Autor Thema: Probleme mit telegram  (Gelesen 319 mal)
Offline dt2510
  • Sr. Member
« am: 17 November 2019, 11:17:46 »
Ich habe am Freitag ein telegram Device eingerichtet um Snapshots meiner Kamera zu versenden. Mein Problem ist allerdings, daß FHEM nach dem Versand nicht mehr funktioniert. Hier mal ein Log Auszug von gestern Abend:
2019.11.16 23:56:34 3: D200 - Snapshot of Camera Eingang created. ID: 16
2019.11.16 23:56:35 3: D200 - Telegram message transaction "2202" successfully sent to "xxxxxxxxx" by "Telegram"
2019.11.16 23:56:35 1: PERL WARNING: Use of uninitialized value $ret in numeric le (<=) at FHEM/HttpUtils.pm line 646.
2019.11.16 23:56:35 3: D200 - Snapshot of Camera Eingang created. ID: 17
2019.11.16 23:56:35 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2218.
2019.11.16 23:56:35 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2227.
2019.11.16 23:56:35 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2183.
2019.11.16 23:56:35 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2175.
2019.11.16 23:56:35 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2169.
2019.11.16 23:56:35 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2242.
2019.11.16 23:56:35 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2359.
2019.11.16 23:56:35 1: ERROR: empty name in readingsBeginUpdate
2019.11.16 23:56:35 1: stacktrace:
2019.11.16 23:56:35 1:     main::readingsBeginUpdate           called by ./FHEM/50_TelegramBot.pm (2397)
2019.11.16 23:56:35 1:     main::TelegramBot_Callback          called by FHEM/HttpUtils.pm (634)
2019.11.16 23:56:35 1:     main::__ANON__                      called by fhem.pl (751)
2019.11.16 23:56:35 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at fhem.pl line 4772.
2019.11.16 23:56:35 1: readingsUpdate(,sentMsgResult,SUCCESS) missed to call readingsBeginUpdate first.
2019.11.16 23:56:35 1:     main::readingsBulkUpdate            called by ./FHEM/50_TelegramBot.pm (2398)
2019.11.16 23:56:35 1: readingsUpdate(,sentMsgId,17) missed to call readingsBeginUpdate first.
2019.11.16 23:56:35 1:     main::readingsBulkUpdate            called by ./FHEM/50_TelegramBot.pm (2399)
2019.11.16 23:56:35 1: readingsUpdate(,sentMsgPeerId,) missed to call readingsBeginUpdate first.
2019.11.16 23:56:35 1:     main::readingsBulkUpdate            called by ./FHEM/50_TelegramBot.pm (2400)
2019.11.16 23:56:35 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4525.
2019.11.16 23:56:35 1: PERL WARNING: Use of uninitialized value $dev in hash element at fhem.pl line 3626.
Can't use an undefined value as an ARRAY reference at ./FHEM/50_TelegramBot.pm line 2403.
2019.11.16 23:56:35 1: SONOS0: Last Listener seems to be died and process started by fhem... stopping Threads and process...
2019.11.16 23:56:35 3: SONOS0: Disconnecting client and shutdown server...
2019.11.16 23:56:35 3: SONOS0: Trying to kill Sonos_Thread...
2019.11.16 23:56:35 3: SONOS0: Trying to kill LongJobs_Thread...
2019.11.16 23:56:35 3: SONOS0: Trying to kill IsAlive_Thread...
2019.11.16 23:56:35 3: SONOS0: Trying to kill PlayerRestore_Thread...
2019.11.16 23:56:35 0: SONOS0: Das Lauschen auf der Schnittstelle wurde beendet. Prozess endet nun auch...
Danach ging nichts mehr bis zum Neustart
Hier noch ein List des Devices
   FAILS      0
   FUUID      xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxxxxxx
   NAME       Telegram
   NR         395
   POLLING    0
   SNAME      Telegram
   STATE      Static
   TYPE       TelegramBot
   UPDATER    0
   WAIT       0
   me         xxxxxxxxxx:FHEM:@xxxxxxxxbot
   Contacts:
     xxxxxxxxx  xxxxxxxxx:xxxxxx_xxxxx:
   HU_DO_PARAMS:
     header     agent: TelegramBot/1.0
User-Agent: TelegramBot/1.0
Accept: application/json
Accept-Charset: utf-8
     hideurl    1
     method     GET
     timeout    30
     url
   HU_UPD_PARAMS:
     hideurl    1
     isPolling  update
     method     GET
     timeout    5
     url
     2019-11-15 11:48:11   Contacts        xxxxxxxxx:xxxxxx_xxxxx:
     2019-11-15 11:48:12   PollingErrCount 0
     2019-11-15 11:48:12   msgChat         xxxxxx_xxxxx
     2019-11-15 11:48:12   msgChatId       xxxxxxxxx
     2019-11-15 11:48:12   msgFileId
     2019-11-15 11:48:12   msgId           2
     2019-11-15 11:48:12   msgPeer         xxxxxx_xxxxx
     2019-11-15 11:48:12   msgPeerId       xxxxxxxxxx
     2019-11-15 11:48:12   msgReplyMsgId
     2019-11-15 11:48:12   msgText         /start
     2019-11-15 11:48:12   prevMsgChat     xxxxxx_xxxxx
     2019-11-15 11:48:12   prevMsgFileId
     2019-11-15 11:48:12   prevMsgId       1
     2019-11-15 11:48:12   prevMsgPeer     xxxxxx_xxxxx
     2019-11-15 11:48:12   prevMsgPeerId   xxxxxxxxx
     2019-11-15 11:48:12   prevMsgReplyMsgId
     2019-11-15 11:48:12   prevMsgText     /start
     2019-11-16 10:10:31   sentMsgId       14
     2019-11-16 10:10:31   sentMsgPeerId   xxxxxxxxx
     2019-11-16 10:10:31   sentMsgResult   SUCCESS
   inlinechats:
   defaultPeer xxxxxxxxx
   room       System
« Letzte Änderung: 18 November 2019, 09:29:06 von dt2510 »
