[Gelöst]FHEM-Connector für Amazon Alexa-Fehlermeldung im Sekundentakt
Begonnen von TL60, 09 März 2020, 14:58:35
TL60
ich habe seid Anfang März (genaueres Datum kann ich nicht sagen, aufgefallen ist es mir am 3 März)folgende Meldungen im Alexa Logfile
[2020-3-3 00:00:00] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:01] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:03] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:04] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:08] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:12] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:14] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:20] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:33] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:37] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:45] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:47] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:48] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:49] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:53] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:57] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:58] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:00:59] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-3 00:01:00] [FHEM]   error processing event data: TypeError: Cannot read property 'Name' of undefined
Das ist nur ein Ausschnitt der sich so bis 23:59 fortsetzt.
Ich habe, bestimmt schon vor 1 Jahr meine lokale FHEM-Connector Instanz um 2 FHEM Installationen erweitert, so das meine alexa-fhem.cfg so aussieht: {
   "sshproxy" : {
      "description" : "FHEM Connector",
      "ssh" : "/usr/bin/ssh"
   "connections" : [
         "name" : "FHEM1",
         "webname" : "fhem",
         "filter" : "alexaName=..*",
         "uid" : 999,
         "port" : "8086",
         "server" : "127.0.0.1"
         "name" : "FHEM2",
         "webname" : "fhem",
         "uid" : 999,
         "port" : "8083",
         "server" : "192.168.178.138"
         "name" : "FHEM3",
         "webname" : "fhem",
         "uid" : 999,
         "port" : "8083",
         "server" : "192.168.178.137"
das hat so auch funktioniert.
Ich habe alle im Wiki angesprochenen Troubleshooting Punkte probiert, keiner hat mich weitergebracht. Das einzige was hilft, ist die beiden entfernten FHEM Instanzen aus der alexa-fhem.cfg zu löschen, so das die alexa-fhem.cfg dann so aussieht: {
   "sshproxy" : {
   "connections" : [
         "name" : "FHEM",
         "webname" : "fhem",
         "uid" : 999,
         "port" : "8086",
heute habe ich dann erst den FHEM-Connector normal (mit1 Instanz) laufen lassen und dann mit der allen 3 Instanzen, so sieht dann das Logfile aus:[2020-3-9 12:49:55] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.Discovery","name":"Discover","payloadVersion":"3","messageId":"9249d995-9948-4483-828e-0a0cbcfc7318"},"payload":{"scope":{"type":"BearerToken","token":"D4200EBC-71D03E94187B7E90"}}}}
[2020-3-9 12:49:55] found 2 device(s)
[2020-3-9 12:49:55] <<<< [ssh] {"event":{"header":{"namespace":"Alexa.Discovery","name":"Discover.Response","payloadVersion":"3","messageId":"5771dbf9-8c56-43de-bb13-83a8e881fbf9"},"payload":{"endpoints":[{"endpointId":"5c5d9897-f33f-567d-e178-70b54974986ad0af","manufacturerName":"MQTT2_DEVICE","description":"n: SonoffBasic1, r: homekitdeb,alexa,googleassistant,mqtt2_device,uebersicht","friendlyName":"deckenstrahler","displayCategories":["SWITCH"],"additionalAttributes":{"manufacturer":"FHEM","model":"<unknown>"},"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"cookie":{"device":"SonoffBasic1","fuuid":"5c5d9897-f33f-567d-e178-70b54974986ad0af"}},{"endpointId":"5c5d9897-f33f-567d-60a3-d1fe4f929e6d6fbc","manufacturerName":"MQTT2_DEVICE","description":"n: SonoffBasic2, r: alexa,homekit,mqtt2_device,uebersicht","friendlyName":"wandlampe","displayCategories":["SMARTPLUG"],"additionalAttributes":{"manufacturer":"FHEM","model":"<unknown>"},"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"cookie":{"device":"SonoffBasic2","fuuid":"5c5d9897-f33f-567d-60a3-d1fe4f929e6d6fbc"}}]}}}
[2020-3-9 14:14:28] Got SIGTERM, shutting down alexa-fhem...
[2020-3-9 14:14:28] Reading alexaFHEM.ProxyConnection set to stopping;; alexa-fhem terminating
[2020-3-9 14:14:28] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20stopping%3B%3B%20alexa-fhem%20terminating%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:14:28] Stopping SSH ...
[2020-3-9 14:14:28] Reading alexaFHEM.ProxyConnection set to stopped
[2020-3-9 14:14:28] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20stopped%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:14:28] *** SSH: exited with 143
[2020-3-9 14:15:56] using config from ./alexa-fhem.cfg
*** CONFIG: parsed completely
[2020-3-9 14:15:56] os.homedir()=/opt/fhem
[2020-3-9 14:15:56] this is alexa-fhem 0.5.49
[2020-3-9 14:15:56] connecting to FHEM ...
[2020-3-9 14:15:56] [FHEM1] defaults to: will not send proactive events
[2020-3-9 14:15:58] [FHEM1] trying longpoll to listen for fhem events
[2020-3-9 14:15:58] [FHEM1] starting longpoll: http://127.0.0.1:8086/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1583759758420
[2020-3-9 14:15:58] [FHEM2] defaults to: will not send proactive events
[2020-3-9 14:15:58] [FHEM2] trying longpoll to listen for fhem events
[2020-3-9 14:15:58] [FHEM2] starting longpoll: http://192.168.178.138:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1583759758472
[2020-3-9 14:15:58] [FHEM3] defaults to: will not send proactive events
[2020-3-9 14:15:58] [FHEM3] trying longpoll to listen for fhem events
[2020-3-9 14:15:58] [FHEM3] starting longpoll: http://192.168.178.137:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1583759758486
[2020-3-9 14:15:58] [FHEM2] got csrfToken: csrf_553464341656572
[2020-3-9 14:15:58] [FHEM2] Checking devices and attributes...
[2020-3-9 14:15:58] [FHEM2]   executing: http://192.168.178.138:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_553464341656572&XHR=1
[2020-3-9 14:15:58] [FHEM2]   executing: http://192.168.178.138:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_553464341656572&XHR=1
[2020-3-9 14:15:58] [FHEM2] waiting for events ...
[2020-3-9 14:15:58] [FHEM2] Fetching FHEM devices...
[2020-3-9 14:15:58] [FHEM2] fetching: http://192.168.178.138:8083/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=csrf_553464341656572&XHR=1
[2020-3-9 14:15:58] [FHEM1] got csrfToken: csrf_290357560160907
[2020-3-9 14:15:58] [FHEM1] Checking devices and attributes...
[2020-3-9 14:15:58] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:15:58] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:15:58] [FHEM1] waiting for events ...
[2020-3-9 14:15:58] [FHEM1] Fetching FHEM devices...
[2020-3-9 14:15:58] [FHEM1] fetching: http://127.0.0.1:8086/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:15:58] [FHEM3] got csrfToken: csrf_358407218513667
[2020-3-9 14:15:58] [FHEM3] Checking devices and attributes...
[2020-3-9 14:15:58] [FHEM3]   executing: http://192.168.178.137:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_358407218513667&XHR=1
[2020-3-9 14:15:58] [FHEM3]   executing: http://192.168.178.137:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_358407218513667&XHR=1
[2020-3-9 14:15:58] [FHEM3] waiting for events ...
[2020-3-9 14:15:58] [FHEM3] Fetching FHEM devices...
[2020-3-9 14:15:58] [FHEM3] fetching: http://192.168.178.137:8083/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=csrf_358407218513667&XHR=1
[2020-3-9 14:15:58] No Alexa device defined - this will not work with sshproxy mode
[2020-3-9 14:15:58] [FHEM2] TypeError: Cannot read property 'Name' of undefined
    at Server.<anonymous> (/usr/lib/node_modules/alexa-fhem/lib/server.js:948:50)
    at emitNone (events.js:106:13)
    at FHEM.emit (events.js:208:7)
    at FHEM.<anonymous> (/usr/lib/node_modules/alexa-fhem/lib/fhem.js:1367:28)
    at Request._callback (/usr/lib/node_modules/alexa-fhem/lib/fhem.js:1606:27)
    at Request.self.callback (/usr/lib/node_modules/alexa-fhem/node_modules/postman-request/request.js:268:12)
    at emitTwo (events.js:126:13)
    at Request.emit (events.js:214:7)
    at Request.<anonymous> (/usr/lib/node_modules/alexa-fhem/node_modules/postman-request/request.js:1464:10)
    at emitOne (events.js:116:13)
    at Request.emit (events.js:211:7)
    at Gunzip.<anonymous> (/usr/lib/node_modules/alexa-fhem/node_modules/postman-request/request.js:1335:12)
    at Object.onceWrapper (events.js:313:30)
    at emitNone (events.js:111:20)
    at Gunzip.emit (events.js:208:7)
    at endReadableNT (_stream_readable.js:1064:12)
[2020-3-9 14:15:58] [FHEM2] failed to parse {  "Arg":"TYPE=alexa",  "Results": [  ],  "totalResultsReturned":0}
*** FHEM: connected
[2020-3-9 14:15:58] [FHEM2] got: 1 results
[2020-3-9 14:15:59] [FHEM2] Staubsauger_dummy is switch
[2020-3-9 14:15:59] [FHEM2] Staubsauger_dummy has
[2020-3-9 14:15:59] [FHEM2]   On [state;on,off]
[2020-3-9 14:15:59] [FHEM2] Staubsauger_dummy will not send proactive events
[2020-3-9 14:15:59] [FHEM2] Staubsauger_dummy uses ID: 5e64f949-f33f-952a-d6ba-f2cdc4e10286236f
  2020-03-09 14:15:59 caching: Staubsauger_dummy-state: off
[2020-3-9 14:15:59] No Alexa device defined - this will not work with sshproxy mode
[2020-3-9 14:15:59] [FHEM3] TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:15:59] [FHEM3] failed to parse {  "Arg":"TYPE=alexa",  "Results": [  ],  "totalResultsReturned":0}
*** FHEM: connected
[2020-3-9 14:15:59] [FHEM3] got: 1 results
[2020-3-9 14:15:59] [FHEM3] Gefrierschrank_dummy is switch
[2020-3-9 14:15:59] [FHEM3] Gefrierschrank_dummy has
[2020-3-9 14:15:59] [FHEM3]   On [state;on,off]
[2020-3-9 14:15:59] [FHEM3] Gefrierschrank_dummy will not send proactive events
[2020-3-9 14:15:59] [FHEM3] Gefrierschrank_dummy uses ID: 5e664053-f33f-aada-cece-3e98c9f4173c4a70
  2020-03-09 14:15:59 caching: Gefrierschrank_dummy-state: off
[2020-3-9 14:15:59] [FHEM1] alexa device is alexa
[2020-3-9 14:15:59] [FHEM1] alexa will not send proactive events
[2020-3-9 14:15:59] [FHEM1] alexa uses ID: 5c5eef7e-f33f-567d-b321-548f9b4589be61b3
[2020-3-9 14:15:59] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.49%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:15:59] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:15:59] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:15:59] Server listening on: http://127.0.0.1:45937 for proxy connections
[2020-3-9 14:15:59] *** SSH: checking proxy configuration
[2020-3-9 14:15:59] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[2020-3-9 14:15:59] Passed config: {"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":45937},"connections":[{"name":"FHEM1","webname":"fhem","filter":"alexaName=..*","uid":999,"port":"8086","server":"127.0.0.1"},{"name":"FHEM2","webname":"fhem","filter":"alexaName=..*","uid":999,"port":"8083","server":"192.168.178.138"},{"name":"FHEM3","webname":"fhem","filter":"alexaName=..*","uid":999,"port":"8083","server":"192.168.178.137"}]}
[2020-3-9 14:15:59] sshautoconf: SSH key seems to exist
[2020-3-9 14:15:59] sshautoconf: Our SSH key is known at the reverse proxy, good!
[2020-3-9 14:15:59] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
*** FHEM: connected
[2020-3-9 14:15:59] [FHEM1] got: 2 results
[2020-3-9 14:15:59] [FHEM1] SonoffBasic1 is switch
[2020-3-9 14:15:59] [FHEM1] SonoffBasic1 has
[2020-3-9 14:15:59] [FHEM1]   On [state;on,off]
[2020-3-9 14:15:59] [FHEM1] SonoffBasic1 will not send proactive events
[2020-3-9 14:15:59] [FHEM1] SonoffBasic1 uses ID: 5c5d9897-f33f-567d-e178-70b54974986ad0af
  2020-03-09 14:15:59 caching: SonoffBasic1-state: off
[2020-3-9 14:15:59] [FHEM1] SonoffBasic2 is outlet
[2020-3-9 14:15:59] [FHEM1] SonoffBasic2 has
[2020-3-9 14:15:59] [FHEM1] SonoffBasic2 will not send proactive events
[2020-3-9 14:15:59] [FHEM1] SonoffBasic2 uses ID: 5c5d9897-f33f-567d-60a3-d1fe4f929e6d6fbc
  2020-03-09 14:15:59 caching: SonoffBasic2-state: on
[2020-3-9 14:15:59] BearerToken '...B7E90' read from alexa
[2020-3-9 14:15:59] [FHEM1] got .eventToken
[2020-3-9 14:15:59] refreshing token
[2020-3-9 14:15:59] 39_alexa.pm is new version: true
[2020-3-9 14:15:59] sshautoconf: completed successfully
[2020-3-9 14:15:59] *** SSH: proxy configuration set up done
[2020-3-9 14:15:59] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2020-3-9 14:15:59] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:15:59] Starting SSH with -R 1234:127.0.0.1:45937 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2020-3-9 14:16:00] failed to refresh token: invalid_grant: 'The request has an invalid grant parameter : refresh_token'
[2020-3-9 14:16:00] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:00] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:00] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2020-3-9 14:16:00] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:16:00] *** SSH: proxy connection established
[2020-3-9 14:16:00] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
[2020-3-9 14:16:01] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:02] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:04] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:08] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:12] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:13] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:18] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:19] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:22] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:23] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:24] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:25] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:25] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:26] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:29] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:30] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:31] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:33] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:34] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:35] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:35] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:36] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:36] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:37] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:37] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:38] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:39] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:40] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:40] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:41] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:16:44] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:17:01] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:17:02] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:17:09] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-9 14:17:12] Got SIGTERM, shutting down alexa-fhem...
[2020-3-9 14:17:12] Reading alexaFHEM.ProxyConnection set to stopping;; alexa-fhem terminating
[2020-3-9 14:17:12] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20stopping%3B%3B%20alexa-fhem%20terminating%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:17:12] Stopping SSH ...
[2020-3-9 14:17:12] Reading alexaFHEM.ProxyConnection set to stopped
[2020-3-9 14:17:12] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20stopped%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:17:12] *** SSH: exited with 143
[2020-3-9 14:20:08] using config from ./alexa-fhem.cfg
[2020-3-9 14:20:08] os.homedir()=/opt/fhem
[2020-3-9 14:20:08] this is alexa-fhem 0.5.49
[2020-3-9 14:20:08] connecting to FHEM ...
[2020-3-9 14:20:08] [FHEM] defaults to: will not send proactive events
[2020-3-9 14:20:10] [FHEM] trying longpoll to listen for fhem events
[2020-3-9 14:20:10] [FHEM] starting longpoll: http://127.0.0.1:8086/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1583760010739
[2020-3-9 14:20:10] [FHEM] got csrfToken: csrf_290357560160907
[2020-3-9 14:20:10] [FHEM] Checking devices and attributes...
[2020-3-9 14:20:10] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:20:10] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:20:10] [FHEM] waiting for events ...
[2020-3-9 14:20:10] [FHEM] Fetching FHEM devices...
[2020-3-9 14:20:10] [FHEM] fetching: http://127.0.0.1:8086/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:20:11] [FHEM] alexa device is alexa
[2020-3-9 14:20:11] [FHEM] alexa will not send proactive events
[2020-3-9 14:20:11] [FHEM] alexa uses ID: 5c5eef7e-f33f-567d-b321-548f9b4589be61b3
[2020-3-9 14:20:11] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.49%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:20:11] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:20:11] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:20:11] Server listening on: http://127.0.0.1:36259 for proxy connections
[2020-3-9 14:20:11] *** SSH: checking proxy configuration
[2020-3-9 14:20:11] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[2020-3-9 14:20:11] Passed config: {"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":36259},"connections":[{"name":"FHEM","webname":"fhem","filter":"alexaName=..*","uid":999,"port":"8086","server":"127.0.0.1"}]}
[2020-3-9 14:20:11] sshautoconf: SSH key seems to exist
[2020-3-9 14:20:11] sshautoconf: Our SSH key is known at the reverse proxy, good!
[2020-3-9 14:20:11] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
*** FHEM: connected
[2020-3-9 14:20:11] [FHEM] got: 2 results
[2020-3-9 14:20:11] [FHEM] SonoffBasic1 is switch
[2020-3-9 14:20:11] [FHEM] SonoffBasic1 has
[2020-3-9 14:20:11] [FHEM]   On [state;on,off]
[2020-3-9 14:20:11] [FHEM] SonoffBasic1 will not send proactive events
[2020-3-9 14:20:11] [FHEM] SonoffBasic1 uses ID: 5c5d9897-f33f-567d-e178-70b54974986ad0af
  2020-03-09 14:20:11 caching: SonoffBasic1-state: off
[2020-3-9 14:20:11] [FHEM] SonoffBasic2 is outlet
[2020-3-9 14:20:11] [FHEM] SonoffBasic2 has
[2020-3-9 14:20:11] [FHEM] SonoffBasic2 will not send proactive events
[2020-3-9 14:20:11] [FHEM] SonoffBasic2 uses ID: 5c5d9897-f33f-567d-60a3-d1fe4f929e6d6fbc
  2020-03-09 14:20:11 caching: SonoffBasic2-state: on
[2020-3-9 14:20:11] 39_alexa.pm is new version: true
[2020-3-9 14:20:11] sshautoconf: completed successfully
[2020-3-9 14:20:11] *** SSH: proxy configuration set up done
[2020-3-9 14:20:11] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2020-3-9 14:20:11] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:20:11] Starting SSH with -R 1234:127.0.0.1:36259 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2020-3-9 14:20:11] [FHEM] got .eventToken
[2020-3-9 14:20:11] refreshing token
[2020-3-9 14:20:12] BearerToken '...B7E90' read from alexa
[2020-3-9 14:20:12] failed to refresh token: invalid_grant: 'The request has an invalid grant parameter : refresh_token'
[2020-3-9 14:20:12] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2020-3-9 14:20:12] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-9 14:20:12] *** SSH: proxy connection established
[2020-3-9 14:20:12] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
erst nachdem ich wieder nur die lokale Instanz einbinde ist alles gut. Netzwerkprobleme kann ich ausschliessen, da sobald ich in einer  der entfernten Instanzen ein Alexa device definiere, die "error processing event data" Meldung in der betreffenden Instanz weg ist, leider bekomme ich dann invalid token Meldungen von den Geräten aus dieser Instanz.
Uff !! Das war jetzt eine ganze Menge, ich hoffe mir kann jemand helfen.
Danke im Voraus
TL60
Hallo ich nochmal,
ich habe ein wenig weiter recherchiert und auf meinem Testsystem mit dem Befehl: npm install -g alexa-fhem@0.5.45 eine ältere Version (0.5.45) installiert, was auch problemlos möglich war. Nachdem ich hier in die alexa-fhem.config meine 3 Systeme eingetragen und das system neu gestartet habe, sind meiner Meinung nach im Logfile keine Auffälligkeiten mehr zu sehen
[2020-3-9 20:59:44] Got SIGTERM, shutting down alexa-fhem...
[2020-3-9 20:59:44] Reading alexaFHEM.ProxyConnection set to stopping;; alexa-fhem terminating
[2020-3-9 20:59:44] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20stopping%3B%3B%20alexa-fhem%20terminating%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_550973033593804&XHR=1
[2020-3-9 20:59:44] Stopping SSH ...
[2020-3-9 20:59:44] Reading alexaFHEM.ProxyConnection set to stopped
[2020-3-9 20:59:44] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20stopped%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_550973033593804&XHR=1
[2020-3-9 20:59:44] *** SSH: exited with 0
[2020-3-9 21:06:39] using config from ./alexa-fhem.cfg
[2020-3-9 21:06:39] os.homedir()=/opt/fhem
[2020-3-9 21:06:39] this is alexa-fhem 0.5.45
[2020-3-9 21:06:39] connecting to FHEM ...
[2020-3-9 21:06:39] [FHEM1] will not proactively report
[2020-3-9 21:06:39] [FHEM1] trying longpoll to listen for fhem events
[2020-3-9 21:06:39] [FHEM1] starting longpoll: http://127.0.0.1:8086/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1583784399334
[2020-3-9 21:06:39] [FHEM2] will not proactively report
[2020-3-9 21:06:39] [FHEM2] trying longpoll to listen for fhem events
[2020-3-9 21:06:39] [FHEM2] starting longpoll: http://192.168.178.138:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1583784399343
[2020-3-9 21:06:39] [FHEM3] will not proactively report
[2020-3-9 21:06:39] [FHEM3] trying longpoll to listen for fhem events
[2020-3-9 21:06:39] [FHEM3] starting longpoll: http://192.168.178.137:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1583784399346
[2020-3-9 21:06:39] [FHEM1] longpoll error: Error: connect ECONNREFUSED 127.0.0.1:8086, retry in: 5000msec
*** FHEM: connection failed: Error: connect ECONNREFUSED 127.0.0.1:8086
[2020-3-9 21:06:39] Got SIGTERM, shutting down alexa-fhem...
[2020-3-9 21:06:39] Reading alexaFHEM.ProxyConnection set to stopping;; alexa-fhem terminating
[2020-3-9 21:08:17] using config from ./alexa-fhem.cfg
[2020-3-9 21:08:17] os.homedir()=/opt/fhem
[2020-3-9 21:08:17] this is alexa-fhem 0.5.45
[2020-3-9 21:08:17] connecting to FHEM ...
[2020-3-9 21:08:17] [FHEM1] will not proactively report
[2020-3-9 21:08:18] [FHEM1] trying longpoll to listen for fhem events
[2020-3-9 21:08:18] [FHEM1] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1583784498031
[2020-3-9 21:08:18] [FHEM2] will not proactively report
[2020-3-9 21:08:18] [FHEM2] trying longpoll to listen for fhem events
[2020-3-9 21:08:18] [FHEM2] starting longpoll: http://192.168.178.138:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1583784498039
[2020-3-9 21:08:18] [FHEM3] will not proactively report
[2020-3-9 21:08:18] [FHEM3] trying longpoll to listen for fhem events
[2020-3-9 21:08:18] [FHEM3] starting longpoll: http://192.168.178.137:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1583784498042
[2020-3-9 21:08:18] [FHEM1] got csrfToken: csrf_550973033593804
[2020-3-9 21:08:18] [FHEM1] Checking devices and attributes...
[2020-3-9 21:08:18] [FHEM1]   executing: http://127.0.0.1:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_550973033593804&XHR=1
[2020-3-9 21:08:18] [FHEM1]   executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_550973033593804&XHR=1
[2020-3-9 21:08:18] [FHEM1] waiting for events ...
[2020-3-9 21:08:18] [FHEM1] Fetching FHEM devices...
[2020-3-9 21:08:18] [FHEM1] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=csrf_550973033593804&XHR=1
[2020-3-9 21:08:18] [FHEM2] got csrfToken: csrf_553464341656572
[2020-3-9 21:08:18] [FHEM2] Checking devices and attributes...
[2020-3-9 21:08:18] [FHEM2]   executing: http://192.168.178.138:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_553464341656572&XHR=1
[2020-3-9 21:08:18] [FHEM2]   executing: http://192.168.178.138:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_553464341656572&XHR=1
[2020-3-9 21:08:18] [FHEM2] waiting for events ...
[2020-3-9 21:08:18] [FHEM2] Fetching FHEM devices...
[2020-3-9 21:08:18] [FHEM2] fetching: http://192.168.178.138:8083/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=csrf_553464341656572&XHR=1
[2020-3-9 21:08:18] [FHEM3] got csrfToken: csrf_358407218513667
[2020-3-9 21:08:18] [FHEM3] Checking devices and attributes...
[2020-3-9 21:08:18] [FHEM3]   executing: http://192.168.178.137:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_358407218513667&XHR=1
[2020-3-9 21:08:18] [FHEM3]   executing: http://192.168.178.137:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_358407218513667&XHR=1
[2020-3-9 21:08:18] [FHEM3] waiting for events ...
[2020-3-9 21:08:18] [FHEM3] Fetching FHEM devices...
[2020-3-9 21:08:18] [FHEM3] fetching: http://192.168.178.137:8083/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=csrf_358407218513667&XHR=1
[2020-3-9 21:08:18] [FHEM1] alexa device is alexa
[2020-3-9 21:08:18] [FHEM1]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.45%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_550973033593804&XHR=1
[2020-3-9 21:08:18] [FHEM1]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_550973033593804&XHR=1
[2020-3-9 21:08:18] [FHEM1]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_550973033593804&XHR=1
[2020-3-9 21:08:18] Server listening on: http://127.0.0.1:44647 for proxy connections
[2020-3-9 21:08:18] *** SSH: checking proxy configuration
[2020-3-9 21:08:18] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[2020-3-9 21:08:18] Passed config: {"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":44647},"connections":[{"name":"FHEM1","webname":"fhem","filter":"alexaName=..*","uid":999,"port":"8083","server":"127.0.0.1"},{"name":"FHEM2","webname":"fhem","filter":"alexaName=..*","uid":999,"port":"8083","server":"192.168.178.138"},{"name":"FHEM3","webname":"fhem","filter":"alexaName=..*","uid":999,"port":"8083","server":"192.168.178.137"}]}
[2020-3-9 21:08:18] sshautoconf: SSH key seems to exist
[2020-3-9 21:08:18] sshautoconf: Our SSH key is known at the reverse proxy, good!
[2020-3-9 21:08:18] [FHEM1]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_550973033593804&XHR=1
*** FHEM: connected
[2020-3-9 21:08:18] [FHEM1] got: 0 results
[2020-3-9 21:08:18] No Alexa device defined - this will not work with sshproxy mode
[2020-3-9 21:08:18] [FHEM2] TypeError: Cannot read property 'Name' of undefined
    at Server.<anonymous> (/usr/lib/node_modules/alexa-fhem/lib/server.js:945:50)
    at FHEM.emit (events.js:321:20)
    at FHEM.<anonymous> (/usr/lib/node_modules/alexa-fhem/lib/fhem.js:1370:28)
    at Request._callback (/usr/lib/node_modules/alexa-fhem/lib/fhem.js:1609:27)
    at Request.self.callback (/usr/lib/node_modules/alexa-fhem/node_modules/request/request.js:185:22)
    at Request.emit (events.js:321:20)
    at Request.<anonymous> (/usr/lib/node_modules/alexa-fhem/node_modules/request/request.js:1154:10)
    at Gunzip.<anonymous> (/usr/lib/node_modules/alexa-fhem/node_modules/request/request.js:1076:12)
    at Object.onceWrapper (events.js:427:28)
[2020-3-9 21:08:18] [FHEM2] failed to parse {  "Arg":"TYPE=alexa",  "Results": [  ],  "totalResultsReturned":0}
[2020-3-9 21:08:18] [FHEM3] TypeError: Cannot read property 'Name' of undefined
[2020-3-9 21:08:18] [FHEM3] failed to parse {  "Arg":"TYPE=alexa",  "Results": [  ],  "totalResultsReturned":0}
*** FHEM: connected
[2020-3-9 21:08:18] [FHEM2] got: 1 results
[2020-3-9 21:08:18] [FHEM2] Staubsauger_dummy is switch
[2020-3-9 21:08:18] [FHEM2] Staubsauger_dummy has
[2020-3-9 21:08:18] [FHEM2]   On [state;on,off]
  2020-03-09 21:08:18 caching: Staubsauger_dummy-state: off
*** FHEM: connected
[2020-3-9 21:08:18] [FHEM3] got: 1 results
[2020-3-9 21:08:18] [FHEM3] Gefrierschrank_dummy is switch
[2020-3-9 21:08:18] [FHEM3] Gefrierschrank_dummy has
[2020-3-9 21:08:18] [FHEM3]   On [state;on,off]
  2020-03-09 21:08:18 caching: Gefrierschrank_dummy-state: off
[2020-3-9 21:08:18] BearerToken '...7AEE5' read from alexa
[2020-3-9 21:08:18] 39_alexa.pm is new version: true
[2020-3-9 21:08:18] sshautoconf: completed successfully
[2020-3-9 21:08:18] *** SSH: proxy configuration set up done
[2020-3-9 21:08:18] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2020-3-9 21:08:18] [FHEM1]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_550973033593804&XHR=1
[2020-3-9 21:08:18] Starting SSH with -R 1234:127.0.0.1:44647 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2020-3-9 21:08:19] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2020-3-9 21:08:19] [FHEM1]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_550973033593804&XHR=1
[2020-3-9 21:08:19] *** SSH: proxy connection established
[2020-3-9 21:08:19] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
So das ich denke, es hat sich von der Version 0.5.45 bis zur 0.5.49 etwas verändert oder eingeschlichen oder  habe ich schlicht vergessen, das ich in der letzten Version ein Attribut neu setzen muss?
@justme: könntest du da mal drüber schauen und könnte ich mit dem oben genannten npm  Befehl auch auf meinem Produktivsystem wieder auf die alte Version zurück?
Danke im Voraus für die Mühe
justme1968
starte alexa-fhem mal mit -D für debug und schau ob mehr im log steht
TL60
Zitatstarte alexa-fhem mal mit -D für debug und schau ob mehr im log steht
Ich habe, um noch teilweise Alexa nutzen zu können, die entfernten Instanzen deaktiviert gehabt. (Konfig geändert) Nach dem wiederherstellen der ursprünglichen Konfig und  Neustart von Alexa mit parameter -D sieht das Log so aus: (ist sehr lang durch die vielen error processing event data Einträge)
[code][2020-3-11 13:16:56] *** SSH: exited with 143
[2020-3-11 13:19:10] using config from ./alexa-fhem.cfg
[2020-3-11 13:19:10] os.homedir()=/opt/fhem
[2020-3-11 13:19:10] this is alexa-fhem 0.5.49
[2020-3-11 13:19:10] connecting to FHEM ...
[2020-3-11 13:19:10] [FHEM1] defaults to: will not send proactive events
[2020-3-11 13:19:12] [FHEM1] trying longpoll to listen for fhem events
[2020-3-11 13:19:12] [FHEM1] starting longpoll: http://127.0.0.1:8086/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1583929152810
[2020-3-11 13:19:12] [FHEM2] defaults to: will not send proactive events
[2020-3-11 13:19:12] [FHEM2] trying longpoll to listen for fhem events
[2020-3-11 13:19:12] [FHEM2] starting longpoll: http://192.168.178.138:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1583929152859
[2020-3-11 13:19:12] [FHEM3] defaults to: will not send proactive events
[2020-3-11 13:19:12] [FHEM3] trying longpoll to listen for fhem events
[2020-3-11 13:19:12] [FHEM3] starting longpoll: http://192.168.178.137:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1583929152868
[2020-3-11 13:19:12] [FHEM2] got csrfToken: csrf_553464341656572
[2020-3-11 13:19:12] [FHEM2] Checking devices and attributes...
[2020-3-11 13:19:13] [FHEM2]   executing: http://192.168.178.138:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_553464341656572&XHR=1
[2020-3-11 13:19:13] [FHEM2]   executing: http://192.168.178.138:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_553464341656572&XHR=1
[2020-3-11 13:19:13] [FHEM2] waiting for events ...
[2020-3-11 13:19:13] [FHEM2] Fetching FHEM devices...
[2020-3-11 13:19:13] [FHEM2] fetching: http://192.168.178.138:8083/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=csrf_553464341656572&XHR=1
[2020-3-11 13:19:13] [FHEM3] got csrfToken: csrf_240956028058433
[2020-3-11 13:19:13] [FHEM3] Checking devices and attributes...
[2020-3-11 13:19:13] [FHEM3]   executing: http://192.168.178.137:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_240956028058433&XHR=1
[2020-3-11 13:19:13] [FHEM3]   executing: http://192.168.178.137:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_240956028058433&XHR=1
[2020-3-11 13:19:13] [FHEM3] waiting for events ...
[2020-3-11 13:19:13] [FHEM3] Fetching FHEM devices...
[2020-3-11 13:19:13] [FHEM3] fetching: http://192.168.178.137:8083/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=csrf_240956028058433&XHR=1
[2020-3-11 13:19:13] [FHEM1] got csrfToken: csrf_290357560160907
[2020-3-11 13:19:13] [FHEM1] Checking devices and attributes...
[2020-3-11 13:19:13] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-11 13:19:13] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-11 13:19:13] [FHEM1] waiting for events ...
[2020-3-11 13:19:13] [FHEM1] Fetching FHEM devices...
[2020-3-11 13:19:13] [FHEM1] fetching: http://127.0.0.1:8086/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-11 13:19:13] No Alexa device defined - this will not work with sshproxy mode
[2020-3-11 13:19:13] [FHEM2] TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:13] [FHEM2] failed to parse {  "Arg":"TYPE=alexa",  "Results": [  ],  "totalResultsReturned":0}
*** FHEM: connected
[2020-3-11 13:19:13] [FHEM2] got: 1 results
[2020-3-11 13:19:13] [FHEM2] mappings for Staubsauger_dummy: { On:
   { reading: 'state',
     valueOff: '/off|Off|OFF|A0|000000/',
     cmdOn: 'on',
     cmdOff: 'off' } }
[2020-3-11 13:19:13] [FHEM2] Staubsauger_dummy is switch
[2020-3-11 13:19:13] [FHEM2] Staubsauger_dummy has
[2020-3-11 13:19:13] [FHEM2]   On [state;on,off]
[2020-3-11 13:19:13] [FHEM2] Staubsauger_dummy will not send proactive events
[2020-3-11 13:19:13] [FHEM2] Staubsauger_dummy uses ID: 5e64f949-f33f-952a-d6ba-f2cdc4e10286236f
  2020-03-11 13:19:13 caching: Staubsauger_dummy-state: off
[2020-3-11 13:19:13] [FHEM3] TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:13] [FHEM3] failed to parse {  "Arg":"TYPE=alexa",  "Results": [  ],  "totalResultsReturned":0}
*** FHEM: connected
[2020-3-11 13:19:13] [FHEM3] got: 1 results
[2020-3-11 13:19:13] [FHEM3] mappings for Gefrierschrank_dummy: { On:
   { reading: 'state',
     cmdOn: 'on',
     cmdOff: 'off' } }
[2020-3-11 13:19:13] [FHEM3] Gefrierschrank_dummy is switch
[2020-3-11 13:19:13] [FHEM3] Gefrierschrank_dummy has
[2020-3-11 13:19:13] [FHEM3]   On [state;on,off]
[2020-3-11 13:19:13] [FHEM3] Gefrierschrank_dummy will not send proactive events
[2020-3-11 13:19:13] [FHEM3] Gefrierschrank_dummy uses ID: 5e664053-f33f-aada-cece-3e98c9f4173c4a70
  2020-03-11 13:19:13 caching: Gefrierschrank_dummy-state: off
[2020-3-11 13:19:13] [FHEM1] alexa device is alexa
[2020-3-11 13:19:13] [FHEM1] mappings for alexa: {}
[2020-3-11 13:19:13] [FHEM1] alexa will not send proactive events
[2020-3-11 13:19:13] [FHEM1] alexa uses ID: 5c5eef7e-f33f-567d-b321-548f9b4589be61b3
[2020-3-11 13:19:13] [FHEM1] homebridgeMapping: #Characteristic=<name>=<value>,...
On=verb=schalte,valueOn=an;ein,valueOff=aus,valueToggle=um
Brightness=verb=stelle,property=helligkeit,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=prozent
Hue=verb=stelle,valuePrefix=auf,values=rot:0;grün:128;blau:200
Hue=verb=färbe,values=rot:0;grün:120;blau:220
Saturation=verb=stelle,property=sättigung,valuePrefix=auf,values=AMAZON.NUMBER
Saturation=verb=sättige,values=AMAZON.NUMBER
TargetPosition=verb=mach,articles=den;die,values=auf:100;zu:0
TargetPosition=verb=stelle,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=prozent
TargetTemperature=verb=stelle,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=grad
Volume:verb=stelle,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=prozent
#Weckzeit=verb=stelle,valuePrefix=auf;für,values=AMAZON.TIME,valueSuffix=uhr
[2020-3-11 13:19:13] [FHEM1] value2homekit: { 'AMAZON.NUMBER': 'AMAZON.NUMBER' }
[2020-3-11 13:19:13] [FHEM1] value2homekit: { rot: '0', 'grün': '128', blau: '200' }
[2020-3-11 13:19:13] [FHEM1] value2homekit: { rot: '0', 'grün': '120', blau: '220' }
[2020-3-11 13:19:13] [FHEM1] value2homekit: { auf: '100', zu: '0' }
[2020-3-11 13:19:13] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.49%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-11 13:19:13] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-11 13:19:13] perfectOfVerb:
[2020-3-11 13:19:13] { stelle: 'gestellt',
  schalte: 'geschaltet',
  'färbe': 'gefärbt',
  mach: 'gemacht' }
[2020-3-11 13:19:13] verbsOfIntent:
[2020-3-11 13:19:13] [ OnIntent: [ 'schalte' ],
  prozentIntent: [ 'stelle' ],
  HueIntent: [ 'stelle' ],
  HueIntentB: [ 'färbe' ],
  SaturationIntent: [ 'stelle' ],
  SaturationIntentB: [ 'sättige' ],
  TargetPositionIntent: [ 'mach' ],
  gradIntent: [ 'stelle' ] ]
[2020-3-11 13:19:13] characteristicsOfIntent:
[2020-3-11 13:19:13] { OnIntent: [ 'On' ],
  prozentIntent: [ 'Brightness', 'TargetPosition', 'Volume' ],
  HueIntent: [ 'Hue' ],
  HueIntentB: [ 'Hue' ],
  SaturationIntent: [ 'Saturation' ],
  SaturationIntentB: [ 'Saturation' ],
  TargetPositionIntent: [ 'TargetPosition' ],
  gradIntent: [ 'TargetTemperature' ] }
[2020-3-11 13:19:13] prefixOfIntent:
[2020-3-11 13:19:13] { OnIntent: undefined,
  prozentIntent: 'auf',
  HueIntent: 'auf',
  HueIntentB: undefined,
  SaturationIntent: 'auf',
  SaturationIntentB: undefined,
  TargetPositionIntent: undefined,
  gradIntent: 'auf' }
[2020-3-11 13:19:13] suffixOfIntent:
  prozentIntent: 'prozent',
  HueIntent: undefined,
  SaturationIntent: undefined,
  gradIntent: 'grad' }
[2020-3-11 13:19:13] alexaTypes:
[2020-3-11 13:19:13] { light: [ 'licht', 'lampen' ],
  blind:
   [ 'rolladen',
     'rolläden',
     'jalousie',
     'jalousien',
     'rollo',
     'rollos' ] }
[2020-3-11 13:19:13] roomOfEcho:
[2020-3-11 13:19:13] {}
[2020-3-11 13:19:13] personOfId:
[2020-3-11 13:19:13] fhemIntents:
[2020-3-11 13:19:13] { FHEMgutenMorgenIntent: 'gutenMorgen',
  FHEMguteNachtIntent: 'guteNacht' }
[2020-3-11 13:19:13] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-11 13:19:13] Server listening on: http://127.0.0.1:42891 for proxy connections
[2020-3-11 13:19:13] *** SSH: checking proxy configuration
[2020-3-11 13:19:13] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[2020-3-11 13:19:13] Passed config: {"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":42891},"connections":[{"name":"FHEM1","webname":"fhem","filter":"alexaName=..*","uid":999,"port":"8086","server":"127.0.0.1"},{"name":"FHEM2","webname":"fhem","filter":"alexaName=..*","uid":999,"port":"8083","server":"192.168.178.138"},{"name":"FHEM3","webname":"fhem","filter":"alexaName=..*","uid":999,"port":"8083","server":"192.168.178.137"}]}
[2020-3-11 13:19:13] sshautoconf: SSH key seems to exist
[2020-3-11 13:19:13] sshautoconf: Our SSH key is known at the reverse proxy, good!
[2020-3-11 13:19:13] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
*** FHEM: connected
[2020-3-11 13:19:14] [FHEM1] got: 2 results
[2020-3-11 13:19:14] [FHEM1] mappings for SonoffBasic1: { On:
   { reading: 'state',
     cmdOn: 'on',
     cmdOff: 'off' } }
[2020-3-11 13:19:14] [FHEM1] SonoffBasic1 is switch
[2020-3-11 13:19:14] [FHEM1] SonoffBasic1 has
[2020-3-11 13:19:14] [FHEM1]   On [state;on,off]
[2020-3-11 13:19:14] [FHEM1] SonoffBasic1 will not send proactive events
[2020-3-11 13:19:14] [FHEM1] SonoffBasic1 uses ID: 5c5d9897-f33f-567d-e178-70b54974986ad0af
  2020-03-11 13:19:14 caching: SonoffBasic1-state: off
[2020-3-11 13:19:14] [FHEM1] mappings for SonoffBasic2: { On:
   { reading: 'state',
     cmdOn: 'on',
     cmdOff: 'off' } }
[2020-3-11 13:19:14] [FHEM1] SonoffBasic2 is outlet
[2020-3-11 13:19:14] [FHEM1] SonoffBasic2 has
[2020-3-11 13:19:14] [FHEM1] SonoffBasic2 will not send proactive events
[2020-3-11 13:19:14] [FHEM1] SonoffBasic2 uses ID: 5c5d9897-f33f-567d-60a3-d1fe4f929e6d6fbc
  2020-03-11 13:19:14 caching: SonoffBasic2-state: on
[2020-3-11 13:19:14] [FHEM1] got .eventToken
[2020-3-11 13:19:14] refreshing token
[2020-3-11 13:19:14] 39_alexa.pm is new version: true
[2020-3-11 13:19:14] sshautoconf: completed successfully
[2020-3-11 13:19:14] *** SSH: proxy configuration set up done
[2020-3-11 13:19:14] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2020-3-11 13:19:14] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-11 13:19:14] Starting SSH with -R 1234:127.0.0.1:42891 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2020-3-11 13:19:14] BearerToken '...B7E90' read from alexa
[2020-3-11 13:19:14] failed to refresh token: invalid_grant: 'The request has an invalid grant parameter : refresh_token'
[2020-3-11 13:19:14] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:14] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2020-3-11 13:19:14] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-11 13:19:14] *** SSH: proxy connection established
[2020-3-11 13:19:14] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
[2020-3-11 13:19:19] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:26] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:27] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:27] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:28] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:29] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:29] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:30] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:30] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:31] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.PowerController","name":"TurnOn","payloadVersion":"3","messageId":"44613e1d-f61c-4d17-b3dd-cbdff67ba8fa","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"D4200EBC-71D03E94187B7E90"},"endpointId":"5c5d9897-f33f-567d-e178-70b54974986ad0af","cookie":{"fuuid":"5c5d9897-f33f-567d-e178-70b54974986ad0af","device":"SonoffBasic1"}},"payload":{}}}
[2020-3-11 13:19:31] [FHEM1] SonoffBasic1: executing set cmd for On with value 1
[2020-3-11 13:19:31] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=set%20SonoffBasic1%20on&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-11 13:19:31] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.PowerController","name":"powerState","value":"ON","timeOfSample":"2020-03-11T12:19:31.035Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"579413bb-49b8-4ea6-847c-c185ae885000","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"D4200EBC-71D03E94187B7E90"},"endpointId":"5c5d9897-f33f-567d-e178-70b54974986ad0af"},"payload":{}}}
[2020-3-11 13:19:31] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
  2020-03-11 13:19:31 caching: SonoffBasic1-state: on
[2020-3-11 13:19:31] [FHEM1] SonoffBasic1-state valueOn/valueOff: value on mapped to 1
[2020-3-11 13:19:31] [FHEM1]     caching: On: 1 (as number; from 'on')
[2020-3-11 13:19:31] [FHEM1] not sending proactive event for: SonoffBasic1:state:on
[2020-3-11 13:19:31] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:32] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:35] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:40] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.PowerController","name":"TurnOff","payloadVersion":"3","messageId":"9e6150e8-3dc4-40a6-a76d-886e48fe2e06","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"D4200EBC-71D03E94187B7E90"},"endpointId":"5c5d9897-f33f-567d-e178-70b54974986ad0af","cookie":{"fuuid":"5c5d9897-f33f-567d-e178-70b54974986ad0af","device":"SonoffBasic1"}},"payload":{}}}
[2020-3-11 13:19:40] [FHEM1] SonoffBasic1: executing set cmd for On with value 0
[2020-3-11 13:19:40] [FHEM1]   executing: http://127.0.0.1:8086/fhem?cmd=set%20SonoffBasic1%20off&fwcsrf=csrf_290357560160907&XHR=1
[2020-3-11 13:19:40] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.PowerController","name":"powerState","value":"OFF","timeOfSample":"2020-03-11T12:19:40.743Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"3af57eeb-99da-49ac-8596-b192b4c74080","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"D4200EBC-71D03E94187B7E90"},"endpointId":"5c5d9897-f33f-567d-e178-70b54974986ad0af"},"payload":{}}}
[2020-3-11 13:19:40] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
  2020-03-11 13:19:40 caching: SonoffBasic1-state: off
[2020-3-11 13:19:40] [FHEM1] SonoffBasic1-state valueOn/valueOff: value off mapped to 0
[2020-3-11 13:19:40] [FHEM1]     caching: On: 0 (as number; from 'off')
[2020-3-11 13:19:40] [FHEM1] not sending proactive event for: SonoffBasic1:state:off
[2020-3-11 13:19:40] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:41] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:42] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:44] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:50] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:55] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:19:58] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:01] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:05] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:06] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:07] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:08] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:09] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:10] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:17] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:18] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:22] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:26] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:27] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:28] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:29] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:30] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:30] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:31] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:31] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:33] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:34] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:35] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:42] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:58] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:20:59] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:06] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:07] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:08] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:10] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:13] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:18] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:18] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:24] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:26] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:26] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:27] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:27] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:28] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:29] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:30] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:31] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:33] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:33] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:35] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:38] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:38] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:39] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:41] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:42] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:48] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:49] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:51] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:52] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:55] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:58] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:21:58] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa","name":"ReportState","payloadVersion":"3","messageId":"664452a6-11a2-471e-a0c0-d79c2c2b0386","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"D4200EBC-71D03E94187B7E90"},"endpointId":"5c5d9897-f33f-567d-60a3-d1fe4f929e6d6fbc","cookie":{"fuuid":"5c5d9897-f33f-567d-60a3-d1fe4f929e6d6fbc","device":"SonoffBasic2"}},"payload":{}}}
[2020-3-11 13:21:58] [FHEM1] SonoffBasic2-state valueOn/valueOff: value on mapped to 1
[2020-3-11 13:21:58] [FHEM1]     caching: On: 1 (as number; from 'on')
[2020-3-11 13:21:58] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.PowerController","name":"powerState","value":"ON","timeOfSample":"2020-03-11T12:21:58.975Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"StateReport","payloadVersion":"3","messageId":"475757bc-1bd5-4597-8dcf-699f9e9ecf8e","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"D4200EBC-71D03E94187B7E90"},"endpointId":"5c5d9897-f33f-567d-60a3-d1fe4f929e6d6fbc"},"payload":{}}}
[2020-3-11 13:22:01] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa","name":"ReportState","payloadVersion":"3","messageId":"61b0cb2b-0d2d-4532-88b2-dbac2d966a83","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"D4200EBC-71D03E94187B7E90"},"endpointId":"5c5d9897-f33f-567d-e178-70b54974986ad0af","cookie":{"fuuid":"5c5d9897-f33f-567d-e178-70b54974986ad0af","device":"SonoffBasic1"}},"payload":{}}}
[2020-3-11 13:22:01] [FHEM1] SonoffBasic1-state valueOn/valueOff: value off mapped to 0
[2020-3-11 13:22:01] [FHEM1]     caching: On: 0 (as number; from 'off')
[2020-3-11 13:22:01] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.PowerController","name":"powerState","value":"OFF","timeOfSample":"2020-03-11T12:22:01.620Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"StateReport","payloadVersion":"3","messageId":"bb9a9164-bd22-44c2-918a-2cddca487e44","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"D4200EBC-71D03E94187B7E90"},"endpointId":"5c5d9897-f33f-567d-e178-70b54974986ad0af"},"payload":{}}}
[2020-3-11 13:22:06] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:08] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:10] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:11] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.Discovery","name":"Discover","payloadVersion":"3","messageId":"75e6d6d5-abd9-4d68-8bda-4790c595e8ec"},"payload":{"scope":{"type":"BearerToken","token":"D4200EBC-71D03E94187B7E90"}}}}
[2020-3-11 13:22:11] found 4 device(s)
[2020-3-11 13:22:11] <<<< [ssh] {"event":{"header":{"namespace":"Alexa.Discovery","name":"Discover.Response","payloadVersion":"3","messageId":"6ec9d03a-533d-4119-8c98-01d9b7e41fde"},"payload":{"endpoints":[{"endpointId":"5e64f949-f33f-952a-d6ba-f2cdc4e10286236f","manufacturerName":"dummy","description":"n: Staubsauger_dummy, r: technik","friendlyName":"staubsauger","displayCategories":["SWITCH"],"additionalAttributes":{"manufacturer":"FHEM","model":"<unknown>"},"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"cookie":{"device":"Staubsauger_dummy","fuuid":"5e64f949-f33f-952a-d6ba-f2cdc4e10286236f"}},{"endpointId":"5e664053-f33f-aada-cece-3e98c9f4173c4a70","manufacturerName":"dummy","description":"n: Gefrierschrank_dummy, r: technik","friendlyName":"gefrierschrank","displayCategories":["SWITCH"],"additionalAttributes":{"manufacturer":"FHEM","model":"<unknown>"},"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"cookie":{"device":"Gefrierschrank_dummy","fuuid":"5e664053-f33f-aada-cece-3e98c9f4173c4a70"}},{"endpointId":"5c5d9897-f33f-567d-e178-70b54974986ad0af","manufacturerName":"MQTT2_DEVICE","description":"n: SonoffBasic1, r: homekitdeb,alexa,googleassistant,mqtt2_device,uebersicht","friendlyName":"deckenstrahler","displayCategories":["SWITCH"],"additionalAttributes":{"manufacturer":"FHEM","model":"<unknown>"},"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"cookie":{"device":"SonoffBasic1","fuuid":"5c5d9897-f33f-567d-e178-70b54974986ad0af"}},{"endpointId":"5c5d9897-f33f-567d-60a3-d1fe4f929e6d6fbc","manufacturerName":"MQTT2_DEVICE","description":"n: SonoffBasic2, r: alexa,homekit,mqtt2_device,uebersicht","friendlyName":"wandlampe","displayCategories":["SMARTPLUG"],"additionalAttributes":{"manufacturer":"FHEM","model":"<unknown>"},"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"cookie":{"device":"SonoffBasic2","fuuid":"5c5d9897-f33f-567d-60a3-d1fe4f929e6d6fbc"}}]}}}
[2020-3-11 13:22:14] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:23] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:26] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:27] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:28] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:29] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:29] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:31] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:33] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:35] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:39] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:42] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:43] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:48] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:50] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:58] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:22:59] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:04] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:06] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:08] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:10] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:11] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:14] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:17] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:26] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:27] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:28] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:29] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:29] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:30] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:31] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:33] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:35] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:35] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:36] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:37] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:38] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:42] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:43] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:43] [FHEM3]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:44] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
[2020-3-11 13:23:46] [FHEM2]   error processing event data: TypeError: Cannot read property 'Name' of undefined
justme1968
die meldung sollte mit der jetzt aktuellen version behoben sein.
die ursache ist das du in den anderen Instanzen kein alexa device hast. leg eines an und schalte den alexa-fhem autostart über disable ab.
TL60
habe so verfahren wie du gesagt hast. Alle Instanzen funktionieren und keine Eintragungen im Logfile mehr. Super !!
Ich bin immer wieder begeistert wie schnell hier geholfen wird. Vollsten Respekt und ..
Danke sehr
Thomas
