Revision 20060: WMBus: correction for negative values (DIF_INT*) and removed ...
Begonnen von System, 25 August 2019, 19:30:49
System
WMBus: correction for negative values (DIF_INT*) and removed validation check fpr LVAR
Source: Revision 20060: WMBus: correction for negative values (DIF_INT*) and removed ...
