max radiator valve RSSI
Begonnen von malc_b, 14 Januar 2017, 19:44:42
malc_b
In fhem the max radiator valve has something called RSSI.  What is that?
malc_b
#2
Thanks.  I had assumed that RSSI was some max parameter and not a standard term.  Dunno why I thought that, DOH!
Update:  Do you know what the figures mean?  What is a good level and what is not?
SibbeH
#3
Hi malc_b
In the figure you see a lot of RSSI-levels of my MAX radiatorvalves (MAX_CV) and some wallthermostats (MAX_WT).
I think all levels are good (I have no problems) but de levels must not below -85 dB.
SibbeH
Raspberry Pi, CULV3, 3xCUNO, MAX Thermostat, MAX Wandthermostat, HM, HmIP. UWZ, WeekProfile
malc_b
