[solved]Fan control problem
Begonnen von H3nr1, 07 Mai 2016, 01:21:30
H3nr1
Hello, i wan't to control my fan. When there is more humidity in my bathroom i wan't the fan to go harder.
DEF
([DS2438_A0608D010000:humidity] > 60) DOELSEIF ([DS2438_A0608D010000:humidity] > 50) DOELSE (set ventilation dim 50|35|25
But the last part doesn't work. Who can help me or is there another way of doing this?
Thanks
chris1284
first i would test it like the commandref explains it:
DOIF ([DS2438_A0608D010000:humidity] > 60) (set ventilation dim 50)
DOELSEIF ([DS2438_A0608D010000:humidity] > 50) (set ventilation dim 35)
DOELSE (set ventilation dim 25)
when this is running you can try to shorten the definition
H3nr1
Thanks Chris this solution works  ;D
