fhemweb.js line 1016: TypeError: selVal is null
Begonnen von Rampler, 15 August 2017, 21:11:16
Rampler
wenn ich bei einem MQTT_Device ein Reading in der Art:
subscribeReading_irgendwas  /hooks/devices/3/SensorData/irgendwas
anklicke, erhalte ich ein Popup-Fenster mit folgendem Inhalt:
Mache ich was falsch, oder ist das noch ein Fehler ?
Definieren konnte ich ohne Probleme:
attr device subscribeReading_irgendwas  /hooks/devices/3/SensorData/irgendwas
Hier das List eines exemplarischen Devices:
   DEF        KE.th
   IODev      MQTT
   NAME       KE.th
   NOTIFYDEV  KE.th
   NR         500
   STATE      T: 20.20 H: 63.00
   TYPE       MQTT_DEVICE
   qos        0
   retain     0
     2017-08-15 20:46:49   Battery         ok
     2017-08-15 20:46:49   Dewpoint        12.94
     2017-08-15 20:46:49   Humidity        63.00
     2017-08-15 20:46:49   Temperature     20.20
     2017-08-15 20:46:48   Voltage         3.64
     2017-08-15 20:46:49   state           T: 20.20 H: 63.00
     2017-08-15 20:46:49   transmission-state incoming publish received
   message_ids:
   sets:
   subscribe:
     /hooks/devices/3/SensorData/Humidity
     /hooks/devices/3/SensorData/Temperature
     /hooks/devices/3/SensorData/Voltage
   subscribeExpr:
     ^\/hooks\/devices\/3\/SensorData\/Humidity$
     ^\/hooks\/devices\/3\/SensorData\/Temperature$
     ^\/hooks\/devices\/3\/SensorData\/Voltage$
   subscribeReadings:
     /hooks/devices/3/SensorData/Humidity Humidity
     /hooks/devices/3/SensorData/Temperature Temperature
     /hooks/devices/3/SensorData/Voltage Voltage
   IODev      MQTT
   alias      Keller Klima
   comment    Accu neu geladen am 12.4.2017
   event-on-change-reading Battery
   event-on-update-reading Humidity,state
   icon       weather_light_meter
   room       Keller
   stateFormat state
   subscribeReading_Humidity /hooks/devices/3/SensorData/Humidity
   subscribeReading_Temperature /hooks/devices/3/SensorData/Temperature
   subscribeReading_Voltage /hooks/devices/3/SensorData/Voltage
   userReadings state:state:Humidity.* {"T: ".ReadingsVal("KE.th","Temperature",0)." H: ".ReadingsVal("KE.th","Humidity",0)} , Battery:Humidity.* { ReadingsVal("KE.th","Voltage",2.9)<3.3 ? "low" : "ok" } , Dewpoint:Humidity.* {myDewpoint($name,"Temperature","Humidity")}
VG
Klaus
3 HMUART (2 via ESP8266), 1 DUOFERN, 12 ESP8266, SolvisBen, GoodWE WR, RPI2 (Bullseye), ZWAVE, HM-Classic, und hoch zufrieden ...
Danke an alle, die was dazu beigetragen haben !!
Ich habe keinen MQTT Broker, habe trotzdem eine FHEM-MQTT-Instanz mit "define MQTT MQTT" angelegt. Ich bekomme dabei folgende Meldungen im Log:
Zitat2017.08.15 21:31:05 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/00_MQTT.pm line 103.
2017.08.15 21:31:05 3: Opening MQTT device
2017.08.15 21:31:05 1: PERL WARNING: Use of uninitialized value $nameOrConf in -f at .../SerialPort.pm line 285.
2017.08.15 21:31:05 1: PERL WARNING: Use of uninitialized value in subroutine entry at .../SerialPort.pm line 311.
2017.08.15 21:31:05 3: Can't open : No such file or directory
aber keine Rueckgabe im Frontend, und MQTT wird angelegt. Optimal faende ich in solchen Faellen eine sinnvolle Rueckgabe (usage) und eine Option "none" fuer Leute wie mich, also ohne Broker.
Danach habe ich KE.th wie vorhin angegeben definiert.
Auf das gezeigte Reading konnte ich nicht klicken, aber ein klick aufs Attribut hat bei mir auch den gleichen Fehler verursacht. Ursache: in der Rueckgabewert von "attr KE.th ?" kommt dieses Attribut nicht vor, nur indirekt als  subscribeReading_.*
Ich habe diese Sorte von Problemen in fhemweb.js jetzt gefixt, das Attribut wird zur Liste hinzugefuegt, falls es noch nicht vorhanden ist.
Rampler
Klar, meinte natürlich Attribut....
Super, dann werde ich morgen mal testen ..  ==> Danke
VG
Klaus
