OWX wird aus cfg gelscht, warum?
Begonnen von Guest, 12 November 2012, 09:11:21
Guest
Hallo
einfache Frage, ich rufe "get OWio1 devices" auf, das OWX findet 7devices
und löscht dann sein define für OWX...warum?
Log: (reverse Log)
2012.11.12 09:04:53 1: OWX: 1-Wire devices found on bus OWio1: (OWX_20_F5930C000000,OWX_10_CD1670010800,OWX_28_B03863010000,OWX_28_18F0A0010000,OWX_28_753863010000,OWX_29_BCAD02000000,OWX_29_AFAD02000000)
2012.11.12 09:04:53 1: OWX: Deleting unused 1-Wire device OWio1 of type OWX
2012.11.12 09:04:53 3: OWSWITCH:   Device OWX_29_AFAD02000000 defined.
2012.11.12 09:04:53 3: OWSWITCH:   Device OWX_29_BCAD02000000 defined.
2012.11.12 09:04:53 3: OWTHERM: Device OWX_28_18F0A0010000 defined.
2012.11.12 09:04:53 3: OWTHERM: Device OWX_28_B03863010000 defined.
2012.11.12 09:04:53 3: OWAD:   Device OWX_20_F5930C000000 defined.
2012.11.12 09:04:42 3: OWTHERM: Could not get values from device OWX_10_CD1670010800, reason 10.CD167001080000 not accessible in 2nd step
2012.11.12 09:04:42 3: OWX: Complex called with unknown interface on bus OWio1
2012.11.12 09:04:42 3: OWX: Reset called with undefined interface
2012.11.12 09:04:42 3: OWTHERM: Could not get values from device OWX_28_753863010000, reason 28.75386301000000 not accessible in 2nd step
2012.11.12 09:02:05 2: COC01: unknown message 7:8300000002ADAF29
2012.11.12 09:02:05 2: COC01: unknown message 6:8100000002ADBC29
2012.11.12 09:02:05 2: COC01: unknown message 5:6400000163387528
2012.11.12 09:02:05 2: COC01: unknown message 4:40000001A0F01828
2012.11.12 09:02:05 2: COC01: unknown message 3:100000016338B028
2012.11.12 09:02:05 2: COC01: unknown message 2:BB0008017016CD10
2012.11.12 09:02:05 2: COC01: unknown message 1:9D0000000C93F520
2012.11.12 09:02:05 3: set COC01 raw Oc
2012.11.12 09:01:46 2: COC01: unknown message OK:1
2012.11.12 09:01:46 3: set COC01 raw ORb
2012.11.12 09:01:43 2: COC01: unknown message OK
2012.11.12 09:01:43 3: set COC01 raw ORm
Vorher habe ich per set raw die Teilnehmer verifiziert...
Config war:
define COC01 CUL /dev/ttyAMA0@38400 1234
attr COC01 dummy 1
attr COC01 room fhem
define OWio1 OWX COC01
attr OWio1 buspower real
attr OWio1 room OWX
define OWX_10_CD1670010800 OWTHERM DS1820 CD1670010800
attr OWX_10_CD1670010800 IODev OWio1
attr OWX_10_CD1670010800 room OWX
attr OWX_10_CD1670010800 stateAH ▴
attr OWX_10_CD1670010800 stateAL ▾
define OWX_28_753863010000 OWTHERM DS18B20 753863010000
attr OWX_28_753863010000 IODev OWio1
attr OWX_28_753863010000 room OWX
attr OWX_28_753863010000 stateAH ▴
attr OWX_28_753863010000 stateAL ▾
Ich hoffe es war nicht zu lang... ;o)
VT
