[Gelöst] FRITZBOX: wlan $EVENT-Befehl gibt Fehlermeldung im Log
Begonnen von Gueco315, 30 Juli 2019, 07:58:05
Gueco315
der Einsatz von $EVENT funktioniert, bringt aber Fehlermeldung im LOG.
Einsatz: Ich möchte, wenn ich Alexa ein- oder ausschalte, gleichzeitig das wlan bei der Fritzbox ein- bzw. ausschalten.
Dazu das Notify:
defmod ntf_alexa_handling notify Alexa set Alexa_buero $EVENT;;set FritzBox_wz wlan $EVENT
bringt im LOG folgende Fehlermeldung:
2019.07.30 06:20:02 3: ntf_alexa_handling return value: Unknown argument set_on, choose one of dim06% dim100% dim12% dim18% dim25% dim31% dim37% dim43% dim50% dim56% dim62% dim68% dim75% dim81% dim87% dim93% dimdown dimup dimupdown off off-for-timer on on-100-for-timer-prev on-for-timer on-old-for-timer on-old-for-timer-prev ramp-off-time ramp-on-time reset sendstate timer toggle dim:slider,0,6.25,100 blink off-till intervals off-till-overnight on-till on-till-overnight
Unknown argument wlan or wrong parameter(s), choose one of call checkAPIs:noArg diversity guestWlan:on,off password ring tam update:noArg wlan:on,off wlan2.4:on,off wlan5:on,off
2019.07.30 06:20:02 3: CUL_HM set Alexa on
2019.07.30 06:20:02 3: ntf_alexa_handling return value: Unknown argument trigLast:, choose one of dim06% dim100% dim12% dim18% dim25% dim31% dim37% dim43% dim50% dim56% dim62% dim68% dim75% dim81% dim87% dim93% dimdown dimup dimupdown off off-for-timer on on-100-for-timer-prev on-for-timer on-old-for-timer on-old-for-timer-prev ramp-off-time ramp-on-time reset sendstate timer toggle dim:slider,0,6.25,100 off-till-overnight on-till-overnight on-till intervals blink off-till
2019.07.30 06:20:04 1: Perfmon: possible freeze starting at 06:20:00, delay is 4.165
2019.07.30 06:20:04 3: ntf_alexa_handling return value: Unknown argument deviceMsg:, choose one of dim06% dim100% dim12% dim18% dim25% dim31% dim37% dim43% dim50% dim56% dim62% dim68% dim75% dim81% dim87% dim93% dimdown dimup dimupdown off off-for-timer on on-100-for-timer-prev on-for-timer on-old-for-timer on-old-for-timer-prev ramp-off-time ramp-on-time reset sendstate timer toggle dim:slider,0,6.25,100 off-till blink intervals on-till on-till-overnight off-till-overnight
2019.07.30 06:20:04 3: ntf_alexa_handling return value: Unknown argument level:, choose one of dim06% dim100% dim12% dim18% dim25% dim31% dim37% dim43% dim50% dim56% dim62% dim68% dim75% dim81% dim87% dim93% dimdown dimup dimupdown off off-for-timer on on-100-for-timer-prev on-for-timer on-old-for-timer on-old-for-timer-prev ramp-off-time ramp-on-time reset sendstate timer toggle dim:slider,0,6.25,100 off-till-overnight on-till on-till-overnight off-till blink intervals
2019.07.30 06:20:04 3: ntf_alexa_handling return value: Unknown argument pct:, choose one of dim06% dim100% dim12% dim18% dim25% dim31% dim37% dim43% dim50% dim56% dim62% dim68% dim75% dim81% dim87% dim93% dimdown dimup dimupdown off off-for-timer on on-100-for-timer-prev on-for-timer on-old-for-timer on-old-for-timer-prev ramp-off-time ramp-on-time reset sendstate timer toggle dim:slider,0,6.25,100 off-till-overnight on-till on-till-overnight intervals off-till blink
2019.07.30 06:20:04 3: FS20 set Alexa_buero on
2019.07.30 06:20:04 3: FRITZBOX: set FritzBox_wz wlan on
2019.07.30 06:20:05 3: ntf_alexa_handling return value: Unknown argument timedOn:, choose one of dim06% dim100% dim12% dim18% dim25% dim31% dim37% dim43% dim50% dim56% dim62% dim68% dim75% dim81% dim87% dim93% dimdown dimup dimupdown off off-for-timer on on-100-for-timer-prev on-for-timer on-old-for-timer on-old-for-timer-prev ramp-off-time ramp-on-time reset sendstate timer toggle dim:slider,0,6.25,100 intervals blink off-till off-till-overnight on-till on-till-overnight
Geht der $EVENT Befehl bei der Fritzbox und dem wlan-schalten etwa nicht?
Guß GÜnter
Fhem 6.0, JeeLink, CUL 868 auf Raspi 4, Buster, IT-1500, 4x SB_Player, Squeezebox auf Raspi 4, 3x Fritzbox,  WIFI Light, EGPM2LAN, ENIGMA, Sec-SCO,CC-RT-DN,TC-IT-WM-W-EU,SEN-Wa-Od,ES-PMSw1-PW,HM-SE, Sonoff, Shelly,SMA
CoolTux
Du solltest Dir vielleicht einmal anschauen wie denn der Inhalt der Variable $EVENT aus schaut. Denke nicht das das nur ein on oder off beinhaltet. Da steht sicherlich noch mehr drin und das wird angemeckert.
Das TuxNet Wiki:
https://www.cooltux.net
Gueco315
Hallo Cooltux,
das wird es sein. Wie kann ich mir den Variableninhalt anzeigen lassen und wie "einschränken"?
Immerhin funktioniert der Befehl eínwandfrei.
Gruß Günter
CoolTux
Zitat von: Gueco315 am 30 Juli 2019, 08:55:49
Hallo Cooltux,
Gruß Günter
Am schnellsten geht es wenn Du in den Eventmonitor schaust und die Zeile welche ausgegeben wird hier kurz zeigst.
Desweiteren empfehle ich Dein Regex etwas ein zu schränken. Ich kenne Alexa nicht, aber so reagiert Dein Notify auf jeden Event vom Alexa Device. Weiß nicht ob das so gewollt ist.
Das TuxNet Wiki:
Gueco315
okay, die Alexa schalte ich über ein HM Mod RE 8 einfach Strom on und Strom off, ist also ein HomeMatic Aktor...
CoolTux
Ah, Also das Device "Alexa" ist ein Homematic Aktor, richtig?
Das TuxNet Wiki:
CoolTux
Ok ich denke ich habe es. Du wirst sicherlich nicht event-on-change-.* beim Homematic Aktor Alexa verwenden. Daher kommen die Befehle mehrmals und einige stimmen halt nicht.
Also
defmod ntf_alexa_handling notify Alexa:(on|off) set Alexa_buero $EVENT;;set FritzBox_wz wlan $EVENT
So sollte es nun gehen.
Das TuxNet Wiki:
Gueco315
Cool Tux :-)
genau das war es. Nun sind die Fehlermeldungen im Log weg.
Danke!
