FHEM => Automatisierung => Thema gestartet von: baukater am 19 Dezember 2016, 18:00:17
Titel: CUL HOERMANN - und welcher gehört jetzt mir :-)
Beitrag von: baukater am 19 Dezember 2016, 18:00:17
Bekomme seit gestern ständig neue Hörmann-Tore dazu. So viele Garagen gibt es hier gar nicht.
CUL_HOERMANN_2527e40000
Defined
CUL_HOERMANN_2527e40018
Defined
CUL_HOERMANN_2527e4005f
Defined
CUL_HOERMANN_2527e50000
Defined
CUL_HOERMANN_2527e50016
Defined
CUL_HOERMANN_2527e50017
Defined
CUL_HOERMANN_2527e50018
Defined
CUL_HOERMANN_2527e50019
Defined
CUL_HOERMANN_2527e50344
Defined
CUL_HOERMANN_2527e60000
Defined
CUL_HOERMANN_2527e60015
Defined
CUL_HOERMANN_2527e60016
Defined
CUL_HOERMANN_2527e60017
Defined
CUL_HOERMANN_2527e60018
Defined
CUL_HOERMANN_2527e60019
Defined
CUL_HOERMANN_2527e70000
Defined
CUL_HOERMANN_2527e70014
Defined
CUL_HOERMANN_2527e70015
Defined
CUL_HOERMANN_2527e70016
Defined
CUL_HOERMANN_2527e70017
Defined
CUL_HOERMANN_2527e70018
Defined
CUL_HOERMANN_2527e70019
Defined
CUL_HOERMANN_2527e80000
Defined
CUL_HOERMANN_2527e80014
Defined
CUL_HOERMANN_2527e80015
Defined
CUL_HOERMANN_2527e80016
Defined
CUL_HOERMANN_2527e80017
Defined
CUL_HOERMANN_2527e80018
Defined
CUL_HOERMANN_2527e80019
Defined
CUL_HOERMANN_2527e8035f
Defined
CUL_HOERMANN_2527e90000
Defined
CUL_HOERMANN_2527e9000b
Defined
CUL_HOERMANN_2527e90014
Defined
CUL_HOERMANN_2527e90015
Defined
CUL_HOERMANN_2527e90016
Defined
CUL_HOERMANN_2527e90017
Defined
CUL_HOERMANN_2527e90018
Defined
CUL_HOERMANN_2527e90019
Defined
CUL_HOERMANN_2527ea0000
Defined
CUL_HOERMANN_2527ea0004
Defined
CUL_HOERMANN_2527ea0014
Defined
CUL_HOERMANN_2527ea0015
Defined
CUL_HOERMANN_2527ea0016
Defined
CUL_HOERMANN_2527ea0017
Defined
CUL_HOERMANN_2527ea0018
Defined
CUL_HOERMANN_2527ea0019
Defined
CUL_HOERMANN_2527ea001b
Defined
CUL_HOERMANN_2527ea0026
Defined
CUL_HOERMANN_2527eb0000
Defined
CUL_HOERMANN_2527eb000e
Defined
CUL_HOERMANN_2527eb0014
Defined
CUL_HOERMANN_2527eb0015
Defined
CUL_HOERMANN_2527eb0016
Defined
CUL_HOERMANN_2527eb0017
Defined
CUL_HOERMANN_2527eb0018
Defined
CUL_HOERMANN_2527eb0019
Defined
CUL_HOERMANN_2527ec0000
Defined
CUL_HOERMANN_2527ec0014
Defined
CUL_HOERMANN_2527ec0015
Defined
CUL_HOERMANN_2527ec0016
Defined
CUL_HOERMANN_2527ec0017
Defined
CUL_HOERMANN_2527ec0018
Defined
CUL_HOERMANN_2527ed0000
Defined
CUL_HOERMANN_2527ed0017
Defined
CUL_HOERMANN_2527ee0000
Defined
CUL_HOERMANN_BF01000010
Defined
Titel: Antw:CUL HOERMANN - und welcher gehört jetzt mir :-)
Beitrag von: rudolfkoenig am 19 Dezember 2016, 18:20:59
Sind vmtl. entfernte Tore, leider kann FHEM/culfw kein Checksum fuer Hoermann berechnen.
Lust auf Algorithmus raten?
Ich habe erst die wichtigen identifiziert/definiert, falsche geloescht und danach das Anlegen von Neuen mit "attr autocreate ignoreTypes CUL_HOERMANN.* unterbunden.
Beitrag von: baukater am 19 Dezember 2016, 23:04:48
Ok, dann mal schauen, was mein Tor sein kann. Wie weit entfernt kann der CUL denn Signale empfangen? Es scheint mir, dass hier mehr Hörrmann-Tore rumstehen, als es hier Häuser gibt. Kann ich mir echt nicht vorstellen.  :D
Beitrag von: RaspiLED am 17 Februar 2017, 20:49:29
also mein Handsender hat 4 Tasten und sendet vier Codes die sich jeweils in den letzten drei Stellen unterscheiden.
Aber ich habe auch Logfiles definiert, da wird ja mit Zeitstempel erfasst. So dass ich mit der Fernbedienung neben dem Rechner entspannt sehe, welche Taste welchen Code als Toggle auslöst.
Leider bewirkt der toggle am Hörmann Device nicht, dass das Tor sich in Bewegung setzt.
Geht das bei Euch? (Neueste CUL FW 868Mhz selbst compiliert und Hoermann aktiviert)
Gruß Arnd
Beitrag von: rudolfkoenig am 17 Februar 2017, 21:06:00
Ja, meins kann ich relativ zuverlaessig oeffnen. Des Nachbars habe ich noch nicht versucht, das Empfange ich nur.
Beitrag von: RaspiLED am 17 Februar 2017, 22:09:56
Hi Rudolf,
ich schaffe leider noch keine Bewegung meines Supramatic E! Was bedeutet relativ bei Dir?
Wer hat denn das Modul  gebaut? Ich würde gerne helfen.
Gruß Arnd
Raspi2 mit FHEM, CUL, MySensor, HomeBridge, Presence, Bravia, ...
Beitrag von: Michael am 18 Februar 2017, 09:35:33
Moin RaspiLED
Hier kannst du den Modul Entwickler (Betreuter) finden.
https://fhem.de/MAINTAINER.txt (https://fhem.de/MAINTAINER.txt)
Und in diesen Fall ist es :
FHEM/18_CUL_HOERMANN.pm      rudolfkoenig         http://forum.fhem.de SlowRF   :)
Beitrag von: RaspiLED am 18 Februar 2017, 11:08:09
Hi, Danke! Was für ein Zufall gelle ;-) Rudolf welches Hörmann Gerät hast Du genau?
Gruß Arnd
Beitrag von: rudolfkoenig am 18 Februar 2017, 12:20:31
ZitatRudolf welches Hörmann Gerät hast Du genau?
Kann ich dir nicht genau sagen, steht auf dem Geraet/Fernbedienung nicht darauf, und in der Anleitung stehen mehrere Typangaben, da sie wohl fuer mehrere gilt. Die Fernbedienung ist haesslich, eckig und grau, mit blauen Knoepfen. Blau steht wohl fuer 868MHz, gruen fuer 433. Ist ueber 10 Jahre alt.
Wenn du die Fernbedienung so 3-4 Meter vom CUL entfernt drueckst, muesste das CUL eigentlich ein sauberes Signal empfangen. Dieses wuerde ich definieren und senden.
"relativ" bedeutet: ca 5-mal zum Testen geschaltet, da hat es einmal nicht geklappt, und 3-mal als "Notschalter" z.Bsp. aus der Ferne, dabei hat es immer geklappt. Bin nicht wirklich geneigt 100 Schaltvorgaenge durchzufuehren, um zu zaehlen :)
Beitrag von: RaspiLED am 18 Februar 2017, 12:28:02
ja die FB habe ich auch und noch 3 andere FB, die diese Signale clonen können!
Ich meinte eher Deinen tatsächlichen Garagenöffner. Z.B. https://www.tor7.de/hoermann-supramatic-e-garagentorantrieb-serie-3-bisecur
Gruß Arnd
Beitrag von: Ranseyer am 18 Februar 2017, 20:02:30
hier habe ich mal ausführlich geforscht da ich auch eine Supramatic habe:
https://forum.fhem.de/index.php/topic,62657.msg544256.html#msg544256
Mich würde z.B. der Status vom Tor interessieren.
Ich denke hier geht nichts / wenig aufgrund der einigermaßen verfügbaren Sicherheit. Hier im Forum gabs mal einen Thread mit der Aussage dass jemand nen Key aus ~"einer Software" extrahiert hat. Ich habe dazu mal schnell die Android App inspiziert und kein direkt offensichtliches Problem gefunden. Also nicht nur ein simpler Key direkt in der App welcher dann an das Hörman Gateway gesendet wird. Eine Firmware für das Hörmann Gateway habe ich soweit ich das noch weiß damals nicht gefunden.
Welche FBs die Hörman-Signale clonen können, würde mich minimal interessieren. Man könnte damit dann steuern (gefällt mir nicht!), oder Angriffsvektoren suchen...
Beitrag von: SamNitro am 27 Februar 2017, 15:36:12
die "einfache" Hörmann Geräte werden bei mir per autocreate eingelesen, leider ist das Tor von meinem Schwiegervater der 15km entfernt wohnt und daher kann ich das leider nicht testen..
Ich habe ein ProMatic 3 Bisecur, da wird nix erkannt, kann es sein dass das tor nicht unterstützt wird bzw nicht per autocreate erfasst wird?
Beitrag von: RaspiLED am 03 August 2017, 23:48:26
Können hier noch einige von Euch helfen?
https://forum.fhem.de/index.php/topic,71877.msg655021.html#msg655021
Gruß Arnd
Beitrag von: Ranseyer am 04 August 2017, 07:48:34
Fürchte nicht... Und sehe ich das richtig ?
M.E. geht bei bisecure Toren gar nichts:
-kein clonen der FB (https://de.aliexpress.com/item/Hormann-HSM2-868-HSM4-868mhz-replacement-remote-control-top-quality/32721318974.html)
-kein exakter Empfang des Status
-auf gar keinen Fall Steuerung des Tors (zumindest ohne gewissen Keys)
Beitrag von: RaspiLED am 04 August 2017, 08:48:45
Hi Martin,
Ich denke im Moment es gibt mehrere Hörmann Systeme:
1) >20 Jahre alt, 433 MHz, orange Tasten FB, keine FHEM Unterstützung
2) >10 Jahre alt, 868 MHz, blaue Tasten FB, toggle geht zum öffnen/schliessen per CUL, aktuelle Tests mit Signalduino,
3) >4 Jahre alt, 868 MHz, blaue Tasten FB (gleich zu 2), wird gehört, aber toggle bewirkt nichts, aktuelle Tests mit Signalduino, zB. Supramatic
4) aktuell, 868 MHz, schwarze Tasten FB mit Encryption oder Signierung (zB. HSE 1 BiSecur), bisher keine Unterstützung in FHEM, zB. Supramatic BiSecur oder HET/S 2 BS
Beitrag von: SamNitro am 04 August 2017, 10:52:28
Mein Garagentor hat einen Eingang für einen potentialfreien Kontakt und eine Anzeige für Garagentor zu...
Habe einen Nodemcu mit Relais dran gehangen nun kann ich das Tor steuern und mir anzeigen lassen ob das Tor auf oder zu ist.
Nodemcu + Relais ca 5-7€
Anzeige für Tor auf oder zu da leider 24v ein eltako 27€
Beitrag von: RaspiLED am 04 August 2017, 12:32:14
Aha, aber Dein Garagentor ist bestimmt auch kein Hörmann, da ist ein potentialfreier Kontakt mit Status offen/zu nur über UAP1 (ca. 67€) nachrüstbar.
Gruß Arnd
Beitrag von: SamNitro am 04 August 2017, 12:34:49
Doch ich habe das Hörmann promatic 3 da hast du die Möglichkeit einen "Taster" anzuschließen
Beitrag von: Ranseyer am 04 August 2017, 12:46:03
ZitatHörmann promatic 3 da hast du die Möglichkeit einen "Taster" anzuschließen
Ich habe auch je einen Taster angeschlossen (Promatik + Supramatik so aus dem Kopf; jedenfalls Modelle mit bisecur)
Das es einen Ausgang zum Zustand gibt ist mir neu und ich würde mich über Infos freuen wo genau du angeflascht hast. (Das blöde an der Sache ist dass so ein Öfnner meist an der Deck hängt und das herumschrauben lieber gut vorbereitet sein sollte...)
Beitrag von: RaspiLED am 04 August 2017, 12:49:11
Hi, kannst Du mal einen Schaltplan posten. Ich habe den Supramatic 2 und ich glaube der BUS Anschluss kann auch direkt per Schalter (in doppelter Funktion) angesteuert werden.
Gruß Arnd
Beitrag von: SamNitro am 04 August 2017, 13:02:06
Ja mache ich fertig ;)
Beitrag von: SamNitro am 04 August 2017, 13:42:38
Das erste Bild zeigt die Ansteuerung,
das zweite Bild zeigt die Anzeige Tor-Zu
Geflachst ist das ganze mit Sonoff Tasmota...
Beitrag von: RaspiLED am 04 August 2017, 13:57:47
Erstmal Danke!
Eine Frage habe ich:
Wann genau liegen die 24V auf dem Eltako? Ist doch quasi wie die Lampe: also bei jeder Bewegung 60s an, oder? Wieso weiss ich dann ob es zu ist?
Gruß Arnd
Beitrag von: SamNitro am 04 August 2017, 14:25:55
Das kannst du an meinem Garagentor über die Dip-Schalter ändern.. die liegen bei mir jetzt an wenn das Tor komplett zu ist.
Beitrag von: Otto123 am 06 August 2017, 22:37:36
Gruß Arnd
Hallo Arnd,
Supramatic kannst Du über die Zusatzbaugruppe UAP1 alles steuern/abfragen. Mit den Schaltern oder Sensoren Deiner Wahl.
Beitrag von: RaspiLED am 06 August 2017, 22:50:35
 Hi Otto,
Stimmt, aber die UAP ist halt teuer.
Die Frage ist was geht ohne ;-)
Gruß Arnd
Beitrag von: Otto123 am 06 August 2017, 23:00:11
Naja die Supramatic war an sich nicht billig. Und da stören Dich die 50 € ?  :o
Bei der Ansteuerung der UAP kannst Du doch wieder preiswert was machen...
Und du hast vollen Komfort! Wenn ich dran denke was dann andere mit Sensoren und Bewegungsrichtungserkennung alles für Krampf haben.
Beitrag von: SamNitro am 07 August 2017, 07:26:57
Genau das ist es, darum musste bei mir leider der eltako her damit ich die 24v abgreifen konnte für die Endlage Tor zu.
Aber ist ja ein anderer Torantrieb bei mir.
