[GELÖST] eQ3 Update / error => no or wrong data from eq3-server!
Begonnen von Burny4600, 09 April 2022, 15:42:53
Burny4600
Hat sich der eQ3 Updatelink geändert, oder gibt es den nicht mehr?.
list eQ3
   BUSY       0
   CFGFN      /media/hdd/fhem/mycfg/HM/hm_rasp01.cfg
   DEF        https://update.homematic.com/firmware/api/firmware/search/DEVICE 86400
   FUUID      5c45b04f-f33f-f4d2-e8ac-6e95ed4c33510da6
   Interval   86400
   MainURL    https://update.homematic.com/firmware/api/firmware/search/DEVICE
   ModuleVersion 4.1.10 - 6.7.2021
   NAME       eQ3
   NOTIFYDEV  global
   NR         6694
   NTFY_ORDER 50-eQ3
   STATE      <div style="text-align:left;"><div>last <a title="eq3-downloads" href="http://www.eq-3.de/service/downloads.html">homematic</a>-fw-check => 2022-04-09 15:39:53</div><div style="color:red;font-weight:bold;">error => no or wrong data from eq3-server!</div><div style="text-align:left;">(next check: 2022-04-10 00:45:00)</div></div>
   TYPE       HTTPMOD
   value
   CompiledRegexes:
   HttpUtils:
     NAME
     addr       https://update.homematic.com:443
     auth       0
     buf
     code       200
     compress   1
     conn
     data
     displayurl https://update.homematic.com/firmware/api/firmware/search/DEVICE
     header
     host       update.homematic.com
     httpheader HTTP/1.1 200 OK
Server: nginx
Date: Sat, 09 Apr 2022 13:39:54 GMT
Content-Type: text/plain
Content-Length: 1094
Connection: close
content-encoding: gzip
Strict-Transport-Security: max-age=31536000; includeSubDomains
Content-Security-Policy: upgrade-insecure-requests
     httpversion 1.0
     hu_blocking 0
     hu_filecount 1
     hu_port    443
     hu_portSfx
     ignoreredirects 1
     loglevel   4
     path       /firmware/api/firmware/search/DEVICE
     protocol   https
     redirects  0
     timeout    2
     sslargs:
   QUEUE:
     2022-04-06 00:45:44   LAST_ERROR      start_SSL https://update.homematic.com:443 timed out
     2022-04-09 15:39:54   LAST_REQUEST    update
     2022-04-09 15:39:54   MATCHED_READINGS hmfw-type-001 hmfw-type-002 hmfw-type-003 hmfw-type-004 hmfw-type-005 hmfw-type-006 hmfw-type-007 hmfw-type-008 hmfw-type-009 hmfw-type-010 hmfw-type-011 hmfw-type-012 hmfw-type-013 hmfw-type-014 hmfw-type-015 hmfw-type-016 hmfw-type-017 hmfw-type-018 hmfw-type-019 hmfw-type-020 hmfw-type-021 hmfw-type-022 hmfw-type-023 hmfw-type-024 hmfw-type-025 hmfw-type-026 hmfw-type-027 hmfw-type-028 hmfw-type-029 hmfw-type-030 hmfw-type-031 hmfw-type-032 hmfw-type-033 hmfw-type-034 hmfw-type-035 hmfw-type-036 hmfw-type-037 hmfw-type-038 hmfw-type-039 hmfw-type-040 hmfw-type-041 hmfw-type-042 hmfw-type-043 hmfw-type-044 hmfw-type-045 hmfw-type-046 hmfw-type-047 hmfw-type-048 hmfw-type-049 hmfw-type-050 hmfw-type-051 hmfw-type-052 hmfw-type-053 hmfw-type-054 hmfw-type-055 hmfw-type-056 hmfw-type-057 hmfw-type-058 hmfw-type-059 hmfw-type-060 hmfw-type-061 hmfw-type-062 hmfw-type-063 hmfw-type-064 hmfw-type-065 hmfw-type-066 hmfw-type-067 hmfw-type-068 hmfw-type-069 hmfw-type-070 hmfw-type-071 hmfw-type-072 hmfw-type-073 hmfw-type-074 hmfw-type-075 hmfw-type-076 hmfw-type-077 hmfw-type-078 hmfw-type-079 hmfw-type-080 hmfw-type-081 hmfw-type-082 hmfw-type-083 hmfw-type-084 hmfw-type-085 hmfw-type-086 hmfw-type-087 hmfw-type-088 hmfw-type-089 hmfw-type-090 hmfw-type-091 hmfw-type-092 hmfw-type-093 hmfw-type-094 hmfw-type-095 hmfw-type-096 hmfw-type-097 hmfw-type-098 hmfw-type-099 hmfw-type-100 hmfw-type-101 hmfw-type-102 hmfw-type-103 hmfw-type-104 hmfw-type-105 hmfw-type-106 hmfw-type-107 hmfw-type-108 hmfw-type-109 hmfw-type-110 hmfw-type-111 hmfw-type-112 hmfw-type-113 hmfw-type-114 hmfw-type-115 hmfw-type-116 hmfw-type-117 hmfw-type-118 hmfw-type-119 hmfw-type-120 hmfw-type-121 hmfw-type-122 hmfw-type-123 hmfw-type-124 hmfw-type-125 hmfw-type-126 hmfw-type-127 hmfw-type-128 hmfw-type-129 hmfw-type-130 hmfw-type-131 hmfw-type-132 hmfw-type-133 hmfw-type-134 hmfw-type-135 hmfw-type-136 hmfw-type-137 hmfw-type-138 hmfw-type-139 hmfw-type-140 hmfw-type-141 hmfw-type-142 hmfw-type-143 hmfw-type-144 hmfw-type-145 hmfw-version-001 hmfw-version-002 hmfw-version-003 hmfw-version-004 hmfw-version-005 hmfw-version-006 hmfw-version-007 hmfw-version-008 hmfw-version-009 hmfw-version-010 hmfw-version-011 hmfw-version-012 hmfw-version-013 hmfw-version-014 hmfw-version-015 hmfw-version-016 hmfw-version-017 hmfw-version-018 hmfw-version-019 hmfw-version-020 hmfw-version-021 hmfw-version-022 hmfw-version-023 hmfw-version-024 hmfw-version-025 hmfw-version-026 hmfw-version-027 hmfw-version-028 hmfw-version-029 hmfw-version-030 hmfw-version-031 hmfw-version-032 hmfw-version-033 hmfw-version-034 hmfw-version-035 hmfw-version-036 hmfw-version-037 hmfw-version-038 hmfw-version-039 hmfw-version-040 hmfw-version-041 hmfw-version-042 hmfw-version-043 hmfw-version-044 hmfw-version-045 hmfw-version-046 hmfw-version-047 hmfw-version-048 hmfw-version-049 hmfw-version-050 hmfw-version-051 hmfw-version-052 hmfw-version-053 hmfw-version-054 hmfw-version-055 hmfw-version-056 hmfw-version-057 hmfw-version-058 hmfw-version-059 hmfw-version-060 hmfw-version-061 hmfw-version-062 hmfw-version-063 hmfw-version-064 hmfw-version-065 hmfw-version-066 hmfw-version-067 hmfw-version-068 hmfw-version-069 hmfw-version-070 hmfw-version-071 hmfw-version-072 hmfw-version-073 hmfw-version-074 hmfw-version-075 hmfw-version-076 hmfw-version-077 hmfw-version-078 hmfw-version-079 hmfw-version-080 hmfw-version-081 hmfw-version-082 hmfw-version-083 hmfw-version-084 hmfw-version-085 hmfw-version-086 hmfw-version-087 hmfw-version-088 hmfw-version-089 hmfw-version-090 hmfw-version-091 hmfw-version-092 hmfw-version-093 hmfw-version-094 hmfw-version-095 hmfw-version-096 hmfw-version-097 hmfw-version-098 hmfw-version-099 hmfw-version-100 hmfw-version-101 hmfw-version-102 hmfw-version-103 hmfw-version-104 hmfw-version-105 hmfw-version-106 hmfw-version-107 hmfw-version-108 hmfw-version-109 hmfw-version-110 hmfw-version-111 hmfw-version-112 hmfw-version-113 hmfw-version-114 hmfw-version-115 hmfw-version-116 hmfw-version-117 hmfw-version-118 hmfw-version-119 hmfw-version-120 hmfw-version-121 hmfw-version-122 hmfw-version-123 hmfw-version-124 hmfw-version-125 hmfw-version-126 hmfw-version-127 hmfw-version-128 hmfw-version-129 hmfw-version-130 hmfw-version-131 hmfw-version-132 hmfw-version-133 hmfw-version-134 hmfw-version-135 hmfw-version-136 hmfw-version-137 hmfw-version-138 hmfw-version-139 hmfw-version-140 hmfw-version-141 hmfw-version-142 hmfw-version-143 hmfw-version-144 hmfw-version-145
     2022-04-09 15:39:54   UNMATCHED_READINGS
     2022-04-09 15:39:54   hmfw-type-001   HmIPW-WTH
     2022-04-09 15:39:54   hmfw-type-002   HM-LC-Dim1L-Pl-3
     2022-04-09 15:39:54   hmfw-type-003   HmIPW-DRD3
     2022-04-09 15:39:54   hmfw-type-004   HmIP-FALMOT-C12
     2022-04-09 15:39:54   hmfw-type-005   HmIP-SWO-PR
     2022-04-09 15:39:54   hmfw-type-006   HM-ES-PMSw1-Pl
     2022-04-09 15:39:54   hmfw-type-007   HmIP-WHS2
     2022-04-09 15:39:54   hmfw-type-008   HmIP-SWO-B
     2022-04-09 15:39:54   hmfw-type-009   HmIPW-FIO6
     2022-04-09 15:39:54   hmfw-type-010   HmIP-eTRV-E
     2022-04-09 15:39:54   hmfw-type-011   HmIP-PDT
     2022-04-09 15:39:54   hmfw-type-012   HM-ES-PMSw1-Pl-DN-R3
     2022-04-09 15:39:54   hmfw-type-013   HmIP-PSM-IT
     2022-04-09 15:39:54   hmfw-type-014   HmIP-PS
     2022-04-09 15:39:54   hmfw-type-015   HmIP-FROLL
     2022-04-09 15:39:54   hmfw-type-016   HmIP-FCI6
     2022-04-09 15:39:54   hmfw-type-017   HM-LC-Dim1TPBU-FM
     2022-04-09 15:39:54   hmfw-type-018   HmIPW-FAL230-C6
     2022-04-09 15:39:54   hmfw-type-019   HM-ES-PMSw1-Pl-DN-R2
     2022-04-09 15:39:54   hmfw-type-020   HmIP-SPDR
     2022-04-09 15:39:54   hmfw-type-021   HmIP-SFD
     2022-04-09 15:39:54   hmfw-type-022   HM-LC-Sw1-Pl-DN-R1
     2022-04-09 15:39:54   hmfw-type-023   HmIP-STHD
     2022-04-09 15:39:54   hmfw-type-024   HmIP-eTRV-C
     2022-04-09 15:39:54   hmfw-type-025   HmIP-SMI
     2022-04-09 15:39:54   hmfw-type-026   HmIPW-DRI32
     2022-04-09 15:39:54   hmfw-type-027   HmIP-SWDO-I
     2022-04-09 15:39:54   hmfw-type-028   HmIP-STHO
     2022-04-09 15:39:54   hmfw-type-029   HmIP-PSM-UK
     2022-04-09 15:39:54   hmfw-type-030   HmIP-WTH-2
     2022-04-09 15:39:54   hmfw-type-031   HmIP-ASIR-O
     2022-04-09 15:39:54   hmfw-type-032   HmIP-ASIR-2
     2022-04-09 15:39:54   hmfw-type-033   HmIP-DRSI1
     2022-04-09 15:39:54   hmfw-type-034   HM-LC-Sw1-Pl-DN-R4
     2022-04-09 15:39:54   hmfw-type-035   HM-LC-Dim1T-DR
     2022-04-09 15:39:54   hmfw-type-036   HmIP-MOD-HO
     2022-04-09 15:39:54   hmfw-type-037   HmIPW-SMI55
     2022-04-09 15:39:54   hmfw-type-038   HmIP-SCI
     2022-04-09 15:39:54   hmfw-type-039   HmIP-FAL230-C6
     2022-04-09 15:39:54   hmfw-type-040   HmIPW-SPI
     2022-04-09 15:39:54   hmfw-type-041   HmIP-DRSI4
     2022-04-09 15:39:54   hmfw-type-042   HmIP-ASIR
     2022-04-09 15:39:54   hmfw-type-043   HmIP-BWTH24
     2022-04-09 15:39:54   hmfw-type-044   HmIP-STHO-A
     2022-04-09 15:39:54   hmfw-type-045   HmIP-BBL
     2022-04-09 15:39:54   hmfw-type-046   HmIP-SMO-A
     2022-04-09 15:39:54   hmfw-type-047   HmIPW-FALMOT-C12
     2022-04-09 15:39:54   hmfw-type-048   HmIP-RC8
     2022-04-09 15:39:54   hmfw-type-049   HmIP-WRC6
     2022-04-09 15:39:54   hmfw-type-050   HmIP-FAL230-C10
     2022-04-09 15:39:54   hmfw-type-051   HmIP-RCB1
     2022-04-09 15:39:54   hmfw-type-052   HmIP-MIOB
     2022-04-09 15:39:54   hmfw-type-053   HmIP-DLD
     2022-04-09 15:39:54   hmfw-type-054   HmIP-STI
     2022-04-09 15:39:54   hmfw-type-055   HmIP-DLS
     2022-04-09 15:39:54   hmfw-type-056   HmIPW-DRAP
     2022-04-09 15:39:54   hmfw-type-057   HmIP-DSD-PCB
     2022-04-09 15:39:54   hmfw-type-058   HM-LC-Sw1-Pl-DN-R5
     2022-04-09 15:39:54   hmfw-type-059   HmIP-SMO-2
     2022-04-09 15:39:54   hmfw-type-060   HmIP-PSM-PE
     2022-04-09 15:39:54   hmfw-type-061   HmIP-BDT
     2022-04-09 15:39:54   hmfw-type-062   HmIP-SWSD-2
     2022-04-09 15:39:54   hmfw-type-063   HmIP-FSM16
     2022-04-09 15:39:54   hmfw-type-064   HmIP-BROLL
     2022-04-09 15:39:54   hmfw-type-065   HmIP-PSM-CH
     2022-04-09 15:39:54   hmfw-type-066   HM-OU-CFM-Pl
     2022-04-09 15:39:54   hmfw-type-067   HM-ES-PMSw1-Pl-DN-R1
     2022-04-09 15:39:54   hmfw-type-068   HmIP-SWO-PL
     2022-04-09 15:39:54   hmfw-type-069   HmIP-WRCC2
     2022-04-09 15:39:54   hmfw-type-070   HmIP-HAP
     2022-04-09 15:39:54   hmfw-type-071   HmIP-WRC2
     2022-04-09 15:39:54   hmfw-type-072   HmIPW-DRS4
     2022-04-09 15:39:54   hmfw-type-073   HmIP-STH
     2022-04-09 15:39:54   hmfw-type-074   HmIP-SMO
     2022-04-09 15:39:54   hmfw-type-075   HM-LC-Sw1-Pl-DN-R3
     2022-04-09 15:39:54   hmfw-type-076   HmIP-BSM
     2022-04-09 15:39:54   hmfw-type-077   HmIP-FCI1
     2022-04-09 15:39:54   hmfw-type-078   HmIP-SRD
     2022-04-09 15:39:54   hmfw-type-079   HmIP-SCTH230
     2022-04-09 15:39:54   hmfw-type-080   HM-LC-RGBW-WM
     2022-04-09 15:39:54   hmfw-type-081   HmIP-SRH
     2022-04-09 15:39:54   hmfw-type-082   HmIP-SPI
     2022-04-09 15:39:54   hmfw-type-083   HmIP-PS-2
     2022-04-09 15:39:54   hmfw-type-084   HmIP-FAL24-C10
     2022-04-09 15:39:54   hmfw-type-085   HmIP-KRCA
     2022-04-09 15:39:54   hmfw-type-086   HmIP-USBSM
     2022-04-09 15:39:54   hmfw-type-087   HmIP-MOD-OC8
     2022-04-09 15:39:54   hmfw-type-088   HmIP-WUA
     2022-04-09 15:39:54   hmfw-type-089   HmIPW-BRC2
     2022-04-09 15:39:54   hmfw-type-090   HM-CC-RT-DN
     2022-04-09 15:39:54   hmfw-type-091   HmIP-FSM
     2022-04-09 15:39:54   hmfw-type-092   HmIP-eTRV-C-2
     2022-04-09 15:39:54   hmfw-type-093   HM-LC-Dim1T-Pl-3
     2022-04-09 15:39:54   hmfw-type-094   HmIP-BSL
     2022-04-09 15:39:54   hmfw-type-095   HmIP-MIO16-PCB
     2022-04-09 15:39:54   hmfw-type-096   HmIP-PDT-UK
     2022-04-09 15:39:54   hmfw-type-097   HmIP-STE2-PCB
     2022-04-09 15:39:54   hmfw-type-098   HmIP-FDT
     2022-04-09 15:39:54   hmfw-type-099   HM-Dis-EP-WM55
     2022-04-09 15:39:54   hmfw-type-100   HM-ES-PMSw1-Pl-DN-R5
     2022-04-09 15:39:54   hmfw-type-101   HmIPW-FAL24-C6
     2022-04-09 15:39:54   hmfw-type-102   HmIPW-STH
     2022-04-09 15:39:54   hmfw-type-103   HmIPW-DRBL4
     2022-04-09 15:39:54   hmfw-type-104   HmIP-WTH
     2022-04-09 15:39:54   hmfw-type-105   HM-ES-PMSw1-Pl-DN-R4
     2022-04-09 15:39:54   hmfw-type-106   HmIP-FAL24-C6
     2022-04-09 15:39:54   hmfw-type-107   HmIPW-WRC2
     2022-04-09 15:39:54   hmfw-type-108   HM-MOD-Re-8
     2022-04-09 15:39:54   hmfw-type-109   HmIP-FSI16
     2022-04-09 15:39:54   hmfw-type-110   HmIP-SMO-A-2
     2022-04-09 15:39:54   hmfw-type-111   HmIP-DRBLI4
     2022-04-09 15:39:54   hmfw-type-112   HmIPW-FAL24-C10
     2022-04-09 15:39:54   hmfw-type-113   HM-LC-Dim1TPBU-FM
     2022-04-09 15:39:54   hmfw-type-114   HmIP-FBL
     2022-04-09 15:39:54   hmfw-type-115   HmIP-MP3P
     2022-04-09 15:39:54   hmfw-type-116   HmIP-MOD-TM
     2022-04-09 15:39:54   hmfw-type-117   HmIP-BWTH
     2022-04-09 15:39:54   hmfw-type-118   HM-OU-CFM-TW
     2022-04-09 15:39:54   hmfw-type-119   HM-LC-Bl1PBU-FM
     2022-04-09 15:39:54   hmfw-type-120   HM-TC-IT-WM-W-EU
     2022-04-09 15:39:54   hmfw-type-121   HmIPW-FAL230-C10
     2022-04-09 15:39:54   hmfw-type-122   HmIP-eTRV
     2022-04-09 15:39:54   hmfw-type-123   HmIP-SWD
     2022-04-09 15:39:54   hmfw-type-124   HmIP-SWDO-PL
     2022-04-09 15:39:54   hmfw-type-125   HM-LC-Sw1PBU-FM
     2022-04-09 15:39:54   hmfw-type-126   HM-LC-Sw1-Pl-DN-R2
     2022-04-09 15:39:54   hmfw-type-127   HmIP-eTRV-2
     2022-04-09 15:39:54   hmfw-type-128   ELV-SH-WSC
     2022-04-09 15:39:54   hmfw-type-129   HmIPW-DRS8
     2022-04-09 15:39:54   hmfw-type-130   HmIP-PSM
     2022-04-09 15:39:54   hmfw-type-131   HmIP-BS2
     2022-04-09 15:39:54   hmfw-type-132   HmIP-SWDO
     2022-04-09 15:39:54   hmfw-type-133   HmIP-PCBS
     2022-04-09 15:39:54   hmfw-type-134   HmIP-PMFS
     2022-04-09 15:39:54   hmfw-type-135   HmIP-PCBS2
     2022-04-09 15:39:54   hmfw-type-136   HmIP-STV
     2022-04-09 15:39:54   hmfw-type-137   HmIP-SLO
     2022-04-09 15:39:54   hmfw-type-138   HmIP-KRC4
     2022-04-09 15:39:54   hmfw-type-139   HmIP-eTRV-2-UK
     2022-04-09 15:39:54   hmfw-type-140   HmIPW-STHD
     2022-04-09 15:39:54   hmfw-type-141   HmIP-SMI55
     2022-04-09 15:39:54   hmfw-type-142   HmIP-WGC
     2022-04-09 15:39:54   hmfw-type-143   HM-LC-Dim1PWM-CV
     2022-04-09 15:39:54   hmfw-type-144   HM-Sen-MDIR-WM55
     2022-04-09 15:39:54   hmfw-type-145   HmIPW-DRI16
     2022-04-09 15:39:54   hmfw-version-001 2.4.6
     2022-04-09 15:39:54   hmfw-version-002 2.9.7
     2022-04-09 15:39:54   hmfw-version-003 1.0.0
     2022-04-09 15:39:54   hmfw-version-004 1.4.6
     2022-04-09 15:39:54   hmfw-version-005 1.0.18
     2022-04-09 15:39:54   hmfw-version-006 2.6.0
     2022-04-09 15:39:54   hmfw-version-007 1.4.2
     2022-04-09 15:39:54   hmfw-version-008 1.0.18
     2022-04-09 15:39:54   hmfw-version-009 1.2.6
     2022-04-09 15:39:54   hmfw-version-010 1.0.10
     2022-04-09 15:39:54   hmfw-version-011 1.4.8
     2022-04-09 15:39:54   hmfw-version-012 2.6.0
     2022-04-09 15:39:54   hmfw-version-013 2.18.22
     2022-04-09 15:39:54   hmfw-version-014 2.6.2
     2022-04-09 15:39:54   hmfw-version-015 1.8.12
     2022-04-09 15:39:54   hmfw-version-016 1.0.16
     2022-04-09 15:39:54   hmfw-version-017 2.9.5
     2022-04-09 15:39:54   hmfw-version-018 2.0.2
     2022-04-09 15:39:54   hmfw-version-019 2.6.0
     2022-04-09 15:39:54   hmfw-version-020 1.2.0
     2022-04-09 15:39:54   hmfw-version-021 1.2.22
     2022-04-09 15:39:54   hmfw-version-022 2.6.0
     2022-04-09 15:39:54   hmfw-version-023 2.6.0
     2022-04-09 15:39:54   hmfw-version-024 1.2.4
     2022-04-09 15:39:54   hmfw-version-025 1.4.8
     2022-04-09 15:39:54   hmfw-version-026 1.2.2
     2022-04-09 15:39:54   hmfw-version-027 1.16.10
     2022-04-09 15:39:54   hmfw-version-028 1.0.6
     2022-04-09 15:39:54   hmfw-version-029 2.18.22
     2022-04-09 15:39:54   hmfw-version-030 2.6.0
     2022-04-09 15:39:54   hmfw-version-031 1.0.6
     2022-04-09 15:39:54   hmfw-version-032 1.4.2
     2022-04-09 15:39:54   hmfw-version-033 1.6.0
     2022-04-09 15:39:54   hmfw-version-034 2.6.0
     2022-04-09 15:39:54   hmfw-version-035 1.1.0
     2022-04-09 15:39:54   hmfw-version-036 1.0.14
     2022-04-09 15:39:54   hmfw-version-037 1.0.20
     2022-04-09 15:39:54   hmfw-version-038 1.0.6
     2022-04-09 15:39:54   hmfw-version-039 2.0.4
     2022-04-09 15:39:54   hmfw-version-040 1.0.30
     2022-04-09 15:39:54   hmfw-version-041 1.4.2
     2022-04-09 15:39:54   hmfw-version-042 1.4.2
     2022-04-09 15:39:54   hmfw-version-043 1.2.4
     2022-04-09 15:39:54   hmfw-version-044 1.0.6
     2022-04-09 15:39:54   hmfw-version-045 1.8.20
     2022-04-09 15:39:54   hmfw-version-046 1.2.8
     2022-04-09 15:39:54   hmfw-version-047 1.4.6
     2022-04-09 15:39:54   hmfw-version-048 1.0.19
     2022-04-09 15:39:54   hmfw-version-049 1.0.19
     2022-04-09 15:39:54   hmfw-version-050 2.0.4
     2022-04-09 15:39:54   hmfw-version-051 1.2.4
     2022-04-09 15:39:54   hmfw-version-052 1.8.4
     2022-04-09 15:39:54   hmfw-version-053 1.4.10
     2022-04-09 15:39:54   hmfw-version-054 1.0.0
     2022-04-09 15:39:54   hmfw-version-055 1.2.4
     2022-04-09 15:39:54   hmfw-version-056 2.4.14
     2022-04-09 15:39:54   hmfw-version-057 1.0.6
     2022-04-09 15:39:54   hmfw-version-058 2.6.0
     2022-04-09 15:39:54   hmfw-version-059 1.2.10
     2022-04-09 15:39:54   hmfw-version-060 2.18.22
     2022-04-09 15:39:54   hmfw-version-061 1.4.8
     2022-04-09 15:39:54   hmfw-version-062 1.0.4
     2022-04-09 15:39:54   hmfw-version-063 1.18.22
     2022-04-09 15:39:54   hmfw-version-064 1.8.20
     2022-04-09 15:39:54   hmfw-version-065 2.18.22
     2022-04-09 15:39:54   hmfw-version-066 2.4.2
     2022-04-09 15:39:54   hmfw-version-067 2.6.0
     2022-04-09 15:39:54   hmfw-version-068 1.0.18
     2022-04-09 15:39:54   hmfw-version-069 2.2.8
     2022-04-09 15:39:54   hmfw-version-070 2.4.12
     2022-04-09 15:39:54   hmfw-version-071 1.10.0
     2022-04-09 15:39:54   hmfw-version-072 1.2.4
     2022-04-09 15:39:54   hmfw-version-073 2.6.0
     2022-04-09 15:39:54   hmfw-version-074 1.2.8
     2022-04-09 15:39:54   hmfw-version-075 2.6.0
     2022-04-09 15:39:54   hmfw-version-076 1.18.14
     2022-04-09 15:39:54   hmfw-version-077 1.0.14
     2022-04-09 15:39:54   hmfw-version-078 1.0.18
     2022-04-09 15:39:54   hmfw-version-079 1.0.6
     2022-04-09 15:39:54   hmfw-version-080 1.0.0
     2022-04-09 15:39:54   hmfw-version-081 1.2.10
     2022-04-09 15:39:54   hmfw-version-082 1.4.0
     2022-04-09 15:39:54   hmfw-version-083 2.22.0
     2022-04-09 15:39:54   hmfw-version-084 2.0.4
     2022-04-09 15:39:54   hmfw-version-085 1.10.0
     2022-04-09 15:39:54   hmfw-version-086 1.0.16
     2022-04-09 15:39:54   hmfw-version-087 1.8.12
     2022-04-09 15:39:54   hmfw-version-088 1.0.14
     2022-04-09 15:39:54   hmfw-version-089 2.2.10
     2022-04-09 15:39:54   hmfw-version-090 1.5.3
     2022-04-09 15:39:54   hmfw-version-091 1.18.22
     2022-04-09 15:39:54   hmfw-version-092 1.4.14
     2022-04-09 15:39:54   hmfw-version-093 2.9.5
     2022-04-09 15:39:54   hmfw-version-094 1.0.2
     2022-04-09 15:39:54   hmfw-version-095 1.0.10
     2022-04-09 15:39:54   hmfw-version-096 1.4.8
     2022-04-09 15:39:54   hmfw-version-097 1.0.26
     2022-04-09 15:39:54   hmfw-version-098 1.4.8
     2022-04-09 15:39:54   hmfw-version-099 1.2.0
     2022-04-09 15:39:54   hmfw-version-100 2.6.0
     2022-04-09 15:39:54   hmfw-version-101 2.0.2
     2022-04-09 15:39:54   hmfw-version-102 2.4.6
     2022-04-09 15:39:54   hmfw-version-103 1.8.2
     2022-04-09 15:39:54   hmfw-version-104 2.4.8
     2022-04-09 15:39:54   hmfw-version-105 2.6.0
     2022-04-09 15:39:54   hmfw-version-106 2.0.4
     2022-04-09 15:39:54   hmfw-version-107 2.2.10
     2022-04-09 15:39:54   hmfw-version-108 1.2.0
     2022-04-09 15:39:54   hmfw-version-109 1.18.22
     2022-04-09 15:39:54   hmfw-version-110 1.2.10
     2022-04-09 15:39:54   hmfw-version-111 1.8.2
     2022-04-09 15:39:54   hmfw-version-112 2.0.2
     2022-04-09 15:39:54   hmfw-version-113 2.9.5
     2022-04-09 15:39:54   hmfw-version-114 1.8.12
     2022-04-09 15:39:54   hmfw-version-115 1.0.26
     2022-04-09 15:39:54   hmfw-version-116 1.0.0
     2022-04-09 15:39:54   hmfw-version-117 1.2.4
     2022-04-09 15:39:54   hmfw-version-118 1.3.0
     2022-04-09 15:39:54   hmfw-version-119 2.11.1
     2022-04-09 15:39:54   hmfw-version-120 1.4.2
     2022-04-09 15:39:54   hmfw-version-121 2.0.2
     2022-04-09 15:39:54   hmfw-version-122 2.2.8
     2022-04-09 15:39:54   hmfw-version-123 1.0.2
     2022-04-09 15:39:54   hmfw-version-124 1.16.10
     2022-04-09 15:39:54   hmfw-version-125 2.8.2
     2022-04-09 15:39:54   hmfw-version-126 2.6.0
     2022-04-09 15:39:54   hmfw-version-127 2.2.8
     2022-04-09 15:39:54   hmfw-version-128 1.0.8
     2022-04-09 15:39:54   hmfw-version-129 1.2.4
     2022-04-09 15:39:54   hmfw-version-130 2.18.22
     2022-04-09 15:39:54   hmfw-version-131 1.8.8
     2022-04-09 15:39:54   hmfw-version-132 1.16.8
     2022-04-09 15:39:54   hmfw-version-133 2.10.2
     2022-04-09 15:39:54   hmfw-version-134 1.0.12
     2022-04-09 15:39:54   hmfw-version-135 1.10.10
     2022-04-09 15:39:54   hmfw-version-136 1.0.16
     2022-04-09 15:39:54   hmfw-version-137 1.0.16
     2022-04-09 15:39:54   hmfw-version-138 1.10.0
     2022-04-09 15:39:54   hmfw-version-139 2.2.8
     2022-04-09 15:39:54   hmfw-version-140 2.4.8
     2022-04-09 15:39:54   hmfw-version-141 1.0.12
     2022-04-09 15:39:54   hmfw-version-142 1.0.2
     2022-04-09 15:39:54   hmfw-version-143 2.9.5
     2022-04-09 15:39:54   hmfw-version-144 1.2.0
     2022-04-09 15:39:54   hmfw-version-145 1.2.2
   REQUEST:
     context    reading
     data
     header
     ignoreredirects 0
     num        unknown
     retryCount 0
     type       update
   defptr:
     readingBase:
       hmfw-type-001 reading
       hmfw-type-002 reading
       hmfw-type-003 reading
       hmfw-type-004 reading
       hmfw-type-005 reading
       hmfw-type-006 reading
       hmfw-type-007 reading
       hmfw-type-008 reading
       hmfw-type-009 reading
       hmfw-type-010 reading
       hmfw-type-011 reading
       hmfw-type-012 reading
       hmfw-type-013 reading
       hmfw-type-014 reading
       hmfw-type-015 reading
       hmfw-type-016 reading
       hmfw-type-017 reading
       hmfw-type-018 reading
       hmfw-type-019 reading
       hmfw-type-020 reading
       hmfw-type-021 reading
       hmfw-type-022 reading
       hmfw-type-023 reading
       hmfw-type-024 reading
       hmfw-type-025 reading
       hmfw-type-026 reading
       hmfw-type-027 reading
       hmfw-type-028 reading
       hmfw-type-029 reading
       hmfw-type-030 reading
       hmfw-type-031 reading
       hmfw-type-032 reading
       hmfw-type-033 reading
       hmfw-type-034 reading
       hmfw-type-035 reading
       hmfw-type-036 reading
       hmfw-type-037 reading
       hmfw-type-038 reading
       hmfw-type-039 reading
       hmfw-type-040 reading
       hmfw-type-041 reading
       hmfw-type-042 reading
       hmfw-type-043 reading
       hmfw-type-044 reading
       hmfw-type-045 reading
       hmfw-type-046 reading
       hmfw-type-047 reading
       hmfw-type-048 reading
       hmfw-type-049 reading
       hmfw-type-050 reading
       hmfw-type-051 reading
       hmfw-type-052 reading
       hmfw-type-053 reading
       hmfw-type-054 reading
       hmfw-type-055 reading
       hmfw-type-056 reading
       hmfw-type-057 reading
       hmfw-type-058 reading
       hmfw-type-059 reading
       hmfw-type-060 reading
       hmfw-type-061 reading
       hmfw-type-062 reading
       hmfw-type-063 reading
       hmfw-type-064 reading
       hmfw-type-065 reading
       hmfw-type-066 reading
       hmfw-type-067 reading
       hmfw-type-068 reading
       hmfw-type-069 reading
       hmfw-type-070 reading
       hmfw-type-071 reading
       hmfw-type-072 reading
       hmfw-type-073 reading
       hmfw-type-074 reading
       hmfw-type-075 reading
       hmfw-type-076 reading
       hmfw-type-077 reading
       hmfw-type-078 reading
       hmfw-type-079 reading
       hmfw-type-080 reading
       hmfw-type-081 reading
       hmfw-type-082 reading
       hmfw-type-083 reading
       hmfw-type-084 reading
       hmfw-type-085 reading
       hmfw-type-086 reading
       hmfw-type-087 reading
       hmfw-type-088 reading
       hmfw-type-089 reading
       hmfw-type-090 reading
       hmfw-type-091 reading
       hmfw-type-092 reading
       hmfw-type-093 reading
       hmfw-type-094 reading
       hmfw-type-095 reading
       hmfw-type-096 reading
       hmfw-type-097 reading
       hmfw-type-098 reading
       hmfw-type-099 reading
       hmfw-type-100 reading
       hmfw-type-101 reading
       hmfw-type-102 reading
       hmfw-type-103 reading
       hmfw-type-104 reading
       hmfw-type-105 reading
       hmfw-type-106 reading
       hmfw-type-107 reading
       hmfw-type-108 reading
       hmfw-type-109 reading
       hmfw-type-110 reading
       hmfw-type-111 reading
       hmfw-type-112 reading
       hmfw-type-113 reading
       hmfw-type-114 reading
       hmfw-type-115 reading
       hmfw-type-116 reading
       hmfw-type-117 reading
       hmfw-type-118 reading
       hmfw-type-119 reading
       hmfw-type-120 reading
       hmfw-type-121 reading
       hmfw-type-122 reading
       hmfw-type-123 reading
       hmfw-type-124 reading
       hmfw-type-125 reading
       hmfw-type-126 reading
       hmfw-type-127 reading
       hmfw-type-128 reading
       hmfw-type-129 reading
       hmfw-type-130 reading
       hmfw-type-131 reading
       hmfw-type-132 reading
       hmfw-type-133 reading
       hmfw-type-134 reading
       hmfw-type-135 reading
       hmfw-type-136 reading
       hmfw-type-137 reading
       hmfw-type-138 reading
       hmfw-type-139 reading
       hmfw-type-140 reading
       hmfw-type-141 reading
       hmfw-type-142 reading
       hmfw-type-143 reading
       hmfw-type-144 reading
       hmfw-type-145 reading
       hmfw-version-001 reading
       hmfw-version-002 reading
       hmfw-version-003 reading
       hmfw-version-004 reading
       hmfw-version-005 reading
       hmfw-version-006 reading
       hmfw-version-007 reading
       hmfw-version-008 reading
       hmfw-version-009 reading
       hmfw-version-010 reading
       hmfw-version-011 reading
       hmfw-version-012 reading
       hmfw-version-013 reading
       hmfw-version-014 reading
       hmfw-version-015 reading
       hmfw-version-016 reading
       hmfw-version-017 reading
       hmfw-version-018 reading
       hmfw-version-019 reading
       hmfw-version-020 reading
       hmfw-version-021 reading
       hmfw-version-022 reading
       hmfw-version-023 reading
       hmfw-version-024 reading
       hmfw-version-025 reading
       hmfw-version-026 reading
       hmfw-version-027 reading
       hmfw-version-028 reading
       hmfw-version-029 reading
       hmfw-version-030 reading
       hmfw-version-031 reading
       hmfw-version-032 reading
       hmfw-version-033 reading
       hmfw-version-034 reading
       hmfw-version-035 reading
       hmfw-version-036 reading
       hmfw-version-037 reading
       hmfw-version-038 reading
       hmfw-version-039 reading
       hmfw-version-040 reading
       hmfw-version-041 reading
       hmfw-version-042 reading
       hmfw-version-043 reading
       hmfw-version-044 reading
       hmfw-version-045 reading
       hmfw-version-046 reading
       hmfw-version-047 reading
       hmfw-version-048 reading
       hmfw-version-049 reading
       hmfw-version-050 reading
       hmfw-version-051 reading
       hmfw-version-052 reading
       hmfw-version-053 reading
       hmfw-version-054 reading
       hmfw-version-055 reading
       hmfw-version-056 reading
       hmfw-version-057 reading
       hmfw-version-058 reading
       hmfw-version-059 reading
       hmfw-version-060 reading
       hmfw-version-061 reading
       hmfw-version-062 reading
       hmfw-version-063 reading
       hmfw-version-064 reading
       hmfw-version-065 reading
       hmfw-version-066 reading
       hmfw-version-067 reading
       hmfw-version-068 reading
       hmfw-version-069 reading
       hmfw-version-070 reading
       hmfw-version-071 reading
       hmfw-version-072 reading
       hmfw-version-073 reading
       hmfw-version-074 reading
       hmfw-version-075 reading
       hmfw-version-076 reading
       hmfw-version-077 reading
       hmfw-version-078 reading
       hmfw-version-079 reading
       hmfw-version-080 reading
       hmfw-version-081 reading
       hmfw-version-082 reading
       hmfw-version-083 reading
       hmfw-version-084 reading
       hmfw-version-085 reading
       hmfw-version-086 reading
       hmfw-version-087 reading
       hmfw-version-088 reading
       hmfw-version-089 reading
       hmfw-version-090 reading
       hmfw-version-091 reading
       hmfw-version-092 reading
       hmfw-version-093 reading
       hmfw-version-094 reading
       hmfw-version-095 reading
       hmfw-version-096 reading
       hmfw-version-097 reading
       hmfw-version-098 reading
       hmfw-version-099 reading
       hmfw-version-100 reading
       hmfw-version-101 reading
       hmfw-version-102 reading
       hmfw-version-103 reading
       hmfw-version-104 reading
       hmfw-version-105 reading
       hmfw-version-106 reading
       hmfw-version-107 reading
       hmfw-version-108 reading
       hmfw-version-109 reading
       hmfw-version-110 reading
       hmfw-version-111 reading
       hmfw-version-112 reading
       hmfw-version-113 reading
       hmfw-version-114 reading
       hmfw-version-115 reading
       hmfw-version-116 reading
       hmfw-version-117 reading
       hmfw-version-118 reading
       hmfw-version-119 reading
       hmfw-version-120 reading
       hmfw-version-121 reading
       hmfw-version-122 reading
       hmfw-version-123 reading
       hmfw-version-124 reading
       hmfw-version-125 reading
       hmfw-version-126 reading
       hmfw-version-127 reading
       hmfw-version-128 reading
       hmfw-version-129 reading
       hmfw-version-130 reading
       hmfw-version-131 reading
       hmfw-version-132 reading
       hmfw-version-133 reading
       hmfw-version-134 reading
       hmfw-version-135 reading
       hmfw-version-136 reading
       hmfw-version-137 reading
       hmfw-version-138 reading
       hmfw-version-139 reading
       hmfw-version-140 reading
       hmfw-version-141 reading
       hmfw-version-142 reading
       hmfw-version-143 reading
       hmfw-version-144 reading
       hmfw-version-145 reading
     readingNum:
       hmfw-type-001 01
       hmfw-type-002 01
       hmfw-type-003 01
       hmfw-type-004 01
       hmfw-type-005 01
       hmfw-type-006 01
       hmfw-type-007 01
       hmfw-type-008 01
       hmfw-type-009 01
       hmfw-type-010 01
       hmfw-type-011 01
       hmfw-type-012 01
       hmfw-type-013 01
       hmfw-type-014 01
       hmfw-type-015 01
       hmfw-type-016 01
       hmfw-type-017 01
       hmfw-type-018 01
       hmfw-type-019 01
       hmfw-type-020 01
       hmfw-type-021 01
       hmfw-type-022 01
       hmfw-type-023 01
       hmfw-type-024 01
       hmfw-type-025 01
       hmfw-type-026 01
       hmfw-type-027 01
       hmfw-type-028 01
       hmfw-type-029 01
       hmfw-type-030 01
       hmfw-type-031 01
       hmfw-type-032 01
       hmfw-type-033 01
       hmfw-type-034 01
       hmfw-type-035 01
       hmfw-type-036 01
       hmfw-type-037 01
       hmfw-type-038 01
       hmfw-type-039 01
       hmfw-type-040 01
       hmfw-type-041 01
       hmfw-type-042 01
       hmfw-type-043 01
       hmfw-type-044 01
       hmfw-type-045 01
       hmfw-type-046 01
       hmfw-type-047 01
       hmfw-type-048 01
       hmfw-type-049 01
       hmfw-type-050 01
       hmfw-type-051 01
       hmfw-type-052 01
       hmfw-type-053 01
       hmfw-type-054 01
       hmfw-type-055 01
       hmfw-type-056 01
       hmfw-type-057 01
       hmfw-type-058 01
       hmfw-type-059 01
       hmfw-type-060 01
       hmfw-type-061 01
       hmfw-type-062 01
       hmfw-type-063 01
       hmfw-type-064 01
       hmfw-type-065 01
       hmfw-type-066 01
       hmfw-type-067 01
       hmfw-type-068 01
       hmfw-type-069 01
       hmfw-type-070 01
       hmfw-type-071 01
       hmfw-type-072 01
       hmfw-type-073 01
       hmfw-type-074 01
       hmfw-type-075 01
       hmfw-type-076 01
       hmfw-type-077 01
       hmfw-type-078 01
       hmfw-type-079 01
       hmfw-type-080 01
       hmfw-type-081 01
       hmfw-type-082 01
       hmfw-type-083 01
       hmfw-type-084 01
       hmfw-type-085 01
       hmfw-type-086 01
       hmfw-type-087 01
       hmfw-type-088 01
       hmfw-type-089 01
       hmfw-type-090 01
       hmfw-type-091 01
       hmfw-type-092 01
       hmfw-type-093 01
       hmfw-type-094 01
       hmfw-type-095 01
       hmfw-type-096 01
       hmfw-type-097 01
       hmfw-type-098 01
       hmfw-type-099 01
       hmfw-type-100 01
       hmfw-type-101 01
       hmfw-type-102 01
       hmfw-type-103 01
       hmfw-type-104 01
       hmfw-type-105 01
       hmfw-type-106 01
       hmfw-type-107 01
       hmfw-type-108 01
       hmfw-type-109 01
       hmfw-type-110 01
       hmfw-type-111 01
       hmfw-type-112 01
       hmfw-type-113 01
       hmfw-type-114 01
       hmfw-type-115 01
       hmfw-type-116 01
       hmfw-type-117 01
       hmfw-type-118 01
       hmfw-type-119 01
       hmfw-type-120 01
       hmfw-type-121 01
       hmfw-type-122 01
       hmfw-type-123 01
       hmfw-type-124 01
       hmfw-type-125 01
       hmfw-type-126 01
       hmfw-type-127 01
       hmfw-type-128 01
       hmfw-type-129 01
       hmfw-type-130 01
       hmfw-type-131 01
       hmfw-type-132 01
       hmfw-type-133 01
       hmfw-type-134 01
       hmfw-type-135 01
       hmfw-type-136 01
       hmfw-type-137 01
       hmfw-type-138 01
       hmfw-type-139 01
       hmfw-type-140 01
       hmfw-type-141 01
       hmfw-type-142 01
       hmfw-type-143 01
       hmfw-type-144 01
       hmfw-type-145 01
       hmfw-version-001 02
       hmfw-version-002 02
       hmfw-version-003 02
       hmfw-version-004 02
       hmfw-version-005 02
       hmfw-version-006 02
       hmfw-version-007 02
       hmfw-version-008 02
       hmfw-version-009 02
       hmfw-version-010 02
       hmfw-version-011 02
       hmfw-version-012 02
       hmfw-version-013 02
       hmfw-version-014 02
       hmfw-version-015 02
       hmfw-version-016 02
       hmfw-version-017 02
       hmfw-version-018 02
       hmfw-version-019 02
       hmfw-version-020 02
       hmfw-version-021 02
       hmfw-version-022 02
       hmfw-version-023 02
       hmfw-version-024 02
       hmfw-version-025 02
       hmfw-version-026 02
       hmfw-version-027 02
       hmfw-version-028 02
       hmfw-version-029 02
       hmfw-version-030 02
       hmfw-version-031 02
       hmfw-version-032 02
       hmfw-version-033 02
       hmfw-version-034 02
       hmfw-version-035 02
       hmfw-version-036 02
       hmfw-version-037 02
       hmfw-version-038 02
       hmfw-version-039 02
       hmfw-version-040 02
       hmfw-version-041 02
       hmfw-version-042 02
       hmfw-version-043 02
       hmfw-version-044 02
       hmfw-version-045 02
       hmfw-version-046 02
       hmfw-version-047 02
       hmfw-version-048 02
       hmfw-version-049 02
       hmfw-version-050 02
       hmfw-version-051 02
       hmfw-version-052 02
       hmfw-version-053 02
       hmfw-version-054 02
       hmfw-version-055 02
       hmfw-version-056 02
       hmfw-version-057 02
       hmfw-version-058 02
       hmfw-version-059 02
       hmfw-version-060 02
       hmfw-version-061 02
       hmfw-version-062 02
       hmfw-version-063 02
       hmfw-version-064 02
       hmfw-version-065 02
       hmfw-version-066 02
       hmfw-version-067 02
       hmfw-version-068 02
       hmfw-version-069 02
       hmfw-version-070 02
       hmfw-version-071 02
       hmfw-version-072 02
       hmfw-version-073 02
       hmfw-version-074 02
       hmfw-version-075 02
       hmfw-version-076 02
       hmfw-version-077 02
       hmfw-version-078 02
       hmfw-version-079 02
       hmfw-version-080 02
       hmfw-version-081 02
       hmfw-version-082 02
       hmfw-version-083 02
       hmfw-version-084 02
       hmfw-version-085 02
       hmfw-version-086 02
       hmfw-version-087 02
       hmfw-version-088 02
       hmfw-version-089 02
       hmfw-version-090 02
       hmfw-version-091 02
       hmfw-version-092 02
       hmfw-version-093 02
       hmfw-version-094 02
       hmfw-version-095 02
       hmfw-version-096 02
       hmfw-version-097 02
       hmfw-version-098 02
       hmfw-version-099 02
       hmfw-version-100 02
       hmfw-version-101 02
       hmfw-version-102 02
       hmfw-version-103 02
       hmfw-version-104 02
       hmfw-version-105 02
       hmfw-version-106 02
       hmfw-version-107 02
       hmfw-version-108 02
       hmfw-version-109 02
       hmfw-version-110 02
       hmfw-version-111 02
       hmfw-version-112 02
       hmfw-version-113 02
       hmfw-version-114 02
       hmfw-version-115 02
       hmfw-version-116 02
       hmfw-version-117 02
       hmfw-version-118 02
       hmfw-version-119 02
       hmfw-version-120 02
       hmfw-version-121 02
       hmfw-version-122 02
       hmfw-version-123 02
       hmfw-version-124 02
       hmfw-version-125 02
       hmfw-version-126 02
       hmfw-version-127 02
       hmfw-version-128 02
       hmfw-version-129 02
       hmfw-version-130 02
       hmfw-version-131 02
       hmfw-version-132 02
       hmfw-version-133 02
       hmfw-version-134 02
       hmfw-version-135 02
       hmfw-version-136 02
       hmfw-version-137 02
       hmfw-version-138 02
       hmfw-version-139 02
       hmfw-version-140 02
       hmfw-version-141 02
       hmfw-version-142 02
       hmfw-version-143 02
       hmfw-version-144 02
       hmfw-version-145 02
     readingOutdated:
     readingSubNum:
       hmfw-type-001 -1
       hmfw-type-002 -2
       hmfw-type-003 -3
       hmfw-type-004 -4
       hmfw-type-005 -5
       hmfw-type-006 -6
       hmfw-type-007 -7
       hmfw-type-008 -8
       hmfw-type-009 -9
       hmfw-type-010 -10
       hmfw-type-011 -11
       hmfw-type-012 -12
       hmfw-type-013 -13
       hmfw-type-014 -14
       hmfw-type-015 -15
       hmfw-type-016 -16
       hmfw-type-017 -17
       hmfw-type-018 -18
       hmfw-type-019 -19
       hmfw-type-020 -20
       hmfw-type-021 -21
       hmfw-type-022 -22
       hmfw-type-023 -23
       hmfw-type-024 -24
       hmfw-type-025 -25
       hmfw-type-026 -26
       hmfw-type-027 -27
       hmfw-type-028 -28
       hmfw-type-029 -29
       hmfw-type-030 -30
       hmfw-type-031 -31
       hmfw-type-032 -32
       hmfw-type-033 -33
       hmfw-type-034 -34
       hmfw-type-035 -35
       hmfw-type-036 -36
       hmfw-type-037 -37
       hmfw-type-038 -38
       hmfw-type-039 -39
       hmfw-type-040 -40
       hmfw-type-041 -41
       hmfw-type-042 -42
       hmfw-type-043 -43
       hmfw-type-044 -44
       hmfw-type-045 -45
       hmfw-type-046 -46
       hmfw-type-047 -47
       hmfw-type-048 -48
       hmfw-type-049 -49
       hmfw-type-050 -50
       hmfw-type-051 -51
       hmfw-type-052 -52
       hmfw-type-053 -53
       hmfw-type-054 -54
       hmfw-type-055 -55
       hmfw-type-056 -56
       hmfw-type-057 -57
       hmfw-type-058 -58
       hmfw-type-059 -59
       hmfw-type-060 -60
       hmfw-type-061 -61
       hmfw-type-062 -62
       hmfw-type-063 -63
       hmfw-type-064 -64
       hmfw-type-065 -65
       hmfw-type-066 -66
       hmfw-type-067 -67
       hmfw-type-068 -68
       hmfw-type-069 -69
       hmfw-type-070 -70
       hmfw-type-071 -71
       hmfw-type-072 -72
       hmfw-type-073 -73
       hmfw-type-074 -74
       hmfw-type-075 -75
       hmfw-type-076 -76
       hmfw-type-077 -77
       hmfw-type-078 -78
       hmfw-type-079 -79
       hmfw-type-080 -80
       hmfw-type-081 -81
       hmfw-type-082 -82
       hmfw-type-083 -83
       hmfw-type-084 -84
       hmfw-type-085 -85
       hmfw-type-086 -86
       hmfw-type-087 -87
       hmfw-type-088 -88
       hmfw-type-089 -89
       hmfw-type-090 -90
       hmfw-type-091 -91
       hmfw-type-092 -92
       hmfw-type-093 -93
       hmfw-type-094 -94
       hmfw-type-095 -95
       hmfw-type-096 -96
       hmfw-type-097 -97
       hmfw-type-098 -98
       hmfw-type-099 -99
       hmfw-type-100 -100
       hmfw-type-101 -101
       hmfw-type-102 -102
       hmfw-type-103 -103
       hmfw-type-104 -104
       hmfw-type-105 -105
       hmfw-type-106 -106
       hmfw-type-107 -107
       hmfw-type-108 -108
       hmfw-type-109 -109
       hmfw-type-110 -110
       hmfw-type-111 -111
       hmfw-type-112 -112
       hmfw-type-113 -113
       hmfw-type-114 -114
       hmfw-type-115 -115
       hmfw-type-116 -116
       hmfw-type-117 -117
       hmfw-type-118 -118
       hmfw-type-119 -119
       hmfw-type-120 -120
       hmfw-type-121 -121
       hmfw-type-122 -122
       hmfw-type-123 -123
       hmfw-type-124 -124
       hmfw-type-125 -125
       hmfw-type-126 -126
       hmfw-type-127 -127
       hmfw-type-128 -128
       hmfw-type-129 -129
       hmfw-type-130 -130
       hmfw-type-131 -131
       hmfw-type-132 -132
       hmfw-type-133 -133
       hmfw-type-134 -134
       hmfw-type-135 -135
       hmfw-type-136 -136
       hmfw-type-137 -137
       hmfw-type-138 -138
       hmfw-type-139 -139
       hmfw-type-140 -140
       hmfw-type-141 -141
       hmfw-type-142 -142
       hmfw-type-143 -143
       hmfw-type-144 -144
       hmfw-type-145 -145
       hmfw-version-001 -1
       hmfw-version-002 -2
       hmfw-version-003 -3
       hmfw-version-004 -4
       hmfw-version-005 -5
       hmfw-version-006 -6
       hmfw-version-007 -7
       hmfw-version-008 -8
       hmfw-version-009 -9
       hmfw-version-010 -10
       hmfw-version-011 -11
       hmfw-version-012 -12
       hmfw-version-013 -13
       hmfw-version-014 -14
       hmfw-version-015 -15
       hmfw-version-016 -16
       hmfw..............
LG Chris
Devices: APC, Davis, Eastron, FS20, Homematic, IT, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, SkyWind, TEK603
yersinia
#1
Nope, keine Probleme hier:
   .Content-Type  text/plain
   .LASTSEND  1649505600.00255
   .LastUpdate 1649505600.00086
   .MaxAgeEnabled 1
   .TRIGGERTIME 1649592000
   .TimeAlign 1649419200
   .getList
   .setList   interval reread:noArg stop:noArg start:noArg clearCookies:noArg upgradeAttributes:noArg storeKeyValue
   BUSY       0
   FUUID      5e33d128-f33f-3151-f713-e0a464384facd1b8
   Interval   86400
   NAME       HM_FW_Check
   NOTIFYDEV  global
   NR         306
   NTFY_ORDER 50-HM_FW_Check
   STATE      <div style="text-align:left;"><div>last <a title="eq3-downloads" href="http://www.eq-3.de/service/downloads.html" rel="noopener noreferrer" target="_blank">homematic</a>-fw-check => 2022-04-09 14:00:00</div><div style="color:limegreen;font-weight:bold;">no fw-updates needed!</div><div style="text-align:left;">(next check: 2022-04-10 14:00:00)</div></div>
   TYPE       HTTPMOD
   value
   .attraggr:
   .attrminint:
   .readingParseList:
     01
     02
   .userReadings:
     HASH(0x5594933f98)
   CompiledRegexes:
   HttpUtils:
     NAME
     auth       0
     buf
     code       200
     compress   1
     conn
     data
     header
Server: nginx
Date: Sat, 09 Apr 2022 12:00:00 GMT
Connection: close
     httpversion 1.0
     hu_blocking 0
     hu_filecount 1
     hu_port    443
     hu_portSfx
     ignoreredirects 1
     loglevel   4
     protocol   https
     redirects  0
     timeout    2
     sslargs:
   QUEUE:
     2021-10-24 14:00:01   LAST_ERROR      DNS 192.168.40.40 timed out
     2022-04-09 14:00:00   LAST_REQUEST    update
     2022-04-09 14:00:00   MATCHED_READINGS hmfw-type-001 hmfw-type-002 hmfw-type-003 hmfw-type-004 hmfw-type-005 hmfw-type-006 hmfw-type-007 hmfw-type-008 hmfw-type-009 hmfw-type-010 hmfw-type-011 hmfw-type-012 hmfw-type-013 hmfw-type-014 hmfw-type-015 hmfw-type-016 hmfw-type-017 hmfw-type-018 hmfw-type-019 hmfw-type-020 hmfw-type-021 hmfw-type-022 hmfw-type-023 hmfw-type-024 hmfw-type-025 hmfw-type-026 hmfw-type-027 hmfw-type-028 hmfw-type-029 hmfw-type-030 hmfw-type-031 hmfw-type-032 hmfw-type-033 hmfw-type-034 hmfw-type-035 hmfw-type-036 hmfw-type-037 hmfw-type-038 hmfw-type-039 hmfw-type-040 hmfw-type-041 hmfw-type-042 hmfw-type-043 hmfw-type-044 hmfw-type-045 hmfw-type-046 hmfw-type-047 hmfw-type-048 hmfw-type-049 hmfw-type-050 hmfw-type-051 hmfw-type-052 hmfw-type-053 hmfw-type-054 hmfw-type-055 hmfw-type-056 hmfw-type-057 hmfw-type-058 hmfw-type-059 hmfw-type-060 hmfw-type-061 hmfw-type-062 hmfw-type-063 hmfw-type-064 hmfw-type-065 hmfw-type-066 hmfw-type-067 hmfw-type-068 hmfw-type-069 hmfw-type-070 hmfw-type-071 hmfw-type-072 hmfw-type-073 hmfw-type-074 hmfw-type-075 hmfw-type-076 hmfw-type-077 hmfw-type-078 hmfw-type-079 hmfw-type-080 hmfw-type-081 hmfw-type-082 hmfw-type-083 hmfw-type-084 hmfw-type-085 hmfw-type-086 hmfw-type-087 hmfw-type-088 hmfw-type-089 hmfw-type-090 hmfw-type-091 hmfw-type-092 hmfw-type-093 hmfw-type-094 hmfw-type-095 hmfw-type-096 hmfw-type-097 hmfw-type-098 hmfw-type-099 hmfw-type-100 hmfw-type-101 hmfw-type-102 hmfw-type-103 hmfw-type-104 hmfw-type-105 hmfw-type-106 hmfw-type-107 hmfw-type-108 hmfw-type-109 hmfw-type-110 hmfw-type-111 hmfw-type-112 hmfw-type-113 hmfw-type-114 hmfw-type-115 hmfw-type-116 hmfw-type-117 hmfw-type-118 hmfw-type-119 hmfw-type-120 hmfw-type-121 hmfw-type-122 hmfw-type-123 hmfw-type-124 hmfw-type-125 hmfw-type-126 hmfw-type-127 hmfw-type-128 hmfw-type-129 hmfw-type-130 hmfw-type-131 hmfw-type-132 hmfw-type-133 hmfw-type-134 hmfw-type-135 hmfw-type-136 hmfw-type-137 hmfw-type-138 hmfw-type-139 hmfw-type-140 hmfw-type-141 hmfw-type-142 hmfw-type-143 hmfw-type-144 hmfw-type-145 hmfw-version-001 hmfw-version-002 hmfw-version-003 hmfw-version-004 hmfw-version-005 hmfw-version-006 hmfw-version-007 hmfw-version-008 hmfw-version-009 hmfw-version-010 hmfw-version-011 hmfw-version-012 hmfw-version-013 hmfw-version-014 hmfw-version-015 hmfw-version-016 hmfw-version-017 hmfw-version-018 hmfw-version-019 hmfw-version-020 hmfw-version-021 hmfw-version-022 hmfw-version-023 hmfw-version-024 hmfw-version-025 hmfw-version-026 hmfw-version-027 hmfw-version-028 hmfw-version-029 hmfw-version-030 hmfw-version-031 hmfw-version-032 hmfw-version-033 hmfw-version-034 hmfw-version-035 hmfw-version-036 hmfw-version-037 hmfw-version-038 hmfw-version-039 hmfw-version-040 hmfw-version-041 hmfw-version-042 hmfw-version-043 hmfw-version-044 hmfw-version-045 hmfw-version-046 hmfw-version-047 hmfw-version-048 hmfw-version-049 hmfw-version-050 hmfw-version-051 hmfw-version-052 hmfw-version-053 hmfw-version-054 hmfw-version-055 hmfw-version-056 hmfw-version-057 hmfw-version-058 hmfw-version-059 hmfw-version-060 hmfw-version-061 hmfw-version-062 hmfw-version-063 hmfw-version-064 hmfw-version-065 hmfw-version-066 hmfw-version-067 hmfw-version-068 hmfw-version-069 hmfw-version-070 hmfw-version-071 hmfw-version-072 hmfw-version-073 hmfw-version-074 hmfw-version-075 hmfw-version-076 hmfw-version-077 hmfw-version-078 hmfw-version-079 hmfw-version-080 hmfw-version-081 hmfw-version-082 hmfw-version-083 hmfw-version-084 hmfw-version-085 hmfw-version-086 hmfw-version-087 hmfw-version-088 hmfw-version-089 hmfw-version-090 hmfw-version-091 hmfw-version-092 hmfw-version-093 hmfw-version-094 hmfw-version-095 hmfw-version-096 hmfw-version-097 hmfw-version-098 hmfw-version-099 hmfw-version-100 hmfw-version-101 hmfw-version-102 hmfw-version-103 hmfw-version-104 hmfw-version-105 hmfw-version-106 hmfw-version-107 hmfw-version-108 hmfw-version-109 hmfw-version-110 hmfw-version-111 hmfw-version-112 hmfw-version-113 hmfw-version-114 hmfw-version-115 hmfw-version-116 hmfw-version-117 hmfw-version-118 hmfw-version-119 hmfw-version-120 hmfw-version-121 hmfw-version-122 hmfw-version-123 hmfw-version-124 hmfw-version-125 hmfw-version-126 hmfw-version-127 hmfw-version-128 hmfw-version-129 hmfw-version-130 hmfw-version-131 hmfw-version-132 hmfw-version-133 hmfw-version-134 hmfw-version-135 hmfw-version-136 hmfw-version-137 hmfw-version-138 hmfw-version-139 hmfw-version-140 hmfw-version-141 hmfw-version-142 hmfw-version-143 hmfw-version-144 hmfw-version-145
     2022-04-09 14:00:00   UNMATCHED_READINGS
     2022-04-09 14:00:00   hmfw-type-001   HmIPW-WTH
     2022-04-09 14:00:00   hmfw-type-002   HM-LC-Dim1L-Pl-3
     2022-04-09 14:00:00   hmfw-type-003   HmIPW-DRD3
     2022-04-09 14:00:00   hmfw-type-004   HmIP-FALMOT-C12
     2022-04-09 14:00:00   hmfw-type-005   HmIP-SWO-PR
     2022-04-09 14:00:00   hmfw-type-006   HM-ES-PMSw1-Pl
     2022-04-09 14:00:00   hmfw-type-007   HmIP-WHS2
     2022-04-09 14:00:00   hmfw-type-008   HmIP-SWO-B
     2022-04-09 14:00:00   hmfw-type-009   HmIPW-FIO6
     2022-04-09 14:00:00   hmfw-type-010   HmIP-eTRV-E
     2022-04-09 14:00:00   hmfw-type-011   HmIP-PDT
     2022-04-09 14:00:00   hmfw-type-012   HM-ES-PMSw1-Pl-DN-R3
     2022-04-09 14:00:00   hmfw-type-013   HmIP-PSM-IT
     2022-04-09 14:00:00   hmfw-type-014   HmIP-PS
     2022-04-09 14:00:00   hmfw-type-015   HmIP-FROLL
     2022-04-09 14:00:00   hmfw-type-016   HmIP-FCI6
     2022-04-09 14:00:00   hmfw-type-017   HM-LC-Dim1TPBU-FM
     2022-04-09 14:00:00   hmfw-type-018   HmIPW-FAL230-C6
     2022-04-09 14:00:00   hmfw-type-019   HM-ES-PMSw1-Pl-DN-R2
     2022-04-09 14:00:00   hmfw-type-020   HmIP-SPDR
     2022-04-09 14:00:00   hmfw-type-021   HmIP-SFD
     2022-04-09 14:00:00   hmfw-type-022   HM-LC-Sw1-Pl-DN-R1
     2022-04-09 14:00:00   hmfw-type-023   HmIP-STHD
     2022-04-09 14:00:00   hmfw-type-024   HmIP-eTRV-C
     2022-04-09 14:00:00   hmfw-type-025   HmIP-SMI
     2022-04-09 14:00:00   hmfw-type-026   HmIPW-DRI32
     2022-04-09 14:00:00   hmfw-type-027   HmIP-SWDO-I
     2022-04-09 14:00:00   hmfw-type-028   HmIP-STHO
     2022-04-09 14:00:00   hmfw-type-029   HmIP-PSM-UK
     2022-04-09 14:00:00   hmfw-type-030   HmIP-WTH-2
     2022-04-09 14:00:00   hmfw-type-031   HmIP-ASIR-O
     2022-04-09 14:00:00   hmfw-type-032   HmIP-ASIR-2
     2022-04-09 14:00:00   hmfw-type-033   HmIP-DRSI1
     2022-04-09 14:00:00   hmfw-type-034   HM-LC-Sw1-Pl-DN-R4
     2022-04-09 14:00:00   hmfw-type-035   HM-LC-Dim1T-DR
     2022-04-09 14:00:00   hmfw-type-036   HmIP-MOD-HO
     2022-04-09 14:00:00   hmfw-type-037   HmIPW-SMI55
     2022-04-09 14:00:00   hmfw-type-038   HmIP-SCI
     2022-04-09 14:00:00   hmfw-type-039   HmIP-FAL230-C6
     2022-04-09 14:00:00   hmfw-type-040   HmIPW-SPI
     2022-04-09 14:00:00   hmfw-type-041   HmIP-DRSI4
     2022-04-09 14:00:00   hmfw-type-042   HmIP-ASIR
     2022-04-09 14:00:00   hmfw-type-043   HmIP-BWTH24
     2022-04-09 14:00:00   hmfw-type-044   HmIP-STHO-A
     2022-04-09 14:00:00   hmfw-type-045   HmIP-BBL
     2022-04-09 14:00:00   hmfw-type-046   HmIP-SMO-A
     2022-04-09 14:00:00   hmfw-type-047   HmIPW-FALMOT-C12
     2022-04-09 14:00:00   hmfw-type-048   HmIP-RC8
     2022-04-09 14:00:00   hmfw-type-049   HmIP-WRC6
     2022-04-09 14:00:00   hmfw-type-050   HmIP-FAL230-C10
     2022-04-09 14:00:00   hmfw-type-051   HmIP-RCB1
     2022-04-09 14:00:00   hmfw-type-052   HmIP-MIOB
     2022-04-09 14:00:00   hmfw-type-053   HmIP-DLD
     2022-04-09 14:00:00   hmfw-type-054   HmIP-STI
     2022-04-09 14:00:00   hmfw-type-055   HmIP-DLS
     2022-04-09 14:00:00   hmfw-type-056   HmIPW-DRAP
     2022-04-09 14:00:00   hmfw-type-057   HmIP-DSD-PCB
     2022-04-09 14:00:00   hmfw-type-058   HM-LC-Sw1-Pl-DN-R5
     2022-04-09 14:00:00   hmfw-type-059   HmIP-SMO-2
     2022-04-09 14:00:00   hmfw-type-060   HmIP-PSM-PE
     2022-04-09 14:00:00   hmfw-type-061   HmIP-BDT
     2022-04-09 14:00:00   hmfw-type-062   HmIP-SWSD-2
     2022-04-09 14:00:00   hmfw-type-063   HmIP-FSM16
     2022-04-09 14:00:00   hmfw-type-064   HmIP-BROLL
     2022-04-09 14:00:00   hmfw-type-065   HmIP-PSM-CH
     2022-04-09 14:00:00   hmfw-type-066   HM-OU-CFM-Pl
     2022-04-09 14:00:00   hmfw-type-067   HM-ES-PMSw1-Pl-DN-R1
     2022-04-09 14:00:00   hmfw-type-068   HmIP-SWO-PL
     2022-04-09 14:00:00   hmfw-type-069   HmIP-WRCC2
     2022-04-09 14:00:00   hmfw-type-070   HmIP-HAP
     2022-04-09 14:00:00   hmfw-type-071   HmIP-WRC2
     2022-04-09 14:00:00   hmfw-type-072   HmIPW-DRS4
     2022-04-09 14:00:00   hmfw-type-073   HmIP-STH
     2022-04-09 14:00:00   hmfw-type-074   HmIP-SMO
     2022-04-09 14:00:00   hmfw-type-075   HM-LC-Sw1-Pl-DN-R3
     2022-04-09 14:00:00   hmfw-type-076   HmIP-BSM
     2022-04-09 14:00:00   hmfw-type-077   HmIP-FCI1
     2022-04-09 14:00:00   hmfw-type-078   HmIP-SRD
     2022-04-09 14:00:00   hmfw-type-079   HmIP-SCTH230
     2022-04-09 14:00:00   hmfw-type-080   HM-LC-RGBW-WM
     2022-04-09 14:00:00   hmfw-type-081   HmIP-SRH
     2022-04-09 14:00:00   hmfw-type-082   HmIP-SPI
     2022-04-09 14:00:00   hmfw-type-083   HmIP-PS-2
     2022-04-09 14:00:00   hmfw-type-084   HmIP-FAL24-C10
     2022-04-09 14:00:00   hmfw-type-085   HmIP-KRCA
     2022-04-09 14:00:00   hmfw-type-086   HmIP-USBSM
     2022-04-09 14:00:00   hmfw-type-087   HmIP-MOD-OC8
     2022-04-09 14:00:00   hmfw-type-088   HmIP-WUA
     2022-04-09 14:00:00   hmfw-type-089   HmIPW-BRC2
     2022-04-09 14:00:00   hmfw-type-090   HM-CC-RT-DN
     2022-04-09 14:00:00   hmfw-type-091   HmIP-FSM
     2022-04-09 14:00:00   hmfw-type-092   HmIP-eTRV-C-2
     2022-04-09 14:00:00   hmfw-type-093   HM-LC-Dim1T-Pl-3
     2022-04-09 14:00:00   hmfw-type-094   HmIP-BSL
     2022-04-09 14:00:00   hmfw-type-095   HmIP-MIO16-PCB
     2022-04-09 14:00:00   hmfw-type-096   HmIP-PDT-UK
     2022-04-09 14:00:00   hmfw-type-097   HmIP-STE2-PCB
     2022-04-09 14:00:00   hmfw-type-098   HmIP-FDT
     2022-04-09 14:00:00   hmfw-type-099   HM-Dis-EP-WM55
     2022-04-09 14:00:00   hmfw-type-100   HM-ES-PMSw1-Pl-DN-R5
     2022-04-09 14:00:00   hmfw-type-101   HmIPW-FAL24-C6
     2022-04-09 14:00:00   hmfw-type-102   HmIPW-STH
     2022-04-09 14:00:00   hmfw-type-103   HmIPW-DRBL4
     2022-04-09 14:00:00   hmfw-type-104   HmIP-WTH
     2022-04-09 14:00:00   hmfw-type-105   HM-ES-PMSw1-Pl-DN-R4
     2022-04-09 14:00:00   hmfw-type-106   HmIP-FAL24-C6
     2022-04-09 14:00:00   hmfw-type-107   HmIPW-WRC2
     2022-04-09 14:00:00   hmfw-type-108   HM-MOD-Re-8
     2022-04-09 14:00:00   hmfw-type-109   HmIP-FSI16
     2022-04-09 14:00:00   hmfw-type-110   HmIP-SMO-A-2
     2022-04-09 14:00:00   hmfw-type-111   HmIP-DRBLI4
     2022-04-09 14:00:00   hmfw-type-112   HmIPW-FAL24-C10
     2022-04-09 14:00:00   hmfw-type-113   HM-LC-Dim1TPBU-FM
     2022-04-09 14:00:00   hmfw-type-114   HmIP-FBL
     2022-04-09 14:00:00   hmfw-type-115   HmIP-MP3P
     2022-04-09 14:00:00   hmfw-type-116   HmIP-MOD-TM
     2022-04-09 14:00:00   hmfw-type-117   HmIP-BWTH
     2022-04-09 14:00:00   hmfw-type-118   HM-OU-CFM-TW
     2022-04-09 14:00:00   hmfw-type-119   HM-LC-Bl1PBU-FM
     2022-04-09 14:00:00   hmfw-type-120   HM-TC-IT-WM-W-EU
     2022-04-09 14:00:00   hmfw-type-121   HmIPW-FAL230-C10
     2022-04-09 14:00:00   hmfw-type-122   HmIP-eTRV
     2022-04-09 14:00:00   hmfw-type-123   HmIP-SWD
     2022-04-09 14:00:00   hmfw-type-124   HmIP-SWDO-PL
     2022-04-09 14:00:00   hmfw-type-125   HM-LC-Sw1PBU-FM
     2022-04-09 14:00:00   hmfw-type-126   HM-LC-Sw1-Pl-DN-R2
     2022-04-09 14:00:00   hmfw-type-127   HmIP-eTRV-2
     2022-04-09 14:00:00   hmfw-type-128   ELV-SH-WSC
     2022-04-09 14:00:00   hmfw-type-129   HmIPW-DRS8
     2022-04-09 14:00:00   hmfw-type-130   HmIP-PSM
     2022-04-09 14:00:00   hmfw-type-131   HmIP-BS2
     2022-04-09 14:00:00   hmfw-type-132   HmIP-SWDO
     2022-04-09 14:00:00   hmfw-type-133   HmIP-PCBS
     2022-04-09 14:00:00   hmfw-type-134   HmIP-PMFS
     2022-04-09 14:00:00   hmfw-type-135   HmIP-PCBS2
     2022-04-09 14:00:00   hmfw-type-136   HmIP-STV
     2022-04-09 14:00:00   hmfw-type-137   HmIP-SLO
     2022-04-09 14:00:00   hmfw-type-138   HmIP-KRC4
     2022-04-09 14:00:00   hmfw-type-139   HmIP-eTRV-2-UK
     2022-04-09 14:00:00   hmfw-type-140   HmIPW-STHD
     2022-04-09 14:00:00   hmfw-type-141   HmIP-SMI55
     2022-04-09 14:00:00   hmfw-type-142   HmIP-WGC
     2022-04-09 14:00:00   hmfw-type-143   HM-LC-Dim1PWM-CV
     2022-04-09 14:00:00   hmfw-type-144   HM-Sen-MDIR-WM55
     2022-04-09 14:00:00   hmfw-type-145   HmIPW-DRI16
     2022-04-09 14:00:00   hmfw-version-001 2.4.6
     2022-04-09 14:00:00   hmfw-version-002 2.9.7
     2022-04-09 14:00:00   hmfw-version-003 1.0.0
     2022-04-09 14:00:00   hmfw-version-004 1.4.6
     2022-04-09 14:00:00   hmfw-version-005 1.0.18
     2022-04-09 14:00:00   hmfw-version-006 2.6.0
     2022-04-09 14:00:00   hmfw-version-007 1.4.2
     2022-04-09 14:00:00   hmfw-version-008 1.0.18
     2022-04-09 14:00:00   hmfw-version-009 1.2.6
     2022-04-09 14:00:00   hmfw-version-010 1.0.10
     2022-04-09 14:00:00   hmfw-version-011 1.4.8
     2022-04-09 14:00:00   hmfw-version-012 2.6.0
     2022-04-09 14:00:00   hmfw-version-013 2.18.22
     2022-04-09 14:00:00   hmfw-version-014 2.6.2
     2022-04-09 14:00:00   hmfw-version-015 1.8.12
     2022-04-09 14:00:00   hmfw-version-016 1.0.16
     2022-04-09 14:00:00   hmfw-version-017 2.9.5
     2022-04-09 14:00:00   hmfw-version-018 2.0.2
     2022-04-09 14:00:00   hmfw-version-019 2.6.0
     2022-04-09 14:00:00   hmfw-version-020 1.2.0
     2022-04-09 14:00:00   hmfw-version-021 1.2.22
     2022-04-09 14:00:00   hmfw-version-022 2.6.0
     2022-04-09 14:00:00   hmfw-version-023 2.6.0
     2022-04-09 14:00:00   hmfw-version-024 1.2.4
     2022-04-09 14:00:00   hmfw-version-025 1.4.8
     2022-04-09 14:00:00   hmfw-version-026 1.2.2
     2022-04-09 14:00:00   hmfw-version-027 1.16.10
     2022-04-09 14:00:00   hmfw-version-028 1.0.6
     2022-04-09 14:00:00   hmfw-version-029 2.18.22
     2022-04-09 14:00:00   hmfw-version-030 2.6.0
     2022-04-09 14:00:00   hmfw-version-031 1.0.6
     2022-04-09 14:00:00   hmfw-version-032 1.4.2
     2022-04-09 14:00:00   hmfw-version-033 1.6.0
     2022-04-09 14:00:00   hmfw-version-034 2.6.0
     2022-04-09 14:00:00   hmfw-version-035 1.1.0
     2022-04-09 14:00:00   hmfw-version-036 1.0.14
     2022-04-09 14:00:00   hmfw-version-037 1.0.20
     2022-04-09 14:00:00   hmfw-version-038 1.0.6
     2022-04-09 14:00:00   hmfw-version-039 2.0.4
     2022-04-09 14:00:00   hmfw-version-040 1.0.30
     2022-04-09 14:00:00   hmfw-version-041 1.4.2
     2022-04-09 14:00:00   hmfw-version-042 1.4.2
     2022-04-09 14:00:00   hmfw-version-043 1.2.4
     2022-04-09 14:00:00   hmfw-version-044 1.0.6
     2022-04-09 14:00:00   hmfw-version-045 1.8.20
     2022-04-09 14:00:00   hmfw-version-046 1.2.8
     2022-04-09 14:00:00   hmfw-version-047 1.4.6
     2022-04-09 14:00:00   hmfw-version-048 1.0.19
     2022-04-09 14:00:00   hmfw-version-049 1.0.19
     2022-04-09 14:00:00   hmfw-version-050 2.0.4
     2022-04-09 14:00:00   hmfw-version-051 1.2.4
     2022-04-09 14:00:00   hmfw-version-052 1.8.4
     2022-04-09 14:00:00   hmfw-version-053 1.4.10
     2022-04-09 14:00:00   hmfw-version-054 1.0.0
     2022-04-09 14:00:00   hmfw-version-055 1.2.4
     2022-04-09 14:00:00   hmfw-version-056 2.4.14
     2022-04-09 14:00:00   hmfw-version-057 1.0.6
     2022-04-09 14:00:00   hmfw-version-058 2.6.0
     2022-04-09 14:00:00   hmfw-version-059 1.2.10
     2022-04-09 14:00:00   hmfw-version-060 2.18.22
     2022-04-09 14:00:00   hmfw-version-061 1.4.8
     2022-04-09 14:00:00   hmfw-version-062 1.0.4
     2022-04-09 14:00:00   hmfw-version-063 1.18.22
     2022-04-09 14:00:00   hmfw-version-064 1.8.20
     2022-04-09 14:00:00   hmfw-version-065 2.18.22
     2022-04-09 14:00:00   hmfw-version-066 2.4.2
     2022-04-09 14:00:00   hmfw-version-067 2.6.0
     2022-04-09 14:00:00   hmfw-version-068 1.0.18
     2022-04-09 14:00:00   hmfw-version-069 2.2.8
     2022-04-09 14:00:00   hmfw-version-070 2.4.12
     2022-04-09 14:00:00   hmfw-version-071 1.10.0
     2022-04-09 14:00:00   hmfw-version-072 1.2.4
     2022-04-09 14:00:00   hmfw-version-073 2.6.0
     2022-04-09 14:00:00   hmfw-version-074 1.2.8
     2022-04-09 14:00:00   hmfw-version-075 2.6.0
     2022-04-09 14:00:00   hmfw-version-076 1.18.14
     2022-04-09 14:00:00   hmfw-version-077 1.0.14
     2022-04-09 14:00:00   hmfw-version-078 1.0.18
     2022-04-09 14:00:00   hmfw-version-079 1.0.6
     2022-04-09 14:00:00   hmfw-version-080 1.0.0
     2022-04-09 14:00:00   hmfw-version-081 1.2.10
     2022-04-09 14:00:00   hmfw-version-082 1.4.0
     2022-04-09 14:00:00   hmfw-version-083 2.22.0
     2022-04-09 14:00:00   hmfw-version-084 2.0.4
     2022-04-09 14:00:00   hmfw-version-085 1.10.0
     2022-04-09 14:00:00   hmfw-version-086 1.0.16
     2022-04-09 14:00:00   hmfw-version-087 1.8.12
     2022-04-09 14:00:00   hmfw-version-088 1.0.14
     2022-04-09 14:00:00   hmfw-version-089 2.2.10
     2022-04-09 14:00:00   hmfw-version-090 1.5.3
     2022-04-09 14:00:00   hmfw-version-091 1.18.22
     2022-04-09 14:00:00   hmfw-version-092 1.4.14
     2022-04-09 14:00:00   hmfw-version-093 2.9.5
     2022-04-09 14:00:00   hmfw-version-094 1.0.2
     2022-04-09 14:00:00   hmfw-version-095 1.0.10
     2022-04-09 14:00:00   hmfw-version-096 1.4.8
     2022-04-09 14:00:00   hmfw-version-097 1.0.26
     2022-04-09 14:00:00   hmfw-version-098 1.4.8
     2022-04-09 14:00:00   hmfw-version-099 1.2.0
     2022-04-09 14:00:00   hmfw-version-100 2.6.0
     2022-04-09 14:00:00   hmfw-version-101 2.0.2
     2022-04-09 14:00:00   hmfw-version-102 2.4.6
     2022-04-09 14:00:00   hmfw-version-103 1.8.2
     2022-04-09 14:00:00   hmfw-version-104 2.4.8
     2022-04-09 14:00:00   hmfw-version-105 2.6.0
     2022-04-09 14:00:00   hmfw-version-106 2.0.4
     2022-04-09 14:00:00   hmfw-version-107 2.2.10
     2022-04-09 14:00:00   hmfw-version-108 1.2.0
     2022-04-09 14:00:00   hmfw-version-109 1.18.22
     2022-04-09 14:00:00   hmfw-version-110 1.2.10
     2022-04-09 14:00:00   hmfw-version-111 1.8.2
     2022-04-09 14:00:00   hmfw-version-112 2.0.2
     2022-04-09 14:00:00   hmfw-version-113 2.9.5
     2022-04-09 14:00:00   hmfw-version-114 1.8.12
     2022-04-09 14:00:00   hmfw-version-115 1.0.26
     2022-04-09 14:00:00   hmfw-version-116 1.0.0
     2022-04-09 14:00:00   hmfw-version-117 1.2.4
     2022-04-09 14:00:00   hmfw-version-118 1.3.0
     2022-04-09 14:00:00   hmfw-version-119 2.11.1
     2022-04-09 14:00:00   hmfw-version-120 1.4.2
     2022-04-09 14:00:00   hmfw-version-121 2.0.2
     2022-04-09 14:00:00   hmfw-version-122 2.2.8
     2022-04-09 14:00:00   hmfw-version-123 1.0.2
     2022-04-09 14:00:00   hmfw-version-124 1.16.10
     2022-04-09 14:00:00   hmfw-version-125 2.8.2
     2022-04-09 14:00:00   hmfw-version-126 2.6.0
     2022-04-09 14:00:00   hmfw-version-127 2.2.8
     2022-04-09 14:00:00   hmfw-version-128 1.0.8
     2022-04-09 14:00:00   hmfw-version-129 1.2.4
     2022-04-09 14:00:00   hmfw-version-130 2.18.22
     2022-04-09 14:00:00   hmfw-version-131 1.8.8
     2022-04-09 14:00:00   hmfw-version-132 1.16.8
     2022-04-09 14:00:00   hmfw-version-133 2.10.2
     2022-04-09 14:00:00   hmfw-version-134 1.0.12
     2022-04-09 14:00:00   hmfw-version-135 1.10.10
     2022-04-09 14:00:00   hmfw-version-136 1.0.16
     2022-04-09 14:00:00   hmfw-version-137 1.0.16
     2022-04-09 14:00:00   hmfw-version-138 1.10.0
     2022-04-09 14:00:00   hmfw-version-139 2.2.8
     2022-04-09 14:00:00   hmfw-version-140 2.4.8
     2022-04-09 14:00:00   hmfw-version-141 1.0.12
     2022-04-09 14:00:00   hmfw-version-142 1.0.2
     2022-04-09 14:00:00   hmfw-version-143 2.9.5
     2022-04-09 14:00:00   hmfw-version-144 1.2.0
     2022-04-09 14:00:00   hmfw-version-145 1.2.2
     2022-04-09 14:00:00   newFwForDevices no fw-updates needed!
   REQUEST:
     context    reading
     data
     header
     ignoreredirects 0
     num        unknown
     retryCount 0
     type       update
   DbLogExclude .*
   alignTime  14:00
   do_not_notify 1
   enableControlSet 1
   icon       hm_ccu
   reading01AutoNumLen 3
   reading01Name hmfw-type
   reading01RegOpt g
   reading01Regex (?i)"type":"((?:\w+[-]*){1,})
   reading02AutoNumLen 3
   reading02Name hmfw-version
   reading02RegOpt g
   reading02Regex (?si)"version":"(\d+[.]\d+[.]\d+)
   readingMaxAge 10
   readingMaxAgeReplacementMode delete
   room       fw-checks
   showError  1
   showMatched 1
   showNewFWOnly yes
   stateFormat {   my $ret ="";
my $lastCheck = FmtDateTime(InternalVal($name,".LastUpdate",0));
my $nextCheck = FmtDateTime(InternalVal($name,".TRIGGERTIME",0));
my $cellstyle = "padding:3pt;border-bottom:1px dotted lightgray;";
    $ret .= '<div style="text-align:left;">';;
    $ret .= '<div>last <a title="eq3-downloads" href="http://www.eq-3.de/service/downloads.html" rel="noopener noreferrer" target="_blank">homematic</a>-fw-check => '.$lastCheck;
    $ret .= '</div>';
    my $check = ReadingsVal($name,"newFwForDevices","error => no or wrong data from eq3-server!");
    if($check eq "no fw-updates needed!") {
      $ret .= '<div style="color:limegreen;font-weight:bold;">';
      $ret .= $check;
      $ret .= '</div>';
    } elsif($check eq "error => no or wrong data from eq3-server!") {
      $ret .= '<div style="color:red;font-weight:bold;">';
      $ret .= $check;
      $ret .= '</div>';
    } else {
$ret .= '<div style="display:table;width:100%;">';
$ret .= '<div style="display:table-row;">';
      $ret .= '<div style="display:table-cell;'.$cellstyle.'width:50%;font-weight:bold;">device</div>';
  $ret .= '<div style="display:table-cell;'.$cellstyle.'width:40%;font-weight:bold;">model</div>';
  $ret .= '<div style="display:table-cell;'.$cellstyle.'width:5%;font-weight:bold;">current</div>';
  $ret .= '<div style="display:table-cell;'.$cellstyle.'width:5%;font-weight:bold;">new</div>';
$ret .= '</div>'; #header
      my @devices = split(',',$check);
      foreach my $devStr (@devices) {
my ($dev,$idx) = $devStr =~ m/([^\s]+)\s[(](\d+)[)]/;
my $md = ReadingsVal($name,("hmfw-type-".$idx),"?");
#my $ofw = AttrVal($dev,"firmware","?");
my $ofw = InternalVal($dev,"firmware",AttrVal($dev,"firmware","0.0"));
my $nfw = ReadingsVal($name,("hmfw-version-".$idx),"none");
        my $fw_link = "https://ccu3-update.homematic.com/firmware/download?cmd=download&serial=0&product=".$md;
$ret .= '<div style="display:table-cell;'.$cellstyle.'width:50%;">';
        $ret .= '<a href="/fhem?detail='.$dev.'" target="_blank">';
$ret .= AttrVal($dev,"alias",$dev);
        $ret .= '</a></div>';
$ret .= '<div style="display:table-cell;'.$cellstyle.'width:30%;font-weight:bold;color:lightgrey;">';
        $ret .= $md;
        $ret .= '</div>';
$ret .= '<div style="display:table-cell;'.$cellstyle.'width:10%;font-weight:bold;color:lightgrey;">';
        $ret .= $ofw;
        $ret .= '</div>';
$ret .= '<div style="display:table-cell;'.$cellstyle.'width:10%;font-weight:bold;color:red;">';
        $ret .= '<a title="download firmware file" href="'.$fw_link.'" rel="noopener noreferrer" target="_blank" style="color:red !important;">';
        $ret .= $nfw;
        $ret .= '</div>'; #row
  $ret .= '</div>'; #table
$ret .= "<div style=\"text-align:left;\">(next check: ".$nextCheck.")</div>";
    $ret .= '</div>';
  return $ret;
   userReadings newFwForDevices:MATCHED_READINGS.* {
  my $ret = "";
  my $newfwonly = AttrVal($name,"showNewFWOnly","yes");
  if (ReadingsVal($name,"UNMATCHED_READINGS","?") eq "") {
    my @eq3FwList = map {
sprintf(uc(ReadingsVal($name,"hmfw-type-".$_,"?")).":".ReadingsVal($name,"hmfw-version-".$_,"?").":".$_);
} ReadingsVal($name,"MATCHED_READINGS","?")=~ m/hmfw-version-(\d\d\d)/g;
foreach my $dev (devspec2array("TYPE=CUL_HM|HMCCUDEV|HMCCUCHN:FILTER=DEF=(......|..............|................):FILTER=subType!=virtual")) {
      my $md = uc(InternalVal($dev,"ccutype",AttrVal($dev,"model","?")));
      my $v = InternalVal($dev,"firmware",AttrVal($dev,"firmware","0.0"));
      my ($h,$l) = split('\.',$v);
      foreach my $newFW (grep m/^${md}:/i,@eq3FwList) {
my ($fwmd, $fwv, $idx) = $newFW =~ m/([^:]+):(\d+[.]\d+[.]\d+):(\d+)$/;
my ($fwh, $fwl) = split('\.',$fwv);
if(($newfwonly eq "no") || (($fwh > $h) || (($fwh == $h) && ($fwl > $l)))) {
          $ret .= "," if($ret ne "");
  $ret .= $dev." (".$idx.")";
  } else {
    $ret = "error => no or wrong data from eq3-server!";
  return ($ret eq "")?"no fw-updates needed!":$ret;
   userattr   showNewF
Auch nicht bei der JsonMod Version.
viele Grüße, yersinia
FHEM 6.4 (SVN) on RPi 4B with RasPi OS Trixie (perl 5.40.1) | FTUI
