Rolladensteuerung über Alexa
Begonnen von juemuc, 26 Januar 2020, 20:38:28
juemuc
gerne  :)
   CFGFN
   FUUID      5e30a973-f33f-ca7c-1d73-f3a53e036132ad07
   NAME       TestRollo
   NR         16223
   STATE      pct-10
   TYPE       ROLLO
   stoptime   1580248103
   OLDREADINGS:
     2020-01-28 22:48:22   command         pct-10
     2020-01-28 22:48:22   desired_pct     10
     2020-01-28 22:48:22   drive-type      modul
     2020-01-28 22:48:22   last_drive      drive-up
     2020-01-28 22:48:23   pct             10
     2020-01-28 22:48:23   state           pct-10
   alexaName  TestRollo
   cmdIcon    open:fts_shutter_up closed:fts_shutter_down stop:fts_shutter_manual half:fts_shutter_50
   devStateIcon open:fts_shutter_10:closed closed:fts_shutter_100:open half:fts_shutter_50:closed drive-up:fts_shutter_up@red:stop drive-down:fts_shutter_down@red:stop pct-100:fts_shutter_100:open pct-90:fts_shutter_80:closed pct-80:fts_shutter_80:closed pct-70:fts_shutter_70:closed pct-60:fts_shutter_60:closed pct-50:fts_shutter_50:closed pct-40:fts_shutter_40:open pct-30:fts_shutter_30:open pct-20:fts_shutter_20:open pct-10:fts_shutter_10:open pct-0:fts_shutter_10:closed
   genericDeviceType blind
   rl_autoStop 0
   rl_excessBottom 1
   rl_excessTop 1
   rl_secondsDown 1
   rl_secondsUp 1
   rl_switchTime 1
   rl_type    normal
   room       Büro
   webCmd     open:closed:half:stop:pct
Jürgen
amenomade
OK pct reading ist da.
Kannst du jetzt bitte in der Log gucken, wie das Device von alexa erkannt wird?
juemuc
#17
Meinst Du dies?
ZitatRollo_Test, r: büro","friendlyName":"rollo test","displayCategories":["EXTERIOR_BLIND"],"additionalAttributes":{"manufacturer":"FHEM","model":"<unknown>"},"capabilities":[{"type":"AlexaInterface","interface":"Alexa.RangeController","instance":"Blind.Position","version":"3","properties":{"supported":[{"name":"rangeValue"}],"proactivelyReported":false,"retrievable":true},"capabilityResources":{"friendlyNames":[{"@type":"asset","value":{"assetId":"Alexa.Setting.Opening"}}]},"configuration":{"supportedRange":{"minimumValue":0,"maximumValue":100,"precision":1},"unitOfMeasure":"Alexa.Unit.Percent"}}],"cookie":{"device":"Rollo_Test","fuuid":"5e2ddf9b-f33f-ca7c-2f33-361c6fe1aa70679a"}},{"endpointId":"5c50c7bb-f33f-ca7c-07b2-490c89fa789dcc59","manufacturerName":"dummy","description":"n:
So wird auch mein Dummy erkannt.
Jürgen
amenomade
Ne, was vorher kommt, wie :
[12/19/2019, 12:17:33 AM] [FHEM] wz_Rolladen is blind
[12/19/2019, 12:17:33 AM] [FHEM] wz_Rolladen has
[12/19/2019, 12:17:33 AM] [FHEM]   CurrentPosition [pct]
[12/19/2019, 12:17:33 AM] [FHEM]   TargetPosition [pct]
juemuc
Ja das steht auch bei mir  :D
Zitat[2020-1-28 22:39:12] [FHEM] Rollo_Buero is blind
[2020-1-28 22:39:12] [FHEM] Rollo_Buero has
[2020-1-28 22:39:12] [FHEM]   CurrentPosition [pct]
[2020-1-28 22:39:12] [FHEM]   TargetPosition [pct]
[2020-1-28 22:39:12] [FHEM] Rollo_Test is blind
[2020-1-28 22:39:12] [FHEM] Rollo_Test has
[2020-1-28 22:39:12] [FHEM] Rollos_Ost is blind
[2020-1-28 22:39:12] [FHEM] Rollos_Ost has
[2020-1-28 22:39:12] [FHEM] Rollos_West is blind
[2020-1-28 22:39:12] [FHEM] Rollos_West has
Jürgen
juemuc
ich habe nun weiter gestestet und auch ein homebridgemapping eingebaut. Leider weiterhin kein Erfolg. Über den Schieberegler in der Alexa-App wird an FHEM übergeben. Das Device zeigt aber weiterhin an, das es ein Problem gibt und erkennt auch keine Änderungen in FHEM. Hier mein aktuelles List
ZitatInternals:
   CFGFN
   FUUID      5e3341b3-f33f-ca7c-be12-22739d05e26c253b
   NAME       Rollo_Test
   NR         809
   STATE      pct 50
   TYPE       dummy
     2020-01-30 22:59:18   state           pct 50
   alexaName  Rollo Test
   alias      Rollo Test
   devStateIcon pct.0:fts_roof_window_shutter_0 pct.25:fts_roof_window_shutter_02 pct.50:fts_roof_window_shutter_05 pct.75:fts_roof_window_shutter_07 pct.100:fts_roof_window_shutter_10 pct.*:unknown
   event-on-change-reading .*
   homebridgeMapping CurrentPosition=pct,minValue=0,maxValue=100,minStep=1 TargetPosition=pct::CurrentPosition,minValue=0,maxValue=100,minStep=25
   icon       it_remote@black
   readingList state
   room       Büro
   setList    state:pct#0,pct#25,pct#50,pct#75,pct#100,STOP
   sortby     01
   webCmd     state
Jürgen
amenomade
Aber dein Device hat jetzt kein Reading pct mehr. Wie soll das funktionieren?
juemuc
Auch das bringt leider keinen Erfolg. Was nun?
   NAME       Rollo_Test
   NR         337
   STATE      pct 75
   TYPE       dummy
     2020-01-31 22:24:33   pct             75
     2020-01-31 22:24:33   state           pct 75
   alias      Rollo Test
   readingList state
   room       Büro
   sortby     01
   userReadings pct {ReadingsNum($name,"state","")}
   webCmd     state
Jürgen
amenomade
Du solltest vielleicht die Doku über homeBridgeMapping wieder lesen.
So kann es nicht gehen.
ZitatTargetPosition=pct::CurrentPosition
Command = pct, aber pct ist nicht in der setList
::CurrentPosition = Reading CurrentPositiongibt es nicht
ZitatCurrentPosition=pct,minValue=0,maxValue=100,minStep=1
CurrentPosition=pct => ok, aber was soll dann minValue maxValue und minStep für die CurrentPosition bedeuten?
juemuc
ich glaube nun die Ursache gefunden zu haben.
Es ligt am genericDeviceType. Wenn ich diesen nicht definiere, wird der Dummy als Lampe erkannt und ich kann per Sprachbefehl die Prozentzahl übergeben. Wenn ich allerdings genericDeviceType "blind" definiere, funktioniert zwar die Kommunikation mit Alexa über die App per Schieberegler aber nicht per Sprache. Hier kommt immer die Info "Alexa unterstützt das nicht". Ein homebridgemapping ist also nicht notwendig.
Hier meine aktuelles List.
   NAME       Rollo_Test
   NR         337
   STATE      pct 0
   TYPE       dummy
     2020-02-01 17:11:27   pct             0
     2020-02-01 17:11:27   state           pct 0
   alias      Rollo Test
   readingList state
   room       Büro
   setList    pct:0,25,50,75,100,STOP
   sortby     01
   webCmd     pct
Ich hoffe, dieses Poblem kann nun jemand nachvollziehenund bestätigen.
Jürgen
amenomade
Du hast aber vor allem setList auf pct gesetzt...
juemuc
amenomade
juemuc
Hallo amenomade,
aus meiner Sicht sind alle Punkte erfüllt. setList ist gesetzt und nun alles mit "position" definiert. Hier das defmod bzw. das list:
defmod Rollo_Test dummy
attr Rollo_Test alexaName Rollo Test
attr Rollo_Test alias Rollo Test
attr Rollo_Test event-on-change-reading .*
attr Rollo_Test genericDeviceType blind
attr Rollo_Test icon it_remote@black
attr Rollo_Test readingList position
attr Rollo_Test room Büro
attr Rollo_Test setList position
attr Rollo_Test stateFormat position
attr Rollo_Test userReadings position
   NAME       Rollo_Test
   NR         337
   STATE      14
   STILLDONETIME 0
   TYPE       dummy
   OLDREADINGS:
     2020-02-02 22:02:10   position        14
   alias      Rollo Test
   room       Büro
   setList    position
Laut hombridgeMapping-Doku sollte kein Mapping notwendig sein. Es funktioniert weiterhin nur über den Schieberegler aber nicht per Sprachbefehl. (auch ein Test mit hombrideMapping war erfolglos). Es kommt weiterhin die Ansage "Rollo_Test unterstützt das nicht".
Alexa habe ich immer dazwischen "reloaded". In der App habe ich das Gerät gelöscht und neu suchen lassen. Was mache ich noch falsch? Ich sege es leider nicht und bitte um Hilfe. Das ganze mit "pct" funktioniert bei mir auch nicht.
Jürgen
PS.: Ich war nur in den anderen Thread gewechselt, da ich die Hoffnung hatte, dass es mit dem Alexa-Modul zusammenhängt.
amenomade
#29
Deine Definition ist jetzt OK (das attr userReadings ist allerdings überflüssig, aber das stört nicht).
Ich habe sie 1 zu 1 inkl userReadings übernommen, ein "set alexa reload" gemacht, und schon funktioniert es
Ich habe "PossibleSets":"position" in jsonlist2, und tatsächlich ist kein homeBridgeMapping nötig
Alexa, setze Rollo Test auf 10 prozent => geht
Alexa, Rollo Test auf 40 prozent => geht
Zeig mal die Log wenn Du das "set alexa reload" machst, und bei  "Alexa, setze Rollo Test auf 20 prozen" (tokens anonymisieren), und guck in der Historie von der alexa App, was für ein Befehl erkannt wurde,
Im alexa Device, hast Du diese 2 Readings?
     2020-01-28 02:32:56   alexaFHEM       running /usr/bin/alexa-fhem
     2020-02-02 03:04:41   alexaFHEM.ProxyConnection running; SSH connected
