Revision 12932: 98_WeekdayTimer, 98_Heating_Contorl: a new try to use a new method to ...
Begonnen von System, 02 Januar 2017, 18:45:04
System
98_WeekdayTimer, 98_Heating_Contorl:  a new try to use a new method to check if a device is a heating - the new method is very easy, it checks if a device understand desired-temp ....
The  first version, that was checked in, was causing errors.
Source: Revision 12932: 98_WeekdayTimer, 98_Heating_Contorl:  a new try to use a new method to ...
