Alexa findet keine Geräte
Begonnen von raspklaus, 20 April 2017, 17:02:39
raspklaus
ich habe nun Skill und Lambda eingerichtet und versuche nun mit dem echo ein Gerät zu finden. Dafür habe ich ein Testgerät angelegt:
   NAME       Testdummy
   NR         2789
   STATE      off
   TYPE       dummy
   Readings:
     2017-04-19 13:05:37   state           off
   alexaName  Licht
   genericDeviceType switch
   room       Alexa
   setList    on off
alexa-fhem wird noch separat gestartet :
[4/20/2017, 4:58:14 PM] using /root/.alexa/config.json
[4/20/2017, 4:58:14 PM] ---
[4/20/2017, 4:58:14 PM] this is alexa-fhem 0.3.3
[4/20/2017, 4:58:14 PM] Fetching FHEM devices...
[4/20/2017, 4:58:14 PM] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON&timestamp=1492700294737
[4/20/2017, 4:58:14 PM] Server listening on: https://:::3000
[4/20/2017, 4:58:15 PM] [FHEM] Checking devices and attributes...
[4/20/2017, 4:58:15 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7BAttrVal(%22global%22,%22userattr%22,%22%22)%7D&XHR=1
[4/20/2017, 4:58:15 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE=alexa&XHR=1
[4/20/2017, 4:58:15 PM] [FHEM] Fetching FHEM devices...
[4/20/2017, 4:58:15 PM] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=Alexa&XHR=1
[4/20/2017, 4:58:15 PM] [FHEM] got: 1 results
[4/20/2017, 4:58:15 PM] [FHEM] Testdummy is switch
[4/20/2017, 4:58:15 PM] [FHEM] Testdummy has
[4/20/2017, 4:58:15 PM] [FHEM]   On [state;on,off]
[4/20/2017, 4:58:15 PM] [FHEM] { reading: 'state',
  valueOff: '/off|A0|000000/',
  cmdOn: 'on',
  cmdOff: 'off',
  device: 'Testdummy',
  informId: 'Testdummy-state',
  characteristic_type: 'On',
  log:
   { [Function: bound ]
     debug: [Function],
     info: [Function],
     warn: [Function],
     error: [Function],
     log: [Function],
     prefix: 'FHEM' } }
  2017-04-20 16:58:15 caching: Testdummy-state: off
[4/20/2017, 4:58:15 PM] [FHEM] alexa device is MyAlexa
[4/20/2017, 4:58:15 PM] [FHEM] MyAlexa is switch
[4/20/2017, 4:58:15 PM] [FHEM] MyAlexa has
[4/20/2017, 4:58:15 PM] [FHEM] homebridgeMapping: #Characteristic=<name>=<value>,...
On=verb=schalte,valueOn=an;ein,valueOff=aus,valueToggle=um
Brightness=verb=stelle,property=helligkeit,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=prozent
Hue=verb=stelle,valuePrefix=auf,values=rot:0;grün:128;blau:200
Hue=verb=färbe,values=rot:0;grün:120;blau:220
Saturation=verb=stelle,property=sättigung,valuePrefix=auf,values=AMAZON.NUMBER
Saturation=verb=sättige,values=AMAZON.NUMBER
TargetPosition=verb=mach,articles=den,values=auf:100;zu:0
TargetPosition=verb=stelle,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=prozent
TargetTemperature=verb=stelle,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=grad
Volume:verb=stelle,valuePrefix=auf,values=AMAZON.NUMBER,valueSuffix=prozent
#Weckzeit=verb=stelle,valuePrefix=auf;für,values=AMAZON.TIME,valueSuffix=uhr
[4/20/2017, 4:58:15 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B$defs%7BMyAlexa%7D-%3E%7B%22active%22%7D%20=%201%7D&XHR=1
[4/20/2017, 4:58:15 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B$defs%7BMyAlexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20=%20%220.3.3%22%7D&XHR=1
[4/20/2017, 4:58:15 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B$defs%7BMyAlexa%7D-%3E%7B%22active%22%7D%20=%200%7D&XHR=1
[4/20/2017, 4:58:15 PM] perfectOfVerb:
[4/20/2017, 4:58:15 PM] { stelle: 'gestellt',
  schalte: 'geschaltet',
  'färbe': 'gefärbt',
  mach: 'gemacht' }
[4/20/2017, 4:58:15 PM] verbsOfIntent:
[4/20/2017, 4:58:15 PM] [ OnIntent: [ 'schalte' ],
  prozentIntent: [ 'stelle' ],
  HueIntent: [ 'stelle' ],
  HueIntentB: [ 'färbe' ],
  SaturationIntent: [ 'stelle' ],
  SaturationIntentB: [ 'sättige' ],
  TargetPositionIntent: [ 'mach' ],
  gradIntent: [ 'stelle' ] ]
[4/20/2017, 4:58:15 PM] characteristicsOfIntent:
[4/20/2017, 4:58:15 PM] { OnIntent: [ 'On' ],
  prozentIntent: [ 'Brightness', 'TargetPosition', 'Volume' ],
  HueIntent: [ 'Hue' ],
  HueIntentB: [ 'Hue' ],
  SaturationIntent: [ 'Saturation' ],
  SaturationIntentB: [ 'Saturation' ],
  TargetPositionIntent: [ 'TargetPosition' ],
  gradIntent: [ 'TargetTemperature' ] }
[4/20/2017, 4:58:15 PM] prefixOfIntent:
[4/20/2017, 4:58:15 PM] { OnIntent: undefined,
  prozentIntent: 'auf',
  HueIntent: 'auf',
  HueIntentB: undefined,
  SaturationIntent: 'auf',
  SaturationIntentB: undefined,
  TargetPositionIntent: undefined,
  gradIntent: 'auf' }
[4/20/2017, 4:58:15 PM] suffixOfIntent:
  prozentIntent: 'prozent',
  HueIntent: undefined,
  SaturationIntent: undefined,
  gradIntent: 'grad' }
[4/20/2017, 4:58:15 PM] alexaTypes:
[4/20/2017, 4:58:15 PM] { light: [ 'licht', 'lampen' ],
  blind:
   [ 'rolladen',
     'rolläden',
     'jalousie',
     'jalousien',
     'rollo',
     'rollos' ] }
[4/20/2017, 4:58:15 PM] roomOfEcho:
[4/20/2017, 4:58:15 PM] {}
[4/20/2017, 4:58:15 PM] fhemIntents:
[4/20/2017, 4:58:15 PM] { FHEMgutenMorgenIntent: 'gutenMorgen',
  FHEMguteNachtIntent: 'guteNacht' }
Ein Discover bzw Suche Geräte erzeugt folgendes Log:
2017-04-20 16:59:52 caching: Testdummy-state: off
[4/20/2017, 5:00:07 PM] accepted new token
**** Received Directive: {"header":{"namespace":"Alexa.ConnectedHome.Discovery","name":"DiscoverAppliancesRequest","payloadVersion":"2","messageId":
"e83aa886-a9b0-45b7-884e-0bd8d87a2e4c"},"payload":{"accessToken":"Atza|IwEBIFIP9I1OvPaqMMWYr1Nakx7Bc6eJ_ktU3Lhc39IhkVLN5fHzzBCv9WaJC4aBwlQEU01ty_
0vMRamgfEempq-BIkyVB9hUVAK6UuQPBwJjS5jWjc9tV0LuNWJcToUjPrtzW_pmQ6n36nRnocowSFWOVYUPl5bz5nSnYhH9B33NElRK3R-
fM7D17srKeNLkLbfZ2hFm6IcWikJg8OA4l3VzjdyDSgdUmPBzGNVHELDjIGOYLydGTtf7N5GmCKFDDzUFAFy6mglr4e4luktlnmzBHyaQM77QVTItPO3dQxHWa5hDSRqvAl2Lpsur9sxNr1D3tjSsnbfkO5eXP-2kja9DP4ZNi_8GLL0AcQLJc9RjvdgaX6y-
jBPrQMP1Q2nhzUZUgDBTtXEcHGUh9Nu_INfMzMOKEhpTGvwEHZlR1sSqlkWe_SiQ49gLijyBWxvVWWEOltzJmBQgIwZba8acPIVXRBfya--
vtGdVN4oCdefZonfAw"}}
response :{"header":{"name":"DiscoverAppliancesResponse","payloadVersion":"2","namespace":"Alexa.ConnectedHome.Discovery","messageId":"
7a8df18e-05a8-4d2e-9c2c-70286aaeb136"},"payload":{"discoveredAppliances":[{"applianceId":"Testdummy","manufacturerName":"FHEMdummy","modelName":"FHEM<unknown>","version":"
<unknown>","friendlyName":"licht","friendlyDescription":"n: Testdummy, r: alexa","isReachable":true,"actions":
["turnOn","turnOff"],"additionalApplianceDetails":{"device":"Testdummy"}}]}}
Es wird aber kein Gerät gefunden bzw angezeigt
Wo könnte der Fehler liegen
Danke für eure Hilfe
MaMi7880
RaspberryPi 3 mit nanoCUL & JeeLink | FHEM 6.0 mit IT, HM  - Sensoren/Aktoren & Lacrosse Temp./Humi. | Shelly | Amazon Echo | Logitech Harmony Hub | Philips HUE | andFHEM
tklein
setlist ist aber in Nutzung. Muss der Raum Alexa groß geschrieben werden? Im Beispiel ist es doch alexa, oder?
Vielleicht ist es das.
Thomas
FHEM auf Pi 3, Echo (Plus, Dot und Connect), CUL868/433, HM Komponenten, Broadlink, Enigma (VU DUO2), Alexa/Homebridge, Sonoffs (POW, RF, Basic), Wemos D1 (IR, DHT, BH1750, OLED, BMP180), IT/Steckdosen, Fritzbox mit SIP, Wifilight, MQTT, Pilight, Xiaomi Flower Sensor, Spotify, Dooya, Shelly, Conbee2
MaMi7880
das sollte egal sein aber laut Wiki muss für ein dummy auch ein alexaRoom definiert werden..
define Alexa.Party dummy
attr Alexa.Party alexaName party
attr Alexa.Party alexaRoom alexaroom
attr Alexa.Party genericDeviceType switch
attr Alexa.Party group AlexaGeräte
attr Alexa.Party room AlexaRoom
attr Alexa.Party setList on off
MadMax-FHEM
#4
alexaRoom ist NUR für den Custom Skill relevant!
Was hast du denn im Filter in der config.json stehen, genau das muss beim Dummy (und jedem Gerät das gefunden werden soll) stehen.
Scheint aber zu passen, da ja alexa-fhem prinzipiell die Geräte findet!
Ich hatte gehofft, dass André (justme1968) mal drüber schaut weil ich denke, dass alle sonstigen "üblichen" Dinge passen, also nicht das Problem sind.
Und es geht ja NICHT um den Dummy, der war nur als einfaches Mittel für die Fehlersuche gedacht, um zu sehen, ob es prinzipiell geht und es also an den IT Geräten liegt oder wie zu sehen schon mit dem Dummy nicht geht.
Und zwar NUR, dass eben Alexa keine Geräte findet...
...alexa-fhem allerdings (so wie es aussieht beim drüber schauen aber vielleicht nicht im Detail [welche ich nicht so genau kenne]) eben schon.
EDIT: @Raspklaus es wäre wichtig die Ausgabe von alexa-fhem bei Starten zu sehen. Ist leider zu früh abgeschnitten. Es ist nur noch der letzte Eintrag des Dummy zu sehen und dann die Gerätesuche. Wichtig wäre zu sehen was alexa-fhem beim Start bzgl. des Dummy ausgibt!
Gruß, Joachim
FHEM PI3 Buster (Test)
MaMi7880
Zitat von: MadMax-FHEM am 21 April 2017, 22:20:00
Ich hatte gehofft, dass nicht auch hier alle möglichen Antworten kommen...
...sondern André (justme1968) mal drüber schaut weil ich denke, dass alle sonstigen offensichtlichen Dinge passen.
Auch wir versuchen  nur  zu helfen... und im Wiki steht es anders...
Und warum darf man nicht über passenden, offensichtlichen Dinge hinweggehen?
Man wird hier animiert sich selber zu helfen und nicht für jeden Mist die Developer anzusprechen und wenn man sich dann gegenseitig helfen will ist es auch nicht recht.
tklein konnte z.B. auch ohne den Modulentwikler geholfen werden.
Schönen Abend  noch...
justme1968
#6
damit ein gerät in alexa auftaucht sind folgende bedingungen zu erfüllen:
1. der filter aus config.json muss das gerät einschliessen.
   auf welche art ist egal. room, name, was auch immer
2. das gerät muss einen bekannten typ haben der entweder automatisch erkannt wird und dem automatisch
   zugehörige kommandos zugeordnet werden können oder es muss ein genericDeviceType gesetzt werden
   und ein homebridgeMapping haben
3. das gerät muss zum jeweiligen skill passen
2. bedeutet das ein dummy entweder eine setList mit on und off oder ein homebridgeMapping haben muss
3. bedeutet das im home automation skill nur schalter, lampen thermostate und rollläden funktionieren
alexaName, alexaRoom und sonstige attribute sind für das erkennen erst mal nicht wichtig. ausser alexaName ins alle anderen attribute und nur für den custom skill relevant.
wie du an dem nicht leeren discoveredAppliances knoten in der response zeile sehen kannst ein device mit namen Testdummy als device licht das sich ein- und ausschalten lässt gefunden und an alexa zurück gemeldet.
wenn die alexa app das gerät nicht anzeigt versuch es mal mit einem anderen namen.
ansonsten schau ins cloudwatch log. vielleicht steht dort etwas.
MadMax-FHEM
So war es nicht gemeint aber raspklaus hat in dem Skill-Thread und Problem-Thread schon einige mehr Infos geliefert, hier leider etwas wenig Input weitergegeben bzw. halt durchaus wichtige Infos "vergessen" (die mir aber bekannt sind und ich daher nicht erneut hier geprüft habe: mein Fehler!!) und viele/die meisten/alle hier bislang gut gemeinten Hilfen wurden dort schon mehrfach ohne Erfolg "durchgekaut" und daher war die Idee einen extra-Thread zu öffnen wegen Übersichtlichkeit...
Gruß, Joachim
MadMax-FHEM
@André:
danke!
Also ich "spreche" mal im Namen von raspklaus...
Wie geschrieben (und in dem/den anderen Threads schon ein wenig "bearbeitet") ging es ursprünglich um IT-Geräte.
Der Dummy war als Test um zu sehen, ob es generell geht.
Der Dummy wurde soweit ich sehen konnte richtig angelegt und passte auch in den Filter und wurde (die Ausgabe fehlt hier leider) von alexa-fhem beim Start gefunden...
...nicht aber von der Alexa-App...
Hmm, der Name kann dort eine Ursache sein?
Wie das?
Gruß, Joachim
justme1968
und wo ist das listing und die ausgabe von dem device das nicht geht?
MadMax-FHEM
Hallo André,
das hat raspklaus leider vergessen mit in diesen Thread zu übernehmen...
...hier ist die Historie:
https://forum.fhem.de/index.php/topic,60244.msg622269.html#msg622269
Sorry! Ebenfalls mal für raspklaus "gesprochen" ;)
Gruß, Joachim
raspklaus
#11
Sorry,
hatte wirklich noch die Ausgabe beim Start von alex-fhem vergessen. Hier ist sie:
[4/22/2017, 5:13:31 PM] using /root/.alexa/config.json
[4/22/2017, 5:13:31 PM] ---
[4/22/2017, 5:13:31 PM] this is alexa-fhem 0.3.3
[4/22/2017, 5:13:31 PM] Fetching FHEM devices...
[4/22/2017, 5:13:31 PM] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON&timestamp=1492874011502
[4/22/2017, 5:13:31 PM] Server listening on: https://:::3000
[4/22/2017, 5:13:31 PM] [FHEM] Checking devices and attributes...
[4/22/2017, 5:13:31 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7BAttrVal(%22global%22,%22userattr%22,%22%22)%7D&XHR=1
[4/22/2017, 5:13:31 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE=alexa&XHR=1
[4/22/2017, 5:13:31 PM] [FHEM] Fetching FHEM devices...
[4/22/2017, 5:13:31 PM] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=Alexa&XHR=1
[4/22/2017, 5:13:32 PM] [FHEM] alexa device is MyAlexa
[4/22/2017, 5:13:32 PM] [FHEM] MyAlexa is switch
[4/22/2017, 5:13:32 PM] [FHEM] MyAlexa has
[4/22/2017, 5:13:32 PM] [FHEM] homebridgeMapping: #Characteristic=<name>=<value>,...
[4/22/2017, 5:13:32 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B$defs%7BMyAlexa%7D-%3E%7B%22active%22%7D%20=%201%7D&XHR=1
[4/22/2017, 5:13:32 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B$defs%7BMyAlexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20=%20%220.3.3%22%7D&XHR=1
[4/22/2017, 5:13:32 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B$defs%7BMyAlexa%7D-%3E%7B%22active%22%7D%20=%200%7D&XHR=1
[4/22/2017, 5:13:32 PM] perfectOfVerb:
[4/22/2017, 5:13:32 PM] { stelle: 'gestellt',
  'färbe': 'gefärbt',
  mach: 'gemacht' }
[4/22/2017, 5:13:32 PM] verbsOfIntent:
[4/22/2017, 5:13:32 PM] [ OnIntent: [ 'schalte' ],
[4/22/2017, 5:13:32 PM] characteristicsOfIntent:
[4/22/2017, 5:13:32 PM] { OnIntent: [ 'On' ],
[4/22/2017, 5:13:32 PM] prefixOfIntent:
[4/22/2017, 5:13:32 PM] { OnIntent: undefined,
  HueIntent: 'auf',
  gradIntent: 'auf' }
[4/22/2017, 5:13:32 PM] suffixOfIntent:
[4/22/2017, 5:13:32 PM] alexaTypes:
[4/22/2017, 5:13:32 PM] { light: [ 'licht', 'lampen' ],
  blind:
   [ 'rolladen',
     'rolläden',
     'jalousie',
     'jalousien',
     'rollo',
     'rollos' ] }
[4/22/2017, 5:13:32 PM] roomOfEcho:
[4/22/2017, 5:13:32 PM] {}
[4/22/2017, 5:13:32 PM] fhemIntents:
[4/22/2017, 5:13:32 PM] { FHEMgutenMorgenIntent: 'gutenMorgen',
[4/22/2017, 5:13:32 PM] [FHEM] got: 1 results
[4/22/2017, 5:13:32 PM] [FHEM] Testdummy is switch
[4/22/2017, 5:13:32 PM] [FHEM] Testdummy has
[4/22/2017, 5:13:32 PM] [FHEM]   On [state;on,off]
[4/22/2017, 5:13:32 PM] [FHEM] { reading: 'state',
  cmdOn: 'on',
  cmdOff: 'off',
  log:
     debug: [Function],
     info: [Function],
     warn: [Function],
     error: [Function],
     log: [Function],
     prefix: 'FHEM' } }
  2017-04-22 17:13:32 caching: Testdummy-state: off
Der Filter selbst passt, denn wenn ich den verändere wird der Testdummy nicht mehr gefunden
Alexaroom hat keine Auswirkung auf den Erfolg und setlist ist vorhanden
MadMax-FHEM
justme1968
was steht im cloud watch log wenn du die alexa geräte suche startest?
raspklaus
Ich weiss, dumme Frage, aber trotzdem:
Wo finde ich das Cloudwatch Log ?
