem ( "set ecoSwitch_dummy eco" );;\
Harald
Ich habe übersehen, dass Himi's Code in der fhem.cfg steht. elfrinjo hat das erkannt und das richtig gestellt. Was ich schrieb, war also nicht richtig. Entschuldigt bitte ...
Harald
elfrinjo
#24
Harald
ich habe mehr dummes Zeug geredet :)
@Himi, hier wird ein wenig auf die unterschiedlichen Methoden zur Konfiguration eingegangen:
https://groups.google.com/forum/#!topic/fhem-users/z2nXv8Kx-Ck
http://www.fhemwiki.de/wiki/Konfiguration
Himi
Hallo elfrinjo,
jetzt sieht es besser aus, keine Fehlermeldung mehr bei der direkt-editierung in der fhem.config
Morgen werde ich die Funktion testen.
Melde mich wieder.
Ich bin begeistert über euere Unterstützung.
Himi
Himi
sorry, melde ich erst jetzt zurück.
Habe den dummy getestet, der Modus aller eigesetzten HK-Thermostate wird nun richtig ausgelesen und im dummy (z.B. "auto") richtig dargestellt.
Meine gestellte Frage ist somit mit euerer Hilfe beantwortet.  -DANKE-
Nachfolgend nochmals der funktionierente Code-Schnipsel...
Nun hätte ich noch einen Wunsch, wie kann ich den dummy so erweitern, das ich den Heizungsmodus im Haus auch umschalten kann?
Das state sollte sich natürlich immer mit aktualisieren.
my $eco = 0;;\
my $auto = 0;;\
   $eco++;;\
   $auto++;;\
else\
elfrinjo
der Code zum umschalten ist eigentlich schon da. Das, was unter dem eco_Switch_notify steht muss nur noch ausgelöst werden.
Versuch doch mal dieses Attribut:
attr ecoSwitch_dummy devStateIcon auto:Heizung_Hauptschalter.on:go eco:Heizung_Hauptschalter.off:go
Das Attribut tut Folgendes:
Statt auto oder eco wird ein Icon angezeigt.
Bei Klick auf das Icon wir das Event go (Name ist egal) generiert, was eco_Switch_notify auslöst, welches dann die Heizungen umschaltet.
Der Dummy wird anschließend über die bisherigen Mechanismen aktualisiert.
Himi
habe das Attribut im ecoSwitch_dummy eingebaut...
Es wird aber kein Icon sichtbar. (auch nicht nach einem Restart von Fhem)
nachfolgend mein Code
attr ecoSwitch_dummy devStateIcon auto:HeatingThermostat.on:go eco:HeatingThermostat.off:go
elfrinjo
#29
Also zumindest in meinem FHEM ist HeatingThermostat.on auch kein gültiges Icon.
Zwischen den Doppelpunkten muss schon eines von den Symbolen stehen, die über Select Icon oder Extend devStateIcon auswählbar sind.
Das devStateIcon fun ktioniert so:
                                    ^               ^            ^   ^Und hier das Ganze nochmal falls STATE = eco
                                    |               |            +--- Wenn das Icon gedrückt wird generiere ein
                                    |               |                 Event "go" für den Dummy
                                    |               +--- Zeige das Symbol Heizung_Hauptschalter.on an
                                    +--- Falls der STATE des dummy auto ist
PS: Ich hoffe das ist lesbar...
