HMLAN sendet nicht mehr nach UPDATE
Begonnen von dieter56, 29 April 2016, 10:41:34
dieter56
ich habe auf meinem HMLAN ein Firmwareupdate gemacht.
Jetzt sendet er kein Befehle mehr.
   DEF        192.168.2.62:1000
   DeviceName 192.168.2.62:1000
   FD         67
   HMLAN1_MSGCNT 451
   HMLAN1_TIME 2016-04-29 10:37:12
   IFmodel    LAN
   NAME       HMLAN1
   NR         23
   NTFY_ORDER 50-HMLAN1
   PARTIAL
   RAWMSG     E20D606,0000,0023888D,FF,FFB9,7CA44120D6062BAC750197C8
   RSSI       -71
   STATE      opened
   TYPE       HMLAN
   XmitOpen   1
   assignedIDsCnt 0
   msgKeepAlive dlyMax:189.528 bufferMin:-184
   msgLoadCurrent 1
   msgLoadHistory 5min steps: 0/0/0/0/0/0/0/0/0/0/0/1
   msgParseDly min:4 max:6904 last:11 cnt:390
   owner      2BAC75
   owner_CCU  VCCU
   uptime     000 00:38:48.717
   Readings:
     2016-04-29 09:39:05   D-HMIdAssigned  2BAC75
     2016-04-29 09:39:05   D-HMIdOriginal  2BAC75
     2016-04-29 09:39:05   D-firmware      0.965
     2016-04-29 09:39:05   D-serialNr      LEQ0579720
     2016-04-29 10:04:14   Xmit-Events     ok:4 timeout:3 disconnected:4 init:4
     2016-04-29 10:04:14   cond            ok
     2016-04-29 10:37:09   loadLvl         low
     2016-04-13 20:35:33   prot_ERROR-Overload last
     2016-04-13 20:35:19   prot_Warning-HighLoad last
     2016-04-29 10:03:09   prot_disconnected last
     2016-04-29 09:08:41   prot_dummy      last
     2016-04-29 10:04:14   prot_init       last
     2016-04-29 00:03:44   prot_keepAlive  last
     2016-04-29 10:04:14   prot_ok         last
     2016-04-29 10:03:09   prot_timeout    last
     2016-04-29 10:04:14   state           opened
   Helper:
     assIdCnt   0
     assIdRep   0
     info       03C5,LEQ0579720,2BAC75,2BAC75
     setTime    44614
     Cnd:
       0          4
       252        3
       253        4
       255        4
     Dly:
       cnt        390
       lst        11
       max        6904
       min        4
     Ids:
     K:
       BufMin     -184
       DlyMax     189.528
       Next       1461919054.87969
       Start      1461919029.87969
     Loadlvl:
       bl         40
       a:
         99
         90
         40
         0
       H:
         0          low
         40         batchLevel
         90         high
         99         suspended
     Log:
       all        0
       sys        0
       ids:
         20E00D
     Q:
       HMcndN     0
       answerPend 0
       hmLanQlen  1
       keepAliveRec 1
       keepAliveRpt 0
       loadLast   1
       loadNo     7
       scnt       4
       apIDs:
     Ref:
       drft       -0.00017998200179982
       hmtL       2326115
       kTs        0
       offL       1461916703768
       sysL       1461919029883
   dummy      0
   hmId       2BAC75
   hmLanQlen  1_min
   icon       hm_lan
   loadLevel  0:low,40:batchLevel,90:high,99:suspended
   logIDs     Schlafzimmer.Thermostat
   room       hidden
Jetzt kann ich zum Beispiel keine Lampe mehr schalten. Es erscheint dann immer "MISSING ACK".
In dem List steht unter logIDs ein Gerät - Schlafzimmer.Thermostat Warum?
Muss ich jetzt alle Geräte neu pairen?
Ich bin kurz vor einem Nervenzusammbruch.
Kann mich jemand retten?
frank
lösch mal das attribut dummy.
attr logIDs musst du selbst gestzt haben. ist aber kein problem, und kannst du wieder löschen.  ;)
FHEM: 6.0(SVN) => Pi3(buster)
dieter56
Ich danke dir.
Nachdem ich deinen Tipp befolgt habe läuft es wieder.
Ich hatte irgendwo gelesen, dass man vor dem update "attr dummy 1" und danach "attr dummy 0" setzen sollte.
Aber das gehört wohl zu den 99 % dessen, was im Internet falsch ist.
