yowsup bringt fhem zum Absturz
Begonnen von tdoe, 15 August 2015, 21:38:02
tdoe
ich hab immer wieder das Problem dass bei eintreffen von Commands über yowsup das ganze System stirbt.
Ich hab mir momentan mit nagios und einem eventhandler beholfen um in diesem Fall fhem wieder zu starten,
doch erscheint es mir nicht als finale Lösung des Problems.
Ich hab folgende Meldung direkt bei einem Absturz aus dem Log gezogen.
Unmatched [ in regex; marked by <-- HERE in m/,connected]:[connected]:[connected]:[ <-- HERE 49***********,/ at ./FHEM/32_yowsup.pm line 374.
Exception in thread Thread-1:
Traceback (most recent call last):
  File "/usr/lib/python2.7/threading.py", line 552, in __bootstrap_inner
    self.run()
  File "/usr/lib/python2.7/threading.py", line 505, in run
    self.__target(*self.__args, **self.__kwargs)
  File "/opt/yowsup-master/yowsup/demos/cli/cli.py", line 153, in startInputThread
    cmd = self._queuedCmds.pop(0) if len(self._queuedCmds) else input(self.getPrompt()).strip()
EOFError: EOF when reading a line
  File "/opt/yowsup-master/yowsup-cli", line 327, in <module>
    if not parser.process():
  File "/opt/yowsup-master/yowsup-cli", line 231, in process
    self.startCmdline()
  File "/opt/yowsup-master/yowsup-cli", line 259, in startCmdline
    stack.start()
  File "/opt/yowsup-master/yowsup/demos/cli/stack.py", line 25, in start
    self.stack.loop(timeout = 0.5, discrete = 0.5)
  File "/opt/yowsup-master/yowsup/stacks/yowstack.py", line 167, in loop
    asyncore.loop(*args, **kwargs)
  File "/usr/lib/python2.7/asyncore.py", line 216, in loop
    poll_fun(timeout, map)
  File "/usr/lib/python2.7/asyncore.py", line 156, in poll
    read(obj)
  File "/usr/lib/python2.7/asyncore.py", line 87, in read
    obj.handle_error()
  File "/usr/lib/python2.7/asyncore.py", line 83, in read
    obj.handle_read_event()
  File "/usr/lib/python2.7/asyncore.py", line 449, in handle_read_event
    self.handle_read()
  File "/opt/yowsup-master/yowsup/layers/network/layer.py", line 73, in handle_read
    self.receive(data)
  File "/opt/yowsup-master/yowsup/layers/network/layer.py", line 80, in receive
    self.toUpper(data)
  File "/opt/yowsup-master/yowsup/layers/__init__.py", line 55, in toUpper
    self.__upper.receive(data)
  File "/opt/yowsup-master/yowsup/layers/stanzaregulator/layer.py", line 28, in receive
    self.processReceived()
  File "/opt/yowsup-master/yowsup/layers/stanzaregulator/layer.py", line 48, in processReceived
    self.toUpper(oneMessageData)
  File "/opt/yowsup-master/yowsup/layers/auth/layer_crypt.py", line 63, in receive
    self.toUpper(payload)
  File "/opt/yowsup-master/yowsup/layers/coder/layer.py", line 35, in receive
    self.toUpper(node)
  File "/opt/yowsup-master/yowsup/layers/logger/layer.py", line 14, in receive
    self.toUpper(data)
  File "/opt/yowsup-master/yowsup/layers/__init__.py", line 160, in receive
    s.receive(data)
  File "/opt/yowsup-master/yowsup/layers/__init__.py", line 97, in receive
    if not self.processIqRegistry(node):
  File "/opt/yowsup-master/yowsup/layers/__init__.py", line 132, in processIqRegistry
    successClbk(protocolTreeNode, originalIq)
  File "/opt/yowsup-master/yowsup/layers/protocol_iq/layer.py", line 30, in onPong
    self.toUpper(ResultIqProtocolEntity.fromProtocolTreeNode(protocolTreeNode))
  File "/opt/yowsup-master/yowsup/layers/interface/interface.py", line 71, in receive
    self.callbacks[entityType](entity)
  File "/opt/yowsup-master/yowsup/demos/cli/layer.py", line 435, in onIq
    print(entity)
IOError: [Errno 32] Broken pipe
Zusätzlich finden sich folgende Meldungen im Logfile:
    self.run()
und:
    self.run()
IOError: [Errno 104] Connection reset by peer
Hat das noch jemand beobachtet?
Das sind alles Meldungen von dem yowsup cli, das ist klar, aber kann man das nicht irgendwie abfangen damit das nicht fhem zum Absturz bringt und im zweifel reconnected?
Hier noch ein list des Devices:
   CONNECTS   6
   FD         49
   LAST_DISCONNECT 2015-08-15 21:04:16
   NAME       WhatsApp
   NR         708
   NTFY_ORDER 50-WhatsApp
   PARTIAL
   PID        23100
   STATE      connected
   TIME       2015-08-15 21:48:45
   TYPE       yowsup
   Readings:
     2015-08-05 17:39:52   sent            49zzzzzzzzz Heyho.
     2015-08-15 21:04:31   state           connected
   acceptFrom 49xxxxxxxxx,49yyyyyyyyyy,49zzzzzzzzzz
   cmd        /opt/yowsup-master/yowsup-cli demos -c /opt/yowsup-config/yowsup.config --yowsup
   home       PWD
   nickname   Home, Sweet Home
   room       yowsup
Fhem info:
  Release  : 5.6
  OS       : linux
  Arch     : arm-linux-gnueabihf-thread-multi-64int
  Perl     : v5.14.2
# $Id: 32_yowsup.pm 8925 2015-07-08 20:38:25Z justme1968 $
Gruß tdoe
justme1968
welche version des modul benutz du? die normale aus dem update oder die mit der erweiterung für die gruppen?
wie schaut deine zeile 374 genau aus?
was steht im log wenn du verbose auf 4 stellt?
  andre
tdoe
#2
hab gerade ein command hingesendet, daraufhin ist prompt die connection abgerissen. Fhem hat diesmal wohl überlebt.
2015.08.15 22:01:09 4: WhatsApp: parse: CHATSTATE:
State: paused
    self.startCmdline()
    stack.start()
    read(obj)
    obj.handle_error()
    self.handle_read()
    self.receive(data)
    self.toUpper(data)
    self.toUpper(node)
    self.toUpper(data)
    s.receive(data)
  File "/opt/yowsup-master/yowsup/layers/__init__.py", line 101, in receive
    recv(node)
  File "/opt/yowsup-master/yowsup/layers/protocol_notifications/layer.py", line 41, in recvNotification
    self.raiseErrorForNode(node)
  File "/opt/yowsup-master/yowsup/layers/__init__.py", line 117, in raiseErrorForNode
    raise ValueError("Unimplemented notification type %s " % node)
ValueError: Unimplemented notification type <notification type="encrypt" from="s.whatsapp.net" id="3008???????" t="14396??????">
<count value="0">
</count>
</notification>
2015.08.15 22:01:09 3: WhatsApp: sending /disconnect
2015.08.15 22:01:09 3: WhatsApp: Disconnected
2015.08.15 22:01:09 3: WhatsApp: read: end of file reached while sysread
2015.08.15 22:01:20 2: WhatsApp: setting $HOME to /opt/fhem
2015.08.15 22:01:20 2: WhatsApp: starting yoswup-cli: /opt/yowsup-master/yowsup-cli demos -c /opt/yowsup-config/yowsup.config --yowsup
2015.08.15 22:01:23 4: WhatsApp: parse: Yowsup Cli client
Type /help for available commands
[offline]:
2015.08.15 22:01:23 3: WhatsApp: sending /L
2015.08.15 22:01:23 3: WhatsApp: sending /presence available
2015.08.15 22:01:23 3: WhatsApp: sending /presence name 'Home, Sweet Home'
    self.startCmdline()
    stack.start()
    read(obj)
    obj.handle_error()
    self.handle_read()
    self.receive(data)
    self.toUpper(data)
    self.toUpper(node)
    self.toUpper(data)
    s.receive(data)
    recv(node)
ValueError: Unimplemented notification type <notification type="encrypt" offline="1" from="s.whatsapp.net" id="3008338???" t="14396??????">
<count value="0">
</count>
</notification>
2015.08.15 22:01:29 4: WhatsApp: parse: Auth: Logged in!
[connected]:[connected]:[connected]:
2015.08.15 22:01:29 3: WhatsApp: sending /disconnect
2015.08.15 22:01:29 3: WhatsApp: Disconnected
2015.08.15 22:01:29 3: WhatsApp: read: end of file reached while sysread
2015.08.15 22:01:39 2: WhatsApp: setting $HOME to /opt/fhem
2015.08.15 22:01:39 2: WhatsApp: starting yoswup-cli: /opt/yowsup-master/yowsup-cli demos -c /opt/yowsup-config/yowsup.config --yowsup
2015.08.15 22:01:42 4: WhatsApp: parse: Yowsup Cli client
2015.08.15 22:02:22 4: WhatsApp: parse:
[offline]:
2015.08.15 22:02:22 3: WhatsApp: sending /L
2015.08.15 22:02:22 3: WhatsApp: sending /presence available
2015.08.15 22:02:22 3: WhatsApp: sending /presence name 'Home, Sweet Home'
2015.08.15 22:02:23 4: WhatsApp: parse: Auth: Logged in!
2015.08.15 22:03:13 4: WhatsApp: parse: Iq:
Type: result
Hier noch wie Zeile 374 aussieht:
366     my $number = $1;
367     my $time = $2;
368     my $id = $3;
369     my $message = $4;
370
371     my $chash = $modules{yowsup}{defptr}{$number};
372     if( !$chash ) {
373       my $accept_from = AttrVal($name, "acceptFrom", undef );
374       if( !$accept_from || ",$accept_from," =~/,$number,/ ) {
375         my $define = "$number yowsup $number";
376         my $cmdret = CommandDefine(undef,$define);
377         if($cmdret) {
378           Log3 $name, 1, "$name: Autocreate: An error occurred while creating device for number '$number': $cmdret";
379         } else {
380           #$cmdret = CommandAttr(undef,"$number alias ".$result->{$id}{name});
381           $cmdret = CommandAttr(undef,"$number room yowsup");
382           #$cmdret = CommandAttr(undef,"$number IODev $name");
383         }
384
385         $chash = $modules{yowsup}{defptr}{$number};
386       }
387     }
388
Ich teste weiter...
Nachtrag:
Ich hab folgende Änderung im Modul:
http://forum.fhem.de/index.php/topic,27543.msg319884.html#msg319884
Gruss tdoe
justme1968
deine zeilennummern passen nicht zu meinen. welche version des moduls ist das?
tdoe
ChrisK
Ich habe hier so ziemlich genau das gleiche Problem.
Modul-Version:
Zeile 371ff:
    if( !$chash ) {
        if($cmdret) {
        } else {
(374 fängt mit "if( !$accept_from ||..." an)
Attribut acceptFrom ist gesetzt auf "49xxxx,49yyyy".
Das Problem tritt nicht immer auf.
Ich habe das Gefühl, dass es nach etwas längerer fhem-Laufzeit auftritt und zwar schon wenn man anfängt zu schreiben (der  chatstate also auf composing geht). Vor dem Schreiben wird das Haus in WhatsApp auf dem Handy als "online" angezeigt. Schon kurz nach dem ersten Buchstaben  (vor dem Absenden) wird es als "zuletzt online am..." angezeigt.
Hilft das bei der Hilfe schon weiter? :)
Marie
ich schliesse mich mal an....hab seit einiger Zeit yowsup laufen, um zu schauen ob es stabil läuft (in der Vergangenheit Problem gehabt). Läuft,aber :
accepptFrom hinzugefügt, ein Kommando gesendet --> WhatsApp offline, reconnect bringt folgendes:
    self.startCmdline()
    stack.start()
    read(obj)
    obj.handle_error()
    self.handle_read()
    self.receive(data)
    self.toUpper(data)
    self.toUpper(node)
    self.toUpper(data)
    s.receive(data)
    recv(node)
ValueError: Unimplemented notification type <notification type="encrypt" offline="3" from="s.whatsapp.net" id="1280259918" t="1440754558">
<count value="0">
</count>
</notification>
2015.08.28 11:36:58 3: Haus: sending /disconnect
2015.08.28 11:36:58 3: Haus: Disconnected
2015.08.28 11:36:58 3: Haus: read: end of file reached while sysread
Habe danach accepptFrom wieder gelöscht, bekomme das Haus aber nicht wieder online....
Any suggestions?
Marie
Banana Pi & FHEM2FHEM Raspberry,RS485 Modbus Stromzähler UMG96, diverse Schaltsteckdosen 433 MHz, 868 MHz, MYSENSORS Temperatursensoren , Smartvisu, Homekit & Siri, Geofency, Zwave Rauchmelder & Steckdosen & Garagensteuerung, TabletUi mit BananaPi M2Ultra im Wohnmobil, Homebridge usw.usw.
groeg
habe so ziehmlich die gleichen Probleme damit.
Yoswup und Fhem mit Yowsup ist anfgangs super gelaufen aber seit ca. 1 Woche nur Probleme damit.
Sobald eine Nachricht an FHEM geht stürzt Yowsup ab.
Auth: Logged in!
[connected]:Traceback (most recent call last):
    self.startCmdline()
    stack.start()
    read(obj)
    obj.handle_error()
    self.handle_read()
  File "/opt/yowsup-master/yowsup/layers/network/layer.py", line 73, in handle_r                                              ead
    self.receive(data)
    self.toUpper(data)
  File "/opt/yowsup-master/yowsup/layers/auth/layer_crypt.py", line 63, in recei                                              ve
    self.toUpper(node)
    self.toUpper(data)
    s.receive(data)
    recv(node)
  File "/opt/yowsup-master/yowsup/layers/__init__.py", line 117, in raiseErrorFo                                              rNode
ValueError: Unimplemented notification type <notification type="encrypt" offline                                              ="3" from="s.whatsapp.net" id="3920258297" t="1441643034">
<count value="0">
</count>
</notification>
Wäre auch um eine Lösung Dankbar.
# $Id: 32_yowsup.pm 9191 2015-09-01 20:29:24Z justme1968 $
groeg
Habs jetzt endlich selbst hin bekommen.
einfach den Aufruf von Yowsup erweitern mit der option --moxie
attr WhatsApp cmd /opt/yowsup-master/yowsup-cli demos -c /opt/yowsup-config/yowsup.config --moxie --yowsup
