Problem mit .*<TeilDerDeviceNamen>
Begonnen von wkarl, 03 August 2014, 13:52:12
wkarl
gut, ich bin nicht der regex-nerd, dennoch glaubte ich es zu verstehen. Folgendes liefert ein eigenartiges Ergebnis.
set .*_TC_Climate controlMode manual
Es werden neben den gewollt adressierten TCs auch alle anderen devices involviert.
Unknown argument controlMode, choose one of absorb:FileLog_Badezimmer_FH,FileLog_Badezimmer_HK,FileLog_Badezimmer_HK_ClimRT_tr,FileLog_Badezimmer_HK_ClimaTeam,FileLog_Badezimmer_HK_Climate,FileLog_Badezimmer_HK_Weather,FileLog_Badezimmer_HK_WindowRec,FileLog_Badezimmer_HK_remote,FileLog_Badezimmer_TC,FileLog_Badezimmer_TC_Weather,FileLog_Badezimmer_TC_WindowRec,FileLog_Bewegungsmelder_HolzHuette,FileLog_BoschEconomic,FileLog_Buero_FH,FileLog_Buero_HK,FileLog_Buero_TC,FileLog_DieleWindfang_TC,FileLog_DieleWindfang_TC_Climate,FileLog_DieleWindfang_TC_Weather,FileLog_DieleWindfang_TC_WindowRec,FileLog_DieleWindfang_TK_HausTuer,FileLog_Diele_FH,FileLog_DimmSteckdose_01,FileLog_DimmSteckdose_02,FileLog_Esszimmer_FH,FileLog_Esszimmer_HK,FileLog_Esszimmer_HK_ClimRT_tr,FileLog_Esszimmer_HK_ClimaTeam,FileLog_Esszimmer_HK_Climate,FileLog_Esszimmer_HK_Weather,FileLog_Esszimmer_HK_WindowRec,FileLog_Esszimmer_HK_remote,FileLog_Esszimmer_TC,FileLog_Esszimmer_TC_Climate,FileLog_Esszimmer_TC_Weather,FileLog_Esszimmer_TC_WindowRec,FileLog_Esszimmer_TK_Tuer,FileLog_GaesteToilette_FH,FileLog_GaesteToilette_TC,FileLog_GaesteToilette_TC_Climate,FileLog_GaesteToilette_TC_Weather,FileLog_GaesteToilette_TC_WindowRec,FileLog_HMLAN_RepeaterEG_01,FileLog_HMLAN_RepeaterEG_02,FileLog_HMLAN_RepeaterOG,FileLog_Janine_FH_Fenster,FileLog_Janine_FH_Tuer,FileLog_Janine_HK,FileLog_Janine_HK_ClimRT_tr,FileLog_Janine_HK_ClimaTeam,FileLog_Janine_HK_Climate,FileLog_Janine_HK_Weather,FileLog_Janine_HK_WindowRec,FileLog_Janine_HK_remote,FileLog_Janine_TC,FileLog_Janine_TC_Climate,FileLog_Janine_TC_Weather,FileLog_Janine_TC_WindowRec,FileLog_Janine_TK_Tuer,FileLog_Klima_TempHum,FileLog_Kueche_FH,FileLog_Kueche_HK,FileLog_Kueche_HK_ClimRT_tr,FileLog_Kueche_HK_ClimaTeam,FileLog_Kueche_HK_Climate,FileLog_Kueche_HK_Weather,FileLog_Kueche_HK_WindowRec,FileLog_Kueche_HK_remote,FileLog_Kueche_TC,FileLog_Kueche_TC_Climate,FileLog_Kueche_TC_Weather,FileLog_Kueche_TC_WindowRec,FileLog_Kueche_TK_Tuer,FileLog_LM_Steckdose_01,FileLog_LM_Steckdose_02,FileLog_SchaltSteckdosePM01,FileLog_SchaltSteckdosePM01_Pwr,FileLog_Schlafzimmer_FH_Fenster,FileLog_Schlafzimmer_FH_Tuer,FileLog_Schlafzimmer_TC,FileLog_Schlafzimmer_TC_Climate,FileLog_Schlafzimmer_TC_Weather,FileLog_Schlafzimmer_TC_WindowRec,FileLog_Schlafzimmer_TK_Tuer,FileLog_Temperatur_FH,FileLog_Temperatur_FH_DiffRLVL,FileLog_Temperatur_FH_DiffVLRL,FileLog_Temperatur_FH_Event,FileLog_Temperatur_FH_Ruecklauf,FileLog_Temperatur_FH_Vorlauf,FileLog_Temperatur_WarmWasser,FileLog_Vanessa_FH_Fenster,FileLog_Vanessa_FH_Tuer,FileLog_Vanessa_HK,FileLog_Vanessa_HK_ClimRT_tr,FileLog_Vanessa_HK_ClimaTeam,FileLog_Vanessa_HK_Climate,FileLog_Vanessa_HK_Weather,FileLog_Vanessa_HK_WindowRec,FileLog_Vanessa_HK_remote,FileLog_Vanessa_TC,FileLog_Vanessa_TC_Climate,FileLog_Vanessa_TC_Weather,FileLog_Vanessa_TC_WindowRec,FileLog_Vanessa_TK_Tuer,FileLog_VerbrauchGas_Zaehler_Gesamt,FileLog_VerbrauchStrom_Zaehler_Gesamt,FileLog_Windfang_FH,FileLog_Wohnzimmer_FH_Ost,FileLog_Wohnzimmer_FH_Sued,FileLog_Wohnzimmer_FH_West,FileLog_Wohnzimmer_HK,FileLog_Wohnzimmer_HK_ClimRT_tr,FileLog_Wohnzimmer_HK_ClimaTeam,FileLog_Wohnzimmer_HK_Climate,FileLog_Wohnzimmer_HK_Weather,FileLog_Wohnzimmer_HK_WindowRec,FileLog_Wohnzimmer_HK_remote,FileLog_Wohnzimmer_RL_Teich,FileLog_Wohnzimmer_RL_Terasse,FileLog_Wohnzimmer_TC,FileLog_Wohnzimmer_TC_Climate,FileLog_Wohnzimmer_TC_Weather,FileLog_Wohnzimmer_TC_WindowRec,FileLog_Wohnzimmer_TK_Tuer,FileLog_Zirkulationspumpe_FH,FileLog_Zirkulationspumpe_HK,Logfile addRegexpPart removeRegexpPart reopen
Ich suche jetzt schon eine geraume Zeit nach der Lösung, aber ich habe nicht den Funken eines Ansatzes.
Vermutlich ist die Ursache so trivial, dass ich es nicht sehe.
Danke und ciao
walter
FHEM 5.7 & TabletUI 2.2 auf Fedora22 Server auf NUC5i5RYK
CUL 868 > FAST EnergyCam
HMLAN > HomeMatic TCs & VDs, Bewegungsmelder, Schalter, Taster, Steckdosen
marvin78
Nun. Welches Ergebnis liefert es denn? Und wie heißen deine Geräte vollständig?
wkarl
sorry, Vorschau mit Schreiben verwechselt. Deswegen unvollständig.  :o
wkarl
Hallo Marvin,
bei den TCs steht vorne das Zimmer - z.B. Kueche_TC_Climate.
ciao walter
Man sollte eine regexp niemals mit .* anfangen.
wkarl
Danke, habe es jetzt über structure gelöst.
ciao walter
UliM
.* ist 'greedy', also gierig - es matcht so viel wie geht - und das ist einfach 'alles'.
Non-greedy geht mit .*? , siehe zB
http://www.itworld.com/nl/perl/01112001
Gruß, Uli
