Perl Warning: Uninitialized Value $fld
Begonnen von stobor, 09 August 2019, 23:31:03
stobor
Wie bekomme ich denn raus, wo genau diese Probleme entstehen?
2019.08.09 19:00:02 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 2194) line 1, <GEN1601> line 17.
2019.08.09 19:00:02 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 2195) line 1, <GEN1601> line 18.
2019.08.09 19:00:02 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 2196) line 1, <GEN1601> line 19.
2019.08.09 19:00:02 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 2197) line 1, <GEN1601> line 20.
2019.08.09 19:00:02 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 2198) line 1, <GEN1601> line 21.
2019.08.09 19:00:02 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 2199) line 1, <GEN1601> line 22.
2019.08.09 19:00:02 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 2200) line 1, <GEN1601> line 23.
2019.08.09 19:00:02 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 2201) line 1, <GEN1601> line 24.
2019.08.09 19:00:02 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 2205) line 1, <GEN1601> line 28.
2019.08.09 19:00:02 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 2274) line 1, <GEN1601> line 97.
2019.08.09 19:00:02 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 2275) line 1, <GEN1601> line 98.
2019.08.09 19:00:02 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 2276) line 1, <GEN1601> line 99.
2019.08.09 19:00:02 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 2277) line 1, <GEN1601> line 100.
2019.08.09 21:25:19 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4186) line 1, <GEN2631> line 3.
2019.08.09 21:25:19 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4187) line 1, <GEN2631> line 4.
2019.08.09 21:25:19 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4188) line 1, <GEN2631> line 5.
2019.08.09 21:25:19 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4189) line 1, <GEN2631> line 6.
2019.08.09 21:25:19 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4190) line 1, <GEN2631> line 7.
2019.08.09 21:25:19 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4191) line 1, <GEN2631> line 8.
2019.08.09 21:25:19 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4192) line 1, <GEN2631> line 9.
2019.08.09 21:25:19 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4193) line 1, <GEN2631> line 10.
2019.08.09 21:25:19 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4197) line 1, <GEN2631> line 14.
2019.08.09 21:25:19 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4266) line 1, <GEN2631> line 83.
2019.08.09 21:25:19 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4267) line 1, <GEN2631> line 84.
2019.08.09 21:25:19 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4268) line 1, <GEN2631> line 85.
2019.08.09 21:25:19 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4269) line 1, <GEN2631> line 86.
2019.08.09 21:28:11 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4579) line 1, <GEN2674> line 3.
2019.08.09 21:28:11 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4580) line 1, <GEN2674> line 4.
2019.08.09 21:28:11 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4581) line 1, <GEN2674> line 5.
2019.08.09 21:28:11 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4582) line 1, <GEN2674> line 6.
2019.08.09 21:28:11 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4583) line 1, <GEN2674> line 7.
2019.08.09 21:28:11 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4584) line 1, <GEN2674> line 8.
2019.08.09 21:28:11 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4585) line 1, <GEN2674> line 9.
2019.08.09 21:28:11 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4586) line 1, <GEN2674> line 10.
2019.08.09 21:28:11 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4590) line 1, <GEN2674> line 14.
2019.08.09 21:28:11 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4659) line 1, <GEN2674> line 83.
2019.08.09 21:28:11 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4660) line 1, <GEN2674> line 84.
2019.08.09 21:28:11 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4661) line 1, <GEN2674> line 85.
2019.08.09 21:28:11 1: PERL WARNING: Use of uninitialized value $fld[3] in pattern match (m//) at (eval 4662) line 1, <GEN2674> line 86.
Intel NUC (Ubuntu 24.04.4 LTS)  mit CUL V3.2 (FW 1.57 CUL868) für FS20 und CCU3 für HM(IP) + Arduino Mega (Firmata) - FHEM Revision: 31515 - FS20, HM(IP), MQTT, Philips HUE, ModBus
amenomade
Zuerst das Attribut stacktrace setzen, dann wieder die Log zeigen
