FHEM startet nach update nicht mehr
Begonnen von GG33, 18 März 2015, 12:13:22
GG33
Nach dem Update startet FHEM nicht mehr. Das Raspi läuft und auch über putty erreichbar.
hier die Meldungen beim uptade
Events (global only):
2015-03-18 10:46:46 Global global MKDIR restoreDir/2015-03-18
2015-03-18 10:46:46 Global global UPD ./CHANGED
2015-03-18 10:46:46 Global global UPD ./configDB.pm
2015-03-18 10:46:46 Global global UPD ./fhem.cfg.demo
2015-03-18 10:46:46 Global global UPD ./fhem.pl
2015-03-18 10:46:46 Global global UPD FHEM/00_CUL.pm
2015-03-18 10:46:46 Global global UPD FHEM/00_FBAHA.pm
2015-03-18 10:46:46 Global global UPD FHEM/00_HMLAN.pm
2015-03-18 10:46:47 Global global UPD FHEM/00_HXB.pm
2015-03-18 10:46:47 Global global UPD FHEM/00_KM271.pm
2015-03-18 10:46:47 Global global UPD FHEM/00_MAXLAN.pm
2015-03-18 10:46:47 Global global UPD FHEM/00_MQTT.pm
2015-03-18 10:46:47 Global global UPD FHEM/00_RPII2C.pm
2015-03-18 10:46:47 Global global UPD FHEM/00_SONOS.pm
2015-03-18 10:46:47 Global global UPD FHEM/00_TCM.pm
2015-03-18 10:46:47 Global global UPD FHEM/00_THZ.pm
2015-03-18 10:46:47 Global global UPD FHEM/00_ZWDongle.pm
2015-03-18 10:46:48 Global global UPD FHEM/01_FHEMWEB.pm
2015-03-18 10:46:48 Global global UPD FHEM/02_FRAMEBUFFER.pm
2015-03-18 10:46:48 Global global UPD FHEM/02_HTTPSRV.pm
2015-03-18 10:46:48 Global global UPD FHEM/02_RSS.pm
2015-03-18 10:46:48 Global global UPD FHEM/09_CUL_FHTTK.pm
2015-03-18 10:46:48 Global global UPD FHEM/10_CUL_HM.pm
2015-03-18 10:46:48 Global global UPD FHEM/10_EnOcean.pm
2015-03-18 10:46:48 Global global UPD FHEM/10_FRM.pm
2015-03-18 10:46:49 Global global UPD FHEM/10_FS20.pm
2015-03-18 10:46:49 Global global UPD FHEM/10_HXBDevice.pm
2015-03-18 10:46:49 Global global UPD FHEM/10_IT.pm
2015-03-18 10:46:49 Global global UPD FHEM/10_KOPP_FC.pm
2015-03-18 10:46:49 Global global UPD FHEM/10_MAX.pm
2015-03-18 10:46:49 Global global UPD FHEM/10_MQTT_BRIDGE.pm
2015-03-18 10:46:49 Global global UPD FHEM/10_MQTT_DEVICE.pm
2015-03-18 10:46:49 Global global UPD FHEM/10_MYSENSORS_DEVICE.pm
2015-03-18 10:46:49 Global global UPD FHEM/10_OWServer.pm
2015-03-18 10:46:49 Global global UPD FHEM/10_RESIDENTS.pm
2015-03-18 10:46:49 Global global UPD FHEM/10_SOMFY.pm
2015-03-18 10:46:49 Global global UPD FHEM/10_ZWave.pm
2015-03-18 10:46:50 Global global UPD FHEM/11_FHT8V.pm
2015-03-18 10:46:50 Global global UPD FHEM/11_OWDevice.pm
2015-03-18 10:46:50 Global global UPD FHEM/14_CUL_MAX.pm
2015-03-18 10:46:50 Global global UPD FHEM/14_CUL_TCM97001.pm
2015-03-18 10:46:50 Global global UPD FHEM/17_EGPM2LAN.pm
2015-03-18 10:46:50 Global global UPD FHEM/20_FRM_ROTENC.pm
2015-03-18 10:46:50 Global global UPD FHEM/20_GUEST.pm
2015-03-18 10:46:50 Global global UPD FHEM/20_ROOMMATE.pm
2015-03-18 10:46:50 Global global UPD FHEM/21_OWCOUNT.pm
2015-03-18 10:46:50 Global global UPD FHEM/21_OWTHERM.pm
2015-03-18 10:46:50 Global global UPD FHEM/21_SONOSPLAYER.pm
2015-03-18 10:46:52 Global global UPD FHEM/23_KOSTALPIKO.pm
2015-03-18 10:46:52 Global global UPD FHEM/23_LUXTRONIK2.pm
2015-03-18 10:46:52 Global global UPD FHEM/30_HUEBridge.pm
2015-03-18 10:46:52 Global global UPD FHEM/30_LIGHTIFY.pm
2015-03-18 10:46:52 Global global UPD FHEM/30_MilightBridge.pm
2015-03-18 10:46:53 Global global UPD FHEM/31_HUEDevice.pm
2015-03-18 10:46:53 Global global UPD FHEM/31_LightScene.pm
2015-03-18 10:46:53 Global global UPD FHEM/31_MilightDevice.pm
2015-03-18 10:46:53 Global global UPD FHEM/32_SYSSTAT.pm
2015-03-18 10:46:53 Global global UPD FHEM/32_mailcheck.pm
2015-03-18 10:46:53 Global global UPD FHEM/32_withings.pm
2015-03-18 10:46:53 Global global UPD FHEM/33_readingsGroup.pm
2015-03-18 10:46:53 Global global UPD FHEM/33_readingsHistory.pm
2015-03-18 10:46:53 Global global UPD FHEM/33_readingsProxy.pm
2015-03-18 10:46:53 Global global UPD FHEM/34_SWAP.pm
2015-03-18 10:46:53 Global global UPD FHEM/34_panStamp.pm
2015-03-18 10:46:57 Global global http://fhem.de/fhemupdate/FHEM/34_panStamp.pm: Can't connect(1) to http://fhem.de:80: IO::Socket::INET: connect: timeout
Wie bringe ich das wieder zu laufen? vielen Dank!
FHEM 5.6 auf Raspi (Debian Wheezy)
Homematic HMLAN
4 x HM-ES-PMSw1-Pl / HM-WDS40-TH-I-2 / HM-SEC-SCo
LUXTRONIK2 / SolarView
bsl02
auf dem RPi kann ein Update schon einmal länger dauern, je nachdem wie lange das letzte Update her ist.
Dein Problem scheint aber woanders zu liegen:
Zitat2015-03-18 10:46:57 Global global http://fhem.de/fhemupdate/FHEM/34_panStamp.pm: Can't connect(1) to http://fhem.de:80: IO::Socket::INET: connect: timeout
Du könntest folgendes versuchen, siehe dort:
Zitathttp://forum.fhem.de/index.php/topic,33155.msg255133.html#msg255133
Gruß und Erfolg,
Stefan
RPi3 (FHEM) / CUL V3 868 (FS20) / nanoCUL868 (HM) / RFXtrx433 (IT & ELRO) / MAX!Cube (Thermostate, Fenster) / Bluetooth (presence Handy) / Sonoff mit Tasmota // Audio: RPi3 mit "max2play"-Image (Squeezeserver+Player) / Video: Synology-NAS mit TVheadend, Triax TSS400 Sat-IP Converter
oder einfach so lange probieren, bis das update durchläuft...
suero
#3
auch bei mir startet FHEM nach einen Update nicht mehr.
Ist vollständig durchgelaufen.
Läuft auf OSX 10.10.2
Scheint Probleme mit Perl zu geben ....
Habe vom TimeCapsule eine Rücksicherung des Ordners fhem vorgenommen.
Damit ging es wieder.
Nicht funktioniert hat das Rücksichern aus dem Ordner restoreDir.
GG33
Ich komme igendwie nicht weiter.
Ich habe jetzt die Berechtigungen für die Logfiles angepasst, diese Fehlermeldungen sind nun auch weg. Aber FHEM läuft immer noch nicht wieder.
Hier das Logfile nach einem Start
2015.03.18 22:34:45 1: Including fhem.cfg
2015.03.18 22:34:46 3: telnetPort: port 7072 opened
2015.03.18 22:34:47 3: WEB: port 8083 opened
2015.03.18 22:34:47 3: WEBphone: port 8084 opened
2015.03.18 22:34:47 3: WEBtablet: port 8085 opened
2015.03.18 22:34:47 2: eventTypes: loaded 170 events from ./log/eventTypes.txt
2015.03.18 22:34:50 2: PVGG33 will read from solarview at 192.168.0.17:15000 every 60 seconds
2015.03.18 22:34:50 2: E350 will read from solarview at 192.168.0.17:15000 every 60 seconds
2015.03.18 22:34:51 3: [wt_Stromtarif] invalid device, <Stromtarif> not found
2015.03.18 22:34:51 1: Including ./log/fhem.save
2015.03.18 22:34:51 1: usb create starting
2015.03.18 22:34:53 3: Probing CUL device /dev/ttyAMA0
2015.03.18 22:34:53 3: Probing TCM_ESP3 device /dev/ttyAMA0
2015.03.18 22:34:53 3: Probing FRM device /dev/ttyAMA0
2015.03.18 22:34:59 1: usb create end
2015.03.18 22:34:59 2: SecurityCheck:  WEB,WEBphone,WEBtablet has no basicAuth attribute. telnetPort has no password/globalpassword attribute.  Restart FHEM for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2015.03.18 22:34:59 0: Server started with 23 defined entities (version $Id: fhem.pl 8207 2015-03-14 13:01:30Z rudolfkoenig $, os linux, user pi, pid 2222)
2015.03.18 22:34:59 2: LUXTRONIK2 Heizung: UpdateDone.972 Alert: Host uses untested Firmware 'V1.73'. Please inform FHEM comunity about compatibility.
Sobald ich aber FHEM über den Browser aufrufe erscheint im Terminal folgende Meldung
Undefined subroutine &main::TcpServer_WriteBlocking called at ./FHEM/01_FHEMWEB.pm line 1533.
Homematic HMLAN
GG33
#5
Hallo, ich habe jetzt auf meinem Rapberry Pi alles neu aufgesetzt.
zuerst das Raspian, dann alle updates.
und danach fhem mit diesem skript von betateilchen
//[code]http://forum.fhem.de/index.php/topic,15848.msg103268.html#msg103268[/code]
das FHEM hat dann einmalig gestartet. nach "shutdown restart" geht nichts mehr und die Datei in fehm in /etc/init.d ist nicht vorhanden. ich weiss echt nicht mehr weiter....
Homematic HMLAN
GG33
Hilfe! ;-()
Also nun habe ich nochmals alles neu aufgesetzt, jetzt nach dieser Metode: https://debian.fhem.de/
Läuft so weit, aber das Problem beim Update bleit das selbe! Was kann ich noch machen? habe jetzt schon sicher 10 mal versucht.
2015-03-22 10:11:23 Global global UPD ./CHANGED
2015-03-22 10:11:23 Global global UPD ./configDB.pm
2015-03-22 10:11:27 Global global http://fhem.de/fhemupdate/./configDB.pm: Can't connect(1) to http://fhem.de:80: IO::Socket::INET: connect: timeout
Homematic HMLAN
bsl02
#7
Was ich schon einmal hatte waren lose sitzende USB-Kontakte zu Transceiver-Kabeln (RFXtrx); die ließen das System nicht richtig booten.
Das scheint aber bei Dir nicht der Fall zu sein - wenn das System vor dem Update einwandfrei läuft.
Fragen am Rande; eine wirkliche Idee fehlt mir zu Deinem Problem:
  • Schon probiert, mit der Demo-Config zu starten und die Updates durchzuführen? (siehe meinen Link)
  • Welche Geräte sind am RPi angeschlossen (RFXtrx, CUL866/433, ...)? Notiz: Diese Infos werden gern auch in die Forum-Signatur dargestellt (Forum Profil > Signatur)
  • Ist der Raspberry Pi evtl. per WLan angebunden?
  • Schon einmal mit einer anderen Speicherkarte auf dem RPi versucht?
Gruß und Erfolg,
Stefan
/Edit: Habe gerade einmal testweise auf einem frischen System FHEM instaliert (Odroid U3 mit Max2Play-Image, http://www.max2play.com/),
"Update" durchgeführt und ähnliche Probleme:
2015-03-24 01:05:47 Global global UPD www/images/fhemSVG/sani_heating_level_0.svg
2015-03-24 01:05:47 Global global UPD www/images/fhemSVG/sani_heating_level_10.svg
2015-03-24 01:05:48 Global global UPD www/images/fhemSVG/sani_heating_level_100.svg
2015-03-24 01:05:48 Global global http://fhem.de/fhemupdate/www/images/fhemSVG/sani_heating_level_100.svg: Can't connect(1) to http://fhem.de:80: IO::Socket::INET: connect: Connection refused
/Edit-2:
Wiederholt "update" ausführen könnte helfen:
Zitat...
2015-03-24 01:15:53 Global global UPD www/pgm2/smallscreenstyle.css
2015-03-24 01:15:53 Global global UPD www/pgm2/svg.js
2015-03-24 01:15:53 Global global UPD www/pgm2/svg_style.css
2015-03-24 01:15:53 Global global update finished, "shutdown restart" is needed to activate the changes.
2015-03-24 01:15:53 Global global Please consider using the global attribute sendStatistics
"update check" anschließend:
Zitatnothing to do...
jetzt natürlich noch "shutdown restart" ;-)
GG33
Hallo zusammen, ich habe das ganze System auf dem Raspi nochmals neu aufgesetzt. Aber beim Update habe ich noch immer das selbe Problem:
Zitat.....Can't connect(1) to http://fhem.de:80: IO::Socket::INET: connect: timeout
Habe auch das Update schon mehrfach ausgeführt. Immer das selbe, aber nicht an der selben Stelle beim Update!?
Ich installiere FHEM so: (mache ich da etwas falsch?)
root passwort setzen -> sudo passwd
#über Konsole als root anmelden
sudo apt-get install apt-transport-https
wget --no-check-certificate -qO - https://debian.fhem.de/archive.key | apt-key add -
/etc/apt/sources.list ergänzen: deb https://debian.fhem.de/stable ./ -> sudo nano /etc/apt/sources.list
#Speichern können wir diese Änderung in dem Editor nano mittels STRG + X, Y und Enter.
echo 'Acquire::https::debian.fhem.de::Verify-Peer "false";' > /etc/apt/apt.conf.d/30nohttps
apt-get update
apt-get install fhem
Homematic HMLAN
