Autor Thema: Panel state (open/close) for the Thermostat and WallThermostat  (Gelesen 3121 mal)
Offline marcinn
  • New Member
Hi
Is there possibility to add this patch to code for fhem?
The main goal is to show if the heating thermostat is locked for manually setting the temperature at the device.
I use it to publish this state to mqtt and present it on GUI.
Patch is very short, because this state is already supported in 10_MAX.pm
There is only one line to be added in two places.
Thanks,
Marcin
Offline rudolfkoenig
  • Administrator
Antw:Panel state (open/close) for the Thermostat and WallThermostat
« Antwort #1 am: 11 Oktober 2019, 14:44:04 »
Sorry for the delay, I successfully tried to forget, that I am the temporary maintainer of this orphaned module.
As Wzut suggested here, I changed the word open to unlocked, and committed the changes.
Offline marcinn
  • New Member
« Antwort #2 am: 31 Oktober 2019, 14:13:03 »
Hi
Thanks a lot.
I've prepared another patch. I've updated the status of RF communication between units and cube
#communication with link partner - if device is not accessible over the air from the cube
BR,
Marcin
  • Administrator
« Antwort #3 am: 31 Oktober 2019, 16:29:04 »
I've commited the patch, but I had to apply it manually, as patch itself rejected it.Can you please check, if I've done it correctly?
Offline marcinn
  • New Member
« Antwort #4 am: 04 November 2019, 16:01:29 »
Hi
I've checked it on rev 20455 and it doesn't look right.
I'll prepare a new patch .
Thanks,
marcin
Offline marcinn
  • New Member
« Antwort #5 am: 05 November 2019, 09:19:57 »
Hi
I've checked again the release 20458. Everything is OK
Thanks a lot,
Marcin
Offline zweiundzwanzig
  • Full Member
« Antwort #6 am: 04 Dezember 2019, 18:01:56 »
Nice! Thank you!
2x MAX CuBe mit a-culf im Moritzbetrieb
1x MAX CuBe mit a-culf im Homematicbetrieb
60x MAX Heizkörperthermostat plus | 2x HM Schaltaktoren | 1x MAX Wandthermostat
1x FHEM Ubuntu Server auf VMWare
24 Räume, die durch ical Kalender geheizt werden
