[gelöst] Im Log CUL_HM 16_LED attack, Warum?
Begonnen von franky08, 03 September 2014, 09:18:39
franky08
Hallo, ich bekomme seit einiger Zeit eine
2014.09.03 07:56:04 2: CUL_HM 16_LED attack:11123ABC1D481F800B02:11123ABC1D481F800B01.
2014.09.03 07:56:05 2: CUL_HM 16_LED attack:11123ABC1D481F800B01:11123ABC1D481F800B02.
Meldung.
Ein list 16_LED zeigt:
   DEF        1D481F
   HMLAN1_MSGCNT 869
   HMLAN1_RAWMSG E1D481F,0000,1174B4CD,FF,FFD5,5680021D481F123ABC010E010026A6559A65
   HMLAN1_RSSI -43
   HMLAN1_TIME 2014-09-03 08:54:30
   IODev      hmusb
   LASTInputDev hmusb
   MSGCNT     1808
   NAME       16_LED
   NR         284
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 16_LED_1
   channel_02 16_LED_2
   channel_03 16_LED_3
   channel_04 16_LED_4
   channel_05 16_LED_5
   channel_06 16_LED_6
   channel_07 16_LED_7
   channel_08 16_LED_8
   channel_09 16_LED_9
   channel_0A 16_LED_10
   channel_0B 16_LED_11
   channel_0C 16_LED_12
   channel_0D 16_LED_13
   channel_0E 16_LED_14
   channel_0F 16_LED_15
   channel_10 LED_Fenster_KinderZi
   hmusb_MSGCNT 939
   hmusb_RAWMSG R3A4B0D40,0001,088A60FF,FF,FFD6,5680021D481F123ABC010E010026A6559A65
   hmusb_RSSI -42
   hmusb_TIME 2014-09-03 08:54:30
   lastMsg    No:56 - t:02 s:1D481F d:123ABC 010E010026A6559A65
   protErrIoAttack 14 last_at:2014-09-03 07:56:05
   protLastRcv 2014-09-03 08:54:30
   protResnd  27 last_at:2014-09-03 07:56:03
   protSnd    906 last_at:2014-09-03 08:54:29
   protState  CMDs_done
   rssi_at_HMLAN1 avg:-47.91 min:-58 max:-40 lst:-43 cnt:869
   rssi_at_hmusb avg:-41.48 min:-45 max:-36 lst:-42 cnt:939
   rssi_hmusb avg:-37.66 min:-42 max:-32 lst:-38 cnt:782
   CHANGETIME:
   Readings:
     2014-09-03 06:41:04   CommandAccepted yes
     2014-06-26 13:34:11   D-firmware      1.1
     2014-06-26 13:34:11   D-serialNr      JEQ0218923
     2014-09-03 06:41:07   PairedTo        0x123ABC
     2014-09-03 06:41:07   R-brightness    1
     2014-06-26 13:37:39   R-energyOpt     0 s
     2014-09-02 06:39:03   R-localResDis   off
     2014-09-02 06:39:03   R-pairCentral   0x123ABC
     2014-09-03 06:41:07   RegL_00:          02:01 04:01 08:00 0A:12 0B:3A 0C:BC 18:00 00:00
     2014-09-03 08:54:30   color           A6559A65
     2014-07-03 14:06:17   powerOn         -
     2014-07-03 14:06:18   recentStateType ack
     2014-09-03 07:56:05   sabotageAttack  ErrIoAttack cnt:14
     2014-09-03 08:54:30   state           CMDs_done
   Helper:
     cSnd       11123ABC1D481F800E01
     mId        006D
     rxType     1
     Io:
       newChn     +1D481F,00,01,00
       nextSend   1409727270.7494
       prefIO
       rxt        0
       vccu       vccu
       p:
         1D481F
         00
         01
         00
     Mrssi:
       mNo        56
       Io:
         HMLAN1     -43
         hmusb      -40
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rssi:
       At_hmlan1:
         avg        -47.9194476409666
         cnt        869
         lst        -43
         max        -40
         min        -58
       At_hmusb:
         avg        -41.4802981895634
         cnt        939
         lst        -42
         max        -36
         min        -45
       Hmusb:
         avg        -37.6662404092071
         cnt        782
         lst        -38
         max        -32
         min        -42
     Shadowreg:
   DbLogExclude .*
   IODev      hmusb
   IOgrp      vccu
   autoReadReg 5_readMissing
   event-on-update-reading .*
   expert     2_full
   firmware   1.1
   fp_Plots   50,100
   model      HM-OU-LED16
   room       Wohnzimmer
   serialNr   JEQ0218923
   subType    outputUnit
   webCmd     getConfig
Kann das mit einem vorher stattgefundenen disconnect vom HMLAN zusammenhängen? HMLAN1 und hmusb sind in einer vccu mit gleicher hmID.
2014.09.03 07:46:02 1: 192.168.2.222:1000 disconnected, waiting to reappear (HMLAN1)
2014.09.03 07:46:02 1: HMLAN_Parse: HMLAN1 new condition disconnected
2014.09.03 07:46:02 1: 192.168.2.222:1000 reappeared (HMLAN1)
2014.09.03 07:46:02 1: HMLAN_Parse: HMLAN1 new condition init
2014.09.03 07:46:02 1: HMLAN_Parse: HMLAN1 new condition ok
2014.09.03 07:50:00 3: WS3600(Msg): myWS1080 Read started
2014.09.03 07:52:22 3: CUL_HM set 16_LED_11 led red
2014.09.03 07:52:26 3: CUL_HM set 16_LED_11 led green
2014.09.03 07:55:00 3: WS3600(Msg): myWS1080 Read started
2014.09.03 07:55:57 3: CUL_HM set 16_LED_11 led red
2014.09.03 07:56:03 3: CUL_HM set 16_LED_11 led green
2014.09.03 07:56:03 3: CUL_HM set 16_LED_11 led red
2014.09.03 07:56:04 3: CUL_HM set 16_LED_11 led red
Hat Martin da einen Tipp?
VG
Frank
mit FHEM aktuell
franky08
#1
Hat Martin keinen Tipp?
Im gesamten Umkreis gibt es auch keinen Nachbarn, der fhem oder Homematic nutzt.
Mmh seltsam  :o
VG
Frank
mit FHEM aktuell
franky08
Leider stimmt die Aussage nicht, dass die attack Meldung nach einem disconnect kommt, habe eben im Log gesehen das es auch ohne disconnect auftritt
2014.09.04 00:00:59 3: CUL_HM set Badlicht on-for-timer 600
2014.09.04 00:00:59 2: CUL_HM 16_LED attack:11123ABC1D481F800A01:11123ABC1D481F800F01.
VG
Frank
mit FHEM aktuell
peterk_de
Hatte ich so ähnlich bei einem Wandthermostaten. Pair mal versuchsweise neu, bei mir war es dann weg.
FHEM auf Ubuntu-VM / 2xNUC Proxmox Cluster
UI: HomeKit, TabletUI, Grafana
IOdevs: 2xHueBridge, RaspiMatic-CCU, CUL868, 2xHarmonyHub, 6xRaspi-Roomnode mit CO2, VOC und lepresenced
Devices: 107xHomematic(IP), 96xPhilips Hue, 17xTECHEM, 12xBTLE, 8xSONOS, 2xHomeConnect, 1xShelly 3em, 1xNanoleaf ...
franky08
Danke für den Tipp, pairing vergessen, hatte ich schon einmal mit einem Schaltaktor. Versuch ich morgen mal.
VG
Frank
mit FHEM aktuell
martinp876
Dieser Log kommt, wenn eine schalt oder config message empfangen wird (kein trigger!) die nicht von FHEM gesendet wurde.
gesendet wurde zuletzt 11123ABC1D481F800A01  (so im FHEM speicher). gesehen wurde 11123ABC1D481F800F01.
Es wurde zuletzt an Kanal 10 gesendet, empfangen wurde, dass kanal 15 gesetzt wurde.
Entweder sendet eine andere Quelle mit der gleichen ID... oder es gibt ein Scenario, in dem dies passieren kann, das ich nicht kenne.
kannst du einmal rohmessags loggen und sagen, ob du ein kommando auslöst?
franky08
#6
Hallo Martin, da ich mittels vccu 3 IO devices definiert habe, wird das loggen der Rohmessages bestimmt ziemlich unübersichtlich werden.
Die Meldung tritt mehr oder weniger spontan auf, ich poste mal aus dem Log um zu sehen welche Events vorher stattfanden.
2014.09.04 19:30:58 1: 192.168.2.222:1000 disconnected, waiting to reappear (HMLAN1)
2014.09.04 19:30:58 1: HMLAN_Parse: HMLAN1 new condition disconnected
2014.09.04 19:30:59 1: 192.168.2.222:1000 reappeared (HMLAN1)
2014.09.04 19:30:59 1: HMLAN_Parse: HMLAN1 new condition init
2014.09.04 19:31:00 3: CUL_HM set Stehlampe on
2014.09.04 19:31:00 1: HMLAN_Parse: HMLAN1 new condition ok
2014.09.04 19:31:00 3: CUL_HM set Kueche_Unterschrank on
2014.09.04 19:31:00 3: CUL_HM set 16_LED_4 led green
2014.09.04 19:35:00 3: WS3600(Msg): myWS1080 Read started
2014.09.04 19:40:00 3: WS3600(Msg): myWS1080 Read started
2014.09.04 19:41:43 3: CUL_HM set 16_LED_6 led green
2014.09.04 19:41:49 3: get Kalender_Frank summary 1jrd41sculejucuhbn2v2snom4googlecom : Gelbersack_morgen
2014.09.04 19:45:00 3: WS3600(Msg): myWS1080 Read started
2014.09.04 19:48:53 2: ENIGMA2 set Dreambox volume 10
2014.09.04 19:49:07 3: CUL_HM set Flurlicht on
2014.09.04 19:49:07 3: CUL_HM set 16_LED_7 led green
2014.09.04 19:49:45 3: CUL_HM set 16_LED ilum 0 0
2014.09.04 19:49:45 2: CUL_HM 16_LED attack:01123ABC1D481F00080400:01123ABC1D481F00050000000000.
2014.09.04 19:49:49 3: CUL_HM set 16_LED getConfig
2014.09.04 19:50:00 3: WS3600(Msg): myWS1080 Read started
2014.09.04 19:51:01 2: ENIGMA2 set Dreambox volume 75
2014.09.04 19:52:40 0: Server shutdown
2014.09.04 19:54:01 1: Including fhem.cfg
2014.09.04 19:54:01 3: Connecting to database SQLite:dbname=/opt/fhem/fhem.db with user
2014.09.04 19:54:02 3: Connection to db SQLite:dbname=/opt/fhem/fhem.db established for pid 2076
2014.09.04 19:54:02 3: telnetPort: port 7072 opened
2014.09.04 19:54:03 3: WEB: port 8083 opened
2014.09.04 19:54:03 3: WEBphone: port 8084 opened
2014.09.04 19:54:03 3: WEBtablet: port 8085 opened
2014.09.04 19:54:03 3: WEBtablet2: port 8086 opened
2014.09.04 19:54:03 1: HMLAN_Parse: HMLAN1 new condition disconnected
2014.09.04 19:54:03 3: Opening HMLAN1 device 192.168.2.222:1000
2014.09.04 19:54:03 3: HMLAN1 device opened
2014.09.04 19:54:03 1: HMLAN_Parse: HMLAN1 new condition init
2014.09.04 19:54:03 1: HMLAN_Parse: HMLAN2 new condition disconnected
2014.09.04 19:54:03 3: Opening HMLAN2 device 192.168.2.223:1000
2014.09.04 19:54:03 3: HMLAN2 device opened
2014.09.04 19:54:03 1: HMLAN_Parse: HMLAN2 new condition init
2014.09.04 19:54:03 1: HMLAN_Parse: hmusb new condition disconnected
2014.09.04 19:54:03 3: Opening hmusb device 127.0.0.1:1234
2014.09.04 19:54:03 3: hmusb device opened
2014.09.04 19:54:03 1: HMLAN_Parse: hmusb new condition init
2014.09.04 19:54:06 2: VIERA: defined with host: 192.168.2.20 and interval: 30
2014.09.04 19:54:09 3: Opening FB7390 device 192.168.2.1:1012
2014.09.04 19:54:09 3: FB7390 device opened
2014.09.04 19:54:11 3: FHEM2FHEM opening ds1 at 192.168.2.30:7072
2014.09.04 19:54:11 3: FHEM2FHEM device opened (ds1)
2014.09.04 19:54:12 2: Heizungen_Sommer: no reading yet for Temperatur_Garten temperature
2014.09.04 19:55:08 3: WS3600(Msg): myWS1080 initialized, setting callback timer to 20:00:00(+  300 s)
2014.09.04 19:55:11 1: Including ./log/fhem.save
2014.09.04 19:55:12 2: SecurityCheck:  WEBtablet,WEBtablet2 has no basicAuth attribute. telnetPort has no password/globalpassword attribute.  Restart FHEM for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2014.09.04 19:55:12 0: Server started with 490 defined entities (version $Id: fhem.pl 6498 2014-09-01 19:24:40Z rudolfkoenig $, os linux, user fhem, pid 2076)
2014.09.04 19:55:12 3: CUL_HM set 16_LED_5 led green
2014.09.04 19:55:14 3: CUL_HM set Kueche_Heizung_ClimRT_tr controlManu off
2014.09.04 19:55:14 3: CUL_HM set Flur_Heizung_Clima controlManu off
2014.09.04 19:55:14 3: CUL_HM set Bad_Heizung_ClimRT_tr controlManu off
2014.09.04 19:55:14 3: CUL_HM set Kinderzimmer_Heizung_links_ClimRT_tr controlManu off
2014.09.04 19:55:14 3: CUL_HM set Kinderzimmer_Heizung_rechts_ClimRT_tr controlManu off
2014.09.04 19:55:14 3: CUL_HM set SZ_Heizung_links_ClimRT_tr controlManu off
2014.09.04 19:55:14 3: CUL_HM set SZ_Heizung_rechts_ClimRT_tr controlManu off
2014.09.04 19:55:15 3: CUL_HM set 16_LED_6 led green
2014.09.04 19:55:15 1: HMLAN_Parse: HMLAN1 new condition ok
2014.09.04 19:55:15 3: CUL_HM set Herdlicht off
2014.09.04 19:55:15 1: HMLAN_Parse: HMLAN2 new condition ok
2014.09.04 19:55:15 1: HMLAN_Parse: hmusb new condition ok
2014.09.04 19:55:16 3: CUL_HM set 16_LED_2 led red
2014.09.04 19:55:16 3: Device BM_WZ added to ActionDetector with 000:20 time
2014.09.04 19:55:16 3: Device Bad_Heizung added to ActionDetector with 000:10 time
2014.09.04 19:55:16 3: Device Diff_Sensor_WZ added to ActionDetector with 012:00 time
2014.09.04 19:55:16 3: Device Diff_Temp_Sensor added to ActionDetector with 000:10 time
2014.09.04 19:55:16 3: Device Fenster_Bad added to ActionDetector with 048:00 time
2014.09.04 19:55:16 3: Device Fenster_KiZi_links added to ActionDetector with 048:00 time
2014.09.04 19:55:16 3: Device Fenster_Kueche added to ActionDetector with 048:00 time
2014.09.04 19:55:16 3: Device Flur_Heizung added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device Heizung_WZ_links added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device Heizung_WZ_rechts added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device IR_Sensor added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device Kinderzimmer_Heizung_links added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device Kinderzimmer_Heizung_rechts added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device Klima_Switch added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device Kueche_Heizung added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device Leistungsmesser_Tablet added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device SZ_Heizung_links added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device SZ_Heizung_rechts added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device Schalter_Tuer added to ActionDetector with 028:00 time
2014.09.04 19:55:17 3: Device Schalter_Tuer_WZ added to ActionDetector with 048:00 time
2014.09.04 19:55:17 3: Device Schalter_Wohnungstuer added to ActionDetector with 028:00 time
2014.09.04 19:55:17 3: Device THSensor added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device TH_Sensor_Bad added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device TH_Sensor_HZ added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device TH_Sensor_KinderZi added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device TH_Sensor_WZ added to ActionDetector with 000:10 time
2014.09.04 19:55:17 3: Device Temperatur_Garten added to ActionDetector with 000:10 time
2014.09.04 19:55:19 3: CUL_HM set 16_LED statusRequest
2014.09.04 19:55:20 3: CUL_HM set 4_Kanal_Platine_Kanal_1 statusRequest
2014.09.04 19:55:21 3: CUL_HM set Aquarium statusRequest
2014.09.04 19:55:21 3: CUL_HM set 16_LED_8 led red
2014.09.04 19:55:22 3: CUL_HM set Badlicht statusRequest
2014.09.04 19:55:23 3: CUL_HM set Flurlicht statusRequest
2014.09.04 19:55:24 3: CUL_HM set Herdlicht statusRequest
2014.09.04 19:55:25 3: CUL_HM set Klima_Schalter statusRequest
2014.09.04 19:55:26 3: CUL_HM set Kueche_Unterschrank statusRequest
2014.09.04 19:55:27 3: CUL_HM set Ladegeraet statusRequest
2014.09.04 19:55:27 3: CUL_HM set 16_LED_12 led red
2014.09.04 19:55:28 3: CUL_HM set Ladegeraet_Tablet statusRequest
2014.09.04 19:55:29 3: CUL_HM set Licht_Wohnungstuer statusRequest
2014.09.04 19:55:30 3: CUL_HM set Radio statusRequest
2014.09.04 19:55:31 3: CUL_HM set Licht_SZ statusRequest
2014.09.04 19:55:31 3: CUL_HM set 16_LED_9 led red
2014.09.04 19:55:32 3: CUL_HM set Stehlampe statusRequest
2014.09.04 19:55:32 3: CUL_HM set Kueche_Unterschrank on
2014.09.04 19:55:32 3: CUL_HM set 16_LED_4 led green
2014.09.04 19:55:33 3: CUL_HM set UV_Lampe statusRequest
2014.09.04 19:55:34 3: CUL_HM set Verstaerker statusRequest
2014.09.04 19:55:34 3: CUL_HM set 16_LED_15 led green
2014.09.04 19:56:41 1: 192.168.2.30:7072 disconnected, waiting to reappear
2014.09.04 19:56:46 1: FHEM2FHEM 192.168.2.30:7072 reappeared (ds1)
2014.09.04 20:00:00 3: WS3600(Msg): myWS1080 Read started
2014.09.04 20:05:00 3: WS3600(Msg): myWS1080 Read started
2014.09.04 20:10:00 3: WS3600(Msg): myWS1080 Read started
2014.09.04 20:12:22 3: CUL_HM set Herdlicht on
2014.09.04 20:12:22 3: CUL_HM set 16_LED_2 led green
2014.09.04 20:12:33 3: CUL_HM set Herdlicht off
2014.09.04 20:12:33 3: CUL_HM set 16_LED_2 led red
2014.09.04 20:15:00 3: WS3600(Msg): myWS1080 Read started
2014.09.04 20:20:00 3: WS3600(Msg): myWS1080 Read started
2014.09.04 20:20:59 3: CUL_HM set 16_LED_11 led red
2014.09.04 20:20:59 3: CUL_HM set 16_LED_11 led green
2014.09.04 20:21:00 3: CUL_HM set 16_LED_11 led green
2014.09.04 20:21:00 3: CUL_HM set 16_LED_11 led red
2014.09.04 20:21:00 2: CUL_HM 16_LED attack:11123ABC1D481F800B02:11123ABC1D481F800B01.
2014.09.04 20:21:03 3: CUL_HM set 16_LED_13 led red
2014.09.04 20:21:03 3: CUL_HM set Licht_Wohnungstuer on-for-timer 60
2014.09.04 20:21:03 2: CUL_HM 16_LED attack:11123ABC1D481F800B02:11123ABC1D481F800B01.
2014.09.04 20:21:07 3: CUL_HM set 16_LED_13 led green
Wenn du die Rohmessages brauchst, dann logge ich nochmals mit, wenn ja, dann von allen 3 IO Devices?
Ich hatte heute Mittag mal Rohmessages vom hmusb geloggt, ob da etwas brauchbares dabei ist kann ich aber nicht sagen (die attack Meldung ist dabei)
2014.09.04 13:36:18 0: HMLAN_Parse: hmusb V:03C7 sNo:JEQ0700806 d:1EBDD2 O:123ABC t:00019DEA IDcnt:0002
2014.09.04 13:36:18 0: HMLAN_Parse: hmusb R:E2A4F5D   stat:0000 t:00019EFE d:FF r:FFD2     m:11 845E 2A4F5D 000000 80726F000000000008D5FC
2014.09.04 13:36:18 0: HMLAN_Parse: hmusb R:R40734AC9 stat:0002 t:00000000 d:FF r:7FFF     m:CC 8002 123ABC 249978 01013700
2014.09.04 13:36:18 0: HMLAN_Parse: hmusb R:E206AA2   stat:0000 t:0001AAEB d:FF r:FFCC     m:72 8670 206AA2 000000 00E639
2014.09.04 13:36:19 0: HMLAN_Parse: hmusb R:E20BD8B   stat:0000 t:0001AB52 d:FF r:FFC4     m:2A 8653 20BD8B 000000 004100E64200E943FFFD440003
2014.09.04 13:36:19 0: HMLAN_Parse: hmusb R:R407358EF stat:0002 t:00000000 d:FF r:7FFF     m:CC 8002 123ABC 249978 01013700
2014.09.04 13:36:19 0: HMLAN_Parse: hmusb R:E1A4F71   stat:0000 t:0001B21A d:FF r:FFC9     m:E1 8410 1A4F71 123ABC 06015A00
2014.09.04 13:36:19 0: HMLAN_Parse: hmusb R:E2225D5   stat:0000 t:0001B87C d:FF r:FFCB     m:3C 8610 2225D5 000000 0A24E60C0069
2014.09.04 13:36:19 0: HMLAN_Parse: hmusb R:R407368AF stat:0001 t:0001BF46 d:FF r:FFD9     m:01 8002 1D481F 123ABC 0105020024A6659A65
2014.09.04 13:36:19 0: HMLAN_Send:  hmusb S:+1D481F,00,01,00
2014.09.04 13:36:19 0: HMLAN_Send:  hmusb S:S40736DAB stat:  00 t:00000000 d:01 r:40736DAB m:04 A001 123ABC 1D481F 010E
2014.09.04 13:36:19 0: HMLAN_Parse: hmusb R:R407368C0 stat:0008 t:00000000 d:FF r:7FFF     m:02 A112 123ABC 2221D0
2014.09.04 13:36:19 0: HMLAN_Parse: hmusb no ACK from 2221D0
2014.09.04 13:36:19 1: 192.168.2.222:1000 disconnected, waiting to reappear (HMLAN1)
2014.09.04 13:36:19 1: HMLAN_Parse: HMLAN1 new condition disconnected
2014.09.04 13:36:19 0: HMLAN_Parse: hmusb R:R40736B61 stat:0008 t:00000000 d:FF r:7FFF     m:03 A112 123ABC 22389B
2014.09.04 13:36:19 0: HMLAN_Parse: hmusb no ACK from 22389B
2014.09.04 13:36:19 1: 192.168.2.222:1000 reappeared (HMLAN1)
2014.09.04 13:36:19 1: HMLAN_Parse: HMLAN1 new condition init
2014.09.04 13:36:19 2: CUL_HM 16_LED attack:01123ABC1D481F010E:11123ABC1D481F800502.
2014.09.04 13:36:19 0: HMLAN_Parse: hmusb R:E123ABC   stat:0000 t:0001C440 d:FF r:FFCF     m:99 8112 123ABC 000000
2014.09.04 13:36:19 1: HMLAN_Parse: HMLAN1 new condition ok
2014.09.04 13:36:19 0: HMLAN_Delay: hmusb 1D481F
2014.09.04 13:36:19 3: CUL_HM set 4_Kanal_Platine_Kanal_2 statusRequest
2014.09.04 13:36:19 0: HMLAN_Parse: hmusb R:E1D481F   stat:0000 t:0001C481 d:FF r:FFD9     m:04 A010 1D481F 123ABC 0601010024A6659A65
2014.09.04 13:36:19 0: HMLAN_Parse: hmusb R:R40736DAB stat:0001 t:0001C486 d:FF r:FFD9     m:04 A010 1D481F 123ABC 0601010024A6659A65
2014.09.04 13:36:19 0: HMLAN_SdDly: hmusb 1D481F
2014.09.04 13:36:19 0: HMLAN_Send:  hmusb S:S40736F21 stat:  00 t:00000000 d:01 r:40736F21 m:05 A001 123ABC 1D481F 020E
2014.09.04 13:36:19 0: HMLAN_Parse: hmusb R:E123ABC   stat:0000 t:0001C53F d:FF r:FFD0     m:08 A112 123ABC 223338
2014.09.04 13:36:20 0: HMLAN_Parse: hmusb R:E123ABC   stat:0000 t:0001C61B d:FF r:FFD0     m:09 A112 123ABC 222575
2014.09.04 13:36:20 0: HMLAN_Delay: hmusb 1D481F
2014.09.04 13:36:20 0: HMLAN_Parse: hmusb R:E1D481F   stat:0000 t:0001C68C d:FF r:FFD9     m:05 A010 1D481F 123ABC 0602010022A6659A65
2014.09.04 13:36:20 0: HMLAN_Parse: hmusb R:E123ABC   stat:0000 t:0001C6CE d:FF r:FFCF     m:08 A112 123ABC 223338
2014.09.04 13:36:20 0: HMLAN_Parse: hmusb R:R40736F21 stat:0001 t:0001C691 d:FF r:FFD9     m:05 A010 1D481F 123ABC 0602010022A6659A65
2014.09.04 13:36:20 0: HMLAN_SdDly: hmusb 1D481F
2014.09.04 13:36:20 0: HMLAN_Send:  hmusb S:+1D481F,00,01,00
2014.09.04 13:36:20 0: HMLAN_Send:  hmusb S:S40737101 stat:  00 t:00000000 d:01 r:40737101 m:06 A001 123ABC 1D481F 030E
2014.09.04 13:36:20 0: HMLAN_Parse: hmusb R:E123ABC   stat:0000 t:0001C721 d:FF r:FFCF     m:0A A112 123ABC 2225D5
2014.09.04 13:36:20 0: HMLAN_Parse: hmusb R:E123ABC   stat:0000 t:0001C7AA d:FF r:FFCF     m:09 A112 123ABC 222575
2014.09.04 13:36:20 0: HMLAN_Parse: hmusb R:E123ABC   stat:0000 t:0001C7E9 d:FF r:FFCE     m:0A A112 123ABC 2225D5
2014.09.04 13:36:20 3: CUL_HM set 4_Kanal_Platine_Kanal_3 statusRequest
VG
Frank
mit FHEM aktuell
franky08
#7
Hallo Martin, ich denke, dass ich die Meldung wahrscheinlich selber provoziert habe. In der IOList von vccu waren keine Trennzeichen gesetzt. Also nicht hmusb,HMLAN1,HMLAN2 sondern hmusb HMLAN1 HMLAN2. Dadurch, dass die IOList nicht OK war, hat vccu wahrscheinlich die 2 anderen IO Devices nicht gekannt und mit attack geantwortet.
Sehe morgen früh nochmal im Log nach, ob es jetzt noch auftritt.
P.S. Dazu kommt das Problem der dauernd auftretenden kurzen disconnects
VG
Frank
mit FHEM aktuell
franky08
Habe den hmusb jetzt aus der vccu genommen und als IO Devices nur noch HMLAN1 und HMLAN2 und das System läuft wesentlich stabiler.
VG
Frank
mit FHEM aktuell
frank
Zitatdas System läuft wesentlich stabiler.
das kann eventuell auch mit der korrektur des IOList zu tun haben.
gruss frank
FHEM: 6.0(SVN) => Pi3(buster)
franky08
Ich beobachte das ganze, hat mir bis eben ein Haufen unknown devices eingebracht, die gerne hmusb als IO device hätten.
VG
Frank
mit FHEM aktuell
franky08
Die Meldung taucht immer noch auf, meist nach einem shutdown restart, logge jetzt mal die Rohmessages und führe einen Neustart durch.
VG
Frank
mit FHEM aktuell
franky08
#12
Hier die Rohmessages von HMLAN1 und HMLAN2
Wenn ich in Code Tags speichern will bekomme ich von der Forensoft einen Datenbankfehler!
mit FHEM aktuell
franky08
Hat jemand schon was rausfinden können? Zeitweise reagiert fhem mit einiger Verspätung weil die IO devices im disconnect sind. Woran das liegt, habe ich bis jetzt nicht eingrenzen können. Habe apptime laufen und poste morgen mal das Ergebnis.
VG
Frank
mit FHEM aktuell
franky08
hier das Ergebnis von apptime:
                                name             function    max  count    total  average maxDly
                     tmr-WS3600_Read      HASH(0x260aa50)  59336    120  7086973 59058.11   1863 HASH(myWS1080)
                              HMLAN1          HMLAN_Ready   3005    245     6661    27.19      0 HASH(HMLAN1)
                 tmr-Calendar_Wakeup      HASH(0x26ba610)   2374     11    19656  1786.91      6 HASH(Kalender_Frank)
                 tmr-VIERA_GetStatus      HASH(0x21a8a88)   2057   1034  1474746  1426.25  59579 HASH(TV)
                              HMLAN1           HMLAN_Read    848  10511   605205    57.58      0 HASH(HMLAN1)
          FHEMWEB:192.168.2.61:54875              FW_Read    717      1      717   717.00      0 HASH(FHEMWEB:192.168.2.61:54875)
          FHEMWEB:192.168.2.61:54874              FW_Read    699      2      789   394.50      0 HASH(FHEMWEB:192.168.2.61:54874)
                    Heizungen_Sommer     THRESHOLD_Notify    558  34150     1313     0.04      0 HASH(Heizungen_Sommer); HASH(Temperatur_Garten)
                              HMLAN2           HMLAN_Read    516  10401    28756     2.76      0 HASH(HMLAN2)
                   myWS1080_notify17          notify_Exec    330    120    16774   139.78      0 HASH(myWS1080_notify17); HASH(myWS1080)
                 tmr-Calendar_Wakeup      HASH(0x25e4918)    292      2      557   278.50   1644 HASH(Ferien)
                      Heizungswerte2 readingsGroup_Notify    271  34150   182070     5.33      0 HASH(Heizungswerte2); HASH(Kinderzimmer_Heizung_rechts_ClimRT_tr)
                   myWS1080_notify11          notify_Exec    266    120    11459    95.49      0 HASH(myWS1080_notify11); HASH(myWS1080)
                   myWS1080_notify14          notify_Exec    265    120    13676   113.97      0 HASH(myWS1080_notify14); HASH(myWS1080)
                    myWS1080_notify8          notify_Exec    262    120    10515    87.62      0 HASH(myWS1080_notify8); HASH(myWS1080)
                    myWS1080_notify2          notify_Exec    260    120    13516   112.63      0 HASH(myWS1080_notify2); HASH(myWS1080)
                    myWS1080_notify5          notify_Exec    259    120    10216    85.13      0 HASH(myWS1080_notify5); HASH(myWS1080)
                    myWS1080_notify4          notify_Exec    258    120    10876    90.63      0 HASH(myWS1080_notify4); HASH(myWS1080)
                    myWS1080_notify6          notify_Exec    253    120    10044    83.70      0 HASH(myWS1080_notify6); HASH(myWS1080)
                                 ds1       FHEM2FHEM_Read    217    893    54038    60.51      0 HASH(ds1)
                   myWS1080_notify12          notify_Exec    216    120     9881    82.34      0 HASH(myWS1080_notify12); HASH(myWS1080)
VG
Frank
mit FHEM aktuell
