CUL / Intertek frustration [solved]
Begonnen von Doddster, 19 März 2017, 10:20:09
KölnSolar
Hi Walter,
the question is, which protocol your switches are using. They are selflearning, right ? Doddsters seemed to be with dip switches and V1 protocol.
You have to analyze the protocol and find a rule. Means, pressing more than 5 times the same button, pressing the related off-button, same thing for the second button and writing down the 8 digits hex-codes received with the CUL.
Another option you can try, if the switches are selflearning: delete the codes of the switches, put them in learning-mode and send a random V3-code from FHEM via CUL to the switches. Maybe it works, but then you can't any longer use the remote. Maybe your switches are able to learn more than one code and you may learn the codes of the remote additionaly.
Regards Markus
