Neues Modul - 74_Unifi - Für den Ubiquiti Networks (UBNT) - Unifi Controller
Begonnen von rapster, 23 August 2015, 02:12:04
roedert
Gibts eigentlich schon Neuigkeiten zu der Kompatibilität mit der neuen Cloudkey-Firmware?
andies
Bei mir werden die Readings nicht aktualisiert und ich habe diese Meldungen im Log, weiß da jemand weiter
2021.03.05 13:30:39 5: Unifi (Unifi_Notify) - executed.
2021.03.05 13:30:40 5: Unifi: get called with ?.
2021.03.05 13:30:42 5: Unifi (Unifi_Notify) - executed.
2021.03.05 13:30:45 5: Unifi: set called with update
2021.03.05 13:30:45 4: Unifi: set update
2021.03.05 13:30:45 5: Unifi (Unifi_DoUpdate) - executed.
2021.03.05 13:30:45 5: Unifi (Unifi_GetEvents_Send) - executed.
2021.03.05 13:30:45 5: Unifi: get called with ?.
2021.03.05 13:30:45 5: Unifi (Unifi_GetEvents_Receive) - executed.
2021.03.05 13:30:45 5: Unifi (Unifi_GetEvents_Receive) - Failed! - state:'error.decode_json' - msg:'malformed JSON string, neither tag, array, object, number, string or atom, at character offset 0 (before "Unauthorized") at ./FHEM/74_Unifi.pm line 1408.
2021.03.05 13:30:45 5: Unifi (Unifi_GetUnarchivedAlerts_Send) - executed.
2021.03.05 13:30:45 5: Unifi (Unifi_GetUnarchivedAlerts_Receive) - executed.
2021.03.05 13:30:45 5: Unifi (Unifi_GetUnarchivedAlerts_Receive) - Failed! - state:'error.decode_json' - msg:'malformed JSON string, neither tag, array, object, number, string or atom, at character offset 0 (before "Unauthorized") at ./FHEM/74_Unifi.pm line 1367.
2021.03.05 13:30:45 5: Unifi (Unifi_GetClients_Send) - executed.
2021.03.05 13:30:45 5: Unifi (Unifi_GetClients_Receive) - executed.
2021.03.05 13:30:45 5: Unifi (Unifi_GetClients_Receive) - Failed! - state:'error.decode_json' - msg:'malformed JSON string, neither tag, array, object, number, string or atom, at character offset 0 (before "Unauthorized") at ./FHEM/74_Unifi.pm line 1015.
2021.03.05 13:30:45 5: Unifi (Unifi_GetClientInsights_Send) - executed.
2021.03.05 13:30:45 5: Unifi (Unifi_GetClientInsights_Receive) - executed.
2021.03.05 13:30:45 5: Unifi (Unifi_GetClientInsights_Receive) - Failed! - state:'error.decode_json' - msg:'malformed JSON string, neither tag, array, object, number, string or atom, at character offset 0 (before "Unauthorized") at ./FHEM/74_Unifi.pm line 1070.
2021.03.05 13:30:45 5: Unifi (Unifi_GetVoucherList_Send) - executed.
2021.03.05 13:30:46 5: Unifi (Unifi_GetVoucherList_Receive) - executed.
2021.03.05 13:30:46 5: Unifi (Unifi_GetVoucherList_Receive) - Failed! - state:'error.decode_json' - msg:'malformed JSON string, neither tag, array, object, number, string or atom, at character offset 0 (before "Unauthorized") at ./FHEM/74_Unifi.pm line 2004.
Das ging komischerweise vor einer Woche; ich kann mich nicht erinnern etwas an FHEM geändert zu haben (Unifi hatte ein update).
FHEM 6.3 auf RaspPi4 (Raspbian:  6.6.28+; Perl: v5.36.0)
Christoph Morrison
Sieht so aus als könnte sich das FHEM-Modul nicht mehr mit dem Controller verbinden (Unauthorized). Die zurückgelieferten Daten sind dann kein valides JSON und das Modul schreibt einen Fehler.
Stimmt die Adresse noch?
andies
ja, die stimmt noch -aber ich kann mich tatsächlich nicht einloggen. Das Prozedere scheint sich da geändert zu haben. Danke für den Tipp, ich forsche da mal weiter.
andies
Kann es sein, dass sich der port geändert hat? Die weboberfläche ist auch eine ganz andere.
root@CloudKey:~# netstat -nlp
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 127.0.0.1:7445          0.0.0.0:*               LISTEN      12800/evostreamms
tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      1219/systemd-resolv
tcp        0      0 0.0.0.0:7446            0.0.0.0:*               LISTEN      12800/evostreamms
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      1262/sshd
tcp        0      0 0.0.0.0:7447            0.0.0.0:*               LISTEN      12800/evostreamms
tcp        0      0 127.0.0.1:9080          0.0.0.0:*               LISTEN      29590/ulp-go-app
tcp        0      0 127.0.0.1:7448          0.0.0.0:*               LISTEN      12800/evostreamms
tcp        0      0 127.0.0.1:1112          0.0.0.0:*               LISTEN      12800/evostreamms
tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      1274/postgres
tcp        0      0 127.0.0.1:7449          0.0.0.0:*               LISTEN      12333/node
tcp        0      0 127.0.0.1:5433          0.0.0.0:*               LISTEN      12059/postgres
tcp        0      0 127.0.0.1:7450          0.0.0.0:*               LISTEN      12333/node
tcp        0      0 0.0.0.0:7550            0.0.0.0:*               LISTEN      12800/evostreamms
tcp        0      0 127.0.0.1:9090          0.0.0.0:*               LISTEN      1054/ubnt-systemhub
tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      1219/systemd-resolv
tcp        0      0 127.0.0.1:27117         0.0.0.0:*               LISTEN      5583/bin/mongod
tcp        0      0 127.0.0.1:7440          0.0.0.0:*               LISTEN      12800/evostreamms
tcp        0      0 0.0.0.0:7441            0.0.0.0:*               LISTEN      12800/evostreamms
tcp        0      0 127.0.0.1:7634          0.0.0.0:*               LISTEN      1038/hddtemp
tcp6       0      0 :::7443                 :::*                    LISTEN      12333/node
tcp6       0      0 :::7444                 :::*                    LISTEN      12333/node
tcp6       0      0 :::22                   :::*                    LISTEN      1262/sshd
tcp6       0      0 :::8888                 :::*                    LISTEN      12333/node
tcp6       0      0 ::1:5432                :::*                    LISTEN      1274/postgres
tcp6       0      0 ::1:5433                :::*                    LISTEN      12059/postgres
tcp6       0      0 :::7877                 :::*                    LISTEN      12333/node
tcp6       0      0 :::6789                 :::*                    LISTEN      4711/java
tcp6       0      0 :::7080                 :::*                    LISTEN      12333/node
tcp6       0      0 :::8843                 :::*                    LISTEN      4711/java
tcp6       0      0 :::5355                 :::*                    LISTEN      1219/systemd-resolv
tcp6       0      0 :::8880                 :::*                    LISTEN      4711/java
tcp6       0      0 :::8080                 :::*                    LISTEN      4711/java
tcp6       0      0 127.0.0.1:8081          :::*                    LISTEN      4711/java
tcp6       0      0 :::7442                 :::*                    LISTEN      12333/node
udp        0      0 0.0.0.0:10001           0.0.0.0:*                           12333/node
udp        0      0 192.168.2.15:42938      0.0.0.0:*                           12333/node
udp        0      0 127.0.0.53:53           0.0.0.0:*                           1219/systemd-resolv
udp        0      0 192.168.2.15:68         0.0.0.0:*                           542/systemd-network
udp        0      0 192.168.2.15:123        0.0.0.0:*                           1264/ntpd
udp        0      0 127.0.0.1:123           0.0.0.0:*                           1264/ntpd
udp        0      0 0.0.0.0:123             0.0.0.0:*                           1264/ntpd
udp        0      0 0.0.0.0:56058           0.0.0.0:*                           1023/avahi-daemon:
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1023/avahi-daemon:
udp        0      0 0.0.0.0:5355            0.0.0.0:*                           1219/systemd-resolv
udp6       0      0 :::10001                :::*                                4711/java
udp6       0      0 :::1900                 :::*                                4711/java
udp6       0      0 fe80::7683:c2ff:fe1:123 :::*                                1264/ntpd
udp6       0      0 2003:cf:5706:c900:7:123 :::*                                1264/ntpd
udp6       0      0 ::1:123                 :::*                                1264/ntpd
udp6       0      0 :::123                  :::*                                1264/ntpd
udp6       0      0 :::55654                :::*                                1023/avahi-daemon:
udp6       0      0 fe80::7683:c2ff:fe1:546 :::*                                542/systemd-network
udp6       0      0 192.168.2.15:51947      :::*                                4711/java
udp6       0      0 :::5353                 :::*                                4711/java
udp6       0      0 :::5353                 :::*                                1023/avahi-daemon:
udp6       0      0 :::5355                 :::*                                1219/systemd-resolv
udp6       0      0 :::3478                 :::*                                4711/java
raw6       0      0 :::58                   :::*                    7           542/systemd-network
Active UNIX domain sockets (only servers)
Proto RefCnt Flags       Type       State         I-Node   PID/Program name     Path
unix  2      [ ACC ]     STREAM     LISTENING     93981    12059/postgres       /var/run/postgresql/.s.PGSQL.5433
unix  2      [ ACC ]     STREAM     LISTENING     39196    1/init               /var/run/avahi-daemon/socket
unix  2      [ ACC ]     STREAM     LISTENING     55257    5583/bin/mongod      /usr/lib/unifi/run/mongodb-27117.sock
unix  2      [ ACC ]     STREAM     LISTENING     39207    1/init               /var/run/dbus/system_bus_socket
unix  2      [ ACC ]     STREAM     LISTENING     96855    12759/ubnt_avcodec_  /var/run/unifi-protect/transcoder
unix  2      [ ACC ]     STREAM     LISTENING     157831   29590/ulp-go-app     /run/ulp-go/jsonrpc.sock
unix  2      [ ACC ]     STREAM     LISTENING     44685    1274/postgres        /var/run/postgresql/.s.PGSQL.5432
unix  2      [ ACC ]     STREAM     LISTENING     16282    1/init               /run/systemd/private
unix  2      [ ACC ]     STREAM     LISTENING     16296    1/init               /run/systemd/fsck.progress
unix  2      [ ACC ]     STREAM     LISTENING     16307    1/init               /run/systemd/journal/stdout
unix  2      [ ACC ]     SEQPACKET  LISTENING     462      1/init               /run/udev/control
Das device
   DEF        cloudkey.fritz.box 443 crypt:*********** crypt:*********** 300
   FUUID      5e244be7-f33f-1115-db34-394dc6a8906d8bfd
   FVERSION   74_Unifi.pm:0.235000/2021-01-09
   LASTInputDev Unifi
   MSGCNT     670825
   NAME       Unifi
   NOTIFYDEV  global
   NR         255
   NTFY_ORDER 50-Unifi
   STATE      disconnected
   TYPE       Unifi
   UC_VERSION unknown
   Unifi_MSGCNT 670825
   Unifi_TIME 2021-03-05 13:23:37
   VERSION    3.5.2
Christoph Morrison
Port 443 stimmt schon, aber ich glaube, der Endpunkt hat sich geändert. Ich habe auf jeden Fall das gleiche Problem wie du.
andies
Ich habe eine neue Firmware aufgespielt und komme nun nicht mehr an die Weboberfläche. Oh mann, manchmal nervt unifi...
Newbie
ich hab die aktuelle Beta-Version 6.1.64 installiert und keine Probleme feststellen können.
viele Grüße
Jens
P.S.: attr Unifi isUDM 1 gesetzt?
fhem-6.1 (configDB+DbLog)  auf ODROID-XU4
andies
Wolle02
Tja, jetzt hat es mich mit meiner UDM scheinbar auch erwischt. state steht auf disconnected und im Logfile finde ich mit Verbose 5 folgendes:
2021.03.10 14:05:40 5: UniFi_UDM (Unifi_Login_Send) - executed.
2021.03.10 14:05:40 5: UniFi_UDM (Unifi_Login_Receive) - executed.
2021.03.10 14:05:40 5: UniFi_UDM (Unifi_Login_Receive) - Login Failed! - state:'error.decode_json' - msg:'malformed JSON string, neither tag, array, object, number, string or atom, at character offset 1 (before "<!doctype html>\n<ht...") at ./FHEM/74_Unifi.pm line 937.
2021.03.10 14:05:40 5: UniFi_UDM (Unifi_Login_Receive) - Connect/Login to Unifi-Controller failed. Will try again after interval...
2021.03.10 14:06:10 5: UniFi_UDM (Unifi_Login_Send) - executed.
2021.03.10 14:06:10 5: UniFi_UDM (Unifi_Login_Receive) - executed.
2021.03.10 14:06:10 5: UniFi_UDM (Unifi_Login_Receive) - Login Failed! - state:'error.decode_json' - msg:'malformed JSON string, neither tag, array, object, number, string or atom, at character offset 1 (before "<!doctype html>\n<ht...") at ./FHEM/74_Unifi.pm line 937.
2021.03.10 14:06:10 5: UniFi_UDM (Unifi_Login_Receive) - Connect/Login to Unifi-Controller failed. Will try again after interval...
2021.03.10 14:06:40 5: UniFi_UDM (Unifi_Login_Send) - executed.
2021.03.10 14:06:41 5: UniFi_UDM (Unifi_Login_Receive) - executed.
2021.03.10 14:06:41 5: UniFi_UDM (Unifi_Login_Receive) - Login Failed! - state:'error.decode_json' - msg:'malformed JSON string, neither tag, array, object, number, string or atom, at character offset 1 (before "<!doctype html>\n<ht...") at ./FHEM/74_Unifi.pm line 937.
2021.03.10 14:06:41 5: UniFi_UDM (Unifi_Login_Receive) - Connect/Login to Unifi-Controller failed. Will try again after interval...
2021.03.10 14:07:11 5: UniFi_UDM (Unifi_Login_Send) - executed.
2021.03.10 14:07:11 5: UniFi_UDM (Unifi_Login_Receive) - executed.
2021.03.10 14:07:11 5: UniFi_UDM (Unifi_Login_Receive) - Login Failed! - state:'error.decode_json' - msg:'malformed JSON string, neither tag, array, object, number, string or atom, at character offset 1 (before "<!doctype html>\n<ht...") at ./FHEM/74_Unifi.pm line 937.
2021.03.10 14:07:11 5: UniFi_UDM (Unifi_Login_Receive) - Connect/Login to Unifi-Controller failed. Will try again after interval...
2021.03.10 14:07:41 5: UniFi_UDM (Unifi_Login_Send) - executed.
2021.03.10 14:07:41 5: UniFi_UDM (Unifi_Login_Receive) - executed.
2021.03.10 14:07:41 5: UniFi_UDM (Unifi_Login_Receive) - Login Failed! - state:'error.decode_json' - msg:'malformed JSON string, neither tag, array, object, number, string or atom, at character offset 1 (before "<!doctype html>\n<ht...") at ./FHEM/74_Unifi.pm line 937.
Ist das mal wieder nur bei den UDMs so und mit den USGs geht es immer noch?
Mitch
Kann man denn den Autocreate der Switche irgendwie ausschalten?
FHEM im Proxmox Container
aski71
ich bin neuer Benutzer des Moduls und habe kriege leider keine Clients gelistet.
2021.03.13 22:39:28 1: UNIFI (Unifi_GetSysinfo_Receive) - Failed! - state:'error' - msg:'api.err.NoSiteContext' - This error indicates that the <siteID> in your definition is wrong. Try to modify your definition with <sideID> = default.
2021.03.13 22:39:28 5: UNIFI (Unifi_UsergroupRestJson_Receive) - executed.
2021.03.13 22:39:28 1: UNIFI (Unifi_UsergroupRestJson_Receive) - Failed! - state:'error' - msg:'api.err.NoSiteContext' - This error indicates that the <siteID> in your definition is wrong. Try to modify your definition with <sideID> = default.
Meine Site-ID hat einen eigenen Namen.
Ich habe in der Definition schon alles versucht:
Ohne Angabe von Site-ID, mit dem Namen default, mit meinem eigenen Sitenamen. Ich kriege aber immer den gleichen Fehler.
Der grundsätzliche Connect geht.
Wer kann helfen?
Danke!
wg25
Zitat von: wg25 am 01 März 2021, 14:35:36
bei mir funktioniert ein disconnectClient nicht mehr. Benutze ich normalerweise, um ein "verlorengegangenen" ESP32 wieder ins Netz zu holen. Das Modul ist verbunden mit einer UDM (state ist connected), aber irgendwie lassen sich keine set-Befehle mehr absetzen, block/unblock geht auch nicht mehr, sehe ich gerade.
Ist das ein bekanntes Problem? Gibt es eine Lösung?
Bin ich tatsächlich alleine mit dem Problem?
andies
Nein, ich kann nichtmal connecten. Anscheinend ein update und dann war Schluss mit dem Zugriff.
Wolle02
Ich habe gestern ein FHEM Upate gefahren. Kurioserweise kann ich jetzt wieder connecten. Dabei wurde aber laut Changelog am Modul gar nicht geändert?
