Firmwareupdate über fhem ->error file corrupt. length:769 expected:772
Begonnen von chris1284, 28 Oktober 2014, 18:40:04
chris1284
file corrupt. length:769 expected:772 Hallo,
versuche gerade über fhem einen rt auf 1.4 zu aktualisieren. Leider funktioniert das nicht
mit
set [name] ./hmupdate/rt/hm_cc_rt_dn_update_V1_4_001_141020.tgz
erhalte ich
Zitatfile corrupt. length:769 expected:772
und im log so was
Zitat2014.10.28 18:29:13 1: PERL WARNING: Illegal hexadecimal digit '' ignored at ./FHEM/10_CUL_HM.pm line 4260, <aUpdtF> line 1.
2014.10.28 18:29:13 1: PERL WARNING: Illegal hexadecimal digit '�' ignored at ./FHEM/10_CUL_HM.pm line 4260, <aUpdtF> line 1.
2014.10.28 18:29:13 1: PERL WARNING: Illegal hexadecimal digit '_' ignored at ./FHEM/10_CUL_HM.pm line 4260, <aUpdtF> line 1.
2014.10.28 18:29:13 1: PERL WARNING: Illegal hexadecimal digit 'O' ignored at ./FHEM/10_CUL_HM.pm line 4260, <aUpdtF> line 1.
2014.10.28 18:29:13 1: PERL WARNING: Illegal hexadecimal digit 'z' ignored at ./FHEM/10_CUL_HM.pm line 4260, <aUpdtF> line 1.
2014.10.28 18:29:13 1: PERL WARNING: Illegal hexadecimal digit '/' ignored at ./FHEM/10_CUL_HM.pm line 4260, <aUpdtF> line 1.
2014.10.28 18:29:13 1: PERL WARNING: Illegal hexadecimal digit '(' ignored at ./FHEM/10_CUL_HM.pm line 4260, <aUpdtF> line 1.
2014.10.28 18:29:13 1: PERL WARNING: Illegal hexadecimal digit 'm' ignored at ./FHEM/10_CUL_HM.pm line 4260, <aUpdtF> line 1.
2014.10.28 18:29:13 1: PERL WARNING: Illegal hexadecimal digit '{' ignored at ./FHEM/10_CUL_HM.pm line 4260, <aUpdtF> line 1.
2014.10.28 18:29:13 1: PERL WARNING: Illegal hexadecimal digit '^' ignored at ./FHEM/10_CUL_HM.pm line 4260, <aUpdtF> line 1.
2014.10.28 18:29:13 1: PERL WARNING: Illegal hexadecimal digit 'R' ignored at ./FHEM/10_CUL_HM.pm line 4260, <aUpdtF> line 1.
2014.10.28 18:29:13 1: PERL WARNING: Illegal hexadecimal digit '~' ignored at ./FHEM/10_CUL_HM.pm line 4260, <aUpdtF> line 1.
geladen habe ich direkt per wget und per firefox (winscp zum rüberschieben auf den cubie).
selbes file (vom cubie und über firefox unter win) funktionieren problemlos unter Windows mit dem HM Update Tool
frank
FHEM: 6.0(SVN) => Pi3(buster)
chris1284
oook, schön dass das nicht dokumentiert ist  >:( sollte man ggf im wiki und der cmd-ref mit aufnehmen.
wer vorher immer mit den eq3 tools geupdated hat hat im hinterkopf "ja das file nicht auspacken auch wenn es ein archiv ist"
Puschel74
hier mal in Codeschnippsel gefunden:
http://forum.fhem.de/index.php/topic,28335.0.html
Evtl. sollte man das irgendwo "sichtbarer" hinterlegen.
chris1284
evtl unter
    FHEM Forum »
    FHEM - Hausautomations-Systeme »
    Homematic
anpinnen oder in HM Update mit in Post 1 (und nat. wiki da man sich dort das update über fhem erwähnt)
Puschel74
Das darf gerne einer von Euch übernehmen - ich hab keine Berechtigung dazu.
Ich fands nur schade für den Fall das der Code verloren gehen würde.
frank
Zitatwer vorher immer mit den eq3 tools geupdated hat hat im hinterkopf "ja das file nicht auspacken auch wenn es ein archiv ist"
mit dem windows-tool kannst du auch eq3-files benutzen.  ;)
Zitatoook, schön dass das nicht dokumentiert ist  >:( sollte man ggf im wiki und der cmd-ref mit aufnehmen.
guggst du hier http://www.fhemwiki.de/wiki/HomeMatic_Firmware_Update#Firmware_Update_mit_CUL.2FHM-CFG-USB_unter_FHEM
gebrauchter tag, würde ich behaupten wollen.  :)
frank
mich würde noch brennend interessieren, ob und unter welchen umständen das update funktioniert hat. (io, vccu, prefered io, abstand devices, versuchsanzahl, fhem-server, etc). danke  :)
Puschel74
martinp876
Beim update hatte ich keine vccu. Ich wuerde darauf achten, das nur ein io aktiv ist. Prefered sollte auch reichen. Die vccu selbst macht kei.e probleme. Die vccu sollte nicht mit einem io verwechselt werden, es steuert ios an ein paar stellen
