mqtt2.template für RFbridge von Sonoff entwickeln
Begonnen von Tueftler1983, 27 März 2019, 10:02:44
Tueftler1983
in diesem Thead soll ein template entwickelt werden um die Sonoff RFBridge gescheit unter MQTT2 anzubinden.
Beta-User und ich beginnen hier mal aber sind für Unterstützung offen und dankbar!
Tueftler1983
#1
So in der Konsole von der RFbridge steht das....
19:35:26 MQT: /SmartHome/Interface/Bridge/tele/LWT = online (beibehalten)
19:35:26 MQT: /SmartHome/Interface/Bridge/cmnd/POWER =
19:35:26 MQT: /SmartHome/Interface/Bridge/tele/INFO1 = {"Module":"Sonoff Bridge","Version":"5.12.0","FallbackTopic":"RFbridge","GroupTopic":"sonoffs"}
19:35:26 MQT: /SmartHome/Interface/Bridge/tele/INFO2 = {"WebServerMode":"Admin","Hostname":"Sonoff","IPAddress":"192.168.2.50"}
19:35:26 MQT: /SmartHome/Interface/Bridge/tele/INFO3 = {"RestartReason":"Software/System restart"}
19:35:34 MQT: /SmartHome/Interface/Bridge/tele/STATE = {"Time":"2019.03.26 19:35:34","Uptime":"0 00:00:13","Vcc":3.471,"Wifi":{"AP":1,"SSId":"FRITZ!Box 6360 Cable Holger","RSSI":68,"APMac":"C8:0E:14:xx:xx:xx"}}
19:44:21 MQT: /SmartHome/Interface/Bridge/tele/RESULT = {"RfReceived":{"Sync":12460,"Low":440,"High":1250,"Data":"128489","RfKey":"None"}}
Dazu das im MQTT2_MQTT2CLIENT
MQTT2Client:/SmartHome/Interface/Bridge/tele/LWT:.* LWT
MQTT2Client:/SmartHome/Interface/tele/sonoff/LWT:.* LWT
MQTT2Client:/SmartHome/Interface/Garten/tele/LWT:.* LWT
MQTT2Client:/SmartHome/Interface/Spuelmaschine/tele/LWT:.* LWT
MQTT2Client:/SmartHome/Interface/Trockner/tele/LWT:.* LWT
MQTT2Client:/SmartHome/Interface/Spuelmaschine/tele/UPTIME:.* { json2nameValue($EVENT) }
MQTT2Client:/SmartHome/Interface/Garten/tele/UPTIME:.* { json2nameValue($EVENT) }
MQTT2Client:/SmartHome/Interface/Trockner/tele/UPTIME:.* { json2nameValue($EVENT) }
MQTT2Client:/SmartHome/Interface/Bridge/tele/UPTIME:.* { json2nameValue($EVENT) }
MQTT2Client:/SmartHome/Interface/Bridge/tele/STATE:.* { json2nameValue($EVENT) }
MQTT2Client:/SmartHome/Interface/Bridge/tele/RESULT:.* { json2nameValue($EVENT) }
Habe dann in der über autocreate angelegten RFbridge 2 Readings hinzugefügt (die zwei unteren Zeilen)
/SmartHome/Interface/Bridge/cmnd/POWER:.* POWER
/SmartHome/Interface/Bridge/tele/INFO1:.* { json2nameValue($EVENT) }
/SmartHome/Interface/Bridge/tele/INFO2:.* { json2nameValue($EVENT) }
/SmartHome/Interface/Bridge/tele/INFO3:.* { json2nameValue($EVENT) }
So und noch die Raw Definition der RFbridge
defmod MQTT2_Bridge MQTT2_DEVICE Bridge
attr MQTT2_Bridge IODev MQTT2_Client
attr MQTT2_Bridge readingList /SmartHome/Interface/Bridge/cmnd/POWER:.* POWER\
/SmartHome/Interface/Bridge/tele/INFO1:.* { json2nameValue($EVENT) }\
/SmartHome/Interface/Bridge/tele/INFO2:.* { json2nameValue($EVENT) }\
/SmartHome/Interface/Bridge/tele/INFO3:.* { json2nameValue($EVENT) }\
/SmartHome/Interface/Bridge/tele/RESULT:.* { json2nameValue($EVENT) }\
attr MQTT2_Bridge room MQTT2_DEVICE
setstate MQTT2_Bridge 2019-03-26 19:35:27 FallbackTopic RFbridge
setstate MQTT2_Bridge 2019-03-26 19:35:27 GroupTopic sonoffs
setstate MQTT2_Bridge 2019-03-26 19:35:27 Hostname Sonoff
setstate MQTT2_Bridge 2019-03-26 19:35:27 IPAddress 192.168.2.50
setstate MQTT2_Bridge 2019-03-26 19:35:27 Module Sonoff Bridge
setstate MQTT2_Bridge 2019-03-26 19:35:27 POWER
setstate MQTT2_Bridge 2019-03-26 19:35:27 RestartReason Software/System restart
setstate MQTT2_Bridge 2019-03-27 10:11:18 RfReceived_Data 100401
setstate MQTT2_Bridge 2019-03-27 10:11:18 RfReceived_High 900
setstate MQTT2_Bridge 2019-03-27 10:11:18 RfReceived_Low 350
setstate MQTT2_Bridge 2019-03-27 10:11:18 RfReceived_RfKey None
setstate MQTT2_Bridge 2019-03-27 10:11:18 RfReceived_Sync 10590
setstate MQTT2_Bridge 2019-03-27 08:55:34 Time 2019.03.27 08:55:33
setstate MQTT2_Bridge 2019-03-27 08:55:34 Uptime 0 13:20:13
setstate MQTT2_Bridge 2019-03-27 08:55:34 Vcc 3.471
setstate MQTT2_Bridge 2019-03-26 19:35:27 Version 5.12.0
setstate MQTT2_Bridge 2019-03-26 19:35:27 WebServerMode Admin
setstate MQTT2_Bridge 2019-03-27 08:55:34 Wifi_AP 1
setstate MQTT2_Bridge 2019-03-27 08:55:34 Wifi_APMac C8:0E:14:55:25:98
setstate MQTT2_Bridge 2019-03-27 08:55:34 Wifi_RSSI 66
setstate MQTT2_Bridge 2019-03-27 08:55:34 Wifi_SSId FRITZ!Box 6360 Cable Holger
setstate MQTT2_Bridge 2019-03-26 19:35:27 associatedWith MQTT2_GeneralBridge
Tueftler1983
In den Readings sind die für mich wichtigen Daten enthalten, das ist das RfReceived_Data das ist das empfangene Funksignal über das ich Events auslösen kann. Ich weiß nicht welche Daten noch benötigt werden.
So, also ausgehend von der Info ist das Ergebnis in etwa so:19:44:21 MQT: /SmartHome/Interface/Bridge/tele/RESULT = {"RfReceived":{"Sync":12460,"Low":440,"High":1250,"Data":"128489","RfKey":"None"}}Aus dem template zur tasmota-IR (A_01d_tasmota_ir) wissen wir, dass bei Ir folgendes funktioniert:
tele/DEVNAME/RESULT:.* { $EVENT =~ m,..IrReceived....Protocol...([A-Za-z0-9]+)...Bits..([\d]+)..Data...([A-Za-z0-9]+)..., ? {"$1_$2"=>$3} : json2nameValue($EVENT) }
Das bildet für jede Protokoll-Bit-Kombination jeweils ein neues Reading und schreibt die Data-Information da rein.
Daraus leite ich mal folgenden Test für die readingList ab:
/SmartHome/Interface/Bridge/tele/RESULT:.* { $EVENT =~ m,..RfReceived....Sync..([A-Za-z0-9]+)..Low..([\d]+)..High..([\d]+)..Data...([A-Za-z0-9]+)...RfKey...([^"]+)..., ? {"$1_$2_$3"=>$4_$5} : json2nameValue($EVENT) }
Kannst du das mal testen und ggf. verbessern? Die Herleitung ist hoffentlich einigermaßen nachvollziehbar...
Tueftler1983
Also das läst sich so nicht in der readingList speichern, gibt einen Syntax error.
syntax error at (eval 535909) line 1, near "$4_"
syntax error at (eval 535909) line 1, near "}}"
Tueftler1983
Diese Readings werden ja schon gebildet:
RfReceived_Data
775151
2019-03-27 07:08:55
RfReceived_High
460
2019-03-27 07:08:55
RfReceived_Low
150
2019-03-27 07:08:55
RfReceived_RfKey
None
2019-03-27 07:08:55
RfReceived_Sync
5070
Durch diese Zeile in der readingList
Tueftler1983
Gut das hat er geschluckt, neue Readings werden aber keine angelegt beim Empfang eines Signales
Zitat von: Beta-User am 27 März 2019, 10:42:12
Dann mach mal Anführungszeichen drumrum:"$4_$5"
Neuer Versuch; ich würde auf den "None"-Teil der regex als Problem tippen, das kann aber auch was anderes sein...
/SmartHome/Interface/Bridge/tele/RESULT:.* { $EVENT =~ m,..RfReceived....Sync..([A-Za-z0-9]+)..Low..([\d]+)..High..([\d]+)..Data...([A-Za-z0-9]+)...RfKey...(None)..., ? {"$1_$2_$3"=>"$4_$5"} : json2nameValue($EVENT) }
Ändere das mal bitte:/SmartHome/Interface/Bridge/tele/RESULT:.* {RfReceived=>encode_json(decode_json($EVENT)->{RfReceived})}
Damit sollten wir erkennen, was bei der anderen verabeitungsmäßig durchläuft (die andere macht Einzelreadings, wenn die regexp nicht paßt), diese hier sollte "den inneren JSON" in ein neues Readings schreiben.
Tueftler1983
Also das bringt noch nen Syntax fehler
/SmartHome/Interface/Bridge/tele/RESULT:.* { $EVENT =~ m,..RfReceived....Sync..([A-Za-z0-9]+)..Low..([\d]+)..High..([\d]+)..Data...([A-Za-z0-9]+)...RfKey...(None)..., ? {"$1_$2_$3"=>"$4_$5"}}
Was meinst du jetzt?
Soll ich die zeile löschen
Und durch diese ersetzen?
Das mit dem Syntaxfehler muß ich mir in Ruhe ansehen (der ":" und die nachfolgende Funktion fehlen mit Absicht?).
Dann verwende für die "RESULT"-Zeile nur noch einen Eintrag.
Wenn das hier geht, dann das:
/SmartHome/Interface/Bridge/tele/RESULT:.* { $EVENT =~ m,..RfReceived.*, ? {RfReceived=>encode_json(decode_json($EVENT)->{RfReceived})} : json2nameValue($EVENT) }
Sonst:/SmartHome/Interface/Bridge/tele/RESULT:.* {RfReceived=>encode_json(decode_json($EVENT)->{RfReceived})}
Tueftler1983
Also der code läuft und erzeugt für jeden empfangenen code ein eigenes Reading
Habe mal Screenshot von den Readings und der readingList gemacht
Hmm, da paßt irgendwas nicht zusammen...
Die Readingnamen mit "Zahl1_Zahl2_Zahl3" und die Readings selbst passen zu dem Code, den ich bis 11:00 Uhr gepostet hatte, vermutlich noch ohne den "None"-Text, aber mit Anführungszeichen.
Jedenfalls paßt es nicht zu dem aktuellen. Der müßte ein Reading mit Namen RfReceived bilden und da einen JSON reinschreiben.
Bitte nochmal alle Readings löschen, und dann die Schritte ab Einführung der Anführungszeichen nochmal durchgehen (nur ein Eintrag für RESULT), dabei das Browserfenster nach dem Senden des RF-Codes aktualisieren. Bitte bei dem Schritt anhalten, der Readings in obigem Format liefert, wenn es sowas gibt...
Dann: RfKey scheint für was "bekanntes" zu stehen, wenn er nicht None ist. Kannst du so eine mal drücken und den MQTT-Verkehr dazu (eigentlich: den JSON) zeigen?
Tueftler1983
#14
Also diese Definition
/SmartHome/Interface/Bridge/tele/RESULT:.* { $EVENT =~ m,..RfReceived....Sync..([A-Za-z0-9]+)..Low..([\d]+)..High..([\d]+)..Data...([A-Za-z0-9]+)...RfKey...([^"]+)..., ? {"$1_$2_$3"=>"$4_$5"} : json2nameValue($EVENT) }
Liefert das Reading wenn ein Signal empfangen wird
5130_150_470
775544_None
RFkey ist, man kann in der Bridge 15 Keys anlernen. Also wie eine frei programmierbare Funkfernbedienung. Habe ich aber keine da ich mit der Bridge nur Signale Empfange aber keine Sende
