(gelöst) nach Update 06.12. -> Error messages while initializing FHEM:
Begonnen von MacDad, 06 Dezember 2015, 14:40:10
MacDad
habe gerade ein Update gemacht und bekomme - auf der FHEM Oberfläche - folgende Meldungen angezeigt:
Error essages while initializing FHEM:
configfile: EG.woz.HZT.Fenster_Clima already defined, delete it first
EG.woz.HZT.Fenster_Clima: unknown attribute model. Type 'attr EG.woz.HZT.Fenster_Clima ?' for a detailed list.
EG.woz.HZT.Fenster_Clima: unknown attribute peerIDs. Type 'attr EG.woz.HZT.Fenster_Clima ?' for a detailed list.
OG.duz.HZT_Clima already defined, delete it first
OG.duz.HZT_Clima: unknown attribute model. Type 'attr OG.duz.HZT_Clima ?' for a detailed list.
OG.duz.HZT_Clima: unknown attribute peerIDs. Type 'attr OG.duz.HZT_Clima ?' for a detailed list.
OG.baz.HZT_Clima already defined, delete it first
OG.baz.HZT_Clima: unknown attribute model. Type 'attr OG.baz.HZT_Clima ?' for a detailed list.
OG.baz.HZT_Clima: unknown attribute peerIDs. Type 'attr OG.baz.HZT_Clima ?' for a detailed list.
OG.anz.HZT_Clima already defined, delete it first
OG.anz.HZT_Clima: unknown attribute model. Type 'attr OG.anz.HZT_Clima ?' for a detailed list.
OG.anz.HZT_Clima: unknown attribute peerIDs. Type 'attr OG.anz.HZT_Clima ?' for a detailed list.
DG.sfz.HZT_Clima already defined, delete it first
DG.sfz.HZT_Clima: unknown attribute model. Type 'attr DG.sfz.HZT_Clima ?' for a detailed list.
DG.sfz.HZT_Clima: unknown attribute peerIDs. Type 'attr DG.sfz.HZT_Clima ?' for a detailed list.
EG.gwc.HZT_Clima already defined, delete it first
EG.gwc.HZT_T: unknown attribute model. Type 'attr EG.gwc.HZT_Clima ?' for a detailed list.
EG.gwc.HZT_Clima: unknown attribute peerIDs. Type 'attr EG.gwc.HZT_Clima ?' for a detailed list.
Das Logfile ist auch voll mit Meldungen ... was ist denn hier falsch gelaufen?
Gruß Dirk
RPI 2 mit FHEM 5.8
FB 7390 OS 6.83 | Synology DS 214+ DSM
VU+: 1 x Solo4k & 2 Solo2 VTi 11.xx.xx
SONOS: BRIDGE | 8x PLAY:1 | 1x PLAY:5 | 1x SUB Vers. 8.1.1
HMLAN: HM-Sec-SC-2 |-Sec-RHS |-CC-RT-DN |-LC-Bl1PBU-FM |-LC-Sw1PBU-FM |-LC-Sw1-FM |-ES-PMSw1-Pl |-WDS10-TH-O |-PBI-4-F
viegener
Irgendetwas scheint in Deinem Configfile --> fhem.cfg durcheinander/falsch zu sein.
Es gibt einen Thread hier: http://forum.fhem.de/index.php/topic,45158.0.html dass u.U. die Reihenfolge im cfg-File durcheinandergerät. Vielleicht hat es etwas damit zu tun?
Vielleicht kannst Du ja den cfg-File oder die relevanten Teile hier posten?
MacDad
#2
Danke für die Info :-)
Ich habe vorm Update meine 99_MyUtils.pm um eine weitere Temperaturkiste ergänzt.
Kann es damit zusammen hängen?
Anbei meine fhem.cfg
RPI 2 mit FHEM 5.8
franky08
Ui, wer soll denn das lesen? Besser als Anhang oder in Code Tags posten
VG
Frank
mit FHEM aktuell
MacDad
Hallo Frank,
ich bekomme die CODE nicht angezeigt, nur in der Vorschau!
Wenn ich auf speichern gehe, sind die CODEs wieder weg.
Wie kann ich die fhem.cfg denn als Anhang hier posten?
Danke, Gruß Dirk
RPI 2 mit FHEM 5.8
franky08
Als Datei-Anhang einfach anhängen unter "Erweiterte Optionen"  ;)
mit FHEM aktuell
MacDad
ups, sorry ... aber wie komme ich an die fhem.cfg?
Wo liegt die denn, damit ich darauf zugreifen kann?
Aus FHEM heraus klappt das irgendwie nicht.
Gruß Dirk
RPI 2 mit FHEM 5.8
franky08
Mit einem ftp Prog. oder anderen aus opt/fhem (bei den meisten Linuxen) herunterladen und lokal speichern.
P.S. ich nutze unter MAC OSX Filezilla zum kopieren
VG
Frank
mit FHEM aktuell
MacDad
#8
Ich habe kein ftp Programm.
Wenn ich mich übers Terminal am Mac einlogge, komme ich auf das Verzeichnis und sehe auch die fhem.cfg.
Kann ich diese auch von hier aus kopieren?
Ist heute nicht mein Tag ... sorry
Gruß Dirk
PS. ich glaube ich habe, siehe Anhang.
RPI 2 mit FHEM 5.8
franky08
mit FHEM aktuell
MacDad
... ein Versuch per CODE
define ActionDetector CUL_HM 000000
attr ActionDetector event-on-change-reading .*
attr ActionDetector model ActionDetector
define OG.arz.TFK CUL_HM 27AA2C
attr OG.arz.TFK IODev HMLAN1
attr OG.arz.TFK actCycle 028:00
attr OG.arz.TFK actStatus dead
attr OG.arz.TFK autoReadReg 4_reqStatus
attr OG.arz.TFK devStateIcon open:fts_window_2w_tilt@red closed:fts_window_2w@green
attr OG.arz.TFK expert 2_full
attr OG.arz.TFK firmware 2.4
attr OG.arz.TFK group Fenster
attr OG.arz.TFK model HM-SEC-SC-2
attr OG.arz.TFK peerIDs 00000000,
attr OG.arz.TFK room CUL_HM,OG_Arbeitszimmer
attr OG.arz.TFK serialNr LTK0008094
attr OG.arz.TFK subType threeStateSensor
define OG.anz.TFK CUL_HM 27B067
attr OG.anz.TFK IODev HMLAN1
attr OG.anz.TFK actCycle 028:00
attr OG.anz.TFK actStatus dead
attr OG.anz.TFK autoReadReg 4_reqStatus
attr OG.anz.TFK devStateIcon open:fts_window_2w_tilt@red closed:fts_window_2w@green
attr OG.anz.TFK expert 2_full
attr OG.anz.TFK firmware 2.4
attr OG.anz.TFK group Fenster
attr OG.anz.TFK model HM-SEC-SC-2
attr OG.anz.TFK peerIDs 00000000,
attr OG.anz.TFK room CUL_HM,OG_Ankleidezimmer
attr OG.anz.TFK serialNr LTK0006505
attr OG.anz.TFK subType threeStateSensor
define FileLog_OG.anz.TFK FileLog ./log/OG.anz.TFK-%Y.log OG.anz.TFK
attr FileLog_OG.anz.TFK logtype text
attr FileLog_OG.anz.TFK room CUL_HM
define OG.baz.TFK CUL_HM 27FB5C
attr OG.baz.TFK IODev HMLAN1
attr OG.baz.TFK IOgrp vccu:HMLAN1
attr OG.baz.TFK actCycle 028:00
attr OG.baz.TFK actStatus alive
attr OG.baz.TFK autoReadReg 4_reqStatus
attr OG.baz.TFK devStateIcon open:fts_window_1w_tilt@red closed:fts_window_1w@green
attr OG.baz.TFK expert 2_full
attr OG.baz.TFK firmware 2.4
attr OG.baz.TFK group Fenster
attr OG.baz.TFK model HM-SEC-SC-2
attr OG.baz.TFK room CUL_HM,OG_Badezimmer
attr OG.baz.TFK serialNr LTK0005662
attr OG.baz.TFK subType threeStateSensor
define FileLog_OG.baz.TFK FileLog ./log/OG.baz.TFK-%Y.log OG.baz.TFK
attr FileLog_OG.baz.TFK logtype text
attr FileLog_OG.baz.TFK room CUL_HM
define OG.duz.TFK.alt CUL_HM 27FA32
attr OG.duz.TFK.alt IODev HMLAN1
attr OG.duz.TFK.alt IOgrp vccu:HMLAN1
attr OG.duz.TFK.alt actCycle 028:00
attr OG.duz.TFK.alt actStatus dead
attr OG.duz.TFK.alt autoReadReg 4_reqStatus
attr OG.duz.TFK.alt devStateIcon open:fts_window_2w_tilt@red closed:fts_window_2w@green .*:fts_window_2w
attr OG.duz.TFK.alt expert 2_full
attr OG.duz.TFK.alt firmware 2.4
attr OG.duz.TFK.alt group Fenster
attr OG.duz.TFK.alt model HM-SEC-SC-2
attr OG.duz.TFK.alt peerIDs 00000000,
attr OG.duz.TFK.alt room OG_Duschzimmer,CUL_HM
attr OG.duz.TFK.alt serialNr LTK0005672
attr OG.duz.TFK.alt subType threeStateSensor
define FileLog_OG.duz.TFK.alt FileLog ./log/OG.duz.TFK.alt-%Y.log OG.duz.TFK.alt
attr FileLog_OG.duz.TFK.alt logtype text
attr FileLog_OG.duz.TFK.alt room CUL_HM
define EG.gwc.TFK CUL_HM 2DE892
attr EG.gwc.TFK IODev HMLAN1
attr EG.gwc.TFK IOgrp vccu:HMLAN1
attr EG.gwc.TFK actCycle 028:00
attr EG.gwc.TFK actStatus alive
attr EG.gwc.TFK autoReadReg 4_reqStatus
attr EG.gwc.TFK devStateIcon open:fts_window_1w_tilt@red closed:fts_window_1w@green
attr EG.gwc.TFK expert 2_full
attr EG.gwc.TFK firmware 2.4
attr EG.gwc.TFK group Fenster
attr EG.gwc.TFK model HM-SEC-SC-2
attr EG.gwc.TFK peerIDs 00000000,27EE6D03,
attr EG.gwc.TFK room EG_Gäste WC,CUL_HM
attr EG.gwc.TFK serialNr LTK0053415
attr EG.gwc.TFK subType threeStateSensor
define FileLog_EG.gwc.TFK FileLog ./log/EG.gwc.TFK-%Y.log EG.gwc.TFK
attr FileLog_EG.gwc.TFK logtype text
attr FileLog_EG.gwc.TFK room CUL_HM
define EG.kue.TFK CUL_HM 2DE899
attr EG.kue.TFK IODev HMLAN1
attr EG.kue.TFK actCycle 028:00
attr EG.kue.TFK actStatus dead
attr EG.kue.TFK autoReadReg 4_reqStatus
attr EG.kue.TFK devStateIcon open:fts_window_1w_tilt@red closed:fts_window_1w@green
attr EG.kue.TFK expert 2_full
attr EG.kue.TFK firmware 2.4
attr EG.kue.TFK group Fenster
attr EG.kue.TFK model HM-SEC-SC-2
attr EG.kue.TFK room CUL_HM,EG_Küche
attr EG.kue.TFK serialNr LTK0053422
attr EG.kue.TFK subType threeStateSensor
define FileLog_EG.kue.TFK FileLog ./log/EG.kue.TFK-%Y.log EG.kue.TFK
attr FileLog_EG.kue.TFK logtype text
attr FileLog_EG.kue.TFK room CUL_HM
define EG.woz.TFK.Terrassentuer CUL_HM 2DF113
attr EG.woz.TFK.Terrassentuer IODev HMLAN1
attr EG.woz.TFK.Terrassentuer IOgrp vccu:HMLAN1
attr EG.woz.TFK.Terrassentuer actCycle 028:00
attr EG.woz.TFK.Terrassentuer actStatus alive
attr EG.woz.TFK.Terrassentuer autoReadReg 4_reqStatus
attr EG.woz.TFK.Terrassentuer devStateIcon open:fts_door_slide_open_m@red closed:fts_door_slide_m@green
attr EG.woz.TFK.Terrassentuer expert 2_full
attr EG.woz.TFK.Terrassentuer firmware 2.4
attr EG.woz.TFK.Terrassentuer group Fenster
attr EG.woz.TFK.Terrassentuer model HM-SEC-SC-2
attr EG.woz.TFK.Terrassentuer peerIDs 00000000,
attr EG.woz.TFK.Terrassentuer room CUL_HM,EG_Wohnzimmer
attr EG.woz.TFK.Terrassentuer serialNr LTK0056273
attr EG.woz.TFK.Terrassentuer subType threeStateSensor
define FileLog_EG.woz.TFK.Terrassentuer FileLog ./log/EG.woz.TFK.Terrassentuer-%Y.log EG.woz.TFK.Terrassentuer
attr FileLog_EG.woz.TFK.Terrassentuer logtype text
attr FileLog_EG.woz.TFK.Terrassentuer room CUL_HM
define DG.sfz.TFK.Dachfenster CUL_HM 27B30C
attr DG.sfz.TFK.Dachfenster IODev HMLAN1
attr DG.sfz.TFK.Dachfenster IOgrp vccu:HMLAN1
attr DG.sfz.TFK.Dachfenster actCycle 028:00
attr DG.sfz.TFK.Dachfenster actStatus alive
attr DG.sfz.TFK.Dachfenster alias Dachgeschossfenster
attr DG.sfz.TFK.Dachfenster autoReadReg 4_reqStatus
attr DG.sfz.TFK.Dachfenster devStateIcon open:fts_window_roof_open_1@red closed:fts_window_roof@green
attr DG.sfz.TFK.Dachfenster expert 2_full
attr DG.sfz.TFK.Dachfenster firmware 2.4
attr DG.sfz.TFK.Dachfenster group Fenster
attr DG.sfz.TFK.Dachfenster model HM-SEC-SC-2
attr DG.sfz.TFK.Dachfenster peerIDs 00000000,27EE9403,
attr DG.sfz.TFK.Dachfenster room CUL_HM,DG_Schlafzimmer
attr DG.sfz.TFK.Dachfenster serialNr LTK0005818
attr DG.sfz.TFK.Dachfenster subType threeStateSensor
define FileLog_DG.sfz.TFK.Dachfenster FileLog ./log/DG.sfz.TFK.Dachfenster-%Y.log DG.sfz.TFK.Dachfenster
attr FileLog_DG.sfz.TFK.Dachfenster logtype text
attr FileLog_DG.sfz.TFK.Dachfenster room CUL_HM
define OG.anz.SATW.Deckenlicht CUL_HM 31B533
attr OG.anz.SATW.Deckenlicht IODev HMLAN1
attr OG.anz.SATW.Deckenlicht IOgrp vccu:HMLAN1
attr OG.anz.SATW.Deckenlicht autoReadReg 4_reqStatus
attr OG.anz.SATW.Deckenlicht devStateIcon open:fts_window_2w_tilt@red closed:fts_window_2w@green
attr OG.anz.SATW.Deckenlicht eventMap on:an off:aus
attr OG.anz.SATW.Deckenlicht expert 2_full
attr OG.anz.SATW.Deckenlicht firmware 2.3
attr OG.anz.SATW.Deckenlicht group Beleuchtung
attr OG.anz.SATW.Deckenlicht icon light_ceiling
attr OG.anz.SATW.Deckenlicht model HM-LC-Sw1PBU-FM
attr OG.anz.SATW.Deckenlicht peerIDs 00000000,
attr OG.anz.SATW.Deckenlicht room CUL_HM,OG_Ankleidezimmer
attr OG.anz.SATW.Deckenlicht serialNr LEQ1017592
attr OG.anz.SATW.Deckenlicht subType switch
attr OG.anz.SATW.Deckenlicht webCmd an:aus
define HM_325CC1 CUL_HM 325CC1
attr HM_325CC1 IODev HMLAN1
attr HM_325CC1 IOgrp vccu:HMLAN1
attr HM_325CC1 actCycle 000:10
attr HM_325CC1 actStatus alive
attr HM_325CC1 autoReadReg 4_reqStatus
attr HM_325CC1 expert 2_full
attr HM_325CC1 firmware 1.6
attr HM_325CC1 model HM-ES-PMSw1-Pl
attr HM_325CC1 room CUL_HM
attr HM_325CC1 serialNr LTK0121811
attr HM_325CC1 subType powerMeter
attr HM_325CC1 webCmd getConfig:clear msgEvents
define KG.flu.SASD.Regenwasserpumpe CUL_HM 325CC101
attr KG.flu.SASD.Regenwasserpumpe alias Regenwasserpumpe
attr KG.flu.SASD.Regenwasserpumpe eventMap on:an off:aus
attr KG.flu.SASD.Regenwasserpumpe group Steckdosensteuerung
attr KG.flu.SASD.Regenwasserpumpe icon ge_wht_steckdose
attr KG.flu.SASD.Regenwasserpumpe model HM-ES-PMSw1-Pl
attr KG.flu.SASD.Regenwasserpumpe peerIDs 00000000,
attr KG.flu.SASD.Regenwasserpumpe room AB_Außenbereich
define HM_325CC1_Pwr CUL_HM 325CC102
attr HM_325CC1_Pwr model HM-ES-PMSw1-Pl
define HM_325CC1_SenPwr CUL_HM 325CC103
attr HM_325CC1_SenPwr model HM-ES-PMSw1-Pl
attr HM_325CC1_SenPwr peerIDs 00000000,
define HM_325CC1_SenI CUL_HM 325CC104
attr HM_325CC1_SenI model HM-ES-PMSw1-Pl
attr HM_325CC1_SenI peerIDs 00000000,
define HM_325CC1_SenU CUL_HM 325CC105
attr HM_325CC1_SenU model HM-ES-PMSw1-Pl
attr HM_325CC1_SenU peerIDs 00000000,
define HM_325CC1_SenF CUL_HM 325CC106
attr HM_325CC1_SenF model HM-ES-PMSw1-Pl
attr HM_325CC1_SenF peerIDs 00000000,
define SonosStereoPlay at *06:00 set FBDECT_17,FBDECT_18 on-for-timer 9000
attr SonosStereoPlay disable 1
attr SonosStereoPlay group Steckdosensteuerung
attr SonosStereoPlay icon time_automatic
attr SonosStereoPlay room EG_Wohnzimmer
define dum_AutomatikAnAus dummy
attr dum_AutomatikAnAus devStateIcon an:general_an aus:general_aus
attr dum_AutomatikAnAus room OG_Ankleidezimmer
attr dum_AutomatikAnAus setList on: an off:aus
attr dum_AutomatikAnAus webCmd an:aus
define DeckenlichtAn at *{"18:04"} {if(Value("dum_AutomatikAnAus") eq "an") {fhem("set OG.anz.SATW.Deckenlicht on")}}
attr DeckenlichtAn room OG_Ankleidezimmer
define Uebersicht Dashboard
attr Uebersicht userattr dashboard_tab2backgroundimage dashboard_tab2colcount dashboard_tab2devices dashboard_tab2groups dashboard_tab2icon dashboard_tab2name dashboard_tab2rowcentercolwidth dashboard_tab2sorting dashboard_tab3backgroundimage dashboard_tab3colcount dashboard_tab3devices dashboard_tab3groups dashboard_tab3icon dashboard_tab3name dashboard_tab3rowcentercolwidth dashboard_tab3sorting dashboard_tab4backgroundimage dashboard_tab4colcount dashboard_tab4devices dashboard_tab4groups dashboard_tab4icon dashboard_tab4name dashboard_tab4rowcentercolwidth dashboard_tab4sorting dashboard_tab5backgroundimage dashboard_tab5colcount dashboard_tab5devices dashboard_tab5groups dashboard_tab5icon dashboard_tab5name dashboard_tab5rowcentercolwidth dashboard_tab5sorting
attr Uebersicht dashboard_activetab 1
attr Uebersicht dashboard_tab1groups Fenster
attr Uebersicht dashboard_tab1name Fenster
attr Uebersicht dashboard_tab2groups Rolladensteuerung
attr Uebersicht dashboard_tab2name Rolladensteuerung
attr Uebersicht dashboard_tab3groups Beleuchtung
attr Uebersicht dashboard_tab3name Beleuchtung
attr Uebersicht dashboard_tab4groups Heizung
attr Uebersicht dashboard_tab4name Heizung
define EG.woz.ROASeitenfenster CUL_HM 310F42
attr EG.woz.ROASeitenfenster IODev HMLAN1
attr EG.woz.ROASeitenfenster IOgrp vccu:HMLAN1
attr EG.woz.ROASeitenfenster autoReadReg 4_reqStatus
attr EG.woz.ROASeitenfenster devStateIcon up:fts_shutter_10@green down:fts_shutter_100@black 9\d.*:fts_shutter_10 8\d.*:fts_shutter_20 7\d.*:fts_shutter_30 6\d.*:fts_shutter_40 5\d.*:fts_shutter_50 4\d.*:fts_shutter_60 3\d.*:fts_shutter_70 2\d.*:fts_shutter_80 1\d.*:fts_shutter_90 0\d.*:fts_shutter_100
attr EG.woz.ROASeitenfenster eventMap on:up off:down
attr EG.woz.ROASeitenfenster expert 2_full
attr EG.woz.ROASeitenfenster firmware 2.3
attr EG.woz.ROASeitenfenster group Rolladensteuerung
attr EG.woz.ROASeitenfenster icon fts_shutter_manual
attr EG.woz.ROASeitenfenster model HM-LC-Bl1PBU-FM
attr EG.woz.ROASeitenfenster peerIDs 00000000,
attr EG.woz.ROASeitenfenster room EG_Wohnzimmer
attr EG.woz.ROASeitenfenster serialNr LEQ1030757
attr EG.woz.ROASeitenfenster subType blindActuator
attr EG.woz.ROASeitenfenster webCmd stop:up:90:80:70:60:50:40:30:20:10:down
define FileLog_EG.woz.ROASeitenfenster FileLog ./log/EG.woz.ROASeitenfenster-%Y.log EG.woz.ROASeitenfenster
attr FileLog_EG.woz.ROASeitenfenster logtype text
attr FileLog_EG.woz.ROASeitenfenster room CUL_HM
define OG.duz.ROA CUL_HM 3BA4A8
attr OG.duz.ROA IODev HMLAN1
attr OG.duz.ROA IOgrp vccu:HMLAN1
attr OG.duz.ROA autoReadReg 4_reqStatus
attr OG.duz.ROA devStateIcon up:fts_shutter_10@green down:fts_shutter_100@black 9\d.*:fts_shutter_10 8\d.*:fts_shutter_20 7\d.*:fts_shutter_30 6\d.*:fts_shutter_40 5\d.*:fts_shutter_50 4\d.*:fts_shutter_60 3\d.*:fts_shutter_70 2\d.*:fts_shutter_80 1\d.*:fts_shutter_90 0\d.*:fts_shutter_100
attr OG.duz.ROA eventMap on:up off:down
attr OG.duz.ROA expert 2_full
attr OG.duz.ROA firmware 2.3
attr OG.duz.ROA group Rolladensteuerung
attr OG.duz.ROA icon fts_shutter_manual
attr OG.duz.ROA model HM-LC-Bl1PBU-FM
attr OG.duz.ROA peerIDs 00000000,
attr OG.duz.ROA room CUL_HM,OG_Duschzimmer
attr OG.duz.ROA serialNr MEQ0335984
attr OG.duz.ROA subType blindActuator
attr OG.duz.ROA webCmd stop:up:90:80:70:60:50:40:30:20:10:down
define FileLog_OG.duz.ROA FileLog ./log/OG.duz.ROA-%Y.log OG.duz.ROA
attr FileLog_OG.duz.ROA logtype text
attr FileLog_OG.duz.ROA room CUL_HM
define DG.sfz.ROA.Seitenfenster CUL_HM 3B9534
attr DG.sfz.ROA.Seitenfenster IODev HMLAN1
attr DG.sfz.ROA.Seitenfenster IOgrp vccu:HMLAN1
attr DG.sfz.ROA.Seitenfenster autoReadReg 4_reqStatus
attr DG.sfz.ROA.Seitenfenster devStateIcon up:fts_shutter_10@green down:fts_shutter_100@black 9\d.*:fts_shutter_10 8\d.*:fts_shutter_20 7\d.*:fts_shutter_30 6\d.*:fts_shutter_40 5\d.*:fts_shutter_50 4\d.*:fts_shutter_60 3\d.*:fts_shutter_70 2\d.*:fts_shutter_80 1\d.*:fts_shutter_90 0\d.*:fts_shutter_100
attr DG.sfz.ROA.Seitenfenster eventMap on:up off:down
attr DG.sfz.ROA.Seitenfenster expert 2_full
attr DG.sfz.ROA.Seitenfenster firmware 2.3
attr DG.sfz.ROA.Seitenfenster group Rolladensteuerung
attr DG.sfz.ROA.Seitenfenster icon fts_shutter_manual
attr DG.sfz.ROA.Seitenfenster model HM-LC-Bl1PBU-FM
attr DG.sfz.ROA.Seitenfenster peerIDs 00000000,
attr DG.sfz.ROA.Seitenfenster room CUL_HM,DG_Schlafzimmer
attr DG.sfz.ROA.Seitenfenster serialNr MEQ0335559
attr DG.sfz.ROA.Seitenfenster subType blindActuator
attr DG.sfz.ROA.Seitenfenster webCmd stop:up:90:80:70:60:50:40:30:20:10:down
define FileLog_DG.sfz.ROA.Seitenfenster FileLog ./log/DG.sfz.ROA.Seitenfenster-%Y.log DG.sfz.ROA.Seitenfenster
attr FileLog_DG.sfz.ROA.Seitenfenster logtype text
attr FileLog_DG.sfz.ROA.Seitenfenster room CUL_HM
define DG_sfz_RolloAutoZu at *22:00 set DG.sfz.ROA.Seitenfenster 0
attr DG_sfz_RolloAutoZu group Rolladensteuerung
attr DG_sfz_RolloAutoZu icon fts_shutter_automatic
attr DG_sfz_RolloAutoZu room DG_Schlafzimmer
define DG_sfz_RolloAutoAuf at *09:40 set DG.sfz.ROA.Seitenfenster 100
attr DG_sfz_RolloAutoAuf group Rolladensteuerung
attr DG_sfz_RolloAutoAuf icon fts_shutter_automatic
attr DG_sfz_RolloAutoAuf room DG_Schlafzimmer
define OG_duz_RolloAutoAuf at *{sunrise("REAL",0,"08:00","11:00")} set OG.duz.ROA 100
attr OG_duz_RolloAutoAuf disable 1
attr OG_duz_RolloAutoAuf group Rolladensteuerung
attr OG_duz_RolloAutoAuf icon fts_shutter_automatic
attr OG_duz_RolloAutoAuf room OG_Duschzimmer
define OG_duz_RolloAutoLueftung at *06:20 set OG.duz.ROA 20
attr OG_duz_RolloAutoLueftung disable 1
attr OG_duz_RolloAutoLueftung group Rolladensteuerung
attr OG_duz_RolloAutoLueftung icon fts_shutter_automatic
attr OG_duz_RolloAutoLueftung room OG_Duschzimmer
define OG_duz_RolloAutoZu at *{sunset(0,"17:00","22:30")} set OG.duz.ROA 0
attr OG_duz_RolloAutoZu disable 1
attr OG_duz_RolloAutoZu group Rolladensteuerung
attr OG_duz_RolloAutoZu icon fts_shutter_automatic
attr OG_duz_RolloAutoZu room OG_Duschzimmer
define EG_woz_RolloSeitenfensterAutoAuf at *06:20 set EG.woz.ROASeitenfenster 100
attr EG_woz_RolloSeitenfensterAutoAuf group Rolladensteuerung
attr EG_woz_RolloSeitenfensterAutoAuf icon fts_shutter_automatic
attr EG_woz_RolloSeitenfensterAutoAuf room EG_Wohnzimmer
define EG_woz_RolloSeitenfensterAutoZu at *17:30 set EG.woz.ROASeitenfenster 0
attr EG_woz_RolloSeitenfensterAutoZu group Rolladensteuerung
attr EG_woz_RolloSeitenfensterAutoZu icon fts_shutter_automatic
attr EG_woz_RolloSeitenfensterAutoZu room EG_Wohnzimmer
define not_SonosPlay1kueAuto notify Sonos_Kueche:presence:.appeared {fhem"set Sonos_Kueche Volume 10";;fhem"set Sonos_Kueche StartFavourite /(?i)Radio/";;}
attr not_SonosPlay1kueAuto disable 1
attr not_SonosPlay1kueAuto room EG_Küche
define Wohnzimmerradio dummy
attr Wohnzimmerradio eventMap on:an off:aus
attr Wohnzimmerradio room EG_Wohnzimmer
attr Wohnzimmerradio setList off on
define WohnzimmerRadioAn notify Wohnzimmerradio:on set FBDECT_17 on;;set FBDECT_18 on
attr WohnzimmerRadioAn room EG_Wohnzimmer
define WohnzimmerRadioAus notify Wohnzimmerradio:off set FBDECT_17 off;;set FBDECT_18 off
attr WohnzimmerRadioAus room EG_Wohnzimmer
define not_SonosStereoplaySubwozAuto notify Sonos_Wohnzimmer:presence:.appeared {fhem"set Sonos_Wohnzimmer Volume 8";;fhem"set Sonos_Wohnzimmer StartFavourite /(?i)Radio/";;}
attr not_SonosStereoplaySubwozAuto room EG_Wohnzimmer
define not_Sonos_MobilAuto notify Sonos_Mobil:presence:.appeared {fhem"set Sonos_Mobil Volume 8";;fhem"set Sonos_Mobil StartFavourite /(?i)Radio/";;}
attr not_Sonos_MobilAuto disable 1
RPI 2 mit FHEM 5.8
MacDad
... Teil 2
define HMremote CUL_HM 37C1EC
attr HMremote IODev HMLAN1
attr HMremote IOgrp vccu:HMLAN1
attr HMremote autoReadReg 4_reqStatus
attr HMremote expert 2_full
attr HMremote firmware 1.1
attr HMremote model HM-RC-8
attr HMremote room CUL_HM
attr HMremote serialNr MEQ0283319
attr HMremote subType remote
attr HMremote webCmd getConfig:clear msgEvents
define FileLog_HMremote FileLog ./log/HMremote-%Y.log HMremote
attr FileLog_HMremote logtype text
attr FileLog_HMremote room CUL_HM
define HMremoteBtn_1 CUL_HM 37C1EC01
attr HMremoteBtn_1 model HM-RC-8
attr HMremoteBtn_1 peerIDs 00000000,ABC12301,
define HMremoteBtn_2 CUL_HM 37C1EC02
attr HMremoteBtn_2 model HM-RC-8
attr HMremoteBtn_2 peerIDs 00000000,ABC12302,
define HMremoteBtn_3 CUL_HM 37C1EC03
attr HMremoteBtn_3 model HM-RC-8
attr HMremoteBtn_3 peerIDs 00000000,ABC12303,
define HMremoteBtn_4 CUL_HM 37C1EC04
attr HMremoteBtn_4 model HM-RC-8
attr HMremoteBtn_4 peerIDs 00000000,ABC12304,
define HMremoteBtn_5 CUL_HM 37C1EC05
attr HMremoteBtn_5 model HM-RC-8
attr HMremoteBtn_5 peerIDs 00000000,ABC12305,
define HMremoteBtn_6 CUL_HM 37C1EC06
attr HMremoteBtn_6 model HM-RC-8
attr HMremoteBtn_6 peerIDs 00000000,ABC12306,
define HMremoteBtn_7 CUL_HM 37C1EC07
attr HMremoteBtn_7 model HM-RC-8
attr HMremoteBtn_7 peerIDs 00000000,ABC12307,
define HMremoteBtn_8 CUL_HM 37C1EC08
attr HMremoteBtn_8 model HM-RC-8
attr HMremoteBtn_8 peerIDs 00000000,ABC12307,ABC12308,
define HMvirtual CUL_HM ABC123
attr HMvirtual IODev HMLAN1
attr HMvirtual expert 2_full
attr HMvirtual model virtual_8
attr HMvirtual room CUL_HM
attr HMvirtual subType virtual
attr HMvirtual webCmd virtual
define HMvirtual_Btn1 CUL_HM ABC12301
attr HMvirtual_Btn1 model virtual_8
attr HMvirtual_Btn1 peerIDs 37C1EC01,
attr HMvirtual_Btn1 webCmd press short:press long
define HMvirtual_Btn2 CUL_HM ABC12302
attr HMvirtual_Btn2 model virtual_8
attr HMvirtual_Btn2 peerIDs 37C1EC02,
attr HMvirtual_Btn2 webCmd press short:press long
define HMvirtual_Btn3 CUL_HM ABC12303
attr HMvirtual_Btn3 model virtual_8
attr HMvirtual_Btn3 peerIDs 37C1EC03,
attr HMvirtual_Btn3 webCmd press short:press long
define HMvirtual_Btn4 CUL_HM ABC12304
attr HMvirtual_Btn4 model virtual_8
attr HMvirtual_Btn4 peerIDs 37C1EC04,
attr HMvirtual_Btn4 webCmd press short:press long
define HMvirtual_Btn5 CUL_HM ABC12305
attr HMvirtual_Btn5 model virtual_8
attr HMvirtual_Btn5 peerIDs 37C1EC05,
attr HMvirtual_Btn5 webCmd press short:press long
define HMvirtual_Btn6 CUL_HM ABC12306
attr HMvirtual_Btn6 model virtual_8
attr HMvirtual_Btn6 peerIDs 37C1EC06,
attr HMvirtual_Btn6 webCmd press short:press long
define HMvirtual_Btn7 CUL_HM ABC12307
attr HMvirtual_Btn7 model virtual_8
attr HMvirtual_Btn7 peerIDs 37C1EC07,37C1EC08,
attr HMvirtual_Btn7 webCmd press short:press long
define HMvirtual_Btn8 CUL_HM ABC12308
attr HMvirtual_Btn8 model virtual_8
attr HMvirtual_Btn8 peerIDs 37C1EC08,
attr HMvirtual_Btn8 webCmd press short:press long
define not_HMremoteBtn1 notify HMremoteBtn_1.Short.* set HUEGroup0 bri 192
define not_HMremoteBtn2 notify HMremoteBtn_2.Short.* set HUEGroup0 off
define not_HMremoteBtn3 notify HMremoteBtn_3.Short.* set Wohnzimmerradio on
define not_HMremoteBtn4 notify HMremoteBtn_4.Short.* set Wohnzimmerradio off
define OG.arz.HZT CUL_HM 27B54C
attr OG.arz.HZT IODev HMLAN1
attr OG.arz.HZT IOgrp vccu:HMLAN1
attr OG.arz.HZT actCycle 000:10
attr OG.arz.HZT actStatus alive
attr OG.arz.HZT autoReadReg 4_reqStatus
attr OG.arz.HZT expert 2_full
attr OG.arz.HZT firmware 1.2
attr OG.arz.HZT model HM-CC-RT-DN
attr OG.arz.HZT room CUL_HM,OG_Arbeitszimmer
attr OG.arz.HZT serialNr LTK0013021
attr OG.arz.HZT subType thermostat
attr OG.arz.HZT webCmd getConfig:clear msgEvents:burstXmit
define FileLog_OG.arz.HZT FileLog ./log/OG.arz.HZT-%Y.log OG.arz.HZT
attr FileLog_OG.arz.HZT logtype text
attr FileLog_OG.arz.HZT room CUL_HM
define OG.arz.HZT_Weather CUL_HM 27B54C01
attr OG.arz.HZT_Weather model HM-CC-RT-DN
attr OG.arz.HZT_Weather peerIDs 00000000,
define OG.arz.HZT_Climate CUL_HM 27B54C02
attr OG.arz.HZT_Climate model HM-CC-RT-DN
attr OG.arz.HZT_Climate peerIDs 00000000,
define OG.arz.HZT_WindowRec CUL_HM 27B54C03
attr OG.arz.HZT_WindowRec model HM-CC-RT-DN
attr OG.arz.HZT_WindowRec peerIDs 00000000,
attr OG.arz.HZT_WindowRec stateFormat last:trigLast
define OG.arz.HZT_Clima CUL_HM 27B54C04
attr OG.arz.HZT_Clima group Heizung
attr OG.arz.HZT_Clima model HM-CC-RT-DN
attr OG.arz.HZT_Clima peerIDs 00000000,
attr OG.arz.HZT_Clima room OG_Arbeitszimmer
define OG.arz.HZT_ClimaTeam CUL_HM 27B54C05
attr OG.arz.HZT_ClimaTeam model HM-CC-RT-DN
attr OG.arz.HZT_ClimaTeam peerIDs 00000000,
define OG.arz.HZT_remote CUL_HM 27B54C06
attr OG.arz.HZT_remote model HM-CC-RT-DN
attr OG.arz.HZT_remote peerIDs 00000000,
define EG.woz.HZT.Fenster CUL_HM 28EF37
attr EG.woz.HZT.Fenster IODev HMLAN1
attr EG.woz.HZT.Fenster IOgrp vccu:HMLAN1
attr EG.woz.HZT.Fenster actCycle 000:10
attr EG.woz.HZT.Fenster actStatus alive
attr EG.woz.HZT.Fenster autoReadReg 4_reqStatus
attr EG.woz.HZT.Fenster expert 2_full
attr EG.woz.HZT.Fenster firmware 1.3
attr EG.woz.HZT.Fenster model HM-CC-RT-DN
attr EG.woz.HZT.Fenster room CUL_HM,EG_Wohnzimmer
attr EG.woz.HZT.Fenster serialNr LTK0027225
attr EG.woz.HZT.Fenster subType thermostat
attr EG.woz.HZT.Fenster webCmd getConfig:clear msgEvents:burstXmit
define FileLog_EG.woz.HZT.Fenster FileLog ./log/EG.woz.HZT.Fenster-%Y.log EG.woz.HZT.Fenster
attr FileLog_EG.woz.HZT.Fenster logtype text
attr FileLog_EG.woz.HZT.Fenster room CUL_HM
define EG.woz.HZT.Fenster_Weather CUL_HM 28EF3701
attr EG.woz.HZT.Fenster_Weather model HM-CC-RT-DN
attr EG.woz.HZT.Fenster_Weather peerIDs 00000000,
define EG.woz.HZT.Fenster_Climate CUL_HM 28EF3702
attr EG.woz.HZT.Fenster_Climate model HM-CC-RT-DN
attr EG.woz.HZT.Fenster_Climate peerIDs 00000000,
define EG.woz.HZT.Fenster_WindowRec CUL_HM 28EF3703
attr EG.woz.HZT.Fenster_WindowRec model HM-CC-RT-DN
attr EG.woz.HZT.Fenster_WindowRec peerIDs 00000000,
attr EG.woz.HZT.Fenster_WindowRec stateFormat last:trigLast
define EG.woz.HZT.Fenster_Clima CUL_HM 28EF3704
attr EG.woz.HZT.Fenster_Clima group Heizung
attr EG.woz.HZT.Fenster_Clima model HM-CC-RT-DN
attr EG.woz.HZT.Fenster_Clima peerIDs 00000000,
attr EG.woz.HZT.Fenster_Clima room EG_Wohnzimmer
define EG.woz.HZT.Fenster_ClimaTeam CUL_HM 28EF3705
attr EG.woz.HZT.Fenster_ClimaTeam model HM-CC-RT-DN
attr EG.woz.HZT.Fenster_ClimaTeam peerIDs 00000000,
define EG.woz.HZT.Fenster_remote CUL_HM 28EF3706
attr EG.woz.HZT.Fenster_remote model HM-CC-RT-DN
attr EG.woz.HZT.Fenster_remote peerIDs 00000000,
define OG.duz.HZT CUL_HM 27B60F
attr OG.duz.HZT IODev HMLAN1
attr OG.duz.HZT IOgrp vccu:HMLAN1
attr OG.duz.HZT actCycle 000:10
attr OG.duz.HZT actStatus alive
attr OG.duz.HZT autoReadReg 4_reqStatus
attr OG.duz.HZT expert 2_full
attr OG.duz.HZT firmware 1.2
attr OG.duz.HZT model HM-CC-RT-DN
attr OG.duz.HZT room CUL_HM
attr OG.duz.HZT serialNr LTK0013196
attr OG.duz.HZT subType thermostat
attr OG.duz.HZT webCmd getConfig:clear msgEvents:burstXmit
define FileLog_OG.duz.HZT FileLog ./log/OG.duz.HZT-%Y.log OG.duz.HZT
attr FileLog_OG.duz.HZT logtype text
attr FileLog_OG.duz.HZT room CUL_HM
define OG.duz.HZT_Weather CUL_HM 27B60F01
attr OG.duz.HZT_Weather model HM-CC-RT-DN
attr OG.duz.HZT_Weather peerIDs 00000000,
define OG.duz.HZT_Climate CUL_HM 27B60F02
attr OG.duz.HZT_Climate model HM-CC-RT-DN
attr OG.duz.HZT_Climate peerIDs 00000000,
define OG.duz.HZT_WindowRec CUL_HM 27B60F03
attr OG.duz.HZT_WindowRec model HM-CC-RT-DN
attr OG.duz.HZT_WindowRec peerIDs 00000000,34591901,
attr OG.duz.HZT_WindowRec stateFormat last:trigLast
define OG.duz.HZT_Clima CUL_HM 27B60F04
attr OG.duz.HZT_Clima group Heizung
attr OG.duz.HZT_Clima model HM-CC-RT-DN
attr OG.duz.HZT_Clima peerIDs 00000000,
attr OG.duz.HZT_Clima room OG_Duschzimmer
define OG.duz.HZT_ClimaTeam CUL_HM 27B60F05
attr OG.duz.HZT_ClimaTeam model HM-CC-RT-DN
attr OG.duz.HZT_ClimaTeam peerIDs 00000000,
define OG.duz.HZT_remote CUL_HM 27B60F06
attr OG.duz.HZT_remote model HM-CC-RT-DN
attr OG.duz.HZT_remote peerIDs 00000000,
define OG.baz.HZT CUL_HM 2F81D1
attr OG.baz.HZT IODev HMLAN1
attr OG.baz.HZT IOgrp vccu:HMLAN1
attr OG.baz.HZT actCycle 000:10
attr OG.baz.HZT actStatus alive
attr OG.baz.HZT autoReadReg 4_reqStatus
attr OG.baz.HZT expert 2_full
attr OG.baz.HZT firmware 1.3
attr OG.baz.HZT model HM-CC-RT-DN
attr OG.baz.HZT room CUL_HM
attr OG.baz.HZT serialNr LTK0087563
attr OG.baz.HZT subType thermostat
attr OG.baz.HZT webCmd getConfig:clear msgEvents:burstXmit
define FileLog_OG.baz.HZT FileLog ./log/OG.baz.HZT-%Y.log OG.baz.HZT
attr FileLog_OG.baz.HZT logtype text
attr FileLog_OG.baz.HZT room CUL_HM
define OG.baz.HZT_Weather CUL_HM 2F81D101
attr OG.baz.HZT_Weather model HM-CC-RT-DN
attr OG.baz.HZT_Weather peerIDs 00000000,
define OG.baz.HZT_Climate CUL_HM 2F81D102
attr OG.baz.HZT_Climate model HM-CC-RT-DN
attr OG.baz.HZT_Climate peerIDs 00000000,
define OG.baz.HZT_WindowRec CUL_HM 2F81D103
attr OG.baz.HZT_WindowRec model HM-CC-RT-DN
attr OG.baz.HZT_WindowRec peerIDs 00000000,27FB5C01,
attr OG.baz.HZT_WindowRec stateFormat last:trigLast
define OG.baz.HZT_Clima CUL_HM 2F81D104
attr OG.baz.HZT_Clima group Heizung
attr OG.baz.HZT_Clima model HM-CC-RT-DN
attr OG.baz.HZT_Clima peerIDs 00000000,
attr OG.baz.HZT_Clima room OG_Badezimmer
define OG.baz.HZT_ClimaTeam CUL_HM 2F81D105
attr OG.baz.HZT_ClimaTeam model HM-CC-RT-DN
attr OG.baz.HZT_ClimaTeam peerIDs 00000000,
define OG.baz.HZT_remote CUL_HM 2F81D106
attr OG.baz.HZT_remote model HM-CC-RT-DN
attr OG.baz.HZT_remote peerIDs 00000000,
define OG.anz.HZT CUL_HM 27EDF0
attr OG.anz.HZT IODev HMLAN1
attr OG.anz.HZT IOgrp vccu:HMLAN1
attr OG.anz.HZT actCycle 000:10
attr OG.anz.HZT actStatus alive
attr OG.anz.HZT autoReadReg 4_reqStatus
attr OG.anz.HZT expert 2_full
attr OG.anz.HZT firmware 1.2
attr OG.anz.HZT model HM-CC-RT-DN
attr OG.anz.HZT room CUL_HM
attr OG.anz.HZT serialNr LTK0013971
attr OG.anz.HZT subType thermostat
attr OG.anz.HZT webCmd getConfig:clear msgEvents:burstXmit
define FileLog_OG.anz.HZT FileLog ./log/OG.anz.HZT-%Y.log OG.anz.HZT
attr FileLog_OG.anz.HZT logtype text
attr FileLog_OG.anz.HZT room CUL_HM
define OG.anz.HZT_Weather CUL_HM 27EDF001
attr OG.anz.HZT_Weather model HM-CC-RT-DN
attr OG.anz.HZT_Weather peerIDs 00000000,
define OG.anz.HZT_Climate CUL_HM 27EDF002
attr OG.anz.HZT_Climate model HM-CC-RT-DN
attr OG.anz.HZT_Climate peerIDs 00000000,
define OG.anz.HZT_WindowRec CUL_HM 27EDF003
attr OG.anz.HZT_WindowRec model HM-CC-RT-DN
attr OG.anz.HZT_WindowRec peerIDs 00000000,27B06701,
attr OG.anz.HZT_WindowRec stateFormat last:trigLast
define OG.anz.HZT_Clima CUL_HM 27EDF004
attr OG.anz.HZT_Clima group Heizung
attr OG.anz.HZT_Clima model HM-CC-RT-DN
attr OG.anz.HZT_Clima peerIDs 00000000,
attr OG.anz.HZT_Clima room OG_Ankleidezimmer
define OG.anz.HZT_ClimaTeam CUL_HM 27EDF005
attr OG.anz.HZT_ClimaTeam model HM-CC-RT-DN
attr OG.anz.HZT_ClimaTeam peerIDs 00000000,
define OG.anz.HZT_remote CUL_HM 27EDF006
attr OG.anz.HZT_remote model HM-CC-RT-DN
attr OG.anz.HZT_remote peerIDs 00000000,
define DG.sfz.HZT CUL_HM 27EE94
attr DG.sfz.HZT IODev HMLAN1
attr DG.sfz.HZT IOgrp vccu:HMLAN1
attr DG.sfz.HZT actCycle 000:10
attr DG.sfz.HZT actStatus alive
attr DG.sfz.HZT autoReadReg 4_reqStatus
attr DG.sfz.HZT expert 2_full
attr DG.sfz.HZT firmware 1.2
attr DG.sfz.HZT model HM-CC-RT-DN
attr DG.sfz.HZT room CUL_HM
attr DG.sfz.HZT serialNr LTK0014191
attr DG.sfz.HZT subType thermostat
attr DG.sfz.HZT webCmd getConfig:clear msgEvents:burstXmit
define FileLog_DG.sfz.HZT FileLog ./log/DG.sfz.HZT-%Y.log DG.sfz.HZT
attr FileLog_DG.sfz.HZT logtype text
attr FileLog_DG.sfz.HZT room CUL_HM
define DG.sfz.HZT_Weather CUL_HM 27EE9401
attr DG.sfz.HZT_Weather model HM-CC-RT-DN
attr DG.sfz.HZT_Weather peerIDs 00000000,
define DG.sfz.HZT_Climate CUL_HM 27EE9402
attr DG.sfz.HZT_Climate model HM-CC-RT-DN
attr DG.sfz.HZT_Climate peerIDs 00000000,
define DG.sfz.HZT_WindowRec CUL_HM 27EE9403
attr DG.sfz.HZT_WindowRec model HM-CC-RT-DN
attr DG.sfz.HZT_WindowRec peerIDs 00000000,27B30C01,
attr DG.sfz.HZT_WindowRec stateFormat last:trigLast
define DG.sfz.HZT_Clima CUL_HM 27EE9404
attr DG.sfz.HZT_Clima group Heizung
attr DG.sfz.HZT_Clima model HM-CC-RT-DN
attr DG.sfz.HZT_Clima peerIDs 00000000,
attr DG.sfz.HZT_Clima room DG_Schlafzimmer
define DG.sfz.HZT_ClimaTeam CUL_HM 27EE9405
attr DG.sfz.HZT_ClimaTeam model HM-CC-RT-DN
attr DG.sfz.HZT_ClimaTeam peerIDs 00000000,
define DG.sfz.HZT_remote CUL_HM 27EE9406
attr DG.sfz.HZT_remote model HM-CC-RT-DN
attr DG.sfz.HZT_remote peerIDs 00000000,
define EG.kue.HZT CUL_HM 2F8AE3
attr EG.kue.HZT IODev HMLAN1
attr EG.kue.HZT IOgrp vccu:HMLAN1
attr EG.kue.HZT actCycle 000:10
attr EG.kue.HZT actStatus alive
attr EG.kue.HZT autoReadReg 4_reqStatus
attr EG.kue.HZT expert 2_full
attr EG.kue.HZT firmware 1.3
attr EG.kue.HZT model HM-CC-RT-DN
attr EG.kue.HZT room CUL_HM
attr EG.kue.HZT serialNr LTK0089153
attr EG.kue.HZT subType thermostat
attr EG.kue.HZT webCmd getConfig:clear msgEvents:burstXmit
define FileLog_EG.kue.HZT FileLog ./log/EG.kue.HZT-%Y.log EG.kue.HZT
attr FileLog_EG.kue.HZT logtype text
attr FileLog_EG.kue.HZT room CUL_HM
define EG.kue.HZT_Weather CUL_HM 2F8AE301
attr EG.kue.HZT_Weather model HM-CC-RT-DN
attr EG.kue.HZT_Weather peerIDs 00000000,
define EG.kue.HZT_Climate CUL_HM 2F8AE302
attr EG.kue.HZT_Climate model HM-CC-RT-DN
attr EG.kue.HZT_Climate peerIDs 00000000,
define EG.kue.HZT_WindowRec CUL_HM 2F8AE303
attr EG.kue.HZT_WindowRec model HM-CC-RT-DN
attr EG.kue.HZT_WindowRec peerIDs 00000000,
attr EG.kue.HZT_WindowRec stateFormat last:trigLast
define EG.kue.HZT_Clima CUL_HM 2F8AE304
attr EG.kue.HZT_Clima group Heizung
attr EG.kue.HZT_Clima model HM-CC-RT-DN
attr EG.kue.HZT_Clima peerIDs 00000000,
attr EG.kue.HZT_Clima room EG_Küche
define EG.kue.HZT_ClimaTeam CUL_HM 2F8AE305
attr EG.kue.HZT_ClimaTeam model HM-CC-RT-DN
attr EG.kue.HZT_ClimaTeam peerIDs 00000000,
define EG.kue.HZT_remote CUL_HM 2F8AE306
attr EG.kue.HZT_remote model HM-CC-RT-DN
attr EG.kue.HZT_remote peerIDs 00000000,
define EG.gwc.HZT CUL_HM 27EE6D
attr EG.gwc.HZT IODev HMLAN1
attr EG.gwc.HZT IOgrp vccu:HMLAN1
attr EG.gwc.HZT actCycle 000:10
attr EG.gwc.HZT actStatus alive
attr EG.gwc.HZT autoReadReg 4_reqStatus
attr EG.gwc.HZT expert 2_full
attr EG.gwc.HZT firmware 1.2
attr EG.gwc.HZT model HM-CC-RT-DN
attr EG.gwc.HZT room CUL_HM
attr EG.gwc.HZT serialNr LTK0014152
attr EG.gwc.HZT subType thermostat
attr EG.gwc.HZT webCmd getConfig:clear msgEvents:burstXmit
define FileLog_EG.gwc.HZT FileLog ./log/EG.gwc.HZT-%Y.log EG.gwc.HZT
attr FileLog_EG.gwc.HZT logtype text
attr FileLog_EG.gwc.HZT room CUL_HM
define EG.gwc.HZT_Weather CUL_HM 27EE6D01
attr EG.gwc.HZT_Weather model HM-CC-RT-DN
attr EG.gwc.HZT_Weather peerIDs 00000000,
define EG.gwc.HZT_Climate CUL_HM 27EE6D02
attr EG.gwc.HZT_Climate model HM-CC-RT-DN
attr EG.gwc.HZT_Climate peerIDs 00000000,
define EG.gwc.HZT_WindowRec CUL_HM 27EE6D03
attr EG.gwc.HZT_WindowRec model HM-CC-RT-DN
attr EG.gwc.HZT_WindowRec peerIDs 00000000,2DE89201,
attr EG.gwc.HZT_WindowRec stateFormat last:trigLast
define EG.gwc.HZT_Clima CUL_HM 27EE6D04
attr EG.gwc.HZT_Clima group Heizung
attr EG.gwc.HZT_Clima model HM-CC-RT-DN
attr EG.gwc.HZT_Clima peerIDs 00000000,
attr EG.gwc.HZT_Clima room EG_Gäste WC
define EG.gwc.HZT_ClimaTeam CUL_HM 27EE6D05
attr EG.gwc.HZT_ClimaTeam model HM-CC-RT-DN
attr EG.gwc.HZT_ClimaTeam peerIDs 00000000,
define EG.gwc.HZT_remote CUL_HM 27EE6D06
attr EG.gwc.HZT_remote model HM-CC-RT-DN
attr EG.gwc.HZT_remote peerIDs 00000000,
define OG.duz.TFK CUL_HM 345919
attr OG.duz.TFK IODev HMLAN1
attr OG.duz.TFK actCycle 028:00
attr OG.duz.TFK actStatus alive
attr OG.duz.TFK autoReadReg 4_reqStatus
attr OG.duz.TFK devStateIcon tilted:fts_window_2w_tilt_r@blue open:fts_window_2w_open_r@red closed:fts_window_2w@green
attr OG.duz.TFK expert 2_full
attr OG.duz.TFK firmware 2.4
attr OG.duz.TFK group Fenster
attr OG.duz.TFK model HM-SEC-RHS
attr OG.duz.TFK peerIDs 00000000,27B60F03,
attr OG.duz.TFK room CUL_HM,OG_Duschzimmer
attr OG.duz.TFK serialNr LEQ1249794
attr OG.duz.TFK subType threeStateSensor
define FileLog_OG.duz.TFK FileLog ./log/OG.duz.TFK-%Y.log OG.duz.TFK
attr FileLog_OG.duz.TFK logtype text
attr FileLog_OG.duz.TFK room CUL_HM
define Sonos_Wohnzimmer_2 SONOSPLAYER RINCON_B8E937E0EB1001400_MR
attr Sonos_Wohnzimmer_2 alias Wohnzimmer 2 - Links
attr Sonos_Wohnzimmer_2 generateInfoSummarize1 <NormalAudio><Artist prefix="(" suffix=")"/><Title prefix=" '" suffix="'" ifempty="[Keine Musikdatei]"/><Album prefix=" vom Album '" suffix="'"/></NormalAudio> <StreamAudio><Sender suffix=":"/><SenderCurrent prefix=" '" suffix="' -"/><SenderInfo prefix=" "/></StreamAudio>
attr Sonos_Wohnzimmer_2 generateInfoSummarize2 <TransportState/><InfoSummarize1 prefix=" => "/>
attr Sonos_Wohnzimmer_2 generateInfoSummarize3 <Volume prefix="Lautstärke: "/><Mute instead=" ~ Kein Ton" ifempty=" ~ Ton An" emptyval="0"/> ~ Balance: <Balance ifempty="Mitte" emptyval="0"/><HeadphoneConnected instead=" ~ Kopfhörer aktiv" ifempty=" ~ Kein Kopfhörer" emptyval="0"/>
attr Sonos_Wohnzimmer_2 generateVolumeSlider 1
attr Sonos_Wohnzimmer_2 getAlarms 1
attr Sonos_Wohnzimmer_2 group Wohnzimmer_2
attr Sonos_Wohnzimmer_2 minVolume 0
attr Sonos_Wohnzimmer_2 model Sonos_S1
attr Sonos_Wohnzimmer_2 room Sonos
attr Sonos_Wohnzimmer_2 sortby 1
attr Sonos_Wohnzimmer_2 stateVariable Presence
attr Sonos_Wohnzimmer_2 userReadings Favourites:LastActionResult.*?GetFavouritesWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer_2", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Radios:LastActionResult.*?GetRadiosWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer_2", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Playlists:LastActionResult.*?GetPlaylistsWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer_2", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, currentTrackPosition:LastActionResult.*?GetCurrentTrackPosition.* { if (ReadingsVal("Sonos_Wohnzimmer_2", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }
define Sonos_Wohnzimmer_2RG readingsGroup Sonos_Wohnzimmer_2:<{SONOS_getCoverTitleRG($DEVICE)}@infoSummarize2>
attr Sonos_Wohnzimmer_2RG group Wohnzimmer_2
attr Sonos_Wohnzimmer_2RG noheading 1
attr Sonos_Wohnzimmer_2RG nonames 1
attr Sonos_Wohnzimmer_2RG room Sonos
attr Sonos_Wohnzimmer_2RG sortby 2
define Sonos_Wohnzimmer_2RG_Favourites readingsGroup Sonos_Wohnzimmer_2:<{SONOS_getListRG($DEVICE,"Favourites",1)}@Favourites>
define Sonos_Wohnzimmer_2RG_Radios readingsGroup Sonos_Wohnzimmer_2:<{SONOS_getListRG($DEVICE,"Radios",1)}@Radios>
define Sonos_Wohnzimmer_2RG_Playlists readingsGroup Sonos_Wohnzimmer_2:<{SONOS_getListRG($DEVICE,"Playlists")}@Playlists>
define Sonos_Wohnzimmer_2RC remotecontrol
attr Sonos_Wohnzimmer_2RC group Sonos
attr Sonos_Wohnzimmer_2RC rc_iconpath icons/remotecontrol
attr Sonos_Wohnzimmer_2RC rc_iconprefix black_btn_
attr Sonos_Wohnzimmer_2RC room hidden
attr Sonos_Wohnzimmer_2RC row00 Play:rc_PLAY.svg,Pause:rc_PAUSE.svg,Previous:rc_PREVIOUS.svg,Next:rc_NEXT.svg,:blank,VolumeD:rc_VOLDOWN.svg,VolumeU:rc_VOLUP.svg,:blank,MuteT:rc_MUTE.svg,ShuffleT:rc_SHUFFLE.svg,RepeatT:rc_REPEAT.svg
define Sonos_Wohnzimmer_2RC_Notify notify Sonos_Wohnzimmer_2RC set Sonos_Wohnzimmer_2 $EVENT
define Sonos_Wohnzimmer_2RC_Weblink weblink htmlCode {fhem("get Sonos_Wohnzimmer_2RC htmlcode", 1)}
attr Sonos_Wohnzimmer_2RC_Weblink group Wohnzimmer_2
attr Sonos_Wohnzimmer_2RC_Weblink room Sonos
attr Sonos_Wohnzimmer_2RC_Weblink sortby 3
define Sonos_Wohnzimmer_RF SONOSPLAYER RINCON_B8E937B54D7201400_MR
attr Sonos_Wohnzimmer_RF alias Wohnzimmer - Rechts
attr Sonos_Wohnzimmer_RF generateInfoSummarize1 <NormalAudio><Artist prefix="(" suffix=")"/><Title prefix=" '" suffix="'" ifempty="[Keine Musikdatei]"/><Album prefix=" vom Album '" suffix="'"/></NormalAudio> <StreamAudio><Sender suffix=":"/><SenderCurrent prefix=" '" suffix="' -"/><SenderInfo prefix=" "/></StreamAudio>
attr Sonos_Wohnzimmer_RF generateInfoSummarize2 <TransportState/><InfoSummarize1 prefix=" => "/>
attr Sonos_Wohnzimmer_RF generateInfoSummarize3 <Volume prefix="Lautstärke: "/><Mute instead=" ~ Kein Ton" ifempty=" ~ Ton An" emptyval="0"/> ~ Balance: <Balance ifempty="Mitte" emptyval="0"/><HeadphoneConnected instead=" ~ Kopfhörer aktiv" ifempty=" ~ Kein Kopfhörer" emptyval="0"/>
attr Sonos_Wohnzimmer_RF generateVolumeSlider 1
attr Sonos_Wohnzimmer_RF getAlarms 1
attr Sonos_Wohnzimmer_RF group Wohnzimmer
attr Sonos_Wohnzimmer_RF minVolume 0
attr Sonos_Wohnzimmer_RF model Sonos_S1
attr Sonos_Wohnzimmer_RF room Sonos
attr Sonos_Wohnzimmer_RF sortby 1
attr Sonos_Wohnzimmer_RF stateVariable Presence
attr Sonos_Wohnzimmer_RF userReadings Favourites:LastActionResult.*?GetFavouritesWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer_RF", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Radios:LastActionResult.*?GetRadiosWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer_RF", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Playlists:LastActionResult.*?GetPlaylistsWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer_RF", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, currentTrackPosition:LastActionResult.*?GetCurrentTrackPosition.* { if (ReadingsVal("Sonos_Wohnzimmer_RF", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }
define Sonos_Bad SONOSPLAYER RINCON_B8E937E0EBF201400_MR
attr Sonos_Bad alias Bad
attr Sonos_Bad generateInfoSummarize1 <NormalAudio><Artist prefix="(" suffix=")"/><Title prefix=" '" suffix="'" ifempty="[Keine Musikdatei]"/><Album prefix=" vom Album '" suffix="'"/></NormalAudio> <StreamAudio><Sender suffix=":"/><SenderCurrent prefix=" '" suffix="' -"/><SenderInfo prefix=" "/></StreamAudio>
attr Sonos_Bad generateInfoSummarize2 <TransportState/><InfoSummarize1 prefix=" => "/>
attr Sonos_Bad generateInfoSummarize3 <Volume prefix="Lautstärke: "/><Mute instead=" ~ Kein Ton" ifempty=" ~ Ton An" emptyval="0"/> ~ Balance: <Balance ifempty="Mitte" emptyval="0"/><HeadphoneConnected instead=" ~ Kopfhörer aktiv" ifempty=" ~ Kein Kopfhörer" emptyval="0"/>
attr Sonos_Bad generateVolumeSlider 1
attr Sonos_Bad getAlarms 1
attr Sonos_Bad group Bad
attr Sonos_Bad minVolume 0
attr Sonos_Bad model Sonos_S1
attr Sonos_Bad room Sonos
attr Sonos_Bad sortby 1
attr Sonos_Bad stateVariable Presence
attr Sonos_Bad userReadings Favourites:LastActionResult.*?GetFavouritesWithCovers.* { if (ReadingsVal("Sonos_Bad", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Radios:LastActionResult.*?GetRadiosWithCovers.* { if (ReadingsVal("Sonos_Bad", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Playlists:LastActionResult.*?GetPlaylistsWithCovers.* { if (ReadingsVal("Sonos_Bad", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, currentTrackPosition:LastActionResult.*?GetCurrentTrackPosition.* { if (ReadingsVal("Sonos_Bad", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }
define Sonos_BadRG readingsGroup Sonos_Bad:<{SONOS_getCoverTitleRG($DEVICE)}@infoSummarize2>
attr Sonos_BadRG group Bad
attr Sonos_BadRG noheading 1
attr Sonos_BadRG nonames 1
attr Sonos_BadRG room Sonos
attr Sonos_BadRG sortby 2
define Sonos_BadRG_Favourites readingsGroup Sonos_Bad:<{SONOS_getListRG($DEVICE,"Favourites",1)}@Favourites>
define Sonos_BadRG_Radios readingsGroup Sonos_Bad:<{SONOS_getListRG($DEVICE,"Radios",1)}@Radios>
define Sonos_BadRG_Playlists readingsGroup Sonos_Bad:<{SONOS_getListRG($DEVICE,"Playlists")}@Playlists>
define Sonos_BadRC remotecontrol
attr Sonos_BadRC group Sonos
attr Sonos_BadRC rc_iconpath icons/remotecontrol
attr Sonos_BadRC rc_iconprefix black_btn_
attr Sonos_BadRC room hidden
attr Sonos_BadRC row00 Play:rc_PLAY.svg,Pause:rc_PAUSE.svg,Previous:rc_PREVIOUS.svg,Next:rc_NEXT.svg,:blank,VolumeD:rc_VOLDOWN.svg,VolumeU:rc_VOLUP.svg,:blank,MuteT:rc_MUTE.svg,ShuffleT:rc_SHUFFLE.svg,RepeatT:rc_REPEAT.svg
define Sonos_BadRC_Notify notify Sonos_BadRC set Sonos_Bad $EVENT
define Sonos_BadRC_Weblink weblink htmlCode {fhem("get Sonos_BadRC htmlcode", 1)}
attr Sonos_BadRC_Weblink group Bad
attr Sonos_BadRC_Weblink room Sonos
attr Sonos_BadRC_Weblink sortby 3
define Sonos_Mobil SONOSPLAYER RINCON_000E586CA9AE01400_MR
attr Sonos_Mobil alias Mobil
attr Sonos_Mobil generateInfoSummarize1 <NormalAudio><Artist prefix="(" suffix=")"/><Title prefix=" '" suffix="'" ifempty="[Keine Musikdatei]"/><Album prefix=" vom Album '" suffix="'"/></NormalAudio> <StreamAudio><Sender suffix=":"/><SenderCurrent prefix=" '" suffix="' -"/><SenderInfo prefix=" "/></StreamAudio>
attr Sonos_Mobil generateInfoSummarize2 <TransportState/><InfoSummarize1 prefix=" => "/>
attr Sonos_Mobil generateInfoSummarize3 <Volume prefix="Lautstärke: "/><Mute instead=" ~ Kein Ton" ifempty=" ~ Ton An" emptyval="0"/> ~ Balance: <Balance ifempty="Mitte" emptyval="0"/><HeadphoneConnected instead=" ~ Kopfhörer aktiv" ifempty=" ~ Kein Kopfhörer" emptyval="0"/>
attr Sonos_Mobil generateVolumeSlider 1
attr Sonos_Mobil getAlarms 1
attr Sonos_Mobil group Mobil
attr Sonos_Mobil minVolume 0
attr Sonos_Mobil model Sonos_S5
attr Sonos_Mobil room Sonos
attr Sonos_Mobil sortby 1
attr Sonos_Mobil stateVariable Presence
attr Sonos_Mobil userReadings Favourites:LastActionResult.*?GetFavouritesWithCovers.* { if (ReadingsVal("Sonos_Mobil", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Radios:LastActionResult.*?GetRadiosWithCovers.* { if (ReadingsVal("Sonos_Mobil", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Playlists:LastActionResult.*?GetPlaylistsWithCovers.* { if (ReadingsVal("Sonos_Mobil", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, currentTrackPosition:LastActionResult.*?GetCurrentTrackPosition.* { if (ReadingsVal("Sonos_Mobil", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }
define Sonos_MobilRG readingsGroup Sonos_Mobil:<{SONOS_getCoverTitleRG($DEVICE)}@infoSummarize2>
attr Sonos_MobilRG group Mobil
attr Sonos_MobilRG noheading 1
attr Sonos_MobilRG nonames 1
attr Sonos_MobilRG room Sonos
attr Sonos_MobilRG sortby 2
define Sonos_MobilRG_Favourites readingsGroup Sonos_Mobil:<{SONOS_getListRG($DEVICE,"Favourites",1)}@Favourites>
define Sonos_MobilRG_Radios readingsGroup Sonos_Mobil:<{SONOS_getListRG($DEVICE,"Radios",1)}@Radios>
define Sonos_MobilRG_Playlists readingsGroup Sonos_Mobil:<{SONOS_getListRG($DEVICE,"Playlists")}@Playlists>
define Sonos_MobilRC remotecontrol
attr Sonos_MobilRC group Sonos
attr Sonos_MobilRC rc_iconpath icons/remotecontrol
attr Sonos_MobilRC rc_iconprefix black_btn_
attr Sonos_MobilRC room hidden
attr Sonos_MobilRC row00 Play:rc_PLAY.svg,Pause:rc_PAUSE.svg,Previous:rc_PREVIOUS.svg,Next:rc_NEXT.svg,:blank,VolumeD:rc_VOLDOWN.svg,VolumeU:rc_VOLUP.svg,:blank,MuteT:rc_MUTE.svg,ShuffleT:rc_SHUFFLE.svg,RepeatT:rc_REPEAT.svg
define Sonos_MobilRC_Notify notify Sonos_MobilRC set Sonos_Mobil $EVENT
define Sonos_MobilRC_Weblink weblink htmlCode {fhem("get Sonos_MobilRC htmlcode", 1)}
attr Sonos_MobilRC_Weblink group Mobil
attr Sonos_MobilRC_Weblink room Sonos
attr Sonos_MobilRC_Weblink sortby 3
define Sonos_Wohnzimmer SONOSPLAYER RINCON_B8E937B54DBE01400_MR
attr Sonos_Wohnzimmer alias Wohnzimmer - Links
attr Sonos_Wohnzimmer generateInfoSummarize1 <NormalAudio><Artist prefix="(" suffix=")"/><Title prefix=" '" suffix="'" ifempty="[Keine Musikdatei]"/><Album prefix=" vom Album '" suffix="'"/></NormalAudio> <StreamAudio><Sender suffix=":"/><SenderCurrent prefix=" '" suffix="' -"/><SenderInfo prefix=" "/></StreamAudio>
attr Sonos_Wohnzimmer generateInfoSummarize2 <TransportState/><InfoSummarize1 prefix=" => "/>
attr Sonos_Wohnzimmer generateInfoSummarize3 <Volume prefix="Lautstärke: "/><Mute instead=" ~ Kein Ton" ifempty=" ~ Ton An" emptyval="0"/> ~ Balance: <Balance ifempty="Mitte" emptyval="0"/><HeadphoneConnected instead=" ~ Kopfhörer aktiv" ifempty=" ~ Kein Kopfhörer" emptyval="0"/>
attr Sonos_Wohnzimmer generateVolumeSlider 1
attr Sonos_Wohnzimmer getAlarms 1
attr Sonos_Wohnzimmer group Wohnzimmer
attr Sonos_Wohnzimmer minVolume 0
attr Sonos_Wohnzimmer model Sonos_S1
attr Sonos_Wohnzimmer room Sonos
attr Sonos_Wohnzimmer sortby 1
attr Sonos_Wohnzimmer stateVariable Presence
attr Sonos_Wohnzimmer userReadings Favourites:LastActionResult.*?GetFavouritesWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Radios:LastActionResult.*?GetRadiosWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Playlists:LastActionResult.*?GetPlaylistsWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, currentTrackPosition:LastActionResult.*?GetCurrentTrackPosition.* { if (ReadingsVal("Sonos_Wohnzimmer", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }
define Sonos_WohnzimmerRG readingsGroup Sonos_Wohnzimmer:<{SONOS_getCoverTitleRG($DEVICE)}@infoSummarize2>
attr Sonos_WohnzimmerRG group Wohnzimmer
attr Sonos_WohnzimmerRG noheading 1
attr Sonos_WohnzimmerRG nonames 1
attr Sonos_WohnzimmerRG room Sonos
attr Sonos_WohnzimmerRG sortby 2
define Sonos_WohnzimmerRG_Favourites readingsGroup Sonos_Wohnzimmer:<{SONOS_getListRG($DEVICE,"Favourites",1)}@Favourites>
define Sonos_WohnzimmerRG_Radios readingsGroup Sonos_Wohnzimmer:<{SONOS_getListRG($DEVICE,"Radios",1)}@Radios>
define Sonos_WohnzimmerRG_Playlists readingsGroup Sonos_Wohnzimmer:<{SONOS_getListRG($DEVICE,"Playlists")}@Playlists>
define Sonos_WohnzimmerRC remotecontrol
attr Sonos_WohnzimmerRC group Sonos
attr Sonos_WohnzimmerRC rc_iconpath icons/remotecontrol
attr Sonos_WohnzimmerRC rc_iconprefix black_btn_
attr Sonos_WohnzimmerRC room hidden
attr Sonos_WohnzimmerRC row00 Play:rc_PLAY.svg,Pause:rc_PAUSE.svg,Previous:rc_PREVIOUS.svg,Next:rc_NEXT.svg,:blank,VolumeD:rc_VOLDOWN.svg,VolumeU:rc_VOLUP.svg,:blank,MuteT:rc_MUTE.svg,ShuffleT:rc_SHUFFLE.svg,RepeatT:rc_REPEAT.svg
define Sonos_WohnzimmerRC_Notify notify Sonos_WohnzimmerRC set Sonos_Wohnzimmer $EVENT
define Sonos_WohnzimmerRC_Weblink weblink htmlCode {fhem("get Sonos_WohnzimmerRC htmlcode", 1)}
attr Sonos_WohnzimmerRC_Weblink group Wohnzimmer
attr Sonos_WohnzimmerRC_Weblink room Sonos
attr Sonos_WohnzimmerRC_Weblink sortby 3
define Sonos_Wohnzimmer_2_RF SONOSPLAYER RINCON_B8E937E30F5001400_MR
attr Sonos_Wohnzimmer_2_RF alias Wohnzimmer 2 - Rechts
attr Sonos_Wohnzimmer_2_RF generateInfoSummarize1 <NormalAudio><Artist prefix="(" suffix=")"/><Title prefix=" '" suffix="'" ifempty="[Keine Musikdatei]"/><Album prefix=" vom Album '" suffix="'"/></NormalAudio> <StreamAudio><Sender suffix=":"/><SenderCurrent prefix=" '" suffix="' -"/><SenderInfo prefix=" "/></StreamAudio>
attr Sonos_Wohnzimmer_2_RF generateInfoSummarize2 <TransportState/><InfoSummarize1 prefix=" => "/>
attr Sonos_Wohnzimmer_2_RF generateInfoSummarize3 <Volume prefix="Lautstärke: "/><Mute instead=" ~ Kein Ton" ifempty=" ~ Ton An" emptyval="0"/> ~ Balance: <Balance ifempty="Mitte" emptyval="0"/><HeadphoneConnected instead=" ~ Kopfhörer aktiv" ifempty=" ~ Kein Kopfhörer" emptyval="0"/>
attr Sonos_Wohnzimmer_2_RF generateVolumeSlider 1
attr Sonos_Wohnzimmer_2_RF getAlarms 1
attr Sonos_Wohnzimmer_2_RF group Wohnzimmer_2
attr Sonos_Wohnzimmer_2_RF minVolume 0
attr Sonos_Wohnzimmer_2_RF model Sonos_S1
attr Sonos_Wohnzimmer_2_RF room Sonos
attr Sonos_Wohnzimmer_2_RF sortby 1
attr Sonos_Wohnzimmer_2_RF stateVariable Presence
attr Sonos_Wohnzimmer_2_RF userReadings Favourites:LastActionResult.*?GetFavouritesWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer_2_RF", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Radios:LastActionResult.*?GetRadiosWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer_2_RF", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Playlists:LastActionResult.*?GetPlaylistsWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer_2_RF", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, currentTrackPosition:LastActionResult.*?GetCurrentTrackPosition.* { if (ReadingsVal("Sonos_Wohnzimmer_2_RF", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }
define Sonos_Wohnzimmer_SW SONOSPLAYER RINCON_B8E93764C43001400_MR
attr Sonos_Wohnzimmer_SW alias Wohnzimmer - Subwoofer
attr Sonos_Wohnzimmer_SW generateInfoSummarize1 <NormalAudio><Artist prefix="(" suffix=")"/><Title prefix=" '" suffix="'" ifempty="[Keine Musikdatei]"/><Album prefix=" vom Album '" suffix="'"/></NormalAudio> <StreamAudio><Sender suffix=":"/><SenderCurrent prefix=" '" suffix="' -"/><SenderInfo prefix=" "/></StreamAudio>
attr Sonos_Wohnzimmer_SW generateInfoSummarize2 <TransportState/><InfoSummarize1 prefix=" => "/>
attr Sonos_Wohnzimmer_SW generateInfoSummarize3 <Volume prefix="Lautstärke: "/><Mute instead=" ~ Kein Ton" ifempty=" ~ Ton An" emptyval="0"/> ~ Balance: <Balance ifempty="Mitte" emptyval="0"/><HeadphoneConnected instead=" ~ Kopfhörer aktiv" ifempty=" ~ Kein Kopfhörer" emptyval="0"/>
attr Sonos_Wohnzimmer_SW generateVolumeSlider 1
attr Sonos_Wohnzimmer_SW getAlarms 1
attr Sonos_Wohnzimmer_SW group Wohnzimmer
attr Sonos_Wohnzimmer_SW minVolume 0
attr Sonos_Wohnzimmer_SW model Sonos_Sub
attr Sonos_Wohnzimmer_SW room Sonos
attr Sonos_Wohnzimmer_SW sortby 1
attr Sonos_Wohnzimmer_SW stateVariable Presence
attr Sonos_Wohnzimmer_SW userReadings Favourites:LastActionResult.*?GetFavouritesWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer_SW", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Radios:LastActionResult.*?GetRadiosWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer_SW", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Playlists:LastActionResult.*?GetPlaylistsWithCovers.* { if (ReadingsVal("Sonos_Wohnzimmer_SW", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, currentTrackPosition:LastActionResult.*?GetCurrentTrackPosition.* { if (ReadingsVal("Sonos_Wohnzimmer_SW", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }
RPI 2 mit FHEM 5.8
franky08
Ist das die komplette fhem.cfg? Da gibt es keine devices OG.duz.HZT_Clima und EG.woz.HZT.Fenster_Clima oder du hattest die mal angelegt und mittels save config gespeichert und dann wurden sie aus welchem Grund auch immer gelöscht aber kein erneutes save config ausgeführt.
Vlt hast du ja deine funktionierende fhem.cfg irgendwo gesichert und kannst diese zurück kopieren. Sonst würde ich raten die fehlenden devices neu anzulegen, speichern nicht vergessen  ;)
P.S. Den Link oben mal verfolgt
ZitatIrgendetwas scheint in Deinem Configfile -->
Code: [Auswählen]
fhem.cfg
VG
Frank
mit FHEM aktuell
MacDad
Hallo Frank,
da ist echt der Wurm drin  :'(
Die OG.duz.HZT_CLima gibt es und die anderen auch.
Da scheint was beim kopieren verloren gegangen zu sein.
schau mal hier:
attr global userattr cmdIcon devStateIcon devStateStyle icon sortby webCmd widgetOverride
attr global latitude 51.4846005
attr global logfile ./log/fhem-%Y-%m.log
attr global longitude 7.5624015
attr global modpath .
attr global motd Error messages while initializing FHEM:\
configfile: EG.woz.HZT.Fenster_Clima already defined, delete it first\
EG.woz.HZT.Fenster_Clima: unknown attribute model. Type 'attr EG.woz.HZT.Fenster_Clima ?' for a detailed list.\
EG.woz.HZT.Fenster_Clima: unknown attribute peerIDs. Type 'attr EG.woz.HZT.Fenster_Clima ?' for a detailed list.\
OG.duz.HZT_Clima already defined, delete it first\
OG.duz.HZT_Clima: unknown attribute model. Type 'attr OG.duz.HZT_Clima ?' for a detailed list.\
OG.duz.HZT_Clima: unknown attribute peerIDs. Type 'attr OG.duz.HZT_Clima ?' for a detailed list.\
OG.baz.HZT_Clima already defined, delete it first\
OG.baz.HZT_Clima: unknown attribute model. Type 'attr OG.baz.HZT_Clima ?' for a detailed list.\
OG.baz.HZT_Clima: unknown attribute peerIDs. Type 'attr OG.baz.HZT_Clima ?' for a detailed list.\
OG.anz.HZT_Clima already defined, delete it first\
OG.anz.HZT_Clima: unknown attribute model. Type 'attr OG.anz.HZT_Clima ?' for a detailed list.\
OG.anz.HZT_Clima: unknown attribute peerIDs. Type 'attr OG.anz.HZT_Clima ?' for a detailed list.\
DG.sfz.HZT_Clima already defined, delete it first\
DG.sfz.HZT_Clima: unknown attribute model. Type 'attr DG.sfz.HZT_Clima ?' for a detailed list.\
DG.sfz.HZT_Clima: unknown attribute peerIDs. Type 'attr DG.sfz.HZT_Clima ?' for a detailed list.\
EG.gwc.HZT_Clima already defined, delete it first\
EG.gwc.HZT_Clima: unknown attribute model. Type 'attr EG.gwc.HZT_Clima ?' for a detailed list.\
attr global statefile ./log/fhem.save
attr global updateInBackground 1
attr global verbose 3
define telnetPort telnet 7072 global
attr WEB basicAuth ZmhlbXBpOm1hY3JwaQ==
attr WEB editConfig 1
attr WEB menuEntries restart,cmd=shutdown+restart,update,cmd=update,updatecheck,cmd=update+check
attr WEB roomIcons Wettervorhersage:weather_cloudy
attr WEB sortRooms DG_Schlafzimmer OG_Badezimmer OG_Arbeitszimmer OG_Ankleidezimmer OG_Duschzimmer EG_Gäste.WC EG_Küche EG_Wohnzimmer AB_Außenbereich Zentral Sonos VUplus HUEDevice FBDECT
define WEBphone FHEMWEB 8084 global
attr WEBphone basicAuth ZmhlbXBpOm1hY3JwaQ==
attr WEBphone stylesheetPrefix smallscreen
attr WEBtablet basicAuth ZmhlbXBpOm1hY3JwaQ==
attr WEBtablet stylesheetPrefix touchpad
# Fake FileLog entry, to access the fhem log from FHEMWEB
define Logfile FileLog ./log/fhem-%Y-%m.log fakelog
define autocreate autocreate
attr autocreate filelog ./log/%NAME-%Y.log
define eventTypes eventTypes ./log/eventTypes.txt
define initialUsbCheck notify global:INITIALIZED usb create
define FritzBox FBAHA fritz.box:2002
define FBDECT_18 FBDECT FritzBox:18 switch
attr FBDECT_18 IODev FritzBox
attr FBDECT_18 alias FBDECT18_woz_SonosSub
attr FBDECT_18 event-min-interval power:120
attr FBDECT_18 eventMap on:an off:aus
attr FBDECT_18 group Steckdosensteuerung
attr FBDECT_18 room EG_Wohnzimmer,FBDECT
define FileLog_FBDECT_18 FileLog ./log/FBDECT_18-%Y.log FBDECT_18:power\x3a.*
attr FileLog_FBDECT_18 logtype power4:Power,text
attr FileLog_FBDECT_18 room FBDECT
define SVG_FBDECT_18 SVG FileLog_FBDECT_18:power4:CURRENT
attr SVG_FBDECT_18 label "FBDECT_18 Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_FBDECT_18 room Plots
define FBDECT_17 FBDECT FritzBox:17 switch
attr FBDECT_17 IODev FritzBox
attr FBDECT_17 alias FBDECT17_woz_SonosStereoPlay1
attr FBDECT_17 event-min-interval power:120
attr FBDECT_17 eventMap on:an off:aus
attr FBDECT_17 group Steckdosensteuerung
attr FBDECT_17 room EG_Wohnzimmer,FBDECT
define FileLog_FBDECT_17 FileLog ./log/FBDECT_17-%Y.log FBDECT_17:power\x3a.*
attr FileLog_FBDECT_17 logtype power4:Power,text
attr FileLog_FBDECT_17 room FBDECT
define SVG_FBDECT_17 SVG FileLog_FBDECT_17:power4:CURRENT
attr SVG_FBDECT_17 label "FBDECT_17 Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_FBDECT_17 room Plots
define FBDECT_16 FBDECT FritzBox:16 switch
attr FBDECT_16 IODev FritzBox
attr FBDECT_16 alias FBDECT16_kue_SonosPlay1
attr FBDECT_16 event-min-interval power:120
attr FBDECT_16 eventMap on:an off:aus
attr FBDECT_16 group Steckdosensteuerung
attr FBDECT_16 room EG_Küche,FBDECT
define FileLog_FBDECT_16 FileLog ./log/FBDECT_16-%Y.log FBDECT_16:power\x3a.*
attr FileLog_FBDECT_16 logtype power4:Power,text
attr FileLog_FBDECT_16 room FBDECT
define SVG_FBDECT_16 SVG FileLog_FBDECT_16:power4:CURRENT
attr SVG_FBDECT_16 label "FBDECT_16 Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_FBDECT_16 room Plots
define FBDECT_19 FBDECT FritzBox:19 switch
attr FBDECT_19 IODev FritzBox
attr FBDECT_19 alias FBDECT19_sfz_SonosPlay1
attr FBDECT_19 event-min-interval power:120
attr FBDECT_19 eventMap on:an off:aus
attr FBDECT_19 group Steckdosensteuerung
attr FBDECT_19 room DG_Schlafzimmer,FBDECT
define FileLog_FBDECT_19 FileLog ./log/FBDECT_19-%Y.log FBDECT_19:power\x3a.*
attr FileLog_FBDECT_19 logtype power4:Power,text
attr FileLog_FBDECT_19 room FBDECT
define SVG_FBDECT_19 SVG FileLog_FBDECT_19:power4:CURRENT
attr SVG_FBDECT_19 label "FBDECT_19 Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_FBDECT_19 room Plots
define vusolo2wz ENIGMA2 192.168.178.51
attr vusolo2wz bouquet-radio 1:7:2:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites.radio" ORDER BY bouquet
attr vusolo2wz bouquet-tv 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.d5915.tv" ORDER BY bouquet
attr vusolo2wz devStateIcon on:rc_GREEN:off off:rc_YELLOW:on absent:rc_STOP:on
attr vusolo2wz disable 1
attr vusolo2wz event-on-change-reading state
attr vusolo2wz http-method GET
attr vusolo2wz icon dreambox
attr vusolo2wz room EG_Wohnzimmer,VUplus
attr vusolo2wz webCmd channel:input
define vusolo2sz ENIGMA2 192.168.178.52
attr vusolo2sz bouquet-radio 1:7:2:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites.radio" ORDER BY bouquet
attr vusolo2sz bouquet-tv 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet
attr vusolo2sz devStateIcon on:rc_GREEN:off off:rc_YELLOW:on absent:rc_STOP:on
attr vusolo2sz disable 1
attr vusolo2sz http-method GET
attr vusolo2sz icon dreambox
attr vusolo2sz room DG_Schlafzimmer,VUplus
attr vusolo2sz webCmd channel:input
define Sonos SONOS localhost:4711 30 1 5
attr Sonos verbose 0
define Sonos_BRIDGE SONOSPLAYER RINCON_B8E9371FB2F001400_MR
attr Sonos_BRIDGE alias BRIDGE
attr Sonos_BRIDGE group BRIDGE
attr Sonos_BRIDGE model Sonos_ZB100
attr Sonos_BRIDGE room Sonos
attr Sonos_BRIDGE sortby 1
attr Sonos_BRIDGE stateFormat presence
define hueBridge2 HUEBridge 192.168.178.81
attr hueBridge2 key 6b8e10abce06100c82d10c3c3cc2911a
define HUEDevice4 HUEDevice 4
attr HUEDevice4 IODev hueBridge2
attr HUEDevice4 alias Fensterbank links
attr HUEDevice4 color-icons 2
attr HUEDevice4 devStateIcon {(HUEDevice_devStateIcon($name),"toggle")}
attr HUEDevice4 eventMap on:an off:aus
attr HUEDevice4 group Beleuchtung
attr HUEDevice4 icon light_led
attr HUEDevice4 model LCT001
attr HUEDevice4 room EG_Wohnzimmer,HUEDevice
attr HUEDevice4 subType extcolordimmer
attr HUEDevice4 webCmd rgb:rgb ff0000:rgb DEFF26:rgb 0000ff:ct 490:ct 380:ct 270:ct 160:an:aus
define HUEDevice1 HUEDevice 1
attr HUEDevice1 IODev hueBridge2
attr HUEDevice1 alias Seitenfenster
attr HUEDevice1 color-icons 2
attr HUEDevice1 devStateIcon {(HUEDevice_devStateIcon($name),"toggle")}
attr HUEDevice1 group Beleuchtung
attr HUEDevice1 icon light_led
attr HUEDevice1 model LLC010
attr HUEDevice1 room EG_Wohnzimmer,HUEDevice
attr HUEDevice1 subType colordimmer
attr HUEDevice1 webCmd hue:rgb:rgb ff0000:rgb 98FF23:rgb 0000ff:toggle:on:off
define HUEDevice3 HUEDevice 3
attr HUEDevice3 IODev hueBridge2
attr HUEDevice3 alias Fensterbank rechts
attr HUEDevice3 color-icons 2
attr HUEDevice3 devStateIcon {(HUEDevice_devStateIcon($name),"toggle")}
attr HUEDevice3 eventMap on:an off:aus
attr HUEDevice3 group Beleuchtung
attr HUEDevice3 icon light_led
attr HUEDevice3 model LCT001
attr HUEDevice3 room EG_Wohnzimmer,HUEDevice
attr HUEDevice3 subType extcolordimmer
attr HUEDevice3 webCmd rgb:rgb ff0000:rgb DEFF26:rgb 0000ff:ct 490:ct 380:ct 270:ct 160:an:aus
define HUEDevice2 HUEDevice 2
attr HUEDevice2 IODev hueBridge2
attr HUEDevice2 alias Schrankwand
attr HUEDevice2 color-icons 2
attr HUEDevice2 devStateIcon {(HUEDevice_devStateIcon($name),"toggle")}
attr HUEDevice2 eventMap on:an off:aus
attr HUEDevice2 group Beleuchtung
attr HUEDevice2 icon light_led
attr HUEDevice2 model LCT001
attr HUEDevice2 room EG_Wohnzimmer,HUEDevice
attr HUEDevice2 subType extcolordimmer
attr HUEDevice2 webCmd rgb:rgb ff0000:rgb DEFF26:rgb 0000ff:ct 490:ct 380:ct 270:ct 160:an:aus
define HUEGroup0 HUEDevice group 0
attr HUEGroup0 IODev hueBridge2
attr HUEGroup0 alias Lightset 0
attr HUEGroup0 delayedUpdate 1
attr HUEGroup0 group Beleuchtung
attr HUEGroup0 room HUEDevice
define HMLAN1 HMLAN 192.168.178.72:1000
attr HMLAN1 hmId 2AEE19
attr HMLAN1 hmKey 01:8e6d015b605cb6b2cb4ebbb7fa3f599d
attr HMLAN1 hmLanQlen 1_min
attr HMLAN1 loadLevel 0:low,40:batchLevel,90:high,99:suspended
attr HMLAN1 room HMDevice
define vccu CUL_HM 2AEE19
attr vccu IODev HMLAN1
attr vccu IOList HMLAN1
attr vccu model CCU-FHEM
attr vccu room HMDevice
attr vccu subType virtual
attr vccu webCmd virtual:update
define LichtWetter Twilight 51.4846005 7.5624015 645458
attr LichtWetter room Wettervorhersage
define dum_solo2wzStatus dummy
attr dum_solo2wzStatus event-on-change-reading state
attr dum_solo2wzStatus room VUplus
define not_solo2wzStatusAn notify vusolo2wz {fhem("set dum_solo2wzStatus an") if (ReadingsVal("vusolo2wz","state","") eq "on")}
attr not_solo2wzStatusAn room VUplus
define not_solo2wzStatusStandby notify vusolo2wz {fhem("set dum_solo2wzStatus standby") if (ReadingsVal("vusolo2wz","state","") eq "off")}
attr not_solo2wzStatusStandby room VUplus
define not_solo2wzStatusAus notify vusolo2wz {fhem("set dum_solo2wzStatus aus") if (ReadingsVal("vusolo2wz","state","") eq "absent")}
attr not_solo2wzStatusAus room VUplus
define dum_solo2szStatus dummy
attr dum_solo2szStatus event-on-change-reading state
attr dum_solo2szStatus room VUplus
define not_solo2szStatusAn notify vusolo2sz {fhem("set dum_solo2szStatus an") if (ReadingsVal("vusolo2sz","state","") eq "on")}
attr not_solo2szStatusAn room VUplus
define not_solo2szStatusStandby notify vusolo2sz {fhem("set dum_solo2szStatus standby") if (ReadingsVal("vusolo2sz","state","") eq "off")}
attr not_solo2szStatusStandby room VUplus
define not_solo2szStatusAus notify vusolo2sz {fhem("set dum_solo2szStatus aus") if (ReadingsVal("vusolo2sz","state","") eq "absent")}
attr not_solo2szStatusAus room VUplus
define log_solo2wzStatus FileLog ./log/dum_solo2wzStatus-%Y.log dum_solo2wzStatus
attr log_solo2wzStatus logtype text
attr log_solo2wzStatus room VUplus
define log_solo2szStatus FileLog ./log/dum_solo2szStatus-%Y.log dum_solo2szStatus
attr log_solo2szStatus logtype text
attr log_solo2szStatus room VUplus
define EG_woz_LichtAutoAn at *{sunset("HORIZON=1.0",0,"16:30","21:30")} set HUEGroup0 bri 10 : transitiontime 0;; set HUEGroup0 bri 192 : transitiontime 9000
attr EG_woz_LichtAutoAn group Beleuchtung
attr EG_woz_LichtAutoAn icon time_automatic
attr EG_woz_LichtAutoAn room EG_Wohnzimmer,HUEDevice
define EG_woz_LichtAutoAus at *22:15 {if((Value("dum_solo2wzStatus") eq "aus")||(Value("dum_solo2wzStatus") eq "standby")) {fhem("set HUEGroup0 off")}}
attr EG_woz_LichtAutoAus group Beleuchtung
attr EG_woz_LichtAutoAus icon time_automatic
attr EG_woz_LichtAutoAus room EG_Wohnzimmer,HUEDevice
define OG.anz.ROA CUL_HM 2906CD
attr OG.anz.ROA IODev HMLAN1
attr OG.anz.ROA IOgrp vccu:HMLAN1
attr OG.anz.ROA autoReadReg 4_reqStatus
attr OG.anz.ROA devStateIcon up:fts_shutter_10@green down:fts_shutter_100@black 9\d.*:fts_shutter_10 8\d.*:fts_shutter_20 7\d.*:fts_shutter_30 6\d.*:fts_shutter_40 5\d.*:fts_shutter_50 4\d.*:fts_shutter_60 3\d.*:fts_shutter_70 2\d.*:fts_shutter_80 1\d.*:fts_shutter_90 0\d.*:fts_shutter_100
attr OG.anz.ROA eventMap on:up off:down
attr OG.anz.ROA expert 2_full
attr OG.anz.ROA firmware 2.3
attr OG.anz.ROA group Rolladensteuerung
attr OG.anz.ROA icon fts_shutter_manual
attr OG.anz.ROA model HM-LC-Bl1PBU-FM
attr OG.anz.ROA peerIDs 00000000,
attr OG.anz.ROA room CUL_HM,OG_Ankleidezimmer
attr OG.anz.ROA serialNr LEQ0270410
attr OG.anz.ROA subType blindActuator
attr OG.anz.ROA webCmd stop:up:90:80:70:60:50:40:30:20:10:down
define FileLog_OG.anz.ROA FileLog ./log/OG.anz.ROA-%Y.log OG.anz.ROA
attr FileLog_OG.anz.ROA logtype text
attr FileLog_OG.anz.ROA room CUL_HM
define OG_anz_RolloAutoAuf at *{sunrise("REAL",0,"08:00","11:00")} set OG.anz.ROA 100
attr OG_anz_RolloAutoAuf group Rolladensteuerung
attr OG_anz_RolloAutoAuf icon fts_shutter_automatic
attr OG_anz_RolloAutoAuf room OG_Ankleidezimmer
define OG_anz_RolloAutoZu at *{sunset(0,"17:00","22:30")} set OG.anz.ROA 0
attr OG_anz_RolloAutoZu group Rolladensteuerung
attr OG_anz_RolloAutoZu icon fts_shutter_automatic
attr OG_anz_RolloAutoZu room OG_Ankleidezimmer
define OG.arz.ROA CUL_HM 310D79
attr OG.arz.ROA IODev HMLAN1
attr OG.arz.ROA IOgrp vccu:HMLAN1
attr OG.arz.ROA autoReadReg 4_reqStatus
attr OG.arz.ROA devStateIcon up:fts_shutter_10@green down:fts_shutter_100@black 9\d.*:fts_shutter_10 8\d.*:fts_shutter_20 7\d.*:fts_shutter_30 6\d.*:fts_shutter_40 5\d.*:fts_shutter_50 4\d.*:fts_shutter_60 3\d.*:fts_shutter_70 2\d.*:fts_shutter_80 1\d.*:fts_shutter_90 0\d.*:fts_shutter_100
attr OG.arz.ROA eventMap on:up off:down
attr OG.arz.ROA expert 2_full
attr OG.arz.ROA firmware 2.3
attr OG.arz.ROA group Rolladensteuerung
attr OG.arz.ROA icon fts_shutter_manual
attr OG.arz.ROA model HM-LC-Bl1PBU-FM
attr OG.arz.ROA peerIDs 00000000,
attr OG.arz.ROA room CUL_HM,OG_Arbeitszimmer
attr OG.arz.ROA serialNr LEQ1031109
attr OG.arz.ROA subType blindActuator
attr OG.arz.ROA webCmd stop:up:90:80:70:60:50:40:30:20:10:down
define FileLog_OG.arz.ROA FileLog ./log/OG.arz.ROA-%Y.log OG.arz.ROA
attr FileLog_OG.arz.ROA logtype text
attr FileLog_OG.arz.ROA room CUL_HM
define EG.kue.ROA CUL_HM 310F5E
attr EG.kue.ROA IODev HMLAN1
attr EG.kue.ROA IOgrp vccu:HMLAN1
attr EG.kue.ROA autoReadReg 4_reqStatus
attr EG.kue.ROA devStateIcon hoch:fts_shutter_10@green runter:fts_shutter_100@black 9\d.*:fts_shutter_10 8\d.*:fts_shutter_20 7\d.*:fts_shutter_30 6\d.*:fts_shutter_40 5\d.*:fts_shutter_50 4\d.*:fts_shutter_60 3\d.*:fts_shutter_70 2\d.*:fts_shutter_80 1\d.*:fts_shutter_90 0\d.*:fts_shutter_100
attr EG.kue.ROA eventMap on:hoch off:runter
attr EG.kue.ROA expert 2_full
attr EG.kue.ROA firmware 2.3
attr EG.kue.ROA group Rolladensteuerung
attr EG.kue.ROA icon fts_shutter_manual
attr EG.kue.ROA model HM-LC-Bl1PBU-FM
attr EG.kue.ROA peerIDs 00000000,
attr EG.kue.ROA room CUL_HM,EG_Küche
attr EG.kue.ROA serialNr LEQ1030710
attr EG.kue.ROA subType blindActuator
attr EG.kue.ROA webCmd stop:hoch:90:80:70:60:50:40:30:20:10:runter
define FileLog_EG.kue.ROA FileLog ./log/EG.kue.ROA-%Y.log EG.kue.ROA
attr FileLog_EG.kue.ROA logtype text
attr FileLog_EG.kue.ROA room CUL_HM
define OG.baz.ROA CUL_HM 310F5F
attr OG.baz.ROA IODev HMLAN1
attr OG.baz.ROA IOgrp vccu:HMLAN1
attr OG.baz.ROA autoReadReg 4_reqStatus
attr OG.baz.ROA devStateIcon up:fts_shutter_10@green down:fts_shutter_100@black 9\d.*:fts_shutter_10 8\d.*:fts_shutter_20 7\d.*:fts_shutter_30 6\d.*:fts_shutter_40 5\d.*:fts_shutter_50 4\d.*:fts_shutter_60 3\d.*:fts_shutter_70 2\d.*:fts_shutter_80 1\d.*:fts_shutter_90 0\d.*:fts_shutter_100
attr OG.baz.ROA eventMap on:up off:down
attr OG.baz.ROA expert 2_full
attr OG.baz.ROA firmware 2.3
attr OG.baz.ROA group Rolladensteuerung
attr OG.baz.ROA icon fts_shutter_manual
attr OG.baz.ROA model HM-LC-Bl1PBU-FM
attr OG.baz.ROA peerIDs 00000000,
attr OG.baz.ROA room CUL_HM,OG_Badezimmer
attr OG.baz.ROA serialNr LEQ1030708
attr OG.baz.ROA subType blindActuator
attr OG.baz.ROA webCmd stop:up:90:80:70:60:50:40:30:20:10:down
define FileLog_OG.baz.ROA FileLog ./log/OG.baz.ROA-%Y.log OG.baz.ROA
attr FileLog_OG.baz.ROA logtype text
attr FileLog_OG.baz.ROA room CUL_HM
define EG.woz.ROATerrassentuer CUL_HM 311CAF
attr EG.woz.ROATerrassentuer IODev HMLAN1
attr EG.woz.ROATerrassentuer IOgrp vccu:HMLAN1
attr EG.woz.ROATerrassentuer autoReadReg 4_reqStatus
attr EG.woz.ROATerrassentuer devStateIcon up:fts_shutter_10@green down:fts_shutter_100@black 9\d.*:fts_shutter_10 8\d.*:fts_shutter_20 7\d.*:fts_shutter_30 6\d.*:fts_shutter_40 5\d.*:fts_shutter_50 4\d.*:fts_shutter_60 3\d.*:fts_shutter_70 2\d.*:fts_shutter_80 1\d.*:fts_shutter_90 0\d.*:fts_shutter_100
attr EG.woz.ROATerrassentuer eventMap on:up off:down
attr EG.woz.ROATerrassentuer expert 2_full
attr EG.woz.ROATerrassentuer firmware 2.3
attr EG.woz.ROATerrassentuer group Rolladensteuerung
attr EG.woz.ROATerrassentuer icon fts_shutter_manual
attr EG.woz.ROATerrassentuer model HM-LC-Bl1PBU-FM
attr EG.woz.ROATerrassentuer peerIDs 00000000,
attr EG.woz.ROATerrassentuer room CUL_HM,EG_Wohnzimmer
attr EG.woz.ROATerrassentuer serialNr LEQ1031803
attr EG.woz.ROATerrassentuer subType blindActuator
attr EG.woz.ROATerrassentuer webCmd stop:up:90:80:70:60:50:40:30:20:10:down
define FileLog_EG.woz.ROATerrassentuer FileLog ./log/EG.woz.ROATerrassentuer-%Y.log EG.woz.ROATerrassentuer
attr FileLog_EG.woz.ROATerrassentuer logtype text
attr FileLog_EG.woz.ROATerrassentuer room CUL_HM
define EG.woz.ROAFenster CUL_HM 311C13
attr EG.woz.ROAFenster IODev HMLAN1
attr EG.woz.ROAFenster IOgrp vccu:HMLAN1
attr EG.woz.ROAFenster autoReadReg 4_reqStatus
attr EG.woz.ROAFenster devStateIcon up:fts_shutter_10@green down:fts_shutter_100@black 9\d.*:fts_shutter_10 8\d.*:fts_shutter_20 7\d.*:fts_shutter_30 6\d.*:fts_shutter_40 5\d.*:fts_shutter_50 4\d.*:fts_shutter_60 3\d.*:fts_shutter_70 2\d.*:fts_shutter_80 1\d.*:fts_shutter_90 0\d.*:fts_shutter_100
attr EG.woz.ROAFenster eventMap on:up off:down
attr EG.woz.ROAFenster expert 2_full
attr EG.woz.ROAFenster firmware 2.3
attr EG.woz.ROAFenster group Rolladensteuerung
attr EG.woz.ROAFenster icon fts_shutter_manual
attr EG.woz.ROAFenster model HM-LC-Bl1PBU-FM
attr EG.woz.ROAFenster peerIDs 00000000,
attr EG.woz.ROAFenster room CUL_HM,EG_Wohnzimmer
attr EG.woz.ROAFenster serialNr LEQ1031649
attr EG.woz.ROAFenster subType blindActuator
attr EG.woz.ROAFenster webCmd stop:up:90:80:70:60:50:40:30:20:10:down
define FileLog_EG.woz.ROAFenster FileLog ./log/EG.woz.ROAFenster-%Y.log EG.woz.ROAFenster
attr FileLog_EG.woz.ROAFenster logtype text
attr FileLog_EG.woz.ROAFenster room CUL_HM
define OG_arz_RolloAutoZu at *{sunset("HORIZON=-3.0",0,"17:00","22:00")} set OG.arz.ROA 0
attr OG_arz_RolloAutoZu group Rolladensteuerung
attr OG_arz_RolloAutoZu icon fts_shutter_automatic
attr OG_arz_RolloAutoZu room OG_Arbeitszimmer
define OG_baz_RolloAutoZu at *{sunset("HORIZON=-3.0",0,"17:00","22:00")} set OG.baz.ROA 0
attr OG_baz_RolloAutoZu group Rolladensteuerung
attr OG_baz_RolloAutoZu icon fts_shutter_automatic
attr OG_baz_RolloAutoZu room OG_Badezimmer
define EG_woz_RolloAutoZu at *{sunset("HORIZON=-3.0",0,"17:00","22:00")} set EG.woz.ROAFenster,EG.woz.ROATerrassentuer 0
attr EG_woz_RolloAutoZu group Rolladensteuerung
attr EG_woz_RolloAutoZu icon fts_shutter_automatic
attr EG_woz_RolloAutoZu room EG_Wohnzimmer
define EG_kue_RolloAutoZu at *{sunset("HORIZON=-3.0",0,"17:00","22:00")} set EG.kue.ROA 0
attr EG_kue_RolloAutoZu group Rolladensteuerung
attr EG_kue_RolloAutoZu icon fts_shutter_automatic
attr EG_kue_RolloAutoZu room EG_Küche
define EG_woz_RolloAutoAuf at *{sunrise("REAL",0,"06:30","09:00")} set EG.woz.ROAFenster,EG.woz.ROATerrassentuer 100
attr EG_woz_RolloAutoAuf group Rolladensteuerung
attr EG_woz_RolloAutoAuf icon fts_shutter_automatic
attr EG_woz_RolloAutoAuf room EG_Wohnzimmer
define EG_kue_RolloAutoAuf at *{sunrise("REAL",0,"06:30","09:00")} set EG.kue.ROA 100
attr EG_kue_RolloAutoAuf group Rolladensteuerung
attr EG_kue_RolloAutoAuf icon fts_shutter_automatic
attr EG_kue_RolloAutoAuf room EG_Küche
define OG_arz_RolloAutoAuf at *{sunrise("REAL",0,"08:00","11:00")} set OG.arz.ROA 100
attr OG_arz_RolloAutoAuf group Rolladensteuerung
attr OG_arz_RolloAutoAuf icon fts_shutter_automatic
attr OG_arz_RolloAutoAuf room OG_Arbeitszimmer
define OG_baz_RolloAutoAuf at *{sunrise("REAL",0,"08:00","11:00")} set OG.baz.ROA 100
attr OG_baz_RolloAutoAuf group Rolladensteuerung
attr OG_baz_RolloAutoAuf icon fts_shutter_automatic
attr OG_baz_RolloAutoAuf room OG_Badezimmer
RPI 2 mit FHEM 5.8
FB 7390 OS 6.83 | Synology DS 214+ DSM
VU+: 1 x Solo4k & 2 Solo2 VTi 11.xx.xx
SONOS: BRIDGE | 8x PLAY:1 | 1x PLAY:5 | 1x SUB Vers. 8.1.1
HMLAN: HM-Sec-SC-2 |-Sec-RHS |-CC-RT-DN |-LC-Bl1PBU-FM |-LC-Sw1PBU-FM |-LC-Sw1-FM |-ES-PMSw1-Pl |-WDS10-TH-O |-PBI-4-F
MacDad
... #14 ist der Anfang, #11 kommt danach und #12 Teil 2 ist der letzte Teil
Ich verzweifle so langsam.
Danke, Gruß Dirk
RPI 2 mit FHEM 5.8
