Autor Thema: Lupus Alarmanlage mit Httpmod/JSON auslesen  (Gelesen 222 mal)
Offline stenny
  • Jr. Member
« am: 07 Oktober 2018, 12:29:42 »
Hallo
Versuche gerade eine Lupus Alarmanlage (XT1+) mit HttpMod auszulesen.
Der Status Funktioniert ohne Fehler
  "updates" : {
    "mode_a1" : "{AREA_MODE_1}",
    "mode_a2" : "{AREA_MODE_1}",
    "dc_ex" : "1",
    "alarm_ex" : "0",
    "battery_ex" : "1",
    "battery_ok" : "1",
    "battery" : "{WEB_MSG_NORMAL}",
    "tamper_ok" : "1",
    "tamper" : "{WEB_MSG_NORMAL}",
    "interference_ok" : "1",
    "interference" : "{WEB_MSG_NORMAL}",
    "ac_activation_ok" : "1",
    "ac_activation" : "{WEB_MSG_NORMAL}",
    "sys_in_inst": "",
    "rssi" : "1",
    "sig_gsm_ok" : "1",
    "sig_gsm" : "{WEB_MSG_NA}"
  "forms" : {
    "pcondform1" : {
      "mode" : "1",
      "f_arm" : "0"
    "pcondform2" : {
      "mode" : "1",
      "f_arm" : "0"
Nur bei den Sensoren werden über extractAllJSON 1 keine Readings erstellt
  "senrows": [
{"area": 1, "zone": 1, "type": 37, "type_f": "{D_TYPE_37}", "name": "Eingang",
"cond": "", "cond_ok": "1", "battery": "", "battery_ok": "1",
"tamper": "", "tamper_ok": "1", "bypass": 0, "rssi": "{WEB_MSG_STRONG} 9",
"resp_mode": [0,5,5,5,5,0], "ammeter": "0", "ver": "",
"hue": "-1", "sat": "-1", "bypass_tamper": 0,
"status": "", "sid": "RF:0073ed70", "su": 0, "alarm_status": "", "status_ex": "0"},
{"area": 2, "zone": 1, "type": 9, "type_f": "{D_TYPE_9}", "name": "BM Treppenhaus",
"resp_mode": [0,0,0,0,0,0], "ammeter": "0", "ver": "",
"status": "", "sid": "RF:04435330", "su": 1, "alarm_status": "", "status_ex": "0"},
{"area": 1, "zone": 2, "type": 4, "type_f": "{D_TYPE_4}", "name": "Wohnungstür",
"resp_mode": [3,1,1,1,1,0], "ammeter": "0", "ver": "",
"status": "{WEB_MSG_DC_CLOSE}", "sid": "RF:04993310", "su": 1, "alarm_status": "", "status_ex": "0"}]
Im Log erhalte ich
2018.10.07 12:14:02 5: HttpUtils https://xxx:xxx@ip/action/deviceListGet: Got data, length: 1260
2018.10.07 12:14:02 5: HttpUtils response header:
HTTP/1.0 200 OK
Server: Mongoose
Pragma: no-cache
Cache-control: no-cache
Expires: 0
Content-Type: application/json; charset=utf-8
2018.10.07 12:14:02 4: Alarmanlage_device: Read callback: request type was update retry 0,
Body: {
  "senrows": [
2018.10.07 12:14:02 3: Alarmanlage_device: error while parsing JSON data: invalid character encountered while parsing JSON string, at character offset 230 (before "\t9", \n"resp_mode":...") at (eval 2730) line 1.
2018.10.07 12:14:02 5: Alarmanlage_device: ExtractSid called, context reading, num
2018.10.07 12:14:02 4: Alarmanlage_device: CheckAuth decided no authentication required
2018.10.07 12:14:02 3: Alarmanlage_device: no parsed JSON structure available
2018.10.07 12:14:02 5: Alarmanlage_device: Read starts parsing response to update with defined readings:
2018.10.07 12:14:02 3: Alarmanlage_device: Read response to update didn't match any Reading
2018.10.07 12:14:02 5: Alarmanlage_device: HandleSendQueue called, qlen = 0
List....
   BUSY       0
   CHANGED
   DEF        https://xxx:xxx@ip/action/deviceListGet 60
   Interval   60
   JSONEnabled 1
   LASTSEND   1538907961.40994
   MainURL    https://xxx:xxx3de@ip/action/deviceListGet
   ModuleVersion 3.5.1 - 5.7.2018
   NAME       Alarmanlage_device
   NR         530
   STATE      ???
   TRIGGERTIME 1538908021.40683
   TRIGGERTIME_FMT 2018-10-07 12:27:01
   TYPE       HTTPMOD
   addr       https://ip
   auth       1
   code       200
   compress   1
   conn
   data
   displayurl https://xxx:xxx@ip/action/deviceListGet
   header
   host       192.168.2.198
   httpheader HTTP/1.0 200 OK
Server: Mongoose
Pragma: no-cache
Expires: 0
   httpversion 1.0
   hu_blocking 0
   hu_filecount 33
   hu_port    443
   hu_portSfx
   ignoreredirects 0
   loglevel   4
   path       /action/deviceListGet
   protocol   https
   pwd        L563fbe3de
   redirects  0
   timeout    2
   user       ckuntze
   value      0
   Helper:
     DBLOG:
       state:
         DBLogging:
           TIME       1538907271.62737
           VALUE      reread
   QUEUE:
   REQUEST:
     data
     header
     ignoreredirects 0
     retryCount 0
     type       update
     value      0
   sslargs:
   enableControlSet 1
   enforceGoodReadingNames 1
   extractAllJSON 1
   room       Lupus
   verbose    5
Wenn ich die Regex umgehen könnte würde es später einfacher wenn alle Sensoren angelernt wären.....
Für Hilfe oder Ideen wäre ich dankbar
Carsten
Offline Rudibarani
  • New Member
Antw:Lupus Alarmanlage mit Httpmod/JSON auslesen
« Antwort #1 am: 06 Januar 2019, 23:50:53 »
Hallo Carsten,
ich habe das bei mir so gelöst:
define Alarmanlage HTTPMOD http://***user***:***password***@192.0.0.140/action/panelCondGet 30
attr Alarmanlage userattr get01Name get01Poll:0,1 get01URL getEncode reading01JSON reading01Name reading01OMap reading02JSON reading02Name reading02OMap reading03JSON reading03Name reading03OMap reading04JSON reading04Name reading04OMap reading05JSON reading05Name reading05OMap reading06JSON reading06Name reading06OMap reading07JSON reading07Name reading07OMap reading08JSON reading08Name reading08OMap readingEncode
attr Alarmanlage enableControlSet 1
attr Alarmanlage event-on-change-reading .*
attr Alarmanlage getEncode UTF-8
attr Alarmanlage icon building_security
attr Alarmanlage reading01JSON forms_pcondform1_mode
attr Alarmanlage reading01Name Modus_Nacht
attr Alarmanlage reading01OMap 0:Aus, 1:Scharf, 2:Nacht
attr Alarmanlage reading02JSON forms_pcondform2_mode
attr Alarmanlage reading02Name Modus_Abwesend
attr Alarmanlage reading02OMap 0:Aus, 1:Scharf, 2:Nacht
attr Alarmanlage reading03JSON updates_alarm_ex
attr Alarmanlage reading03Name Alarm_Status
attr Alarmanlage reading03OMap 0:OK, 1:Alarm
attr Alarmanlage reading04JSON updates_ac_activation_ok
attr Alarmanlage reading04Name Strom_Status
attr Alarmanlage reading04OMap 1:OK, 0:Stromausfall
attr Alarmanlage reading05JSON updates_tamper_ok
attr Alarmanlage reading05Name Sabotage
attr Alarmanlage reading05OMap 1:OK, 0:Sabotagealarm
attr Alarmanlage reading06JSON updates_battery_ok
attr Alarmanlage reading06Name Batterie
attr Alarmanlage reading06OMap 1:OK, 0:Batterie schwach
attr Alarmanlage reading07JSON updates_sig_gsm_ok
attr Alarmanlage reading07Name GSM_Status
attr Alarmanlage reading07OMap 1:OK, 0:GSM Verbindungsfehler
attr Alarmanlage reading08JSON updates_interference_ok
attr Alarmanlage reading08Name Signalinterferenz
attr Alarmanlage reading08OMap 1:OK, 0:Funktstörung
attr Alarmanlage readingEncode UTF-8
attr Alarmanlage room System,Haus
attr Alarmanlage stateFormat EG: Modus_Nacht | Info: Modus_Abwesend | Status: Alarm_Status | GSM: GSM_Status
#Aktoren Alarmanlage
define Alarmanlage_SmartHome HTTPMOD http://***USER***:***PASSWORD***@192.0.0.140/action/deviceListGet 30
attr Alarmanlage_SmartHome userattr getEncode readingEncode
attr Alarmanlage_SmartHome enableControlSet 1
attr Alarmanlage_SmartHome event-on-change-reading .*
attr Alarmanlage_SmartHome extractAllJSON 1
attr Alarmanlage_SmartHome getEncode UTF-8
attr Alarmanlage_SmartHome icon security
attr Alarmanlage_SmartHome preProcessRegex s/\"rssi\"\: \"\D*\t/\"rssi\"\: \"/g
attr Alarmanlage_SmartHome readingEncode UTF-8
attr Alarmanlage_SmartHome room System
attr Alarmanlage_SmartHome stateFormat lastReading
Schau mal, wie weit Du damit kommst. Bei den Autoren musst Du eine nicht Standard-konforme JSON-Implementierung von Lupus Electronics fixen, bevor Du das extractAllJSON durchführen kannst. Dafür gibt es die Option preProcessRegex.
decade-submarginal
