[SOLVED] EnOcean XML functions are not available
Begonnen von claudio, 04 März 2018, 03:44:55
claudio
Hi all
I need your help once again guys !
recently, I got theses message in the logfile :
2018.03.04 02:29:57 2: EnOcean XML functions are not available.
2018.03.04 02:29:59 2: EnOcean EnO_switch_FSB14 XML functions are not available
2018.03.04 02:29:59 2: EnOcean FSR14_01_A XML functions are not available
2018.03.04 02:29:59 2: EnOcean FSR14_01_B XML functions are not available
2018.03.04 02:29:59 2: EnOcean FSR14_02_A XML functions are not available
2018.03.04 02:29:59 2: EnOcean FSR14_02_B XML functions are not available
2018.03.04 02:29:59 2: EnOcean FSR14_03_A XML functions are not available
2018.03.04 02:29:59 2: EnOcean FSR14_03_B XML functions are not available
2018.03.04 02:29:59 2: EnOcean FSR14_04_A XML functions are not available
2018.03.04 02:29:59 2: EnOcean FSR14_04_B XML functions are not available
2018.03.04 02:29:59 2: EnOcean FSR14_05_A XML functions are not available
2018.03.04 02:29:59 2: EnOcean FSR14_05_B XML functions are not available
2018.03.04 02:29:59 2: EnOcean FSR14_06_A XML functions are not available
2018.03.04 02:29:59 2: EnOcean FSR14_06_B XML functions are not available
EnOcean appear to work correctly until this afternoon when I've tried to add some new eltako FSR14-2x to my cabinet.
The teach in wouldn't work
set FSR14_05_B teach produce nothing, the FSR14-2x don't receive anything. The exact same procedure worked before.
Have you any ideas of the problem ?
You did not installed XML::Simple.
Dont know about the consequences, though.
claudio
Hi thanks for your suggestion.
Since I can't get it to work, I've reinstalled perl entirely. This is what I did for future reference (as I will forget it) :
PS : please note this was done on an arm router (tomato shibby firmware) where fhem and entware-ng are installed.
others systems may behave differently.
#first update the package list
opkg update
#install perl from scratch from entware-ng
opkg install perlbase-cpan
opkg install perlbase-devel
opkg install perlbase-data
opkg install perlbase-compress
opkg install perlbase-perlio
opkg install perlbase-json-pp
opkg install perlbase-digest
opkg install perlbase-math
opkg install perl-uri
opkg install perl-cgi
opkg install perl-dev
opkg install perl-www
opkg install perlbase-dumpvalue
#this will install most perl related stuff from entware-ng
for pkg in `opkg list | grep perl | cut -d' ' -f1 | grep -v Multiple`; do opkg install $pkg; done
#json is required by many modules
cpanm -n install JSON
#IO::Socket::SSL is required by telegram module
cpanm -n install IO::Socket::SSL
#unzip is required since busybox unzip doesn't have all options
opkg install unzip
#Math::Pari, Crypt::Rijndael, Crypt::Random are required for enocean Cryptographic functions
cpanm -n install Math::Pari
cpanm -n install Crypt::Rijndael
cpanm -n install Crypt::Random
opkg install xmlstarlet
#required by enocean stuff
cpanm -n install XML::Simple
