Exclude on from structure but not off
Begonnen von andyclimb, 01 Oktober 2016, 14:26:39
andyclimb
I'd like to exclude the on command from a structure but not the off.
I'd i'd like structure off to turn the device off, but for structure on to be ignored...
Is this possible.. I've tried various methods... i hoped this might work but it does not...
structexclude
livingroom.structure.room:FILTER=STATE=on
any ideas?
AM
The FILTER=STATE=on suffix is only used in the devspec2array function, it is irrelevant for structexclude.
You cannot filter single commands with structexclude, only prevent a device to execute any command, if it is originated from a structure he belongs to.
The only solution coming to my mind which might help is a cmdalias.
andyclimb
Ok thanks. That is good to know. I'll get around it with a dummy device and notify.
AM
