CUL 868 sowie 433 ccconf Anzeige Probleme?
Begonnen von b0mb4, 16 September 2018, 18:54:33
b0mb4
Hallo zusammen
Ich habe seit Ende August irgendwie Probleme meine Systeme richtig anzusprechen oder auszulesen.
Bei meinem nanoCUL 433 zeigt er mir bei list device folgendes an:
   CMDS       ABCeFfGiKLlMNRTtUVWXx
   Clients    :FS20:FHT.*:KS300:USF1000:BS:HMS: :CUL_EM:CUL_WS:CUL_FHTTK:CUL_HOERMANN: :ESA2000:CUL_IR:CUL_TX:Revolt:IT:UNIRoll:SOMFY: :STACKABLE_CC:TSSTACKED:STACKABLE:CUL_RFR::CUL_TCM97001:CUL_REDIRECT:
   DEF        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI04XE7J-if00-port0@38400 0000
   DeviceName /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI04XE7J-if00-port0@38400
   FD         11
   FHTID      0000
   NAME       CUL_433
   NR         41
   PARTIAL
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.26.02 a-culfw Build: 275 (2018-02-07_20-27-53) nanoCUL433 (F-Band: 433MHz)
   initString X21
   Helper:
     DBLOG:
       ccconf:
         logdb:
           TIME       1537116557.7246
           VALUE      freq:1.644MHz bWidth:650KHz rAmpl:33dB sens:4dB
       raw:
         logdb:
           TIME       1537116741.69045
           VALUE      isFF0000000FF0
       state:
         logdb:
           TIME       1537116523.49289
           VALUE      sens 8
   MatchList:
     1:USF1000  ^81..(04|0c)..0101a001a5ceaa00....
     2:BS       ^81..(04|0c)..0101a001a5cf
     3:FS20     ^81..(04|0c)..0101a001
     4:FHT      ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
     5:KS300    ^810d04..4027a001
     6:CUL_WS   ^K.....
     7:CUL_EM   ^E0.................$
     8:HMS      ^810e04......a001
     9:CUL_FHTTK ^T[A-F0-9]{8}
     A:CUL_RFR  ^[0-9A-F]{4}U.
     B:CUL_HOERMANN ^R..........
     C:ESA2000  ^S................................$
     D:CUL_IR   ^I............
     E:CUL_TX   ^TX[A-F0-9]{10}
     F:Revolt   ^r......................$
     G:IT       ^i......
     H:STACKABLE_CC ^\*
     I:UNIRoll  ^[0-9A-F]{5}(B|D|E)
     J:SOMFY    ^Y[r|t|s]:?[A-F0-9]+
     K:CUL_TCM97001 ^s[A-F0-9]+
     L:CUL_REDIRECT ^o+
     M:TSSTACKED ^\*
     N:STACKABLE ^\*
     2018-09-16 18:49:17   ccconf          freq:1.644MHz bWidth:650KHz rAmpl:33dB sens:4dB
     2018-09-16 18:22:20   cmds             A B C e F f G i K L l M N R T t U V W X x
     2018-09-16 18:52:21   raw             isFF0000000FF0
     2018-09-16 18:22:20   state           Initialized
     2018-03-28 15:14:27   uptime          0 00:00:31
     2018-09-15 20:08:08   version         V 1.26.02 a-culfw Build: 275 (2018-02-07_20-27-53) nanoCUL433 (F-Band: 433MHz)
   icon       cul_cul
   rfmode     SlowRF
   room       CUL_HM
   verbose    5
Bei meinem 868 nanoCUL
   CMDS       ABCEeFfGiKlMNRTtUVWXxZ
   CUL_868_MSGCNT 43
   CUL_868_TIME 2018-09-16 18:52:07
   Clients    :CUL_HM:HMS:CUL_IR:STACKABLE_CC:TSSTACKED:STACKABLE:
   DEF        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AH06LB8I-if00-port0@38400 1234
   DeviceName /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AH06LB8I-if00-port0@38400
   FD         10
   FHTID      1234
   NAME       CUL_868
   NR         28
   NR_CMD_LAST_H 12
   PARTIAL
   RAWMSG     A0F80861061577C0000000A50EC0E00002E
   RSSI       -51
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.26.02 a-culfw Build: 275 (2018-02-07_20-27-53) nanoCUL868 (F-Band: 868MHz)
   initString X21
Ar
   owner_CCU  VCCU
   Helper:
     DBLOG:
       state:
         logdb:
           TIME       1537115477.02947
           VALUE      UNKNOWNCODE ERR:CCA
   MatchList:
     1:CUL_HM   ^A....................
     8:HMS      ^810e04....(1|5|9).a001
     H:STACKABLE_CC ^\*
     M:TSSTACKED ^\*
     N:STACKABLE ^\*
     2018-09-16 15:46:19   ccconf          freq:868.300MHz bWidth:101KHz rAmpl:33dB sens:8dB
     2018-09-16 18:22:15   cmds             A B C E e F f G i K l M N R T t U V W X x Z
     2018-09-16 18:52:07   state           Initialized
     2018-09-16 14:57:18   uptime          0 00:05:50
     2018-09-16 14:57:22   version         V 1.26.02 a-culfw Build: 275 (2018-02-07_20-27-53) nanoCUL868 (F-Band: 868MHz)
   XMIT_TIME:
     1537114995.32967
     1537115020.45302
     1537115031.76778
     1537115144.46245
     1537115181.20663
     1537115193.89668
     1537115279.47277
     1537115327.47229
     1537115341.90551
     1537115399.9822
     1537115459.22718
     1537115475.39919
   helper:
     615100:
       QUEUE:
     61577C:
       QUEUE:
     6412A0:
       QUEUE:
   hmId       AABBCC
   icon       cul_868
   rfmode     HomeMatic
   room       CUL_HM
   verbose    0
Ich möchte den Teil der Frequenz etc. hinterfragen.
Ich kann ändern was ich will, er frisst die neue Frequenz einfach nicht.
Beim 868 hab ich sogar die Lötstellen und den nano ersetzt, half alles nichts.
Jetzt bin ich langsam mit meinem Latein am Ende.
Für Hilfe wäre ich Mega dankbar!
Liebe Grüsse und Danke
Alex
Den 433-er solltest du mal in den Werkszustand versetzen. Wenn dann über ccconf nix kommt, ist entweder der CC1101 nicht richtig angeschlossen oder kaputt.
Der 868-er sieht m.E. ok aus. Wenn er im HM-Mode ist, scheint sich der CC1101 automatisch auf die richtige Frequenz einstellen (meiner hat ähnliche Werte...).
Aber vielleicht solltest du einen nach dem anderen angehen, nicht, dass da der 433er für HM verwendet wird usw.. Das würde nicht oder schlecht klappen.
b0mb4
Hi
Erstmal Danke für den Hinweis!
In den Werkszustand hatte ich beide schon versetzt.
Half leider nichts.
Hab für beide die alternative firmware drauf gespielt.
Das die Beiden ne komische Frequenz anzeigen habe ich noch nicht so lange, kann mich allerdings auch nicht daran errinern wann ich es das letzte mal richtig gesehen hatte.
Ich weiß nur das die ganze Umgebung Ende August angefangen hat zu spacken.
Aber frag mich nicht was da war.
ZitatAber vielleicht solltest du einen nach dem anderen angehen, nicht, dass da der 433er für HM verwendet wird usw.. Das würde nicht oder schlecht klappen.
Wie schaue ich das oder verhindere das?
Danke für weiteren Input!
Liebe Grüsse
Alex
Ich kann nur bei einem eine komische Frequenz erkennen (dem 433-er).
Du mußt halt nachsehen, ob die by-id-Angabe so wirklich korrekt ist. Da das aber Nachbauten sind, ist das nicht so einfach von hier aus zu beurteilen. Schau mal in's Wiki zu Selbstbau-CUL, da sind einige unterschiedliche CC1101-Varianten abgebildet.
b0mb4
Für alle die so verzweifelt gesucht haben wie ich, hier die Lösung:
Ein USB-Hub mit Stromversorgung und die Probleme waren gegessen.
Nachdem ich das angeschlossen hatte, waren die Frequenzen Stabil und mein CUL ist auch nicht mehr abgestürzt und blinkt auch nicht mehr schnell wie wild.
Danke an alle Beteiligten!
Grüsse
Alex
